  4. iobroker funktioniert nicht js:638
27 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
  • C calli236
    @thomas-braun das kam beim Ersten
    pi@raspberrypi:~ $ iobroker status
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    dann das !
    system.adapter.admin                   : admin          - v5.2.3
    system.adapter.discovery               : discovery      - v2.7.3
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + instance is alive
    Thomas BraunT Offline
    @calli236
    Und der Rest? Und bitte komplette Ein- wie Ausgaben posten, ich rate ungern auf welches Kommando das nun die Ausgabe sein soll.
    • C calli236
      Objects type: file
      States  type: file
      dann das !
      pi@raspberrypi:~ $
      + instance is alive
      @calli236
      iobroker start
      iobroker start admin
      C 1 Antwort Letzte Antwort
        @calli236
        iobroker start
        calli236
        pi@raspberrypi:~ $ iobroker start
        pi@raspberrypi:~ $ iobroker start admin
        Objects type: file
        States  type: file
        pi@raspberrypi:~ $ iobroker list adapters
        pi@raspberrypi:~ $ iobroker instances
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start                                               Starts the js-controller
          iobroker stop                                                stops the js-controller
          iobroker restart                                             Restarts js-controller
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter
          iobroker install <adapter>                                   Installs a specified adapter
          iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter from system
          iobroker del <adapter>.<instance>                            Remove adapter instance
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload                                              Upload management
          iobroker object                                              Object management
          iobroker state                                               State management
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
          iobroker plugin                                              Plugin management
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
        Options:
              --help     Show help  [boolean]
          -v, --version  Show version  [boolean]
        pi@raspberrypi:~ $ wich nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        -bash: wich: Kommando nicht gefunden.
        pi@raspberrypi:~ $
        • C calli236
          Objects type: file
          States  type: file
          iobroker [command]
          Commands:
          Options:
          pi@raspberrypi:~ $
          @calli236
          Kopier doch die Befehle...
          which usw. heißt das
            @calli236
            calli236
            pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/node
            /usr/bin/npm
            pi@raspberrypi:~ $
            • C calli236
              /usr/bin/node
              /usr/bin/npm
              pi@raspberrypi:~ $
              @calli236
                @calli236
                calli236
                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.8
                v12.22.8
                6.14.15
                Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                Es wurden 15,0 kB in 1 s geholt (15,9 kB/s).
                Alle Pakete sind aktuell.
                Paketdateien:
                 100 /var/lib/dpkg/status
                     release a=now
                 500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                     release o=Raspberry Pi Foundation,a=oldstable,n=buster,l=Raspberry Pi Foundation,c=main,b=armhf
                     origin archive.raspberrypi.org
                 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     release o=Node Source,n=buster,l=Node Source,c=main,b=armhf
                     origin deb.nodesource.com
                 500 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages
                     release o=Raspbian,a=oldstable,n=buster,l=Raspbian,c=rpi,b=armhf
                     origin raspbian.raspberrypi.org
                 500 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages
                     release o=Raspbian,a=oldstable,n=buster,l=Raspbian,c=non-free,b=armhf
                 500 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages
                     release o=Raspbian,a=oldstable,n=buster,l=Raspbian,c=contrib,b=armhf
                     release o=Raspbian,a=oldstable,n=buster,l=Raspbian,c=main,b=armhf
                Mit Pinning verwaltete Pakete:
                pi@raspberrypi:~ $
                code_text
