  4. Fehler im Rpc Adapter
    6.3k
26 Beiträge 9 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • dslraserD dslraser
    @tg-71 sagte in Fehler im Rpc Adapter:
      "type": "state",
      "common": {
        "name": "###INT0000003:1.SET_TEMPERATURE",
        "def": "20.0",
        "type": "number",
        "read": true,
        "write": true,
        "min": "5.0",
        "max": "30.0",
        "unit": "°C",
        "role": "level.temperature"
      "native": {
        "UNIT": "�C",
        "MIN": "5.0",
        "MAX": "30.0",
        "OPERATIONS": 7,
        "FLAGS": 1,
        "ID": "SET_TEMPERATURE",
        "TAB_ORDER": 4,
        "TYPE": "FLOAT",
        "DEFAULT": "20.0",
        "CONTROL": "HEATING_CONTROL.SETPOINT"
      "from": "system.adapter.hm-rega.0",
      "user": "system.user.admin",
      "ts": 1621541001807,
      "_id": "hm-rpc.2.INT0000003.1.SET_TEMPERATURE",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    In der Parameterdefinition von "Set_Temperature" ist für die Gruppen 5 als Minimum angegeben. Beim Thermostatventilen steht 4.5...
    Kann ich nicht bestätigen. Bei mir ist egal ob Wandthermostat/Heizungsventil oder Gruppe 4,5 als min...
    Vielleicht mal neu erstellen lassen ?
     "ts": 1623050297585,
     "common": {
       "name": "Heizung Flur.SET_POINT_TEMPERATURE",
       "type": "number",
       "unit": "°C",
       "role": "level.temperature",
       "def": 4.5,
       "min": 4.5,
       "max": 30.5,
       "read": true,
       "write": true,
       "custom": {
         "influxdb.0": {
           "enabled": true,
           "changesOnly": true,
           "debounce": "1000",
           "retention": 0,
           "changesRelogInterval": 0,
           "changesMinDelta": 0,
           "storageType": "",
           "aliasId": ""
         "iqontrol.0": {
           "enabled": true,
           "readonly": false,
           "invert": false,
           "confirm": false,
           "pincode": "",
           "unit": "°C",
           "unit_zero": "°C",
           "unit_one": "°C",
           "min": 4.5,
           "max": 30.5,
           "step": "",
           "roundDigits": 2,
           "timeFormat": "x",
           "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
           "type": "number",
           "role": "",
           "targetValueId": "",
           "statesAddInput": false,
           "statesAddInputCaption": "Enter other value...",
           "showOnlyTargetValues": false
     "native": {
       "UNIT": "�C",
       "ID": "SET_POINT_TEMPERATURE",
       "TYPE": "FLOAT",
       "CONTROL": "HEATING_CONTROL_HMIP.SETPOINT",
       "MIN": 4.5,
       "OPERATIONS": 7,
       "MAX": 30.5,
       "FLAGS": 1,
       "DEFAULT": 4.5
     "acl": {
       "object": 1636,
       "state": 1636
     "_id": "hm-rpc.2.INT0000004.1.SET_POINT_TEMPERATURE",
     "type": "state"
    sissiwupS Offline
    sissiwupS Offline
    sissiwup
    @dslraser
    Neu erstellen hat nichts gebracht. Gleiche Warnung
    MfG
    Sissi
    draexlerD 1 Antwort Letzte Antwort
    • sissiwupS sissiwup
      @dslraser
      draexlerD Offline
      draexlerD Offline
      draexler
      @sissiwup Hast du eine Lösung gefunden?
      sissiwupS 1 Antwort Letzte Antwort
      • draexlerD draexler
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        @draexler
        leider nein. Problem habe ich grade festgestellt ist immer noch da.
        Es herrscht hier leider die Meinung vor, ioBroker hat immer Recht, auch wenn das Ursprungssystem was anderes liefert.
        Warnungen ausschalten beim Adapter ist das einzige was hilft.
        MfG
        Sissi
          @draexler
          @sissiwup sagte in Fehler im Rpc Adapter:
          wer sagt das?
          Habe keine HM Heizungsteile, kann das daher nicht überprüfen, glaube mich aber erinnern zu können, dass das ein Bug seitens der CCU rpc sei und von Seiten EQ-3 gelöst werden müsse.
            wer sagt das?
            sissiwupS Offline
            sissiwupS Offline
            sissiwup
            @homoran sagte in Fehler im Rpc Adapter:
            wer sagt das?
            in der CCU kann ich OFF = 4,5 Grad wählen.
            Das Thermostat zeigt dann OFF an. Ausgelesen ist das aber wieder 4,5 Grad.
            War immer so. Was soll da falsch sein?
            MfG
            Sissi
              wer sagt das?
              @sissiwup das wurde dir doch beteits in deinem anderen Thread gesagt
              https://forum.iobroker.net/topic/54990/hm-rpc-adapter-falsche-grenzwerte/2?_=1652980482742
              es geht nicht um die 4.5°C, sondern um den gleichzeitig von der CCU übermittelten Min-Wert von 5°C
