  4. Alexa kann Geräte nicht erreichen
    6.7k
187 Beiträge 11 Kommentatoren 27.4k Aufrufe 7 Beobachtet
  • haselchenH haselchen
    @michael-pusch
    Poste mal noch mehr Logs....was nach Alexa noch kommt
    michael.puschM Offline
    michael.pusch
    #141
    @haselchen
    2021-06-24 22:00:12.311 - info: sonoff.0 (19496) Starting MQTT authenticated server on port 8883
    2021-06-24 22:01:03.974 - info: sonoff.0 (19496) Client [SHP_Scentsy_Vorraum] connected with secret 1624564863954_6506
    2021-06-24 22:01:04.501 - info: sonoff.0 (19496) Client [SHP_Scentsy_Vorraum] connection closed: disconnected
    2021-06-24 22:01:10.814 - info: sonoff.0 (19496) Client [SHP_Scentsy_Vorraum] connected with secret 1624564870812_9015
    2021-06-24 22:01:11.037 - info: alexa2.0 (19323) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-06-24 22:02:11.572 - info: alexa2.0 (19323) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-06-24 22:03:12.102 - info: alexa2.0 (19323) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-06-24 22:03:25.754 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2021-06-24 22:03:25.762 - info: alexa2.0 (19323) Got terminate signal TERMINATE_YOURSELF
    2021-06-24 22:03:25.763 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
    2021-06-24 22:03:25.764 - info: alexa2.0 (19323) terminating
    2021-06-24 22:03:25.767 - info: alexa2.0 (19323) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-06-24 22:03:26.376 - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-06-24 22:03:28.970 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 19527
    2021-06-24 22:03:30.565 - info: alexa2.0 (19527) starting. Version 3.9.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
    Gradeaus ---------->
    • michael.puschM michael.pusch
      @haselchen
      haselchenH Offline
      haselchenH Offline
      haselchen
      #142
      @michael-pusch
      Die Steckdose scheint noch verbunden zu sein.
      Ändern sich die Datenpunkte?
      Die Einstellungen vom Alexa Adapter bitte...
      Da ist echt ne Menge im Argen in dem System.
      michael.puschM 1 Antwort Letzte Antwort
        @michael-pusch
        michael.pusch
        schrieb am zuletzt editiert von michael.pusch
        #143
        @haselchen
        gehgeh.. i hab lediglich den alexa adapter komplett eliminiert und war zwischenzeitlich neu im verbinden... dadurch das ich da grad mit dir schreib, pfuscht ma der alexaadapter in das log... mitlerweile kommt nix mehr vom adapter im log...
        Und alles andere war ja auch immer verbunden, wie gesagt, ich kann ja auch alles ansprechen über VIS... eben nur ned über alexa ;)
        sonoff.0   2021-06-24 22:15:00.016        warn (19496) Client "Sonoff_4ch" not connected
        web.0	2021-06-24 22:12:57.937	info	(19724) ==>Connected system.user.admin from 192.168.1.107
        web.0	2021-06-24 22:12:57.514	info	(19724) http server listening on port 8082
        web.0	2021-06-24 22:12:57.509	info	(19724) socket.io server listening on port 8082
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          #144
          @michael-pusch
          Lösch mal den Cookie und lass ihn neu holen.
          Deine Steckdose ist noch mit dem Sonoff Adapter verbunden?
          Datenpunkte ändern sich?
            @michael-pusch
            michael.pusch
            #145
            @haselchen
            Cockie gelöscht, und neu geholt...
            alexa2.0	2021-06-24 22:21:25.416	info	(19827) starting. Version 3.9.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
            host.raspberrypi	2021-06-24 22:21:23.823	info	instance system.adapter.alexa2.0 started with pid 19827
            host.raspberrypi	2021-06-24 22:21:21.264	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            alexa2.0	2021-06-24 22:21:20.672	info	(19812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            alexa2.0	2021-06-24 22:21:20.670	info	(19812) terminating
            alexa2.0	2021-06-24 22:21:20.668	info	(19812) Got terminate signal TERMINATE_YOURSELF
            host.raspberrypi	2021-06-24 22:21:20.668	info	stopInstance system.adapter.alexa2.0 send kill signal
            host.raspberrypi	2021-06-24 22:21:20.660	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
            Steckdose is nach wie vor verbunden
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              #146
              @michael-pusch
              Da steht nix mit neuem Cookie....?!
              Guck mal in den Adapter, ob da wirklich nen neuer ist.
              Nicht nur den Adapter neu starten, sondern vorher das Feld mit dem Cookie löschen.
                @michael-pusch
                michael.pusch
                #147
                @haselchen
                Das Feld wird geleert/gelöscht und dann gespeichert... somit startet Adapter neu...
                Das folgende kam zwischenzeitlich rein...
                Nur zur Info, das AlexaPush Connection hatte ich vorher nicht, bevor ich den Adapter gelöscht und neu installeirt hatte...
                Das kam erst seit der neuinstallation
                  @haselchen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #148
                  @michael-pusch
                  Okay.
                  Dann in den IOT jetzt.
                  Dort neues Verbindungszertifikat anfordern.
                  Danach in der Alexa App den IOT Skill deaktivieren und wieder neu aktivieren.
                  Wenn du soweit dann bist, sag Bescheid.
                    @michael-pusch
                    Okay.
                    michael.pusch
                    #149
                    @haselchen
                    21:01:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:01:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:06:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:06:18","Uptime":"0T00:05:16","UptimeSec":316,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":80,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:06:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:06:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:11:02 APP: Serielles Logging deaktiviert
                    21:11:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:11:18","Uptime":"0T00:10:16","UptimeSec":616,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":82,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:11:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:11:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:16:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:16:18","Uptime":"0T00:15:16","UptimeSec":916,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":80,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:16:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:16:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:21:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:21:18","Uptime":"0T00:20:16","UptimeSec":1216,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":80,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:21:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:21:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:26:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:26:18","Uptime":"0T00:25:16","UptimeSec":1516,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":80,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:26:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:26:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    21:31:18 MQT: tele/shp_scentsy_vorraum/STATE = {"Time":"2021-06-24T21:31:18","Uptime":"0T00:30:16","UptimeSec":1816,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"iobroker","BSSId":"5E:D4:F7:F9:1A:9A","Channel":3,"RSSI":80,"LinkCount":1,"Downtime":"0T00:00:05"}}
                    21:31:18 MQT: tele/shp_scentsy_vorraum/SENSOR = {"Time":"2021-06-24T21:31:18","ENERGY":{"TotalStartTime":"2019-02-08T18:12:31","Total":25.439,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                    Das macht der Tasmotastecker zwischenzeitlich in seinem Log
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #150
                      @michael-pusch
                      Sieht gut aus....
                      Kurz nebenbei...MQTT "funkt" auf 2 Ports -> 1883 und 8883
                      Und da meistens 1883 voreingestellt ist, kollidieren Sonoff und MQTT Adapter.
                      Und so kannst du dem aus dem Weg gehen.
                      Der 1 Adapter bekommt den Port und der Andere den anderen.
                      michael.puschM 2 Antworten Letzte Antwort
                        @michael-pusch
                        Sieht gut aus....
                        michael.pusch
                        #151
                        @haselchen
                        Da war auch nie was anderes.. lief ja alles
                        iot.0	2021-06-24 22:37:28.251	info	(19938) Connection changed: connect
                        iot.0	2021-06-24 22:37:25.320	info	(19938) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                        iot.0	2021-06-24 22:37:25.255	info	(19938) starting. Version 1.8.22 in /opt/iobroker/node_modules/iobroker.iot, node: v12.22.1, js-controller: 3.2.16
                        host.raspberrypi	2021-06-24 22:37:22.891	info	instance system.adapter.iot.0 started with pid 19938
                        host.raspberrypi	2021-06-24 22:37:20.347	info	instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        iot.0	2021-06-24 22:37:19.789	info	(19662) Connection lost
                        iot.0	2021-06-24 22:37:19.789	info	(19662) Connection changed: disconnect
                        iot.0	2021-06-24 22:37:19.733	info	(19662) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        iot.0	2021-06-24 22:37:19.732	info	(19662) terminating
                        host.raspberrypi	2021-06-24 22:37:19.729	info	stopInstance system.adapter.iot.0 send kill signal
                        iot.0	2021-06-24 22:37:19.729	info	(19662) Got terminate signal TERMINATE_YOURSELF
                        host.raspberrypi	2021-06-24 22:37:19.717	info	stopInstance system.adapter.iot.0 (force=false, process=true)
                        alexa2.0	2021-06-24 22:24:14.952	info	(19827) Alexa-Push-Connection established. Disable Polling
                        Das passierte nach dem "neu anfordern"
                          @michael-pusch
                          Sieht gut aus....
                          michael.pusch
                          #152
                          @haselchen
                          Ja, zu Mqtt adapter, den hab i ja nur wegen Sonoff adapter ausschluss installiert gehabt... gleiche einstellungen beim mqtt adapter gemacht... der sonoff war dabei vorher schon 2-3 minuten down...
                          und die geräte haben sich alle nach der reihe neu verbunden... allerdings wurden sie nicht über iot auf alexa übernommen...
                          somit hab ich wieder zrück auf den sonoff geschaltet...
                            @haselchen
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #153
                            @michael-pusch
                            Sehr gut...einige Infos habe ich eben oben noch geschrieben, bezüglich Ports...
                            Alexa App IOT Skill..deaktivieren....aktivieren...
                            Dann in der App die Steckdose als Gerät löschen.
                            Danach in den IOT und dort die Steckdose auch löschen.
                            Dann Bescheid geben :)
                              @michael-pusch
                              michael.pusch
                              #154
                              @haselchen
                              erledigt
                                @haselchen
                                erledigt
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #155
                                @michael-pusch
                                Dann jetzt in den IOT und auf das + drücken.
                                Dann von der Steckdose am besten den Datenpunkt mit "switch" nehmen (true/false).
                                Dann einen Namen eingeben Duftlampe zum Beispiel.
                                Und Typ SWITCH.
                                Speichern.
                                Sobald es grün im IOT erscheint, in der Alexa App auf Geräte suchen drücken.
                                Und dabei "Sonstige" nehmen.
                                45 Sekunden warten und dann findet Alexa hoffentlich die Duftlampe.
                                  @michael-pusch
                                  Und Typ SWITCH.
                                  Speichern.
                                  michael.pusch
                                  #156
                                  @haselchen
                                  Alter, pass auf...
                                  Ich hab das jetzt alles so wie wir auch gerade die letzten 3 Tage die schritte durchgemacht, die gleichen schritte...
                                  Jetzt mach ichs mit DIR nochmal... und plötzlich gehts?
                                  Aber ACHTUNG !! Ich geh davon aus, ich habe ALEXA App am Android komplett gelöscht und neu registriert... das hatte ich bis dato noch nicht gemacht gehabt... das war neu, aber den Skill entkoppelt, neu installiert und die Keys mit IOT verbunden hab i glaub i 30x gmacht gehabt...
                                  JETZT GEHTS... i weard deppat...
                                    @haselchen
                                    Alter, pass auf...
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #157
                                    @michael-pusch
                                    Sag, dass du mich liebst 😬 😬 😬
                                      @michael-pusch
                                      michael.pusch
                                      #158
                                      @haselchen
                                      :couple_with_heart: HAHAHAHAHA
                                      so, na ich stell mal das ganze auf 1883 retour und hol mir mal alle anderen Aktoren rein... mal schauen obs geht....
                                        @haselchen
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #159
                                        @michael-pusch
                                        Eigentlich musste jetzt nur noch die anderen Geräte auf den Port 8883 switchen und im IOT und in der Alexa App löschen und dann die letzten Schritte von eben wiederholen und anlegen und suchen lassen.
                                        Nee nee, lass das auf 8883.
                                        Sonst hauste dir wieder nen Knüppel zwischen die Beine, wenn du das jetzt wieder änderst.
                                          @michael-pusch
                                          michael.pusch
                                          #160
                                          @haselchen
                                          Na das mit dem mqtt port auf 8883 wird heut nimmer erledigt... sind mir dann ein bisserl zu viele geräte...
                                          bin froh wenn das graffelwerk (sinnloses technisches produkt) wieder rennt ;)
                                          das mach ich morgen in ruhe...
                                          Lieber Haselchen,
                                          Ich sage 👑 👑 👑 DANKE FÜR DEINE ZEIT 👑 👑 👑 !!!!
                                          Ist nicht selbstverständlich !!!!
                                          Hoffe ich hab dich nicht von etwas abgehalten ;)
                                          Ich wünsche dir noch einen schönene Abend, nen schönen Freitag und ein ruhiges Wochenende 🤙
