  4. [gelöst] fehlende Pakete bei Installation
    6.5k
19 Beiträge 4 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • apollon77A apollon77
    @sigi234 Habe gerade vorhin ein neues Repo Buidl angestoßen ... danach sollte das weg gehen. Da hatte sich ein Pfad geändert.
    heinhanH Offline
    heinhanH Offline
    heinhan
    schrieb am zuletzt editiert von heinhan
    @apollon77
    beim Update auf 3.3.17 wurde folgendes beim Update angezeigt:
    pi@raspberrypi:~ $ iob upgrade self
    Update js-controller from @3.3.15 to @3.3.17
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.17 --loglevel error --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v72-linux-glibc-arm.tar.gz
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.43-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.22.6
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.10.43-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.22.6
    node-pre-gyp ERR! node-pre-gyp -v v1.0.5
    node-pre-gyp ERR! not ok
    Iob läuft nach dem Start ohne Probleme.
    Wie bekommt man die Meldeungen bei zukünftigen Updates weg?
    • heinhanH heinhan
      @apollon77
      gyp ERR! not ok
      @heinhan
      iobroker stop
      iobroker fix
      iobroker start
      Das spült soweit ich weiß die benötigten Pakete für pixman-1 und canvas auf dein System.
      heinhanH 2 Antworten Letzte Antwort
        @heinhan
        iobroker stop
        iobroker fix
        iobroker start
        heinhanH Offline
        heinhanH Offline
        heinhan
        @thomas-braun Danke für den Tipp. Mal schauen wie es beim nächsten Update aussieht.
          @heinhan
          iobroker stop
          iobroker fix
          iobroker start
          heinhanH Offline
          heinhanH Offline
          heinhan
          @thomas-braun Leider immer noch folgende Meldungen beim Update:
          Update js-controller from @3.3.17 to @3.3.18
          npm install iobroker.js-controller@3.3.18 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
          gyp ERR! not ok
          Woran könnte es liegen?
          • heinhanH heinhan
            gyp ERR! not ok
            @heinhan
            Debian?
            apt policy libpixman-1-dev
            bzw.
            sudo apt update
            sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
              @heinhan
              Debian?
              bzw.
              sudo apt update
              heinhanH Offline
              heinhanH Offline
              heinhan
              Hallo, Policy sieht so aus:
              pi@raspberrypi:~ $ apt policy libpixman-1-dev
              libpixman-1-dev:
                Installiert:           (keine)
                Installationskandidat: 0.36.0-1
                Versionstabelle:
                   0.36.0-1 500
                      500 http://archive.raspbian.org/raspbian buster/main armhf Packages
              Das Update... so:
              pi@raspberrypi:~ $ sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
              build-essential ist schon die neueste Version (12.6).
              libgif-dev ist schon die neueste Version (5.1.4-3).
              libjpeg-dev ist schon die neueste Version (1:1.5.2-2+deb10u1).
              Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
              Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
              Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
              nicht erstellt wurden oder Incoming noch nicht verlassen haben.
              Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
              Die folgenden Pakete haben unerfüllte Abhängigkeiten:
               libcairo2-dev : Hängt ab von: libcairo2 (= 1.16.0-4+deb10u1) aber 1.16.0-4+rpt1 soll installiert werden
                               Hängt ab von: libcairo-gobject2 (= 1.16.0-4+deb10u1) aber 1.16.0-4+rpt1 soll installiert werden
                               Hängt ab von: libpixman-1-dev (>= 0.22.0) soll aber nicht installiert werden
              E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
              Dies zur Info. Was kann ich noch machen um mein System gerade zu biegen?
              • heinhanH heinhan
                libpixman-1-dev:
                  Versionstabelle:
                     0.36.0-1 500
                Das Update... so:
                @heinhan
                sudo apt install libpixman-1-dev
                sudo apt update
                sudo apt dist-upgrade
                  @heinhan
                  Debian?
                  bzw.
                  sudo apt update
                  heinhanH Offline
                  heinhanH Offline
                  heinhan
                  @thomas-braun Hier noch das Update Bild:
                  pi@raspberrypi:~ $ sudo apt update
                  Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                  Holen:2 http://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
                  OK:3 https://packages.grafana.com/oss/deb stable InRelease
                  OK:4 https://repos.influxdata.com/debian buster InRelease
                  OK:5 https://deb.nodesource.com/node_12.x buster InRelease
                  Es wurden 30,0 kB in 2 s geholt (12,0 kB/s).
                  Alle Pakete sind aktuell.
                  • heinhanH heinhan
                    @heinhan Mach besser einen eigenen Thread dazu auf, das hat ja mit dem Thema hier nix zu tun.
                    opossumO heinhanH 2 Antworten Letzte Antwort
                      opossumO Offline
                      opossumO Offline
                      opossum
                      Hallo, @heinhan,
                      habe Dir mal ne Chatnachricht geschickt.
                      https://www.schlepper-petersdorf.de
                      • opossumO opossum
                        Hallo, @heinhan,
                        @opossum
                        Mit den richtigen Repos? Sind die geheim?
                        opossumO 1 Antwort Letzte Antwort
                          heinhanH Offline
                          heinhanH Offline
                          heinhan
                          @thomas-braunGibt es eine Möglichkeit mein Start Thread zu verschieben? Habe dazu nichts in der Hilfe gefunden. Also neu aufmachen?
                          paul53P Thomas BraunT 2 Antworten Letzte Antwort
                          • heinhanH heinhan
                            @heinhan sagte: neu aufmachen?
                            Ja und Moderator bitten, dorthin zu verschieben.
                            • heinhanH heinhan
                              @heinhan
                              apt policy libcairo2-dev libcairo2 libcairo-gobject2 libpixman-1-dev libpixman-1-0
                              heinhanH 1 Antwort Letzte Antwort
                                @heinhan
                                heinhanH Offline
                                heinhanH Offline
                                heinhan
                                @thomas-braun Vorab, Danke der das Paket verschoben hat.
                                Hier das Ergebnis von der Policy:
                                libcairo2-dev:
                                  Installationskandidat: 1.16.0-4+deb10u1
                                  Versionstabelle:
                                     1.16.0-4+deb10u1 500
                                libcairo2:
                                  Installiert:           1.16.0-4+rpt1
                                  Installationskandidat: 1.16.0-4+rpt1
                                  Versionstabelle:
                                 *** 1.16.0-4+rpt1 100
                                        100 /var/lib/dpkg/status
                                libcairo-gobject2:
                                  Versionstabelle:
                                libpixman-1-dev:
                                  Versionstabelle:
                                     0.36.0-1 500
                                libpixman-1-0:
                                  Installiert:           0.36.0-1+rpt1
                                  Installationskandidat: 0.36.0-1+rpt1
                                  Versionstabelle:
                                 *** 0.36.0-1+rpt1 100
                                     0.36.0-1 500
                                • heinhanH heinhan
                                  libcairo2-dev:
                                    Versionstabelle:
                                  libcairo2:
                                    Versionstabelle:
                                  libcairo-gobject2:
                                    Versionstabelle:
                                  libpixman-1-dev:
                                    Versionstabelle:
                                       0.36.0-1 500
                                  libpixman-1-0:
                                    Versionstabelle:
                                       0.36.0-1 500
                                  @heinhan
                                  Versuch mal so:
                                  sudo apt install libcairo2=1.16.0-4+deb10u1 libcairo-gobject2=1.16.0-4+deb10u1 libpixman-1-0=0.36.0-1
                                  wenn das funktioniert nochmal
                                    @heinhan
                                    Versuch mal so:
                                    heinhanH Offline
                                    heinhanH Offline
                                    heinhan
                                    @thomas-braun Habe beide Sudo´s ausgeführt, ohne Probleme. Alle Programme sind jetzt installiert laut policy. Nach einem Reboot läuft alles.
                                    pi@raspberrypi:~ $ apt policy libcairo2-dev libcairo2 libcairo-gobject2 libpixman-1-dev libpixman-1-0
                                    libcairo2-dev:
                                      Installiert:           1.16.0-4+deb10u1
                                      Versionstabelle:
                                     *** 1.16.0-4+deb10u1 500
                                    libcairo2:
                                      Versionstabelle:
                                    libcairo-gobject2:
                                      Versionstabelle:
                                    libpixman-1-dev:
                                      Versionstabelle:
                                     *** 0.36.0-1 500
                                    libpixman-1-0:
                                      Versionstabelle:
                                     *** 0.36.0-1 500
                                    Setze mal das Thread auf gelöst in der Hoffnung, dass nächste Update installiert sich ohne Fehlermeldungen. Danke für Deine Hilfe und noch einen schönen Abend.
                                    • heinhanH heinhan
                                      libcairo2-dev:
                                        Versionstabelle:
                                      libcairo2:
                                        Versionstabelle:
                                      libcairo-gobject2:
                                        Versionstabelle:
                                      libpixman-1-dev:
                                        Versionstabelle:
                                       *** 0.36.0-1 500
                                      libpixman-1-0:
                                        Versionstabelle:
                                       *** 0.36.0-1 500
                                      @heinhan
                                      Jetzt sollten zumindest die für pixman und canvas erforderlichen Pakete richtig auf dem System sein.
                                        @opossum
                                        opossumO Offline
                                        opossumO Offline
                                        opossum
                                        @thomas-braun ,
                                        nein, nichts Geheimes. Ich hatte empfohlen, mal alle Zusatzmodule testweise zu entfernen. Wollte nur nicht den Post hier noch mehr aufblähen. Ich hatte weiter oben ja auch diesen gyp-Fehler. Bei mir war es das Zusatzmodul simple-ssh. Sorry, war also nicht geheim.
