  4. Problem bei ioBroker Installation-> iobroker.js-controller
    6.3k
16 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    darulor
    ich versuche auf einen PI4 die ioBroker Installation gem. der Anleitung hier aus dem Forum.
    Mir scheint es macht der jscontroller Probleme, kann aber die Fehlermeldung nicht ganz deuten
    "Failed at the iobroker.js-controller@3.3.18 install script".
    Die Installation läuft bis 3/4 sauber durch, dann kommen div. Errors und Fehlermeldungen.
    Betriebsystem: Raspberrian Buster
    NODE: v12.22.7
    NODEJS: v12.22.7
    NPM: 6.14.15
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /home/markus/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/markus/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@3.3.18 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.3.18 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/markus/.npm/_logs/2021-10-28T19_20_15_297Z-debug.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
    Was mache ich falsch, wo liegt das Problem?
    Besten Dank für eure Hilfe!
    • D darulor
      NODE: v12.22.7
      NODEJS: v12.22.7
      NPM: 6.14.15
      npm ERR! errno 22
      npm ERR!
      Autostart enabled!
      @darulor sagte in Problem bei ioBroker Installation-> iobroker.js-controller:
      ELIFECYCLE
      Sind eigentlich Probleme skripte auszuführen, soweit ich weiß.
      Node ist sauber?
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      • D darulor
        NODE: v12.22.7
        NODEJS: v12.22.7
        NPM: 6.14.15
        npm ERR! errno 22
        npm ERR!
        Autostart enabled!
        sollte in
        A complete log of this run can be found in: /home/markus/.npm/_logs/2021-10-28T19_20_15_297Z-debug.log
        stehen
          ELIFECYCLE
          Node ist sauber?
          darulor
          @thomas-braun sagte in Problem bei ioBroker Installation-> iobroker.js-controller:
          ja Node ist sauber, bekomme bei der Installation weiterhin die gleiche Fehlermeldung
          • D darulor
            @darulor Bitte nicht nacherzählen, komplette Ein- und Ausgaben posten. In CodeTags eingebettet.
              sollte in
              stehen
              darulor
              schrieb am zuletzt editiert von darulor
              @homoran das ist richtig ich kann aber mit der Info nichts anfangen, sieht für mich als Neuling nahezu identisch mit der Fehlerausgabe bei der Installation aus.
              Ich habe heute im Ordner /opt/iobroker verscht den jscontroller zu installieren.
              Der Befehl npm install iobroker.js-controller@3.3.18 brachte mir folgende Fehlermeldung:
              root@pi4:/opt/iobroker# npm install iobroker.js-controller@3.3.18
              npm ERR! code EACCES
              npm ERR! syscall mkdir
              npm ERR! path /home/iobroker
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'
              npm ERR!  [OperationalError: EACCES: permission denied, mkdir '/home/iobroker'] {
              npm ERR!   cause: [Error: EACCES: permission denied, mkdir '/home/iobroker'] {
              npm ERR!     errno: -13,
              npm ERR!     code: 'EACCES',
              npm ERR!     syscall: 'mkdir',
              npm ERR!     path: '/home/iobroker'
              npm ERR!   },
              npm ERR!   isOperational: true,
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              Ich habe doch den Befehl als root ausgeführt...
              Kann es sein als ich meinen User pi in markus umbenannt habe Rechte "verloren" gegangen sind?
              • D darulor
                npm ERR! errno -13
                npm ERR!   },
                npm ERR! }
                npm ERR!
                npm ERR!
                Falsch. Man meldet sich nie als root an.
                Auch falsch. Man nennt User (insbesondere den Pi nicht) nicht einfach um.
                Am besten fängst du nochmal bei Null an. Das hört sich alles total verfummelt an.
                  darulor
                  @thomas-braun ich habe heute bei null angefangen, mir mit dem Pi Imager, Pi OS Lite auf eine nagelneue SD-Karte gespielt und die Iobroker Installation nochmals durchgeführt. Die Fehlermeldung ist identisch ebenso so das Log-File, lag leider nicht am verfummelten PI.
                  Fehlermeldung sieht identisch aus:
                  npm ERR! errno 22
                  npm ERR!
                  npm ERR!     /home/pi/.npm/_logs/2021-10-30T19_05_28_576Z-debug.log
                  Log-File ebenfalls (Auszug am Ende)
                  5267 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  5268 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  5269 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
                  5269 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
                  5269 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
                  5269 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
                  5270 verbose stack Error: iobroker.js-controller@3.3.18 install: `node iobroker.js setup first`
                  5270 verbose stack Exit status 22
                  5270 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                  5270 verbose stack     at EventEmitter.emit (events.js:314:20)
                  5270 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  5270 verbose stack     at ChildProcess.emit (events.js:314:20)
                  5270 verbose stack     at maybeClose (internal/child_process.js:1022:16)
                  5270 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
                  5271 verbose pkgid iobroker.js-controller@3.3.18
                  5272 verbose cwd /opt/iobroker
                  5273 verbose Linux 5.10.76-v7l+
                  5274 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--loglevel" "error" "--unsafe-perm"
                  5275 verbose node v12.22.7
                  5276 verbose npm  v6.14.15
                  5277 error code ELIFECYCLE
                  5278 error errno 22
                  5279 error iobroker.js-controller@3.3.18 install: `node iobroker.js setup first`
                  5279 error Exit status 22
                  5280 error Failed at the iobroker.js-controller@3.3.18 install script.
                  5280 error This is probably not a problem with npm. There is likely additional logging output above.
                  5281 verbose exit [ 22, true ]
                  • D darulor
                    npm ERR! errno 22
                    npm ERR!
                    5278 error errno 22
                    wie genau hast du das gemacht?
                      darulor
                      @homoran gem. der Anleitung hier aus dem Forum „Neue Installationroutine unter Linux“
                      • D darulor
                        @darulor
                        Ich weiß nicht genau was du da treibst, die Installation geht per Einzeiler.
                          @darulor
                          darulor
                          @thomas-braun meine Befehle für die Installation waren wie folgt:
                          sudo apt-get update && sudo apt-get upgrade
                          curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                          sudo apt install -y nodejs
                          Sudo reboot
                          curl -sLf https://iobroker.net/install.sh | bash -
                          • D darulor
                            Sudo reboot
                            @darulor
                            Sieht gar nicht verkehrt aus.
                            Lass die manuelle Installation von nodeJS mal weg.
                            • D darulor
                              muss ich mal suchen.
                              Denke aber, dass die wohl schon was älter ist.
                              mit dem aktuellen Installer von ioBroker (siehe unten) wird auf einem System ohne node.js automatisch die aktuell empfohlene Version von node.js mit installiert! Eine vorherige separate Installation von node.js ist somit nicht mehr nötig.
                              Quelle: https://www.iobroker.net/#de/documentation/install/linux.md
                              Edit:
                              solltest du dies meinen:
                              "Neue Installationsroutine (für Linux)"
                              dann ist das von 2018!
                              das ist nicht gerade aktuell.
                                darulor
                                -> Das war es! Vielen Dank für den Hinweis!!!
                                Ich habe diese Punkt in der Installation "übersprungen"
                                In neueren Installationen kann es sein, dass der Befehl nodejs -v eine Fehlermeldung wie “nicht gefunden” erzeugt. Dies ist prinzipiell unbedenklich, da der Befehl nodejs schon länger nicht mehr verwendet wird, kann aber über einen Symlink mit dem Befehl sudo ln -s /usr/bin/node /usr/bin/nodejs "repariert" werden.
                                Jetzt bekam ich keine Fehlermeldung mehr bei der Installation und Iobroker startet :-)
                                • D darulor
                                  steht über dem von dir zitierten in der Anleitung:
