  4. web.0 fehler im log (alias)
    6.3k
3 Beiträge 2 Kommentatoren 141 Aufrufe 2 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    habe diese fehler von web-adapter, bei denen ein problem mit einem alias sein soll - das alias funktioniert
    hat jmd eine idee dazu ?
    web.1
    	2021-11-16 18:39:00.928	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.battery, sourceObj={"type":"state","common":{"name":"battery status","type":"number","min":0,"max":100,"unit":"%","read":true,"write":false,"role":"value","desc":"battery status"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566145,"_id":"fritzdect.0.DECT_119610651024.battery","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    web.1
    	2021-11-16 18:39:00.927	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.tist, sourceObj={"type":"state","common":{"name":"Actual temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":false,"role":"value","desc":"Actual temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566136,"_id":"fritzdect.0.DECT_119610651024.tist","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    web.1
    	2021-11-16 18:39:00.915	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610651024.tsoll, sourceObj={"type":"state","common":{"name":"Setpoint Temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":true,"role":"value.temperature","desc":"Setpoint Temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566136,"_id":"fritzdect.0.DECT_119610651024.tsoll","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    • liv-in-skyL liv-in-sky
      web.1
      web.1
      web.1
      crunchipC Abwesend
      crunchipC Abwesend
      @liv-in-sky so eine Meldung hatte ich gester auch bemerkt, jedoch nicht weiter verfolgt, trat bisher erst einmal auf und weiss auch gerade nicht mehr was ich da gemacht hatte, glaube zu meinen, es kam nach einem Adapter Update, welcher mit alias jedoch nichts zu tun hat
      War auch nur ein alias betroffen in dieser Meldung, den ich mal mit dem Adapter Geräte verwalten angelegt hatte.
        liv-in-skyL Offline
        liv-in-sky
        habe das mal auf git gepostet
        https://github.com/ioBroker/ioBroker.web/issues/159
