  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 579.6k Aufrufe 64 Beobachtet
  • S saeft_2003
    Seit dem js controller update auf 4.0.24 kommt jede Nacht um 00:01 diese Error…
    Hat das noch jemand?
    host.iobroker
    	2023-01-20 00:01:00.787	error	instance system.adapter.worx.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at processImmediate (node:internal/timers:466:21)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5919:53)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.emit (node:domain:489:12)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.emit (node:events:513:28)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.onStateChange (/opt/iobroker/node_modules/iobroker.worx/main.js:967:26)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.changeMowerCfg (/opt/iobroker/node_modules/iobroker.worx/main.js:1305:32)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: TypeError: Cannot read properties of null (reading 'payload')
    host.iobroker
    	2023-01-20 00:01:00.786	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    worx.0
    	2023-01-20 00:01:00.178	error	Cannot read properties of null (reading 'payload')
    worx.0
    	2023-01-20 00:01:00.178	error	TypeError: Cannot read properties of null (reading 'payload') at Worx.changeMowerCfg (/opt/iobroker/node_modules/iobroker.worx/main.js:1305:32) at Worx.onStateChange (/opt/iobroker/node_modules/iobroker.worx/main.js:967:26) at Worx.emit (node:events:513:28) at Worx.emit (node:domain:489:12) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5919:53) at processImmediate (node:internal/timers:466:21)
    worx.0
    	2023-01-20 00:01:00.071	error	unhandled promise rejection: Cannot read properties of null (reading 'payload')
    worx.0
    	2023-01-20 00:01:00.064	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    #681
    @saeft_2003
    Ja, hab den Adapter aber zur Zeit deaktiviert da Onkel im Winterschlaf ist…
    • S saeft_2003
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      worx.0
      worx.0
      worx.0
      worx.0
      L Online
      L Online
      Lucky_ESA
      #682
      @saeft_2003 sagte in Adapter: Worx Landroid v2.x.x:
      Kann das gerade nicht bestätigen da mein Adapter deaktiviert ist. Habe das Thema schon gefunden und kann das zum Saisonbeginn fixen.
      Allerdings muss ich mir die Frage stellen, warum dieser Fehler kommt...Hat da Worx schon wieder was geändert...
      Der Fehler kommt um 00:01 weil du den Blockly aus diesem Forum für VIS-Anzeige verwendest...
      Gruß//Lucky
      • L Lucky_ESA
        Gruß//Lucky
        saeft_2003
        schrieb am zuletzt editiert von saeft_2003
        #683
        @lucky_esa sagte in Adapter: Worx Landroid v2.x.x:
        Gruß//Lucky
        Ja das habe ich mittlerweile auch rausgefunden. Aber auch wenn ich einen wert im calender manuell in Objekte ändere kommt es auch zum absturzt.
        Mein Robby ist aber auch noch im Winterschlaf, aber der Fehler tritt erst seit kurzem auf. Gleichzeitig mit dem update vom js controller auf 4.0.24 zufall?
        L 1 Antwort Letzte Antwort
        • S saeft_2003
          Gruß//Lucky
          L Online
          L Online
          Lucky_ESA
          #684
          @saeft_2003
          Da habe ich eine Vermutung. Wenn der Worx x Monate Offline ist kommen dann die Payload Daten nicht mehr. Das mit JS-Controller ist nur ein Zufall.
          Deaktiviere den Adapter oder das Script.
          Gruß//Lucky
          • L Lucky_ESA
            @saeft_2003
            Gruß//Lucky
            saeft_2003
            #685
            @lucky_esa
            Alles klar. Funktioniert dann wieder alles wenn Robby wieder online ist, oder muss am Adapter was gefixt werden?
            L T 2 Antworten Letzte Antwort
            • S saeft_2003
              @lucky_esa
              L Online
              L Online
              Lucky_ESA
              #686
              @lucky_esa
              Wird wieder funktionieren wenn der Mower wieder Online ist. Aber für den nächsten Winterschlaf werde ich das trotzdem fixen.
              Gruß//Lucky
              • S saeft_2003
                @lucky_esa
                tombox
                #687
                @saeft_2003 Probier mal die GitHub version zu installieren ob das verhalten dann weg ist.
                • L Lucky_ESA
                  @lucky_esa
                  Gruß//Lucky
                  saeft_2003
                  #688
                  @lucky_esa
                  Gruß//Lucky
                  Ok alles klar jetzt hab ichs kapiert 👍
                  • T tombox
                    L Online
                    L Online
                    Lucky_ESA
                    #689
                    @tombox sagte in Adapter: Worx Landroid v2.x.x:
                    Das war jetzt für mich nicht so gut. Habe doch viele Veränderungen auf`m Git die die fehlerhaften Abfragen blockiert und somit das Blockly umbrauchbar macht. Habe eigentlich den Text für die neuen Funktionen fertig und das neue Blockly zu 90%...Aber du hast ja Recht, ihr werdet jetzt über Sentrys zugespamt...
                    • L Lucky_ESA
                      saeft_2003
                      #690
                      @lucky_esa
                      Ich hab gerade aktualisiert über git. Heißt das ich kann jetzt mein blockly nicht mehr verwenden, oder habe ich das falsch verstanden?
                      • S saeft_2003
                        @lucky_esa
                        L Online
                        L Online
                        Lucky_ESA
                        #691
                        @lucky_esa
                        So ist es!
                        • L Online
                          L Online
                          Lucky_ESA
                          #692
                          Hier mein Text den ich im November geschrieben hatte.
                          kurz vor der Winterpause gibt es noch ein Update auf dem GIT was ich gerne noch erklären möchte.
                          Fix:
                          • bei 2 Mäher mit Off Limit Modul
                          • versenden von calJson und calJson2
                          • edgeCut
                          Neu:
                          • Die 24h Sperre wird nun im Log angezeigt. Wenn ihr den u. a. Text im Log findet, dann öffnet bitte eure Worx APP und wischt mal von oben nach unten. Wenn dann ein "Verbindungsfehler" angezeigt wird, dann bitte iobroker bzw. den Worx Adapter nicht neu starten. Die Mqtt Verbindung wird automatisch getrennt und nach 24h wieder neu gestartet und alles ist GUT. Macht ihr einen Restart, löscht ihr den Intervall und müsst dann nach 24h manuelll den Adapter neu starten. Leider spreche ich aus eigener Erfahrung... Kommt kein Verbindungsfehler ist eventuell euer Worx Offline oder Worx hat ein Problem.
                            "Maybe your connection is blocked from Worx. Restart Mqtt connection automatic in 24h"
                          • Wenn ihr Blocklys erstellt und Datenpunkte steuert, muss immer min. 1,1 Sekunden Timeout zwischen dem Setzen sein. Wer diese nicht einhält bekommt diese Meldung: "Time between requests within (die Zahl) ms is not allowed. STOP Request (Datenpunkt) with value (Wert)"
                          • Für den der automatischen Mähplan aktiviert hat sind die DB im Folder "Calendar" gesperrt. Wenn ihr diese ändert, wird die APP sofort seine geplanten Zeiten erneut zum Mower senden, daher diese Sperre. Meldung: "Automatic mowing plan active! Times cannot be changed."
                          • CMD Commands sind von 0 bis 9 begrenzt. Habe zum testen immer eine Zahl >9 verwendet und wurde gesperrt. Ob es wirklich daran lag, kann ich natürlich nicht bestätigen.
                          • Es gibt einen neuen Datenpunkt xx.mower.last_command. Hier werden eure Request und Response vom Worx gespeichert (Max. 20x). Diesen Inhalt könnt ihr auswerten und prüfen, ob euer Request vom Worx empfangen wurde. Die Daten könnt ihr auswerten und euch per VIS anzeigen lassen. Wie ihr das umsetzen könnt werde ich noch ein Blockly als Beispiel hier einfügen. Bei "user" kann nur iobroker oder APP stehen...
                             "request": 1667452500820,
                             "response": 1667452501610,
                             "action": "worx.0.xxxx.calendar.calJson",
                             "user": "iobroker"
                          Wenn ich viel Zeit habe, werde ich ein korrigiertest Blockly für die Vis Darstellung zur Verfügung stellen.
                          Gruß//Lucky
                          • L Lucky_ESA
                            @lucky_esa
                            So ist es!
                            saeft_2003
                            #693
                            @lucky_esa
                            So ist es!
                            Kann ich nicht einfach die 2.0.3 drüber installieren? Sonst gehe ich mit einem snapshot zurück…
                            • S saeft_2003
                              @lucky_esa
                              So ist es!
                              L Online
                              L Online
                              Lucky_ESA
                              schrieb am zuletzt editiert von Lucky_ESA
                              #694
                              @lucky_esa
                              So ist es!
                              Es werden einfach nicht die Zeiten gelöscht die um 00:01 gelöscht werden sollen. Das ist euch nie aufgefallen da es eigentlich keinen Impakt auf die Mähzeiten hat. Du kannst vom GIT laden...Ohne Mäher kannst du den Blockly sowieso nicht gebrauchen :-)
                              Gruß//Lucky
                              • L Online
                                L Online
                                Lucky_ESA
                                #695
                                es wird hier darüber berichtet, dass der Adapter eine 24h Sperre auslöst.
                                Woran es wirklich liegt kann ich derzeit leider nicht sagen. Hatte gestern gegen 18 Uhr meinen Mäher aufgestellt und den Adapter wieder aktiviert. Es lief alles min. 12 Stunden einwandfrei und aufgrund dieses Issues musste ich meinen Dev Server starten. Folglich im Live System Adapter deaktiviert und auf dem Dev gestartet. Nach 2 x absenden eines Befehls habe ich nun auch die 24h Sperre vor mir.
                                Zur Sichertheit möchte ich noch das unötige Absenden von Befehlen reduzieren. Hierzu gibt es bald 2 neue Datenpunkte:
                                worx.0.xxx.calendar.calJson_tosend: Wenn ihr Zeiten eintragt (wahrscheinlich über Blockly) werden diese hier als JSON gesammelt.
                                worx.0.xxx.calendar.calJson_sendto Wenn ihr alle Änderungen vorgenommen habt. muss dieser Button zum versenden auf true gesetzt werden.
                                Warum dieser Umstand?
                                Die Blocklys hier im Forum steuern alles einzeln.
                                Vortag borderCut -> Wird sofort versendet 1. MQTT Übertragung
                                Vortag startTime -> Wird sofort versendet 2. MQTT Übertragung
                                Vortag workTime -> Wird sofort versendet 3. MQTT Übertragung
                                Heute borderCut -> Wird sofort versendet 4. MQTT Übertragung
                                Heute startTime -> Wird sofort versendet 5. MQTT Übertragung
                                Heute workTime -> Wird sofort versendet 6. MQTT Übertragung
                                Und das ganze zeitgleich noch für den schedule2 diese sowieso nicht durchgehen da dieser zeitgleich gestartet wird.
                                Dann noch tagsüber mehrfache Zeitenänderung in der Reihenfolge 1-3 wie oben beschrieben.
                                Ihr müsst dann nur worx.0.xxx.calendar.calJson_sendto am Ende eure 4 x schedules (2 x Datensetzung 3min vor Startzeit und 2 x Löschung des von vor zwei Tagen um 00:01) setzen...Am besten mit einem 3 Sekunden timeout.
                                Bei den minütlichen Interval bei jedem Tag hinzufügen und um Mitternacht am Ende der Funktion "Zeiten_setzen".
                                Gruß//Lucky
                                Merlin123M I 2 Antworten Letzte Antwort
                                • L Lucky_ESA
                                  Gruß//Lucky
                                  Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  #696
                                  @lucky_esa Zum Verständnis: Das passiert, wenn man über den Adapter was ändert? Nicht, wenn man nur liest?
                                  Beta-Tester
                                  • Merlin123M Merlin123
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #697
                                    @merlin123 sagte in Adapter: Worx Landroid v2.x.x:
                                    Das kann ich leider nicht bestätigen. Das probiere ich gerade aus daher kann ich die Änderungen vom Code nicht testen. Das müsst ihr dann machen. Gebe bescheid wenn die Änderungen auf`m GIT sind.
                                    Gruß//Lucky
                                    • L Online
                                      L Online
                                      Lucky_ESA
                                      #698
                                      Auch auf die Gefahr hin hier als Alleinunterhalter von einem Admin gesperrt zu werden, mache ich trotzdem weiter.
                                      Auf`m GIT sind nun die o. g. Änderung implementiert. Ihr müsst eure Blocklys wie oben beschrieben anpassen. Aktualisierungen der Datenpunkte xx.calendar.wochentag können dann ohne "Timeout" gesetzt werden.
                                      Es gibt allerdings noch die Möglichkeit, dass beim Ausführen euer Blockys der Interval für die Aktualisierung startet. Dann werden eure Daten eventuell fehlerhaft übertragen.
                                      Wenn das zu oft vorkommt, muss ich dann noch einen dritten Datenpunkt hinzufügen, der die automatische Aktualisierung unterbindet.
                                      Des Weiteren haben wir eine kleine Änderung hinzugefügt um die 24h Sperre eventuell zu verhindern.
                                      Ihr müsst nun die aktuelle Version vom GIT laden um zu testen.
                                      Gruß//Lucky
                                      falke69F 1 Antwort Letzte Antwort
                                      • L Lucky_ESA
                                        Gruß//Lucky
                                        falke69F Offline
                                        falke69F Offline
                                        falke69
                                        #699
                                        @lucky_esa
                                        hättest Du vielleicht ein fertiges Blockly mit den Datenpunkten, welches Du zur Verfügung stellen könntest?
                                        • L Lucky_ESA
                                          Gruß//Lucky
                                          I Offline
                                          I Offline
                                          iobroker2001
                                          #700
                                          @lucky_esa
                                          Ich verwende meine eigenen Blocklys für die Mähzeitänderung/Kantenschnitt per VIS und Regenerkennung -> mowTimeExtend auf -100% setzen etc. Die zugehörigen Datenpunkte in "worx" werden aber nicht wie in den zitierten Blocklys häufig gesetzt, schon garnicht minütlich oder viele direkt hintereinander.
                                          Und dennoch bin ich gestern wieder ausgesperrt worden, warte z. Zt. auf Wiederfreigabe. Also meiner Beobachtung nach scheint es nicht unbedingt ein Problem der häufigen Befehle in kurzer Zeit zu sein. Im Gegensatz zu meinem obigen Post konnte ich durch Stoppen des Worx-Adapters die Sperre nicht wieder aufheben.
                                          Das soll bitte nur ein Hinweis für die Fehlersuche sein! Vielen Dank dafür, dass Du Dich darum kümmerst!
                                          P.S.: Sollen die neuen JSON-Objekte dann zwingend immer für Zeitenänderung gesetzt werden oder nur alternativ, wenn viele Änderungen übertragen werden müssen? Bleiben dann die alten Datenpunkte "...workTime" etc. erhalten?
