  4. Radar2 macht aktuell Probleme
    6.5k
6 Beiträge 4 Kommentatoren 843 Aufrufe 4 Beobachtet
    timtaylor
    schrieb am zuletzt editiert von timtaylor
    Meine System:
    Platform: linux
    Betriebssystem: Ubuntu
    Architektur: x64
    CPUs: 4
    Geschwindigkeit: 1617 MHz
    Modell: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
    RAM: 7.62 GB
    Node.js: v12.22.1
    NPM: 6.14.12
    aktuell macht der RADAR2 Adapter Probleme. Hat jemand eine Idee woran das liegen könnte?
    Der aktuelle Log:
    2021-04-09 17:30:01.768 - info: radar2.0 (20190) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.22.1, js-controller: 3.2.16
    2021-04-09 17:30:01.943 - info: radar2.0 (20190) radar2 initialization started...
    2021-04-09 17:30:01.954 - info: radar2.0 (20190) Will use l2Ping for BT scans.
    2021-04-09 17:30:01.970 - info: radar2.0 (20190) debug: started #1 hcitool dev
    2021-04-09 17:30:01.995 - info: radar2.0 (20190) Will run hcitool-mode and not noble on device [ [Object] ]!
    2021-04-09 17:30:02.001 - info: radar2.0 (20190) debug: started #2 hciconfig hci0 down
    2021-04-09 17:30:02.130 - info: radar2.0 (20190) debug: started #3 hciconfig hci0 up
    2021-04-09 17:30:02.320 - info: radar2.0 (20190) net-ping not available! Will try to use normal ping!
    2021-04-09 17:30:02.325 - info: radar2.0 (20190) debug: radar2 set to flag items away if they are not seen for 3 minutes
    2021-04-09 17:30:02.326 - info: radar2.0 (20190) debug: use known BT list: [ '01:12:23:34:45:56' ]
    2021-04-09 17:30:02.327 - info: radar2.0 (20190) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
    2021-04-09 17:30:02.327 - info: radar2.0 (20190) arp-scan will use the following interfaces: [ 'eno1' ]
    2021-04-09 17:30:02.336 - error: radar2.0 (20190) uncaught exception: bind EACCES 0.0.0.0:67
    2021-04-09 17:30:02.337 - error: radar2.0 (20190) Error: bind EACCES 0.0.0.0:67
    at dgram.js:338:20
    at processTicksAndRejections (internal/process/task_queues.js:85:21)
    2021-04-09 17:30:02.337 - error: radar2.0 (20190) Exception-Code: EACCES: bind EACCES 0.0.0.0:67
    2021-04-09 17:30:02.339 - warn: radar2.0 (20190) Uncaught Exception: bind EACCES 0.0.0.0:67
    2021-04-09 17:30:02.353 - info: radar2.0 (20190) Unload adapter now with null
    2021-04-09 17:30:02.353 - info: radar2.0 (20190) Adapter disconnected and stopped with dostop(null) and callback(true)
    2021-04-09 17:30:02.354 - info: radar2.0 (20190) terminating
    2021-04-09 17:30:02.355 - warn: radar2.0 (20190) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-04-09 17:30:02.360 - info: radar2.0 (20190) debug: created State radar2.0.info.connection
    2021-04-09 17:30:02.365 - info: radar2.0 (20190) debug: ChangeState ack:false of radar2.0.info.connection = false
    2021-04-09 17:30:02.470 - info: radar2.0 (20190) debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
    2021-04-09 17:30:02.471 - info: radar2.0 (20190) debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
    2021-04-09 17:30:02.486 - info: radar2.0 (20190) Will try to scan BT devices: hci0 A0:9F:10:BA:B8:4C
    2021-04-09 17:30:02.512 - info: radar2.0 (20190) Init item Ich- with {name: 'Ich-',bluetooth: [],enabled: -1,id: 'Ich',type: 'IP',rip: [ '127.0.0.1', '::1' ]}
    2021-04-09 17:30:02.561 - info: radar2.0 (20190) Init item Fritzbox with {name: 'Fritzbox',bluetooth: [],enabled: -1,id: 'Fritzbox',type: 'IP',hasMAC: [ '18:10:d5:08:1e:18', 'e0:28:6d:48:2a:da' ],ipVendor: 'N/A',rip: [ '192.168.178.1' ]}
    2021-04-09 17:30:02.571 - info: radar2.0 (20190) Init item G-Tags- with {name: 'G-Tags-',ip: [],bluetooth: [ '01:23:45:56:78:89' ],enabled: -1,id: 'G-Tags',type: 'BT',btVendor: 'N/A'}
    2021-04-09 17:30:02.577 - info: radar2.0 (20190) Init item HP-5230- with {name: 'HP-5230-',ip: [ '192.168.178.100' ],bluetooth: [],enabled: -1,id: 'HP-5230',type: 'printer'}
    2021-04-09 17:30:02.585 - info: radar2.0 (20190) Init item ECB- with {name: 'ECB-',ip: [ 'USD', 'RUB', 'GBP' ],bluetooth: [],enabled: -1,id: 'ECB',type: 'ECB'}
    2021-04-09 17:30:02.592 - info: radar2.0 (20190) Init item Forum with {name: 'Forum',ip: [ 'https://forum.iobroker.net' ],bluetooth: [],enabled: 10,id: 'Forum',type: 'URL'}
    2021-04-09 17:30:02.621 - info: radar2.0 (20190) Init item Handy-Paul with {name: 'Handy-Paul',bluetooth: [ 'ac:a7:b9:9d:ba:1b' ],id: 'Handy-Paul',type: 'BT',hasMAC: [ '04:d6:aa:05:70:1e', '00:24:7e:08:fc:06' ],ipVendor: 'Samsung Electro-Mechanics(Thailand)',btVendor: 'N/A',rip: [ '192.168.178.99' ]}
    2021-04-09 17:30:02.979 - error: host.smarthome instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-04-09 17:30:02.980 - info: host.smarthome Restart adapter system.adapter.radar2.0 because enabled
    2021-04-09 17:30:02.980 - warn: host.smarthome Do not restart adapter system.adapter.radar2.0 because restart loop detected
    Danke im Voraus!
    Holger
    • T timtaylor
      Meine System:
      Platform: linux
      Architektur: x64
      CPUs: 4
      RAM: 7.62 GB
      Node.js: v12.22.1
      NPM: 6.14.12
      Der aktuelle Log:
      at dgram.js:338:20
      Danke im Voraus!
      Holger
      @timtaylor
      Kannst du die Ausgaben des log files bitte in CodeTags setzen? Danke.
      • T timtaylor
        Meine System:
        Platform: linux
        Architektur: x64
        CPUs: 4
        RAM: 7.62 GB
        Node.js: v12.22.1
        NPM: 6.14.12
        Der aktuelle Log:
        at dgram.js:338:20
        Danke im Voraus!
        Holger
        crunchipC Abwesend
        crunchipC Abwesend
        @timtaylor kann es sein, dass du ein ubuntu update gemacht hast?
        Desweitere, ist die Infomeldung zwecks Forum Eintrags in der Instanz, an dir vorbei gegangen?
        Dieser sollte aus der Instanz gelöscht werden.
          timtaylor
          @crunchip
          Kann es sein, dass du ein ubuntu update gemacht hast? > JA.
          Desweitere, ist die Infomeldung zwecks Forum Eintrags in der Instanz, an dir vorbei gegangen? > Wie geht das?
          Danke Dir!
          crunchipC amg_666A 2 Antworten Letzte Antwort
          • T timtaylor
            @crunchip
            Danke Dir!
            crunchipC Abwesend
            crunchipC Abwesend
            @timtaylor dann les mal den Hinweis im Adapter(setcup)
            Oder
            iobroker fix
            Du hast die Abfrage/Eintrag noch drin, ob das Forum online ist, dieser muss rausgelöscht werden
            • T timtaylor
              @crunchip
              Danke Dir!
              amg_666A Offline
              amg_666A Offline
              amg_666
              schrieb am zuletzt editiert von amg_666
              @timtaylor sagte in Radar2 macht aktuell Probleme:
              Mach in der Adminoberfläche ganz oben links beim Dreieck einen Haken bei "info", falls noch nicht geschehen. Dann siehst du links den Menupunkt Info und wenn du da drauf klickst solltest du folgendes sehen und befolgen :-)
              "Der Radar2-Adapter enthält einen Standardeintrag, der das ioBroker-Forum überwacht. Bitte entfernen Sie diesen Eintrag ("Forum" genannt und verweist auf forum.iobroker.net) aus Ihrer Adapterkonfiguration, da dies einen großen, nicht benötigten Datenverkehr im Forum erzeugt."
