  4. Javascript und Web Adapter laufen nicht mehr
    6.3k
javascriptwebadminupdate
33 Beiträge 3 Kommentatoren 4.1k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    Was kommt auf dem SLAVE ?
    matzesutopia
    @wendy2702
    pi@iobroker-aquarium:~ $ iobroker update && iobroker upgrade
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
    Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
    Adapter    "backitup"      : 2.1.13   , installed 2.1.15
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "coronavirus-statistics": 0.6.3   , installed 0.6.3
    Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
    Adapter    "devices"       : 1.0.9    , installed 0.3.16 [Updateable]
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "echarts"       : 0.4.13   , installed 1.0.3
    Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
    Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
    Adapter    "flot"          : 1.10.6   , installed 1.10.6
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "i2c"           : 1.2.0    , installed 1.2.0
    Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Controller "js-controller" : 3.3.15   , installed 3.3.15
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "nina"          : 0.0.25   , installed 0.0.25
    Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
    Adapter    "owfs"          : 0.6.4    , installed 0.6.4
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
    Adapter    "spotify-premium": 1.0.0   , installed 1.1.3
    Adapter    "statistics"    : 1.0.9    , installed 1.0.9
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "text2command"  : 2.1.1    , installed 2.1.1
    Adapter    "tuya"          : 3.6.5    , installed 3.6.9
    Adapter    "virtualpowermeter": 1.4.2   , installed 1.4.2
    Adapter    "vis"           : 1.4.3    , installed 1.3.6 [Updateable]
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "wled"          : 0.5.6    , installed 0.5.6
    Required dependency "web" not found on this host.
    This upgrade of "admin" will at least introduce the following changes:
    -> 5.1.23:
    Corrected some errors reported via sentry
    -> 5.1.22:
    -> 5.1.21:
    -> 5.1.20:
    -> 5.1.19:
    Corrected some GUI errors
    -> 5.1.18:
    Corrected some GUI errors: theme switching, system settings
    -> 5.1.17:
    Corrected the error on the adapter's tab
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]:
    wenn ich mit yes bestätige, kommt danach eine Fehlermeldung. Kleinen moment, reiche ich sofort nach
    • M matzesutopia
      @wendy2702
      update done
      -> 5.1.23:
      -> 5.1.22:
      -> 5.1.21:
      -> 5.1.20:
      -> 5.1.19:
      -> 5.1.18:
      -> 5.1.17:
      @matzesutopia
        @matzesutopia
        Rückmeldungen in der Konsole...
        Nicht 'Hat nicht geklappt'. Da kann keiner was mit anfangen.
        matzesutopia
        brauchst du den kompletten log davon?
        • M matzesutopia
          wendy2702W Online
          wendy2702W Online
          wendy2702
          @matzesutopia kurze Frage.
          Der Aquarium war mal ein Master?
          Benötigst du die ganzen Instanzen auf dem Slave bzw. Sind die dort überhaupt aktiv?
          Sonst lösche alle Instanzen vom Slave die du dort nicht benötigst inklusive Admin.
          M 2 Antworten Letzte Antwort
            matzesutopia
            @wendy2702
            Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]: y
            Update admin from @4.2.1 to @5.1.23
            NPM version: 6.14.12
            npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
            npm ERR! code EINTEGRITY
            npm ERR! errno EINTEGRITY
            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/depd: Integrity verification failed for sha512-4LnpbjdJ7Aia2yIhzsT7YFDSNUEVWhe/86Ht3cEAtvX2HpV81Cy1rWTq0sU9ujYWVGoahyyL4FoJZZCjs7CzJg== (/home/iobroker/.npm/_cacache/content-v2/sha512/e0/b9/e96e3749ec089adb2221cec4fb6050d23541155a17bff3a1edddc100b6f5f61e957cd42cb5ad64ead2c53dba3616546a1a872c8be05a096590a3b3b0b326)
            npm ERR!     /home/iobroker/.npm/_logs/2021-08-06T21_15_31_482Z-debug.log
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            Adapter "admin" updated
            Invalid version of "admin". Installed "4.2.1", required ">=5.1.0
            • M matzesutopia
              @wendy2702
              @matzesutopia
              Bitte auch die Eingabezeile nicht verheimlichen.
              cd /opt/iobroker
              npm cache verify
                matzesutopia
                @wendy2702
                nein er war kein Master.
                Dort läuft auch nur I2C und der DS18B2 Adapter
                  @matzesutopia
                  cd /opt/iobroker
                  npm cache verify
                  matzesutopia
                  matze@iobroker-master:~$ cd /opt/iobroker
                  matze@iobroker-master:/opt/iobroker$ npm cache verify
                  Cache verified and compressed (~/.npm/_cacache):
                  Content verified: 0 (0 bytes)
                  Index entries: 0
                  Finished in 0.013s
                  pi@iobroker-aquarium:~ $ cd /opt/iobroker
                  pi@iobroker-aquarium:/opt/iobroker $ npm cache verify
                  Content verified: 1352 (296466020 bytes)
                  Corrupted content removed: 10
                  Content garbage-collected: 160 (13662853 bytes)
                  Missing content: 10
                  Index entries: 2137
                  Finished in 26.679s
                  • M matzesutopia
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    @matzesutopia warum sind dann soviel installiert?
                    Aber eigentlich egal, dein System.
                    Aber entweder Admin Updaten oder löschen.
                    • M matzesutopia
                      Index entries: 0
                      Finished in 0.013s
                      Missing content: 10
                      Index entries: 2137
                      Finished in 26.679s
                      @matzesutopia
                      Jetzt nochmal
                      iobroker update
                      iobroker upgrade
                        @matzesutopia
                        Jetzt nochmal
                        iobroker update
                        iobroker upgrade
                        matzesutopia
                        kommt die gleiche Fehlermeldung
                        pi@iobroker-aquarium:~ $ iobroker upgrade
                        -> 5.1.23:
                        -> 5.1.22:
                        -> 5.1.21:
                        -> 5.1.20:
                        -> 5.1.19:
                        -> 5.1.18:
                        -> 5.1.17:
                        Bekomme den Admin Adapter auch nicht gelöscht
                        • M matzesutopia
                          -> 5.1.23:
                          -> 5.1.22:
                          -> 5.1.21:
                          -> 5.1.20:
                          -> 5.1.19:
                          -> 5.1.18:
                          -> 5.1.17:
                          @matzesutopia
                          iobroker add web
                            @matzesutopia
                            iobroker add web
                            matzesutopia
                            @thomas-braun und @wendy2702
                            vielen Dank euch beiden. es funktioniert nun endlich wieder :)
