  4. Install node-red
Install node-red
3 Beiträge 2 Kommentatoren 2.1k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    habe node-red update durchgeführt. Danach ging nix mehr.
    Danach habe ich node-red in iobroker deinstalliert.
    Wenn ich neu installieren möchte kommt:
    $ ./iobroker add node-red
    host.zotac create instance node-red
    ERROR: host.zotac error: reading io-package.json Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.node-red/io-package.json'
    ERROR: process exited with code 20
    bei manueller Installation kommt:
    iobroker.core@1.0.0 /opt/iobroker
    └── mongodb@2.2.22  extraneous
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/buildmail/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/commist/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/concat-stream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/duplexify/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/feedparser/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/follow-redirects/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fs.notify/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/glob-stream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/imap/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/js2xmlparser/package.json'
    npm ERR! Linux 3.16.0-4-amd64
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.node-red"
    npm ERR! node v6.9.2
    npm ERR! npm  v4.1.2
    npm ERR! path /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven
    npm ERR! code EEXIST
    npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven: is outside /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/leven and not a link
    npm ERR! File exists: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven
    npm ERR! Move it away, and try again.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    MfG
    Sissi
    • BluefoxB Offline
      BluefoxB Offline
      Ich vermute, dass node-red gerade läuft und deswegen nicht gelöscht werden kann.
      cd /opt/iobroker
      iobroker stop node-red
      cd /opt/iobroker/node_modules/iobroker.node-red/
      sudo rm * -R
      cd ..
      sudo rmdir iobroker.node-red
      cd /opt/iobroker
      sudo npm i iobroker.node-red
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        Habe node-red jetzt komplett gelöscht. Der Adapter hat nur Probleme gemacht.
        Bei jeden update wurden die nachinstallierten Nodes vergessen etc.
        Die Sachen, die ich damit gemacht habe, können fast alles andere Adapter mittlerweile.
        Zusätzlich ein wenig Java-Skript und es läuft.
        MfG
        Sissi
