  4. WLED Variablentyp falsch nach JS Controller Update 3.3.15
    6.4k
typvariablewled
5 Beiträge 5 Kommentatoren 530 Aufrufe 3 Beobachtet
    mguenther
    schrieb am zuletzt editiert von mguenther
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Node-Version: 12.22.4
    Nodejs-Version: 12.22.4
    NPM-Version: 6.14.14
    Installationsart: Skript
    Image genutzt: Ja
    Ort/Name der Imagedatei: Original
    ich weiß nicht, ob es hier richtig ist, aber ich schreibe es mal hier hinein. Nach dem fehlerfreien Update des JS-Controllers auf 3.3.15 erscheint bei mir im LOG folgende Info:
    wled.0	2021-08-05 00:37:44.760	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
    wled.0	2021-08-05 00:37:14.445	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
    wled.0	2021-08-05 00:37:14.436	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
    wled.0	2021-08-05 00:37:14.425	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
    wled.0	2021-08-05 00:37:14.182	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.mac" has to be type "number" but received type "string"
    wled.0	2021-08-05 00:37:14.062	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
    und
    wled.0	2021-08-05 00:50:26.144	info	(8316) [Error catched and send to Sentry, thank you collaborating!] error: State attribute definition missing for + ndc
    wled.0	2021-08-05 00:50:25.618	info	(8316) [Error catched and send to Sentry, thank you collaborating!] error: State attribute definition missing for + fps
    Wenn ich das richtig verstehe, scheint es hier ein "Format Problem" mit dem Adapter zugeben. Ich selber rufe diese Objekte gar nicht auf, von daher denke ich mir mal, dass der WLED Adapter hier versucht, zu kommunizieren. Bis jetzt scheint noch alles zu funktionieren...
    Marcus
    Thomas BraunT F 2 Antworten Letzte Antwort
    • M mguenther
      Hardwaresystem: Pi4
      Festplattenart: SSD
      Image genutzt: Ja
      und
      Marcus
      @mguenther
      Das war hiermit gemeint:
      Informationen zur Version
      Die neue Version fokussiert sich neben Optimierungen, Bugfixes und einigen neuen Features vor allem weiter daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen. Im Zuge dieser neuen Checks wurden eine ganze Reihe Adapter aktualisiert - zu viele um hier alle zu nennen!
      Bitte unterstützt hier weiter für ggf. noch übriggebliebene Adapter und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
      • M mguenther
        Hardwaresystem: Pi4
        Festplattenart: SSD
        Image genutzt: Ja
        und
        Marcus
        Fabian1
        @mguenther Bitte unbedingt ein Issue auf Github beim WLED Adapter aufmachen.
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @mguenther fixed in 0.5.7 sollte heute nachmittag im latest sein und nieste Woche im stable
          • DutchmanD Dutchman
            tony63526
            @dutchman Vielen Dank!
