  4. SOLVED : notarget No matching version found for XYZ@<ver>
    6.6k
notargettelegramm
8 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • moelskiM Offline
    moelskiM Offline
    moelski
    schrieb am zuletzt editiert von moelski
    Moinsen !
    In meinem iob stehen 9 Adapter zur Aktuualisierung bereit. Ich wollte mal den Telegramm Adapter updaten, bekomme aber folgenden Fehler:
    $ ./iobroker upgrade telegram
    Update telegram from @1.8.1 to @1.9.0
    host.SHome-IoBroker Adapter "system.adapter.telegram.0" is stopped.
    NPM version: 7.16.0
    npm install iobroker.telegram@1.9.0 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.telegram@1.9.0.
    npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-08-09T13_24_58_625Z-debug.log
    upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
    Update "system.adapter.telegram.0"
    upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
    upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
    upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
    upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
    upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
    upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
    Adapter "telegram" updated
    host.SHome-IoBroker Adapter "system.adapter.telegram.0" is started
    process exited with code 0
    Auch andere Adapter bringen den gleichen Fehler.
    NPN und Node:
    dominik@SHome-IoBroker:/opt/iobroker$ npm -v
    7.16.0
    dominik@SHome-IoBroker:/opt/iobroker$ node -v
    v14.17.0
    js-controller ist auf Version 3.2.16.
    Ich habe mal ein
    probiert, aber da passiert gar nichts. Null Ausgabe - es kommt einfach ein neuer Prompt und das wars.
    Kann mir vielleicht wer einen Tip geben was ich nun machen könnte ?
    Grüße Dominik
    Grüße Dominik
    FredFF 1 Antwort Letzte Antwort
    • moelskiM moelski
      Moinsen !
      NPM version: 7.16.0
      NPN und Node:
      7.16.0
      v14.17.0
      Ich habe mal ein
      Grüße Dominik
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      @moelski sagte in notarget No matching version found for XYZ@<ver>:
      NPM version: 7.16.0
      Das ist wohl dein Problem. npm7 wird nicht unterstützt
      moelskiM 1 Antwort Letzte Antwort
      • FredFF FredF
        NPM version: 7.16.0
        moelskiM Offline
        moelskiM Offline
        moelski
        @fredf
        Ok, und wie komme ich zurück nach 6 ?
        Grüße Dominik
        • moelskiM moelski
          @fredf
          @moelski
          Schau in meiner Signatur wie man unter Debian nodeJS (inkl. npm) sauber installiert.
          Davon ab:
          1.10.0 ist die aktuelle Version für den telegram-Adapter.
          iobroker update
          iobroker upgrade
          (Nachdem nodeJS sauber im System ist...)
            @moelski
            Davon ab:
            iobroker update
            iobroker upgrade
            moelskiM Offline
            moelskiM Offline
            moelski
            @thomas-braun said in notarget No matching version found for XYZ@<ver>:
            @moelski
            Mache ich. Danke.
            Aber ich glaube ich hab da noch ein anderes Problem.
            Irgendwie scheint der ganze Server mehr oder minder offline.
            sudo apt update liefert nämlich auch nur Fehler.
            Ich forsche mal weiter. Danke erstmal
            Grüße Dominik
            • moelskiM moelski
              @moelski
              Mache ich. Danke.
              Geheime Fehler?
              Das sind die schlimmsten...
              Du scheinst da aber ein Netzwerkproblem zu haben.
                Geheime Fehler?
                moelskiM Offline
                moelskiM Offline
                moelski
                Geheime Fehler?
                Ja definitiv Netzwerk erstmal.
                Ich geb mal Feedback was ich rausgefunden habe ...
                Grüße Dominik
                • moelskiM moelski
                  Geheime Fehler?
                  moelskiM Offline
                  moelskiM Offline
                  moelski
                  Sooo, um es kurz zu machen.
                  Der Fehler war zum Teil hausgemacht.
                  1. Man sollte keine Kindersicherung in der Fritzbox für den iob aktiv haben. Warum auch immer die an war ... Danach war auch inet wieder da in iob :-)
                  2. NPM auf Version 6 gebracht
                  3. mit Thomas' Infos nodejs und node wieder gerade gezogen
                  Und nun laufen die Updates.
                  Danke trotzdem allen für die schnelle Hilfe.
                  Grüße Dominik
                  Grüße Dominik
