  5. [gelöst]Trockenlaufschutz, Problem mit Blockly
    2.9k
    5.0k
107 Beiträge 6 Kommentatoren 11.4k Aufrufe 2 Beobachtet
  • N nole
    @jan1 Das skript sieht bei mir jetzt so aus:
      <variables>
        <variable type="timeout" id="timeout3">timeout3</variable>
        <variable type="timeout" id="timeout4">timeout4</variable>
      </variables>
      <block type="on_ext" id="FB^,o-|.DkV*l1Zpw1ev" x="-487" y="88">
        <value name="OID0">
          <shadow type="field_oid" id="w]B4izL8Xi6Xis[a47]}">
            <field name="oid">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="o9}:IIEo};jIF72b9AA.">
            <value name="IF0">
              <block type="logic_operation" id="k/5vYdt)FO5#4fIMa~m;" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="logic_compare" id="ViV`%UQ}k~UPs7,j-ryV">
                    <field name="OP">GTE</field>
                    <value name="A">
                      <block type="on_source" id="u:72U[-3Dnb8^3xE,|!!">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="!{rp568)Xa_3X^/P-X67">
                        <field name="NUM">100</field>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="{T1t5z14z,+4|DC]gOXz">
                    <field name="OP">LT</field>
                    <value name="A">
                      <block type="on_source" id="=QYK}e_eO)R!UP9V$lM^">
                        <field name="ATTR">oldState.val</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="hLUSUOYJL$qWXsN7kTk8">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="timeouts_cleartimeout" id="U_%ugF^L^YUcG@wP=]~Z">
                <field name="NAME">timeout4</field>
                <next>
                  <block type="control" id="hZTA=BSjCVV{]?(0pVgY">
                    <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.POWER</field>
                    <value name="VALUE">
                      <block type="logic_boolean" id="R||h%3X{{l}e4p`%Yawz">
                      </block>
                    </value>
                    <next>
                      <block type="timeouts_settimeout" id=".o~uvJbWt^KQ`oiI!e$!">
                        <field name="DELAY">30</field>
                        <field name="UNIT">min</field>
                          <block type="control" id="4S}(|m-Kt)y5P9txPZ+I">
                              <block type="logic_boolean" id="}wd]{cXQ@x{`KvgI26LW">
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_operation" id="!/F3qNm$R2Q]m/jo|f#T" inline="false">
                <value name="A">
                  <block type="logic_compare" id="iHA4@^BN{s/[}$=sq31n">
                    <field name="OP">LTE</field>
                    <value name="A">
                      <block type="on_source" id="gQBF^?(7;hKwq*ro`;LK">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="E1Co9VoP0Z]U].V}:dk6">
                        <field name="NUM">50</field>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="2[[fJeqHxkcfP[F^]I-Q">
                    <field name="OP">GT</field>
                    <value name="A">
                      <block type="on_source" id="f5IDFVCeLD}U6K[_XEG@">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="2k,M4Zr}0C_#uR%MuF|Q">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO1">
              <block type="timeouts_cleartimeout" id="cL@Uuw#K=7Oj=lJL/W:h">
                <next>
                  <block type="control" id="dYN%$E|/?la90IKRz{*w">
                      <block type="logic_boolean" id="lU?:V,sk#5e#Zs@){!|m">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="debug" id=",qorWlCkGFLb!+WM7/rO">
                <value name="TEXT">
                  <shadow type="text">
                  </shadow>
                  <block type="text_join" id="8h9QE+{dve}o}{xFz4^/">
                    <value name="ADD0">
                      <block type="text" id="^^vC/IAZ$YnpMiFFn.nC">
                        <field name="TEXT">Watt:</field>
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="on_source" id="-bW!=3`GYzyDgu_1}k0G">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on_ext" id=")3Y6O)OSZ6,a.eId9_([" disabled="true" x="-487" y="688">
        <value name="OID0">
          <shadow type="field_oid" id="FB}qA2j)SArn`ar=BQ8z">
          </shadow>
        </value>
          <block type="controls_if" id="nT8{B{T^As}6|P1eFdAp">
            <value name="IF0">
              <block type="logic_compare" id="h=ll3)j0~lH*]vID@v{h">
                <value name="A">
                  <block type="get_value" id="prv]M@]WP)O8k`WxQv,M">
                    <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="QWMd~%R.#BvSN.-Jr7|S">
                  </block>
                </value>
              </block>
            </value>
              <block type="controls_if" id=";N~?jZO,:^+(B6c4+e.p">
                <value name="IF0">
                  <block type="logic_compare" id="nLGp=iM$L~IydiZi8!Z?">
                    <value name="A">
                      <block type="get_value" id="#X;Nd8faxS1r?ibN,9Ur">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="3L+Hx`ZZZ[6;bcStTgXv">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="timeouts_cleartimeout" id="s_tu+G)JzfXKRo!,-i?j">
                    <field name="NAME">timeout3</field>
                  </block>
                </statement>
                <next>
                  <block type="timeouts_settimeout" id="|y|12`S1gi{?f|+:!d87">
                      <block type="control" id="]:Q/hgD*3Ye$XrhiCKVK">
                          <block type="logic_boolean" id="]qeVb0?p3y!^dSP8T!{!">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="debug" id="jv2kcn+O#/wer{(+o+DW">
                <value name="TEXT">
                  </shadow>
                  <block type="text_join" id="FXin0|uc^i=Wm;0R-Jtj">
                    <value name="ADD0">
                      <block type="text" id="Z##h?{^2;N/L6AAv4~..">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="on_source" id="t@LBx#Y!8Fv5({,pHM[,">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    #61
    @nole sagte in Trockenlaufschutz, Problem mit Blockly:
    warum nie als screenshot??
    Am Handy nutzt der xml-Export rein gar nix
    N 2 Antworten Letzte Antwort
      N Offline
      N Offline
      nole
      #62
      • N nole
        @jan1 irgendwas stimmt noch nicht, ich weiß nur noch nicht was. Schaltet immer noch ohne erkennbaren Grund aus. Ich probiere den Fehler zu finden.
        #63
        und was steht dann im debug?
        Hast du mal auf "geändert" getriggert und das Problem bleibt?
        ich weiß nicht, ob der Sensor ggf. 2x hintereinander den selben Wert liefert
        lass dir vielleicht zusätzlich noch den vorherigen Wert ausgeben
        N 1 Antwort Letzte Antwort
          N Offline
          N Offline
          nole
          #64
          @homoran Die Pumpe hat wenn sie kein Wasser hat, also im Trockenlauf vor der ich die Pumpe schützen will, zwischen 150 und 200 Watt Verbrauch. Im Pumpen mit Wasser über 300 Watt und natürlich wenn der Wasserdruck im Haus ok ist 0 Watt.
          Wenn der Druck erreicht ist und die Pumpe abschaltet zeigt die Wattanzeige vom Sonoff PowR2 kurze Zeit noch ein paar Watt an ( Zwischen 4 und 50 Watt).
          HomoranH 3 Antworten Letzte Antwort
          • N nole
            #65
            @nole ich hatte noch was editiert:
            @homoran sagte in Trockenlaufschutz, Problem mit Blockly:
              N Offline
              N Offline
              nole
              #66
              @homoran ich werde es nochmal mit "geändert" probieren.
              • N nole
                #67
                und warum prüfst du nicht auf diesen Bereich, sondern auf >100 um die Pumpe anzuschalten?
                  N Offline
                  N Offline
                  nole
                  #68
                  @homoran das ist das was ich bei dem Skript auch noch nicht verstehe
                  • N nole
                    #69
                    Aber das ist doch dein Ansatz gewesen.
                    Was genau hast du dir denn dabei gedacht?
                      N Offline
                      N Offline
                      nole
                      #70
                      @homoran eigentlich müsste es doch gehen wenn ich oben Wert größer als 100 und kleiner als 200 prüfe und danach den timeout starten lasse und nach 30 Minuten ausschalten lasse. Den Rest müsste ich doch weglassen können, oder habe ich mich da jetzt total verannt?
                      • N nole
                        #71
                        Was hast du denn genau vor?
                        Welche Zustände mit welche Werten gibt es in welchen Situationen?
                        Was willst du erreichen?
                        Ich denke, du willst verhindern, dass die Pumpe trocken läuft.
                        kann das auch passieren, dass die Pumpe anspringt ohne dass Wasser da ist?
                        Oder nur, dass die Pumpe nicht ausgeht, nachdem sie gepumpt hat?
                        • N nole
                          #72
                          also hast du im Prinzip nur drei Zustände:
                          • aus = 0W (ok)
                          • Trockenlauf = 150-200 (nicht ok)
                          • aktiv pumpend > 300 W (ok)
                          Habe ich das richtig verstanden?
                          Gibt es für das Hauswasserwerk(???) noch eine weitere Steuerung (Wasserdruck???) oder ziehst du mit dem SonoffPOW der Pumpe den ganzen Strom einfach weg?
                          Wenn letzteres, wie osll die dann jemals wieder anspringen?
                          • N nole
                            BBTownB Offline
                            BBTownB Offline
                            BBTown
                            #73
                            Ich kann nicht nachvollziehen weshalb Vorschläge nicht so übernommen werden wie sie zur Verfügung gestellt werden. Zudem schon früher hier im Thread von @Jan1 darauf hingewiesen wurde, dass anstelle von "aktualisieren" "geändert" gesetzt werden soll.
                              • aus = 0W (ok)
                              N Offline
                              N Offline
                              nole
                              #74
                              @homoran Die Pumpe startet sobald der Wasserdruck im Haus abfällt, also wenn Wasser entnommen wird. Wenn die Pumpe kein Wasser hat ist also zwangsläufig der Wasserdruck im Haus auch nicht da und die Pumpe läuft und läuft. Den Hitzetod der Pumpe möchte ich verhindern. Der Strom soll nur weggenommen werden wenn die Pumpe trocken läuft.
                              • N nole
                                #75
                                das geht aber nicht, wenn sie keinen Strom hat.
                                das macht dein Skript aber nicht.
                                Sobald der Wasserdruck hoch genug ist und die Leistung <50W ist zieht dein Blockly der Pumpe dauerhaft den Strom weg
                                Langsam habe ich den Eindruck, du hast false und true vertauscht (abgesehen von den übrigen Denkfehlern)
                                Wie bereits geschrieben, wäre es für dich hilfreich, die möglichen Szenarien und die jeweils gewünschten Aktionen mal auf einem Papier aufzumalen.
                                • BBTownB BBTown
                                  N Offline
                                  N Offline
                                  nole
                                  #76
                                  @bbtown Ich bin dankbar für die Vorschläge und ich habe einiges gelernt heute. Beide Varianten mit "aktualisieren" und mit "geändert" habe ich ausprobiert, aber das Skript schaltet die Pumpe immer noch aus mir unerklärlichen Gründen aus. Daraus ist meine Idee "eigentlich müsste es doch gehen wenn ich oben Wert größer als 100 und kleiner als 200 prüfe und danach den timeout starten lasse und nach 30 Minuten ausschalten lasse. Den Rest müsste ich doch weglassen können, oder habe ich mich da jetzt total verannt?" entstanden. Ich weiß nicht ob ich damit weiterkomme.
                                    N Offline
                                    N Offline
                                    nole
                                    #77
                                    @homoran Ja, ich habe den Denkfehler nur noch nicht gefunden.
                                    • N nole
                                      #78
                                      "auf Änderung" kann eine weiter Option zu Finetunig sein.
                                      Im Moment passt die von dir angewandte Logik IMHO in keinem Fall zu der geplanten Aufgabe
                                      • N nole
                                        #79
                                        Ja, was?
                                        Schreib bitte mal auf, was passieren soll wen welcher Zustand existiert.
                                        Ich habe dir schon einige spezifische Fragen gestellt, ohne deren Antwort eine Hilfe nicht möglich ist
                                        Leider kommen diese Antworten nicht, nur immer neue Ungereimtheiten :-(
                                        Du solltest am besten nochmal komplett neu auf Start gehen
                                          Ja, was?
                                          N Offline
                                          N Offline
                                          nole
                                          #80
                                          @homoran Ok, die Pumpe soll automatisch abgeschaltet werden wenn sie trocken läuft um dann mit Wasser aufgefüllt manuel am Sonoff PowR2 wieder eingeschaltet werden.
                                          Im Trockenlauf liegt die Pumpe zwischen 150 und 190 Watt.
                                          Im Normal Pumpbetrieb bei über 300 Watt, allerdings wenn die Pumpe bei erreichen des Wasserdrucks selber abschaltet werden noch ein paar Watt zwischen 4 und 15 angezeigt bis sie dann auf 0 Watt geht.
                                          Ich hatte jetzt mal folgendes Blockly gebastelt:
                                            <variables>
                                              <variable type="timeout" id="timeout5">timeout5</variable>
                                            </variables>
                                            <block type="on_ext" id="s@2OLG^WQ0Uz${3=]rcu" x="-487" y="963">
                                              <value name="OID0">
                                                <shadow type="field_oid" id="Ai;g1E]yx1YU@CvQU0_?">
                                                </shadow>
                                              </value>
                                                <block type="controls_if" id="BFG#q9C:Ry7e,fB1,ReS">
                                                  <value name="IF0">
                                                    <block type="logic_operation" id="}0|Ibdz}[$u!,s@1umt+" inline="false">
                                                      <value name="A">
                                                        <block type="logic_compare" id="umRBm=/5V?A]aGtdTt,(">
                                                          <value name="A">
                                                            <block type="on_source" id="iU5;dy./4gJ2yO1Yy,w,">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="pVQ+AKU+f$FBVl?7#xdZ">
                                                              <field name="NUM">51</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_compare" id="rP:D]GlY.!b+*YH+yKGB">
                                                          <value name="A">
                                                            <block type="on_source" id="v/2uJg+d3`wLl!~G*m!R">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="[XFgC?0]Uk+4ioWy$bh2">
                                                              <field name="NUM">190</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="timeouts_cleartimeout" id="NkHbFSo4*d9Q*`.:YX{(">
                                                      <field name="NAME">timeout5</field>
                                                      <next>
                                                        <block type="control" id="]Dno,P3;6dYZ:5Xp4;E`">
                                                            <block type="logic_boolean" id="%`XG|!/aW/;C[bnZj%8f">
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="timeouts_settimeout" id=",XnI}PNQCo`}8_M}Wh{8">
        <block type="control" id="KRlV$DRq[]=@3e6wW~^Y">
        <block type="logic_boolean" id="1?u+p!PCnX{mK*+Fc.oY">
        </block>
        </value>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                    <block type="logic_operation" id="@w,+i@%MeuH{lT)|XxBH" inline="false">
                                                      <field name="OP">OR</field>
                                                      <value name="A">
                                                        <block type="logic_compare" id="Lc64TT##]i[Mj0XMkJH(">
                                                          <value name="A">
                                                            <block type="on_source" id="GYWZfP!GgQH)]K@e[h)6">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="EnF1k6FG|l{~tOj-bmV;">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_compare" id="O]kgyw2#SRIiy|f9Unv.">
                                                          <value name="A">
                                                            <block type="on_source" id="lG/{Z`298OF.VUq~Hhzr">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="h1;v$D/G!wHNBhYqBq;j">
                                                              <field name="NUM">191</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="timeouts_cleartimeout" id="a4*9:he[uuWGBNB9E:#t">
                                                      <next>
                                                        <block type="control" id=")jNRwK{Uik_:R$lzdORT">
                                                            <block type="logic_boolean" id="vq-KULo#Tk?qM!WE^c[+">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="debug" id="hR+`P5qaHhOUzOb2oFF#">
                                                      <value name="TEXT">
                                                        <shadow type="text" id="U9Upn~:#r}gU|h^9`RwR">
                                                        </shadow>
                                                        <block type="text_join" id="EjlpL|_8ocdIR=pUZ:GN">
                                                          <value name="ADD0">
                                                            <block type="text" id="~W4iG)g]v[b--o;@IZE]">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                            <block type="on_source" id="}^ELsWj}n/S7ee^X@lO1">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </xml>
                                          BBTownB HomoranH 3 Antworten Letzte Antwort
