  4. "iobroker upgrade self" not working [SOLVED]
    6.5k
8 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
    miggedy
    schrieb am zuletzt editiert von miggedy
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 12.20.0
    Nodejs-Version: 12.20.0
    NPM-Version: 6.14,.8
    Installationsart: Skript
    System is running without any issues but upgrading it not working. I'm on js-controller 3.2.16 and if I execute iobroker upgrade self I get the following output:
    pi@iobroker-pi4:~ $ iobroker upgrade self
    No connection to databases possible ...
     redis get system.host.iobroker-pi4.alive, error - Connection is closed.
    No repositories defined.
    Cannot get repository under "undefined"
    pi@iobroker-pi4:~ $
    • M miggedy
      Hardwaresystem: Pi3
      pi@iobroker-pi4:~ $
      @miggedy
      iobroker repo list
      iobroker update
      And please keep your nodeJS installation up-to-date.
        @miggedy
        iobroker repo list
        iobroker update
        miggedy
        Thanks @thomas-braun, sadly this didn't help.
        pi@iobroker-pi4:~ $ iobroker repo list
        stable      : http://download.iobroker.net/sources-dist.json
        beta        : http://download.iobroker.net/sources-dist-latest.json
        Active repo: beta
        pi@iobroker-pi4:~ $ iobroker update
        pi@iobroker-pi4:~ $ iobroker stop
        • M miggedy
          Active repo: beta
          @miggedy
          Maybe there is still something running in the background?
          ps aux | grep ^io
            @miggedy
            ps aux | grep ^io
            miggedy
            No, nothing is running anymore. That command doesn't return anything.
            Maybe also interesting:
            While iobroker is not running, these commands also fail (but work if iobroker is running):
            Cannot get list: Error: Connection is closed.
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:982
                                    for (const name of Object.keys(links)) {
            TypeError: Cannot convert undefined or null to object
                at Function.keys (<anonymous>)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:982:51
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2615:37)
                at processImmediate (internal/timers.js:463:21)
            pi@iobroker-pi4:~ $
            • M miggedy
              pi@iobroker-pi4:~ $
              @miggedy
              Not sure if this helps but try jumping to the version you want to have:
              3.3.5 is beta-stage:
              Controller "js-controller" : 3.3.5    , installed 3.3.5
              Try
              iobroker stop
              cd /opt/iobroker
              npm install iobroker.js-controller@3.3.5
              iobroker start
              iobroker status
              • crunchipC Abwesend
                crunchipC Abwesend
                Test this rep
                Stable
                http://iobroker.live/repo/sources-dist.json
                Latest
                http://iobroker.live/repo/sources-dist-latest.json
                  @miggedy
                  Try
                  iobroker stop
                  cd /opt/iobroker
                  iobroker start
                  iobroker status
                  miggedy
                  I tested the manual installation @thomas-braun mentioned (npm install...) and this worked. I'm now on 3.3.5 and running iobroker upgrade self now doesn't show any errors anymore (just that it's up-to-date).
                  In case this happens again for the next update I will try the different repo @crunchip mentioned.
                  Thank you both for your support.
