  4. Harmony Adapter Installation
    5.8k
15 Beiträge 5 Kommentatoren 2.9k Aufrufe
    MicF1968
    ich bekomme den Harmony Adapter nicht installiert.
    Alle anderen Adapter waren kein Problem.
    Deswegen wundert mich die Fehlermeldung, denn wenn git nicht da wäre, würden die anderen ja auch nicht gehen.
    Kann mich jemand auf den richtigen Weg schubsen.
    $ ./iobroker add harmony
    npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
    npm
     WARN
    addRemoteGit Error: not found: gitnpm
    WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:73:28)
    npm
     WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:76:29)npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:84:16
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
    npm
    WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87 because of error: { [Error: not found: git] code: 'ENOGIT' }
    npm
     WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">npm
     ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87:
     undefined
    npm
    ERR!
     undefined
    npm
     WARN
    install
     Couldn't install optional dependency: not found: git
    host.Seven24 install adapter harmony
    npm
    WARN deprecated
     WARN
    npm
    WARN
    addRemoteGit
         at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:73:28)npm
    WARN
    npm
    WARN
    addRemoteGit
         at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:84:16npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
    npm
    ERR!
     git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefinednpm ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefined
    npm
    WARN
    install Couldn't install optional dependency: not found: git
    npm
     WARN
    addRemoteGit
    npm
     WARN
    npm
    WARN
     WARN addRemoteGit
     WARN
     addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)npm
    npm
    ERR!
     undefined
    npm
     WARN install Couldn't install optional dependency: not found: git
    ERROR: host.Seven24 Cannot install harmony
    ERROR: process exited with code 13</https:></https:></https:>
      @MicF1968:
      Kann mich jemand auf den richtigen Weg schubsen. `
      ich habe zwar noch nie eine Windows Installation gemacht, daher weiss ich auch nicht wie… (unter Linux: sudo apt-get install git)
      Aber dir fehlt GIT (oder npmGit) das musst du noch installieren.
      Rainer
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        @Homoran:
        @MicF1968:
        Rainer `
        Unter windows einfach github installieren: https://desktop.github.com/
          MicF1968
          ich habe sowohl die Windows Version installiert als auch
          npm install gitnpm -g
          ausgeführt und es wurde auch installiert.
          An der Harmony Adapter Installation hat das nichts geändert.
          Mic
            Pman
            GIT muss als Systembefehl bekannt sein, sich also in der PATH variablen befinden. Dazu einfach mal Googlen oder hier im Forum suchen, war schon sehr häufig der Grund für fehlgeschlagene Adapterinstallationen.
              MicF1968
              Das klang schon ziemlich einleuchtend ….
              ... aber git ist im path drin.
              Ich kann mit der Console von überall git aufrufen und es kommt die Parameterliste.
              Noch 'ne Idee?
                MicF1968
                Von der Console aus aufgerufen sieht es ähnlich aus:
                C:\>npm install iobroker.harmony --production --prefix "C:/ioBroker"
                npm ERR! git clone --template=C:\Users\Michael\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Michael\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefined
                npm WARN install Couldn't install optional dependency: not found: git
                npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  Ich steh aufm Schlauch Sorry, bei mir war damals genügen um den Client zu installieren
                    MicF1968
                    fragt mich jetzt nicht warum, aber jetzt gings.
                    ich hatte davor nicht gebootet, vermutlich lags daran, dass nach Installation von git noch ein boot notwendig war.
                    danke für die hilfe.
                      Pman
                      Ja, für laufende Prozesse wird der PATH nicht aktualisiert, vermutlich lag es daran.
                        Blackeye
                        ich schaffe es leider auch nicht. iobrker läuft bei mir unter Jessie Light ..
                        npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
                        npm
                         WARN
                        addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                        npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                        npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                        npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                        npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                        npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                        npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
                        npm
                        WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                        npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                        npm
                         ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
                        npm
                         WARN
                        npm
                         ERR!
                         Linux 4.9.24-v7+
                        npm ERR! argv
                         "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
                        npm
                         ERR! node v6.10.3
                        npm ERR! npm  v3.10.10npm ERR! code ENOGIT
                        npm
                         ERR! not found: gitnpm ERR!
                        npm ERR! Failed using git.
                        npm ERR! This is most likely not a problem with npm itself.
                        npm ERR! Please check if you have git installed and in your PATH.
                        npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
                        host.ioBroker-RasPi install adapter harmony
                        npm
                         WARN addRemoteGit Error: not found: gitnpm
                         WARN addRemoteGit
                        npm
                         WARN
                         addRemoteGit
                             at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                        npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
                        npm
                        ERR!
                        npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
                        npm ERR!
                         Linux 4.9.24-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
                        npm
                        ERR! node v6.10.3npm ERR! npm  v3.10.10
                        npm ERR! not found: gitnpm ERR!
                        npm
                         WARN
                             at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm
                         WARN
                        npm WARN
                        addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                        npm
                        npm
                        npm
                        ERR! Linux 4.9.24-v7+
                        npm ERR! node v6.10.3
                        ERR! npm ERR! Failed using git.
                        ERROR: host.ioBroker-RasPi Cannot install harmony
                        Wenn ich versuche Git zu installieren, nur Fehler…..
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Die Meldung von der harmony Installation sagt das git fehlt.
                          Welchen Fehler bekommst du Dan Bein installieren von git ?
                          Send from mobile device
                            Blackeye
                            hier die Meldungen. Ist wohl nicht mehr da :-(
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              hast du
                              sudo apt-get update --fix-missing
                              ausgefuehrt ?
                                Blackeye
                                nein, natürlich nicht…. Danach klappt auch die git Installation und der Adapter läuft auch
                                @Dutchman:
                                hast du
                                ausgefuehrt ? `
