  4. [gelöst] fehlende Pakete bei Installation
    6.5k
19 Beiträge 4 Kommentatoren 1.5k Aufrufe 2 Beobachtet
    @heinhan
    iobroker stop
    iobroker fix
    iobroker start
    Das spült soweit ich weiß die benötigten Pakete für pixman-1 und canvas auf dein System.
    heinhanH Offline
    heinhanH Offline
    heinhan
    @thomas-braun Leider immer noch folgende Meldungen beim Update:
    pi@raspberrypi:~ $ iob upgrade self
    Update js-controller from @3.3.17 to @3.3.18
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.18 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v72-linux-glibc-arm.tar.gz
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.43-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.22.6
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.10.43-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.22.6
    node-pre-gyp ERR! node-pre-gyp -v v1.0.5
    node-pre-gyp ERR! not ok
    Woran könnte es liegen?
    • heinhanH heinhan
      gyp ERR! not ok
      @heinhan
      Debian?
      apt policy libpixman-1-dev
      bzw.
      sudo apt update
      sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      heinhanH 2 Antworten Letzte Antwort
        @heinhan
        Debian?
        bzw.
        sudo apt update
        heinhanH Offline
        heinhanH Offline
        heinhan
        Hallo, Policy sieht so aus:
        pi@raspberrypi:~ $ apt policy libpixman-1-dev
        libpixman-1-dev:
          Installiert:           (keine)
          Installationskandidat: 0.36.0-1
          Versionstabelle:
             0.36.0-1 500
                500 http://archive.raspbian.org/raspbian buster/main armhf Packages
        Das Update... so:
        pi@raspberrypi:~ $ sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
        build-essential ist schon die neueste Version (12.6).
        libgif-dev ist schon die neueste Version (5.1.4-3).
        libjpeg-dev ist schon die neueste Version (1:1.5.2-2+deb10u1).
        Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
        Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
        Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
        nicht erstellt wurden oder Incoming noch nicht verlassen haben.
        Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
        Die folgenden Pakete haben unerfüllte Abhängigkeiten:
         libcairo2-dev : Hängt ab von: libcairo2 (= 1.16.0-4+deb10u1) aber 1.16.0-4+rpt1 soll installiert werden
                         Hängt ab von: libcairo-gobject2 (= 1.16.0-4+deb10u1) aber 1.16.0-4+rpt1 soll installiert werden
                         Hängt ab von: libpixman-1-dev (>= 0.22.0) soll aber nicht installiert werden
        E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
        Dies zur Info. Was kann ich noch machen um mein System gerade zu biegen?
        • heinhanH heinhan
          libpixman-1-dev:
            Versionstabelle:
               0.36.0-1 500
          Das Update... so:
          @heinhan
          sudo apt install libpixman-1-dev
          sudo apt update
          sudo apt dist-upgrade
            @heinhan
            Debian?
            bzw.
            sudo apt update
            heinhanH Offline
            heinhanH Offline
            heinhan
            @thomas-braun Hier noch das Update Bild:
            pi@raspberrypi:~ $ sudo apt update
            Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            Holen:2 http://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
            OK:3 https://packages.grafana.com/oss/deb stable InRelease
            OK:4 https://repos.influxdata.com/debian buster InRelease
            OK:5 https://deb.nodesource.com/node_12.x buster InRelease
            Es wurden 30,0 kB in 2 s geholt (12,0 kB/s).
            Alle Pakete sind aktuell.
            • heinhanH heinhan
              @heinhan Mach besser einen eigenen Thread dazu auf, das hat ja mit dem Thema hier nix zu tun.
              opossumO heinhanH 2 Antworten Letzte Antwort
                opossumO Offline
                opossumO Offline
                opossum
                Hallo, @heinhan,
                habe Dir mal ne Chatnachricht geschickt.
                https://www.schlepper-petersdorf.de
                • opossumO opossum
                  Hallo, @heinhan,
                  @opossum
                  Mit den richtigen Repos? Sind die geheim?
                  opossumO 1 Antwort Letzte Antwort
                    heinhanH Offline
                    heinhanH Offline
                    heinhan
                    @thomas-braunGibt es eine Möglichkeit mein Start Thread zu verschieben? Habe dazu nichts in der Hilfe gefunden. Also neu aufmachen?
                    paul53P Thomas BraunT 2 Antworten Letzte Antwort
                    • heinhanH heinhan
                      @heinhan sagte: neu aufmachen?
                      Ja und Moderator bitten, dorthin zu verschieben.
                      • heinhanH heinhan
                        @heinhan
                        apt policy libcairo2-dev libcairo2 libcairo-gobject2 libpixman-1-dev libpixman-1-0
                        heinhanH 1 Antwort Letzte Antwort
                          @heinhan
                          heinhanH Offline
                          heinhanH Offline
                          heinhan
                          @thomas-braun Vorab, Danke der das Paket verschoben hat.
                          Hier das Ergebnis von der Policy:
                          libcairo2-dev:
                            Installationskandidat: 1.16.0-4+deb10u1
                            Versionstabelle:
                               1.16.0-4+deb10u1 500
                          libcairo2:
                            Installiert:           1.16.0-4+rpt1
                            Installationskandidat: 1.16.0-4+rpt1
                            Versionstabelle:
                           *** 1.16.0-4+rpt1 100
                          libcairo-gobject2:
                            Versionstabelle:
                          libpixman-1-dev:
                            Versionstabelle:
                               0.36.0-1 500
                          libpixman-1-0:
                            Installiert:           0.36.0-1+rpt1
                            Installationskandidat: 0.36.0-1+rpt1
                            Versionstabelle:
                           *** 0.36.0-1+rpt1 100
                               0.36.0-1 500
                          • heinhanH heinhan
                            libcairo2-dev:
                              Versionstabelle:
                            libcairo2:
                              Versionstabelle:
                            libcairo-gobject2:
                              Versionstabelle:
                            libpixman-1-dev:
                              Versionstabelle:
                                 0.36.0-1 500
                            libpixman-1-0:
                              Versionstabelle:
                                 0.36.0-1 500
                            @heinhan
                            Versuch mal so:
                            sudo apt install libcairo2=1.16.0-4+deb10u1 libcairo-gobject2=1.16.0-4+deb10u1 libpixman-1-0=0.36.0-1
                            wenn das funktioniert nochmal
                              @heinhan
                              Versuch mal so:
                              heinhanH Offline
                              heinhanH Offline
                              heinhan
                              @thomas-braun Habe beide Sudo´s ausgeführt, ohne Probleme. Alle Programme sind jetzt installiert laut policy. Nach einem Reboot läuft alles.
                              pi@raspberrypi:~ $ apt policy libcairo2-dev libcairo2 libcairo-gobject2 libpixman-1-dev libpixman-1-0
                              libcairo2-dev:
                                Installiert:           1.16.0-4+deb10u1
                                Versionstabelle:
                               *** 1.16.0-4+deb10u1 500
                              libcairo2:
                                Versionstabelle:
                              libcairo-gobject2:
                                Versionstabelle:
                              libpixman-1-dev:
                                Versionstabelle:
                               *** 0.36.0-1 500
                              libpixman-1-0:
                                Versionstabelle:
                               *** 0.36.0-1 500
                              Setze mal das Thread auf gelöst in der Hoffnung, dass nächste Update installiert sich ohne Fehlermeldungen. Danke für Deine Hilfe und noch einen schönen Abend.
                              • heinhanH heinhan
                                libcairo2-dev:
                                  Versionstabelle:
                                libcairo2:
                                  Versionstabelle:
                                libcairo-gobject2:
                                  Versionstabelle:
                                libpixman-1-dev:
                                  Versionstabelle:
                                 *** 0.36.0-1 500
                                libpixman-1-0:
                                  Versionstabelle:
                                 *** 0.36.0-1 500
                                @heinhan
                                Jetzt sollten zumindest die für pixman und canvas erforderlichen Pakete richtig auf dem System sein.
                                  @opossum
                                  opossumO Offline
                                  opossumO Offline
                                  opossum
                                  @thomas-braun ,
                                  nein, nichts Geheimes. Ich hatte empfohlen, mal alle Zusatzmodule testweise zu entfernen. Wollte nur nicht den Post hier noch mehr aufblähen. Ich hatte weiter oben ja auch diesen gyp-Fehler. Bei mir war es das Zusatzmodul simple-ssh. Sorry, war also nicht geheim.
