  4. HarmonyHub fehlermeldung aus Log
3 Beiträge 3 Kommentatoren 1.1k Aufrufe
  • C Offline
    ccc.ggg73
    kann mir jemand sagen warum ich dieser Fehlermeldung bekomme?
    Das harmonyhub funktioniert einigermaßen zuverlässig aber manchmal blockiert und muss adapter neu starten.
    LG
    Giovanni
    harmony.0	2017-01-16 11:12:07.503	info	harmony.0 synced hub config
    harmony.0	2017-01-16 11:12:07.497	info	harmony.0 creating activities and devices
    harmony.0	2017-01-16 11:12:06.556	info	harmony.0 connected to Harmony Hub
    harmony.0	2017-01-16 11:12:05.201	info	harmony.0 connecting to Harmony Hub
    harmony.0	2017-01-16 11:12:05.195	info	harmony.0 discovered Harmony Hub
    harmony.0	2017-01-16 11:12:04.034	info	harmony.0 discover started
    harmony.0	2017-01-16 11:12:03.987	info	harmony.0 hub initialized
    harmony.0	2017-01-16 11:12:03.948	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    raspberrypi	2017-01-16 11:12:01.460	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 951
    raspberrypi	2017-01-16 11:12:00.451	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
    raspberrypi	2017-01-16 11:12:00.451	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:12:00.420	info	harmony.0 Scheduled restart.
    harmony.0	2017-01-16 11:11:07.950	info	harmony.0 synced hub config
    harmony.0	2017-01-16 11:11:07.948	info	harmony.0 creating activities and devices
    harmony.0	2017-01-16 11:11:07.052	info	harmony.0 connected to Harmony Hub
    harmony.0	2017-01-16 11:11:05.712	info	harmony.0 connecting to Harmony Hub
    harmony.0	2017-01-16 11:11:05.711	info	harmony.0 discovered Harmony Hub
    harmony.0	2017-01-16 11:11:04.552	info	harmony.0 discover started
    harmony.0	2017-01-16 11:11:04.489	info	harmony.0 hub initialized
    harmony.0	2017-01-16 11:11:04.449	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    raspberrypi	2017-01-16 11:11:01.942	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 31047
    raspberrypi	2017-01-16 11:11:00.922	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
    raspberrypi	2017-01-16 11:11:00.922	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:11:00.893	info	harmony.0 Scheduled restart.
    harmony.0	2017-01-16 11:10:07.464	info	harmony.0 synced hub config
    harmony.0	2017-01-16 11:10:07.463	info	harmony.0 creating activities and devices
    harmony.0	2017-01-16 11:10:06.517	info	harmony.0 connected to Harmony Hub
    harmony.0	2017-01-16 11:10:05.184	info	harmony.0 connecting to Harmony Hub
    harmony.0	2017-01-16 11:10:05.182	info	harmony.0 discovered Harmony Hub
    harmony.0	2017-01-16 11:10:04.019	info	harmony.0 discover started
    harmony.0	2017-01-16 11:10:03.971	info	harmony.0 hub initialized
    harmony.0	2017-01-16 11:10:03.936	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    raspberrypi	2017-01-16 11:10:01.417	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 28568
    raspberrypi	2017-01-16 11:10:00.405	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
    raspberrypi	2017-01-16 11:10:00.404	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:10:00.368	warn	harmony.0 client ended
    harmony.0	2017-01-16 11:10:00.367	info	harmony.0 terminating
    harmony.0	2017-01-16 11:10:00.367	info	harmony.0 Scheduled restart.
    harmony.0	2017-01-16 11:09:07.911	info	synced hub config
    harmony.0	2017-01-16 11:09:07.896	info	creating activities and devices
    harmony.0	2017-01-16 11:09:07.001	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:09:05.652	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:09:05.652	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:09:04.469	info	discover started
    harmony.0	2017-01-16 11:09:04.432	info	hub initialized
    harmony.0	2017-01-16 11:09:04.293	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:09:01.919	info	instance system.adapter.harmony.0 started with pid 26237
    host.raspberrypi	2017-01-16 11:09:00.896	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:09:00.895	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:09:00.872	info	terminating
    harmony.0	2017-01-16 11:09:00.851	warn	client ended
    harmony.0	2017-01-16 11:09:00.842	info	terminating
    harmony.0	2017-01-16 11:09:00.840	info	Scheduled restart.
    harmony.0	2017-01-16 11:08:07.440	info	synced hub config
    harmony.0	2017-01-16 11:08:07.405	info	creating activities and devices
    harmony.0	2017-01-16 11:08:06.471	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:08:05.143	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:08:05.142	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:08:03.960	info	discover started
    harmony.0	2017-01-16 11:08:03.922	info	hub initialized
    harmony.0	2017-01-16 11:08:03.791	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:08:01.365	info	instance system.adapter.harmony.0 started with pid 23714
    host.raspberrypi	2017-01-16 11:08:00.350	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:08:00.349	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:08:00.301	info	terminating
    harmony.0	2017-01-16 11:08:00.281	warn	client ended
    harmony.0	2017-01-16 11:08:00.273	info	terminating
    harmony.0	2017-01-16 11:08:00.271	info	Scheduled restart.
    cloud.0	2017-01-16 11:07:39.209	info	Request devices
    harmony.0	2017-01-16 11:07:08.001	info	synced hub config
    harmony.0	2017-01-16 11:07:07.990	info	creating activities and devices
    harmony.0	2017-01-16 11:07:07.104	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:07:05.746	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:07:05.746	info	discovered Harmony Hub
    cloud.0	2017-01-16 11:07:05.288	info	Request enums
    harmony.0	2017-01-16 11:07:04.563	info	discover started
    harmony.0	2017-01-16 11:07:04.521	info	hub initialized
    harmony.0	2017-01-16 11:07:04.219	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:07:01.799	info	instance system.adapter.harmony.0 started with pid 21383
    host.raspberrypi	2017-01-16 11:07:00.784	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:07:00.783	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:07:00.745	warn	client ended
    harmony.0	2017-01-16 11:07:00.740	info	terminating
    harmony.0	2017-01-16 11:07:00.738	info	Scheduled restart.
    host.raspberrypi	2017-01-16 11:06:11.443	info	instance system.adapter.yr.0 terminated with code 0 (OK)
    harmony.0	2017-01-16 11:06:07.348	info	synced hub config
    harmony.0	2017-01-16 11:06:07.326	info	creating activities and devices
    harmony.0	2017-01-16 11:06:06.397	info	connected to Harmony Hub
    yr.0	2017-01-16 11:06:06.324	info	got weather data from yr.no
    harmony.0	2017-01-16 11:06:05.036	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:06:05.035	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:06:03.852	info	discover started
    harmony.0	2017-01-16 11:06:03.819	info	hub initialized
    harmony.0	2017-01-16 11:06:03.692	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    yr.0	2017-01-16 11:06:02.230	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v4.7.2
    host.raspberrypi	2017-01-16 11:06:01.195	info	instance system.adapter.harmony.0 started with pid 18926
    host.raspberrypi	2017-01-16 11:06:00.335	info	instance system.adapter.yr.0 started with pid 18920
    host.raspberrypi	2017-01-16 11:06:00.182	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:06:00.182	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:06:00.149	warn	client ended
    harmony.0	2017-01-16 11:06:00.141	info	terminating
    harmony.0	2017-01-16 11:06:00.139	info	Scheduled restart.
    harmony.0	2017-01-16 11:05:07.793	info	synced hub config
    harmony.0	2017-01-16 11:05:07.778	info	creating activities and devices
    harmony.0	2017-01-16 11:05:06.845	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:05:05.446	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:05:05.446	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:05:04.257	info	discover started
    harmony.0	2017-01-16 11:05:04.221	info	hub initialized
    harmony.0	2017-01-16 11:05:04.094	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:05:01.512	info	instance system.adapter.harmony.0 started with pid 16586
    host.raspberrypi	2017-01-16 11:05:00.499	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:05:00.498	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:05:00.478	info	terminating
    harmony.0	2017-01-16 11:05:00.464	warn	client ended
    harmony.0	2017-01-16 11:05:00.458	info	terminating
    harmony.0	2017-01-16 11:05:00.457	info	Scheduled restart.
    harmony.0	2017-01-16 11:04:07.993	info	synced hub config
    harmony.0	2017-01-16 11:04:07.980	info	creating activities and devices
    harmony.0	2017-01-16 11:04:07.087	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:04:05.756	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:04:05.756	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:04:04.575	info	discover started
    harmony.0	2017-01-16 11:04:04.541	info	hub initialized
    harmony.0	2017-01-16 11:04:04.411	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:04:02.019	info	instance system.adapter.harmony.0 started with pid 14134
    host.raspberrypi	2017-01-16 11:04:00.996	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:04:00.995	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:04:00.974	info	terminating
    harmony.0	2017-01-16 11:04:00.959	warn	client ended
    harmony.0	2017-01-16 11:04:00.951	info	terminating
    harmony.0	2017-01-16 11:04:00.950	info	Scheduled restart.
    harmony.0	2017-01-16 11:03:07.537	info	synced hub config
    harmony.0	2017-01-16 11:03:07.522	info	creating activities and devices
    harmony.0	2017-01-16 11:03:06.635	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:03:05.298	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:03:05.298	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:03:04.099	info	discover started
    harmony.0	2017-01-16 11:03:04.061	info	hub initialized
    harmony.0	2017-01-16 11:03:03.895	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:03:01.490	info	instance system.adapter.harmony.0 started with pid 11802
    host.raspberrypi	2017-01-16 11:03:00.478	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:03:00.477	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:03:00.458	info	terminating
    harmony.0	2017-01-16 11:03:00.444	warn	client ended
    harmony.0	2017-01-16 11:03:00.438	info	terminating
    harmony.0	2017-01-16 11:03:00.436	info	Scheduled restart.
    harmony.0	2017-01-16 11:02:07.974	info	synced hub config
    harmony.0	2017-01-16 11:02:07.963	info	creating activities and devices
    harmony.0	2017-01-16 11:02:07.075	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:02:05.725	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:02:05.724	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:02:04.542	info	discover started
    harmony.0	2017-01-16 11:02:04.511	info	hub initialized
    harmony.0	2017-01-16 11:02:04.390	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:02:01.908	info	instance system.adapter.harmony.0 started with pid 9351
    host.raspberrypi	2017-01-16 11:02:00.886	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:02:00.885	error	instance system.adapter.harmony.0 terminated with code 156 ()
    harmony.0	2017-01-16 11:02:00.866	info	terminating
    harmony.0	2017-01-16 11:02:00.850	warn	client ended
    harmony.0	2017-01-16 11:02:00.844	info	terminating
    harmony.0	2017-01-16 11:02:00.842	info	Scheduled restart.
    harmony.0	2017-01-16 11:01:07.502	info	synced hub config
    harmony.0	2017-01-16 11:01:07.488	info	creating activities and devices
    harmony.0	2017-01-16 11:01:06.547	info	connected to Harmony Hub
    harmony.0	2017-01-16 11:01:05.137	info	connecting to Harmony Hub
    harmony.0	2017-01-16 11:01:05.136	info	discovered Harmony Hub
    harmony.0	2017-01-16 11:01:03.953	info	discover started
    harmony.0	2017-01-16 11:01:03.920	info	hub initialized
    harmony.0	2017-01-16 11:01:03.795	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
    host.raspberrypi	2017-01-16 11:01:01.379	info	instance system.adapter.harmony.0 started with pid 6897
    host.raspberrypi	2017-01-16 11:01:00.365	info	Restart adapter system.adapter.harmony.0 because enabled
    host.raspberrypi	2017-01-16 11:01:00.364	error	instance system.adapter.harmony.0 terminated with code 156 ()
      Pman
      Wenn ich das Log richtig verstehe machst du jede Minute eine Restart des Adapters. Hast du das unabsichtlich im Admin unter Instanzen so eingestellt?
        @Pman:
        Wenn ich das Log richtig verstehe machst du jede Minute eine Restart des Adapters. `
        Schon, aber was ist code 156??
        Rainer
