  4. ioBroker und openhabian image
31 Beiträge 3 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • Marko1974M Offline
    Marko1974M Offline
    Marko1974
    aktuell habe ich ein openhabian image auf meinem raspberry pi4. Eigentlich läuft die Sache wunderbar mit openhab und homebridge, trotzdem wollte ich mich mal an ioBroker probieren.
    Leider bekomme ich es gar nicht installiert, da irgendwelche Fehlermedungen während der Installation auftauchen.
    Hat hier jemand ioBroker auf openhabian laufen?
        Installing prerequisites (1/4)
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:4 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
    Reading package lists... Done
    N: Ignoring file 'openhab2.liste' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
                     from ../src/main.cpp:3:
    /home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:566:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8:        :Value>, void*)â} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:600:3: note: in expansion of macro âNODE_MODULE_Xâ
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro âNODE_MODULEâ
     NODE_MODULE(diskusage, Init)
    In file included from /home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:63,
    /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of âvoid v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callb        ack, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]â:
    /home/openhabian/.cache/node-gyp/12.14.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from âv8::WeakCallbackInfo<node::ObjectWrap>::Callbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)â} t        o âCallbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<void>&)â} [-Wcast-functio        n-type]
                    reinterpret_cast<Callback>(callback), type);
    • Marko1974M Marko1974
      Installed gcc-c++
      @marko1974 sagte in ioBroker und openhabian image:
      weiter machen - abwarten, da kommt noch was nach einer Pause
      Das sind keine "echten" Fehler, da gibt es nur keine fertigen Pakete und er geht ins build - das dauert dann..
      (hoffe ich)
      Marko1974M 1 Antwort Letzte Antwort
        Installed gcc-c++
        Ignoring file openhab2.liste in directory /etc/apt/sources.list.d
        Die Datei muss openhab2.list heißen
          (hoffe ich)
          Marko1974M Offline
          Marko1974M Offline
          Marko1974
          @homoran Ja da kommt noch was und die Installation läuft auch durch. Jedoch komme ich dann nicht ins interface....
          meine Nodejs und node version ist auch nicht gleich - dies scheint voraussetzung für die installation zu sein.
          zudem läuft der logger von openhab auf port 9001 .... das hatte ich aber schon in der config geändert.
          Ich möchte node halt jetzt nicht deinstallieren und dann eine nicht funktionierende homebridge haben, die aus 7 instanzen besteht....ich hänge mal eben alles an.
            @marko1974
            nodejs muss halt sauber installiert sein.
              da kann man dann ansetzen.
              Nicht wirklich!
              Zwei verschiedene Versionen ist ein Zeichen dafür, dass es zwei verschiedene unabhängige nodejs-Installationen gibt, die sich gegenseitig stören.
                @marko1974
                Marko1974M Offline
                Marko1974M Offline
                Marko1974
                @thomas-braun nunja...das ist es.
                Marko1974M Thomas BraunT 2 Antworten Letzte Antwort
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  @marko1974
                                  from ../../../nan/nan.h:56,
                                  from ../src/poller.cpp:1:
                  /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of âvoid v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]â:
                  /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from âv8::WeakCallbackInfo<node::ObjectWrap>::Callbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)â} to âCallbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<void>&)â} [-Wcast-function-type]
                  /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of âvoid v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]â:
                  ../../../nan/nan_object_wrap.h:65:61:   required from here
                  /home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from âv8::WeakCallbackInfo<Nan::ObjectWrap>::Callbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)â} to âCallbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<void>&)â} [-Wcast-function-type]
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 22
                  npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
                  npm ERR! Exit status 22
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/openhabian/.npm/_logs/2021-05-23T18_14_18_955Z-debug.log
                     Finalizing installation (4/4)
                  Enabling autostart...
                  Autostart enabled!
                     ioBroker was installed successfully
                     Open http://192.168.178.72:8081 in a browser and start configuring!
                    @marko1974
                    Unterschiedliche Versionen von node und nodejs spricht nicht dafür. Da ist was doppelt installiert.
                      @marko1974
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      [20:14:21] openhabian@openhab:~$ npm -v
                      6.14.8
                      [20:22:02] openhabian@openhab:~$ nodejs -v
                      v12.22.1
                      [20:22:05] openhabian@openhab:~$ node -v
                      v12.14.0
                      [20:22:11] openhabian@openhab:~$
                        6.14.8
                        v12.22.1
                        v12.14.0
                        @marko1974 Und das ist falsch.
                        Schau in meiner Signatur wie man nodejs sauber über apt installiert.
                        Wobei ich nicht weiß wie/ob openhab dann läuft.
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          [21:23:54] openhabian@openhab:/var/homebridge$ sudo apt update
                          Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4,584 B]
                          Err:3 https://deb.nodesource.com/node_14.x buster InRelease
                           The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
                          W: GPG error: https://deb.nodesource.com/node_14.x buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
                          E: The repository 'https://deb.nodesource.com/node_14.x buster InRelease' is not signed.
                          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                          N: See apt-secure(8) manpage for repository creation and user configuration details.
                          Da gehts schon los...nur eben die Pfade abgeändert
                            @marko1974
                            curl -fsSL https://deb.nodesource.com/gpgkey/nodesource.gpg.key | sudo apt-key add -
                            Was kommt zu
                            which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                            Marko1974M 2 Antworten Letzte Antwort
                              @marko1974
                              Was kommt zu
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              @thomas-braun das war schonmal gut :-)
                              aber ich habs wohl auch im falschen verzeichnis und node ist immer noch auf 12
                              [21:33:22] openhabian@openhab:/var/homebridge$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              v14.17.0
                              v12.14.0
                              6.14.8
                              Hit:1 https://deb.nodesource.com/node_14.x buster InRelease
                              Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                              Building dependency tree
                              7 packages can be upgraded. Run 'apt list --upgradable' to see them.
                              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:3 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
                              Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              nodejs:
                                Installed: 14.17.0-1nodesource1
                                Candidate: 14.17.0-1nodesource1
                                Version table:
                               *** 14.17.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u1 500
                                @marko1974
                                Was kommt zu
                                Marko1974M Offline
                                Marko1974M Offline
                                Marko1974
                                [21:37:06] openhabian@openhab:/var/homebridge$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                                /usr/bin/nodejs
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                v14.17.0
                                v12.14.0
                                6.14.8
                                Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                nodejs:
                                 Version table:
                                  /usr/bin/nodejs
                                  /usr/local/bin/node
                                  /usr/local/bin/npm
                                  v14.17.0
                                  v12.14.0
                                  6.14.8
                                  nodejs:
                                    Version table:
                                  /usr/local/bin/node
                                  /usr/local/bin/npm
                                  Das ist aus ioBroker Sicht falsch.
                                    /usr/local/bin/node
                                    /usr/local/bin/npm
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    @thomas-braun wenn ich das ändere geht meine homebridge nicht mehr, oder?
                                      @marko1974 Das weiß ich nicht.
                                      Hängt davon ab ob die das statisch verlinkt haben und/oder ob deren Code mit node14 sauber tickt.
                                      Unter der Voraussetzung, die Installation in /usr/local/bin kommt schon so in deren Image mit und nicht von dir.
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        @thomas-braun `lass mal probieren....notfalls gibts n backup.
                                        haste den befehl für mich?
                                          @marko1974
                                          Die stehen in dem HowTo drin.
                                          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
