  4. Fehler im Log
Fehler im Log
2 Beiträge 2 Kommentatoren 672 Aufrufe
    simpixo
    Hallo zusammen
    Seit neustem habe ich den folgenden Fehler im Log, kann mir jemand sagen woher dieser kommt oder hat gar eine Lösung?
    TypeError:	2017-01-09 20:03:00.724	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2017-01-09 20:03:00.724	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    TypeError:	2017-01-09 20:03:00.724	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    TypeError:	2017-01-09 20:03:00.724	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2017-01-09 20:03:00.724	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
    TypeError:	2017-01-09 20:03:00.724	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
    TypeError:	2017-01-09 20:03:00.724	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    TypeError:	2017-01-09 20:03:00.724	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
    TypeError:	2017-01-09 20:03:00.724	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2187:71)
    TypeError:	2017-01-09 20:03:00.724	error	at Object.cb (script.js.Stromzähler.Ermittelt_Einzelne_Werte:207:50)
    TypeError:	2017-01-09 20:03:00.724	error	Cannot read property 'val' of undefined
    message	2017-01-09 20:03:00.724	error	messagebox.system.adapter.javascript.0 [object Object] Cannot read property 'val' of undefined
    TypeError:	2017-01-09 20:03:00.714	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2017-01-09 20:03:00.714	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    TypeError:	2017-01-09 20:03:00.714	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    TypeError:	2017-01-09 20:03:00.714	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2017-01-09 20:03:00.714	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
    TypeError:	2017-01-09 20:03:00.714	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
    TypeError:	2017-01-09 20:03:00.714	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    TypeError:	2017-01-09 20:03:00.714	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
    TypeError:	2017-01-09 20:03:00.714	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2187:71)
    TypeError:	2017-01-09 20:03:00.714	error	at Object.cb (script.js.Stromzähler.Ermittelt_Einzelne_Werte:207:50)
    TypeError:	2017-01-09 20:03:00.714	error	Cannot read property 'val' of undefined
    message	2017-01-09 20:03:00.713	error	messagebox.system.adapter.javascript.0 [object Object] Cannot read property 'val' of undefined
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      bin jetzt kein Script guru aber aus meiner sich verweist dein Log auf einen Fehler in einem Script:
      Das Script "Stromzähler.Ermittelt_Einzelne_Werte" solltest du vielleicht auch mal posten.
