  4. Telegram sendet nicht mehr
    6.4k
8 Beiträge 3 Kommentatoren 590 Aufrufe 2 Beobachtet
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    schrieb am zuletzt editiert von sissiwup
    telegram hat das senden eingestellt:
    telegram.0 29239	2021-08-14 11:29:51.111	debug	Received command "send": {"text":"Anzahl Servicemeldungen:27\nEG <br>\nhttp://192.168.1.13/wh.html"}
    telegram.0 29239	2021-08-14 11:28:43.345	debug	getMe: {"id":*,"is_bot":true,"first_name":"*","username":"*_bot","can_join_groups":true,"can_read_all_group_messages":false,"supports_inline_queries":false}
    telegram.0 29239	2021-08-14 11:28:38.230	debug	Start polling with: 300(number) ms interval
    telegram.0 29239	2021-08-14 11:28:38.148	debug	Schedule restart: 4 5 * * *
    telegram.0 29239	2021-08-14 11:28:38.128	info	starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v14.17.0, js-controller: 3.3.15
    telegram.0 29239	2021-08-14 11:28:37.969	debug	statesDB connected
    telegram.0 29239	2021-08-14 11:28:37.968	debug	States connected to redis: 127.0.0.1:9000
    telegram.0 29239	2021-08-14 11:28:37.923	debug	States create User PubSub Client
    telegram.0 29239	2021-08-14 11:28:37.922	debug	States create System PubSub Client
    telegram.0 29239	2021-08-14 11:28:37.919	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    telegram.0 29239	2021-08-14 11:28:37.919	debug	objectDB connected
    telegram.0 29239	2021-08-14 11:28:37.917	debug	Objects connected to redis: 127.0.0.1:9001
    telegram.0 29239	2021-08-14 11:28:37.909	debug	Objects client initialize lua scripts
    telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects create User PubSub Client
    telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects create System PubSub Client
    telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects client ready ... initialize now
    telegram.0 29239	2021-08-14 11:28:37.897	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.zotac 2021-08-14 11:28:37.558	info	instance system.adapter.telegram.0 started with pid 29239
    host.zotac 2021-08-14 11:28:35.510	info	instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Fehler sehe ich keine. Adapter ist grün. Es komme auch nicht die "-" Meldungen zum Start / Stop
    Token und Passwort habe ich nicht geändert. Hat auch schonmal funktioniert.
    MfG
    Sissi
    • sissiwupS sissiwup
      haselchenH Offline
      haselchenH Offline
      haselchen
      @sissiwup
      Ich hab 8 Instanzen, laufen alle.
      Heute Nacht hatte ich 2-3 Polling Warnungen im Log.
      Kann bei dem ganzen Traffic mal passieren.
      Ich benutze allerdings kein Redis.
      Den Scheduled Restart solltest du mal löschen.
      Für mich unsinnig den Adapter jeden Tag um 5 Uhr oder so ähnlich,neu zu starten.
      sissiwupS crunchipC 2 Antworten Letzte Antwort
      • haselchenH haselchen
        @sissiwup
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        @haselchen sagte in Telegram sendet nicht mehr:
        @sissiwup
        Ok, das mit den restart kann ich machen. Was bedeutet "redis" in diesen Zusammenhang?
        PS: telegram über homematic und über server laufen auch noch ohne Probleme.
        MfG
        Sissi
          @sissiwup
          crunchipC Offline
          crunchipC Offline
          tust du sehr wohl, man achte auf den Port, das ist die interne iobroker redis Datenbank
          das war mal so eingebaut, da telegram hin und wieder Probleme bereitete und damit behoben wurde
          @sissiwup sagte in Telegram sendet nicht mehr:
          hast du mal versucht etwas anderes zu senden, als deine "html"
          sissiwupS 1 Antwort Letzte Antwort
            @sissiwup
            haselchenH Offline
            haselchenH Offline
            haselchen
            @sissiwup
            Ist nur ne Vermutung, weil ich das in deinem Log gelesen habe.
            Einen erklärenden Beitrag kann dazu bestimmt @Homoran leisten :)
              sissiwupS Offline
              sissiwupS Offline
              sissiwup
              @crunchip sagte in Telegram sendet nicht mehr:
              ja, ich habe auch mal nur "test" las Text gesendet. Im log taucht das auch brav auf. Nur mehr sagt er auch nicht. Log steht auf debug.
              telegram.0 29239	2021-08-14 12:09:46.997	debug	Received command "send": {"text":"Test","disable_notification":true}
              PS: Ich mache das über Blocky.
              Normal kam aber auch immer eine Meldung wenn der Adpater neu gestartet wurde ... (telegram)
              MfG
              Sissi
                crunchipC Offline
                crunchipC Offline
                mal javascript instanz neu starten, vllt hilfts
                kannst auch mal so testen, ob das funktioniert, such dir nen Datenpunkt in den Objekten und rechts über das Zahnrad...Einstellungen telegram mal aktivieren
                  sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  @crunchip
                  @crunchip
                  Habs zum laufen bekommen, wodran es nun wirklich lag?
                  Ich habe vom bot eine Nachricht an den iobroker gesendet.
                  Hier habe ich dass Passwort geändert. Dann hat er gefragt ob ich
                  die User neuer anlegen möchte (im Telegram Adapter, nachdem ich dort auch das Passwort geändert habe)
                  danach ging es auch wieder mit dem Senden
                  MfG
                  Sissi
