  4. Skript gestartet ja / nein
9 Beiträge 4 Kommentatoren 353 Aufrufe 5 Beobachtet
  • K Offline
    Kuddel
    ich möchte gern den Status von einem Skript anzeigen.
    Der Pfad zum Skript ist:
    javascript.0.scriptEnabled.smarthome.sontiges.bewaesserung_v2107
    Diesen Pfad habe ich in einem DP gespeichert, damit die VIS auch für andere verwendet werdet kann
    javascript.0.bewaesserung.vis.skript_pfad
    Jetzt scheitere ich leider bei der Darstellung:
    Editor Widget Einstellungen
    Editor:
    VIS Runtime
    Widget Export:
    [{"tpl":"tplValueListHtml8","data":{"oid":"{javascript.0.bewaesserung.vis.skript_pfad}","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"count":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Skript_Status","value2":"Flur","value3":"Gäste WC","value5":"Wohnzimmer","value6":"Home","value7":"Sleeping","value8":"Wird geladen","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"0","style2":"color: red","value0":"","value1":"","value4":"Küche","value9":"9","value10":"10","value11":"11","style0":"background: red","style7":"color: #e92716","style8":"color: #ffffff","style3":"color: red","style1":"background: #41f316","style4":"color: red","style9":"color: #e92716","style10":"color: #e92716","style11":"color: #e92716","value12":"Error","comment":"","value17":"Zone Cleanup","style17":"color: #yellow","style14":"","style12":"color: #e92716","views":null,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"455px","top":"5px","width":"20px","height":"20px","z-index":"20","border-radius":"10px","border-style":"","border-width":"","border-color":""},"widgetSet":"basic"}]
    Der Fehler ist wohl das Binding. Kann jemand helfen ?
    • K Kuddel
      Editor:
      VIS Runtime
      Widget Export:
      sigi234S Online
      sigi234S Online
      sigi234
      @kuddel
      Hallo, es gibt ja unter Objekt ob ein Skript true or false ist oder verstehe ich dich falsch?
      Immer Daten sichern!
      K 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @kuddel
        Kuddel
        @sigi234 ja genau um den DP geht es.
        Ich will den DP in der VIS aber nicht fest angeben, da sich die Versionnummer ändert und ich das dann in der VIS ändern müsste.
        Daher habe ich es mit dem anderen DP versucht, der den Pfad zum Skript enthält. Der Pfad wird autmatisch durch das Skript erstellt
        • K Kuddel
          sigi234S Online
          sigi234S Online
          sigi234
          @kuddel
          Gib mal bei Objekt ID den Pfad ohne Klammer ein und bei Wert das binding.
          Mit den bindings bin ich auf Kriegsfuß..😀
          https://github.com/ioBroker/ioBroker.vis#special-bindings
          • sigi234S sigi234
            @kuddel
            Kuddel
            @sigi234 meinst du so ?
            Funzt nicht. Schalter erwarter einen Boolean. Mein DPs ist aber natürlich ein String.
            Wert[0] und Wert [1] gibt nur Strings aus.
            Somit wird der Pfad nicht verarbeitet, sondern als Text ausgegeben
            • K Kuddel
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @kuddel
              ich glaube, dass ist nicht so einfach - da brauchst du ein script IN der vis. im bindings kannst du keine datenpunkte abfragen, denn du brauchst ja den "wert eines wertes" - also ein getstate im binding
              eigentlich sollten scripte immer laufen, daher frage ich mich, wie es sein könnte, dass dein script "nicht aktiv" ist. scripte sollten nicht enabled und disabled werden, sondern im script soll abgefragt werden, ob darin etwas ausgeführt wird oder nicht
              wenn du trotzdem mit dem enabled arbeiten willst:
              am einfachsten wäre es ein kleines extra blockly-script zu machen und dir damit den enabled "spiegelst". also ein eigenes blockly-script, welches herausfindet, ob dein script aktiv(enabled) ist und das ergebnis in einen eigenen dp scheibt - diesen nutzt du dann - so kannst du ein binding/script in der vis umgehen
              • liv-in-skyL liv-in-sky
                @kuddel
                Kuddel
                @liv-in-sky danke für die ausführliche Beantwortung.
                Wäre nur eine "nice to have" Funktion.
                Da es aber doch sehr umständlich wird, lasse ich das einfach mal weg.
                • K Kuddel
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @kuddel
                  umstandlich - ich weiß nicht
                  einen datenpunkt anlegen (im beispiel: testlogic) und dieses script erstellen
                  A 1 Antwort Letzte Antwort
                    @kuddel
                    Ahnungsbefreit
                    @liv-in-sky @Kuddel ich denke, hier tut's sogar ein Einzeiler:
                    Dabei ist Object ID 1 der "echte" Datenpunkt und ID2 der eigene.
