  4. HM-RPC Fehler seit Update auf 1.4.0
22 Beiträge 6 Kommentatoren 3.0k Aufrufe
  • C Offline
    cruezcruel
    seit dem Update auf 1.4.0 terminiert der Adapter rpc.1 (CuxD) in regelmäßigen Abständen.
    Hier das LOG:
    Beim initialen Start:
    host.raspberrypi3	2017-01-17 12:51:17.447	error	instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
    hm-rpc.1	2017-01-17 12:51:17.423	info	terminating
    hm-rpc.1	2017-01-17 12:51:17.399	info	binrpc -> xxx.xxx.x.xxx:8701 init ["xmlrpc_bin://xxx.xxx.x.xxx:8701",""]
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    hm-rpc.1	2017-01-17 12:51:17.396	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:988:52)
    hm-rpc.1	2017-01-17 12:51:17.396	error	TypeError: undefined is not a function
    hm-rpc.1	2017-01-17 12:51:17.379	error	uncaught exception: undefined is not a function
    Im Intervall:
    raspberrypi3	2017-01-17 13:25:32.045	error	host.raspberrypi3 instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
    hm-rpc.1	2017-01-17 13:25:32.006	info	hm-rpc.1 binrpc -> xxx.xxx.x.xxx:8701 init ["xmlrpc_bin://xxx.xxx.x.xxx:8701",""]
    hm-rpc.1	2017-01-17 13:25:32.006	error	hm-rpc.1 TypeError: undefined is not a function at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:988:52) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-cont
    hm-rpc.1	2017-01-17 13:25:32.005	error	hm-rpc.1 uncaught exception: undefined is not a function
    Es haben keine anderen Veränderungen am System stattgefunden (weder Raspberry noch CCU)
    Hat jemand eine Idee an was das liegen kann?
    Viele Grüße!
    • apollon77A Online
      apollon77A Online
      Da müsste noch eine logzeile sein mit
      rpc -> listDevices
      … was sagt Die denn?
      • C Offline
        cruezcruel
        hm-rpc.1 2017-01-17 13:43:11.470 info binrpc -> listDevices 61
        • jens.mausJ Offline
          jens.mausJ Offline
          jens.maus
          @cruezcruel:
          Hat jemand eine Idee an was das liegen kann? `
          Welche nodejs version verwendet du denn?
          RaspberryMatic @ PromoxVE mit ~190 HomeMatic Geräten + ioBroker – GitHub – GitHub Sponsors / PayPal
          • apollon77A Online
            apollon77A Online
            findIndex ist ES6 … also damit node 4.x+ ... Korrekt?
            Fürchte bei den Adapter sollten wir 0.10/0.12 noch unterstützen.
            @jens-maus: Kannst Du das bitte ersetzen :-)) Daaaanke!
              jens.mausJ Offline
              jens.maus
              @apollon77:
              @jens-maus: Kannst Du das bitte ersetzen :-)) Daaaanke! `
              Argh. Aber hat bluefox nicht eh vor kurzem (gestern oder so) den node 0.10.x support komplett rausgeworfen?
              Und wenn du ne alternative zu findexIndex & Co hast, sag bescheid :)
              • C Offline
                cruezcruel
                Hallo zusammen :-)
                Ich verwende die 0.14.0
                  @jens.maus:
                  Argh. Aber hat bluefox nicht eh vor kurzem (gestern oder so) den node 0.10.x support komplett rausgeworfen? `
                  Das habe ich
                  a) nicht mitbekommen (wo steht das???)
                  und
                  b) gibt es noch hunderte 0.1x.xx Installationen, deren Grundfunktionalität dann leiden würde,
                  also
                  c) kann ich mir vorstellen, dass das "nur" für neue Adapter gilt (sonst: gelten sollte!)
                  Wenn ich mich da täusche muss IMHO irgendwie (da bin ich als Script-Legastheniker vollkommen raus ;-) )vor dem Update ggf. geprüft werden, welche nodejs Version auf dem System drauf ist, und eine riesige Warnung mit der Möglichkeit das Upgrade abzubrechen auf dem Bildschirm erscheinen.
                  Rainer
                  • apollon77A Online
                    apollon77A Online
                    @jens.maus:
                    Hätte ich auch nicht gesehen. Biser sind alle diese neuen Abhängigkeiten "optional" (z.B. Let's Encrypt). Es mag sein das neue Adapter hier und da ES6 Features nutzen und damit nur ab 4.x laufen, aber Bestandsadapter sind immer nso eine Sache. Man muss nen guten Grund haben da die Kompatibilität zu brechen.
                    @jens.maus:
                    Und wenn du ne alternative zu findexIndex & Co hast, sag bescheid :) `
                    Naja, ne schleife über das Array (so ganz Altmodisch) ;-))
                    var index= -1;
                    for (var i = 0; i < newDevices.length; i++) {
                    	if (logik) {
                    		index=i;
                    		break;
                    oder so in der Art (achtung blind ungetesteter geschriebener Code) :-)
                      jens.mausJ Offline
                      jens.maus
                      @Homoran:
                      @jens.maus:
                      Das habe ich
                      a) nicht mitbekommen (wo steht das???) `
                      Nun, er hat zumindest den javascript adapter als 0.12+ only geflaggt. Siehe hier:
                      https://github.com/ioBroker/ioBroker.ja … 43753eee91
                      Mittelfristig denke ich aber es macht eh sinn 0.10 und 0.12 komplett zu entsorgen. Die Zukunft gehört den Vollversionen von nodejs :)
                        @jens.maus:
                        Mittelfristig denke ich aber es macht eh sinn 0.10 und 0.12 komplett zu entsorgen. Die Zukunft gehört den Vollversionen von nodejs `
                        Im Prinzip gehe ich da voll mit, aber da ich das personifizierte schlechte Gewissen und der Anwalt der Nicht-Programmierer bin, erlaube ich mir darauf hinzuweisen, dass es bei den Einsteigern sowieso schon reichlich Hürden für den Einstieg gibt, die leider auch im HM-Forum in nicht ganz reelle Äußerungen wie "ioBroker ist nur für Programmierer" münden.
                        Leider laufen auch noch viele Installationen aus der ioBroker Anfangszeit mit wheezy und nodejs 0.1x.xx.
                        Ich habe bisher keine Möglichkeit gefunden, solche System garantiert ohne Totalverlust einfach upzugraden.
                        Rainer
                        • apollon77A Online
                          apollon77A Online
                          @jens.maus:
                          Mittelfristig denke ich aber es macht eh sinn 0.10 und 0.12 komplett zu entsorgen. Die Zukunft gehört den Vollversionen von nodejs :) `
                          ich persönlich denke das man 0.10 abhaken kann weil es an sich für jedes System was 0.10 kann auch mindestens 0.12 gibt (wenn nicht 0.14). Ich denke das ist etwas wo man nachdenken kann.
                          Grundsätzlich stimme ich Dir zu mit "Vollversionen", so lange es aber noch so viele Raspis mit altem Rasbian (Wheezy basiert) gibt ist halt nix mit .4x :-( Da brauchts schon Jessie … Über die Zeit kommt das automatisch (hoffentlich) ...aber vor allem "Fixes" sollte man kompatibel machen ... vllt kann man irgendwann mal mit neuen Features alte Zöpfe abschneiden :-)
                          • C Offline
                            cruezcruel
                            Finde ich alles echt super! ;-)
                            Aber was bedeutet das jetzt in meinem Fall?
                            • apollon77A Online
                              apollon77A Online
                              Das es bald nen Fix geben sollte.
                                ich hab da mal was vorbereitet:
                                http://forum.iobroker.net/viewtopic.php?f=8&t=4836
                                vielleicht hilft das ja mittelfristig Entscheidungen zu fällen.
                                Rainer
                                • C Offline
                                  cruezcruel
                                  OK - Danke!
                                  • malorossM Offline
                                    malorossM Offline
                                    maloross
                                    Ich habe ebenfalls Probleme mit diesem Adapter, vermutlich ebenfalls seit dem Update. Die Signaldiode bleibt gelb, Neustarts (einzelne Adapter, ioBroker, Raspi) haben ebenfalls nichts geändert.
                                    Habe eben eine neue Installation auf dem NAS durchgeführt, aber auch da tritt dies auf. Als Anfängerin weiß ich jetzt nicht mehr weiter.
                                    Fehler im Protokoll: hm-rpc.0 init error: Error: read ECONNRESET
                                    Versionen: node v7.4.0, npm v4.0.5
                                    Auch Frauen können sich für Technik begeistern! ;)
                                    Equipment:
                                    diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
                                      jens.mausJ Offline
                                      jens.maus
                                      @maloross:
                                      Versionen: node v7.4.0, npm v4.0.5 `
                                      Das hört/sieht nicht nach dem gleichen problem aus sondern ist sicher was anderes. Das liest sich eher danach als das der Adapter zu deiner CCU keine Verbindung aufbauen kann.
                                      • apollon77A Online
                                        apollon77A Online
                                        Hey,
                                        zuerst bitte mal die node Version auf 6.x "downgraden". der 7.x Branch ist per Definition "unstable" und nur die Entwicklungsversion als Vorstufe zur 8.x
                                        • apollon77A Online
                                          apollon77A Online
                                          @cruezcruel und die andere 0.x Nutzer:
                                          Fix (1.4.1) auf Github. Bitte mal testen
