  4. Zigbee Adapter mit Sonoff Zigbee Bridge
    1.0k
    6.1k
24 Beiträge 7 Kommentatoren 11.4k Aufrufe 13 Beobachtet
  • P pi_noob15
    zigbee.0
    	2021-11-09 11:30:57.501	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0
    	2021-11-09 11:30:57.499	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    	2021-11-09 11:30:57.498	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    @pi_noob15
    Da ist nicht vollständig. Da kommt mehr.
      @pi_noob15
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @thomas-braun sagte in Zigbee Adapter mit Sonoff Zigbee Bridge:
      @pi_noob15
      Um es genauer zu sagen: Um zu sehen was passiert werden alle Log-Einträge des Zigbee-Adapters ab Startversuch des Adapters benötigt, nicht nur irgendwelche kryptischen Fehlermeldungen ohne Kontext.
      A.
      P 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @pi_noob15
        A.
        pi_noob15
        schrieb am zuletzt editiert von pi_noob15
        hoffe das ist ausreichend
        [zigbee_log.js](/assets/uploads/files/1636455141350-zigbee_log.js
        zigbee.0
        	2021-11-09 11:48:52.715	silly	States user redis pmessage io.zigbee.0.*/io.zigbee.0.info.connection:{"val":false,"ack":true,"ts":1636454932706,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1636451476847}
        zigbee.0
        	2021-11-09 11:48:52.708	silly	States system redis pmessage io.system.adapter.zigbee.0.logLevel/io.system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1636454932621,"q":0,"from":"system.adapter.zigbee.0","lc":1636454721207}
        zigbee.0
        	2021-11-09 11:48:52.707	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        	2021-11-09 11:48:52.438	debug	Starting zigbee-herdsman...
        zigbee.0
        	2021-11-09 11:48:52.436	info	Starting Zigbee npm ...
        zigbee.0
        	2021-11-09 11:48:52.432	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.1.210:8888","adapter":"ezsp"}}
        zigbee.0
        	2021-11-09 11:48:52.390	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.18
        zigbee.0
        	2021-11-09 11:48:46.535	error	Cannot read property 'getEntries' of null
        zigbee.0
        	2021-11-09 11:48:46.534	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0
        	2021-11-09 11:48:46.532	error	unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0
        	2021-11-09 11:48:46.531	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        	2021-11-09 11:48:46.528	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        	2021-11-09 11:48:46.526	info	terminating
        zigbee.0
        	2021-11-09 11:48:46.525	warn	Failed to stop zigbee during startup
        zigbee.0
        	2021-11-09 11:48:46.522	info	Zigbee: disabling joining new devices.
        zigbee.0
        	2021-11-09 11:48:46.515	info	cleaned everything up...
        zigbee.0
        	2021-11-09 11:48:46.512	info	Got terminate signal TERMINATE_YOURSELF
        zigbee.0
        	2021-11-09 11:48:46.510	silly	States system redis pmessage io.system.adapter.zigbee.0.sigKill/io.system.adapter.zigbee.0.sigKill:{"val":-1,"ack":false,"ts":1636454926504,"q":0,"from":"system.host.iobroker","lc":1636454926504}
        zigbee.0
        	2021-11-09 11:47:48.693	silly	States user redis pmessage io.zigbee.0.*/io.zigbee.0.info.connection:{"val":false,"ack":true,"ts":1636454868684,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1636451476847}
        zigbee.0
        	2021-11-09 11:47:48.687	silly	States system redis pmessage io.system.adapter.zigbee.0.logLevel/io.system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1636454868604,"q":0,"from":"system.adapter.zigbee.0","lc":1636454721207}
        zigbee.0
        	2021-11-09 11:47:48.686	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        	2021-11-09 11:47:48.427	debug	Starting zigbee-herdsman...
        zigbee.0
        	2021-11-09 11:47:48.425	info	Starting Zigbee npm ...
        zigbee.0
        	2021-11-09 11:47:48.420	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.1.210:8888","adapter":"ezsp"}}
        zigbee.0
        	2021-11-09 11:47:48.380	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.18
        zigbee.0
        	2021-11-09 11:47:48.152	debug	statesDB connected
        zigbee.0
        	2021-11-09 11:47:48.151	debug	States connected to redis: 127.0.0.1:6379
        zigbee.0
        	2021-11-09 11:47:48.142	debug	States create User PubSub Client
        zigbee.0
        	2021-11-09 11:47:48.140	debug	States create System PubSub Client
        zigbee.0
        	2021-11-09 11:47:48.132	debug	Redis States: Use Redis connection: 127.0.0.1:6379
        zigbee.0
        	2021-11-09 11:47:48.129	debug	objectDB connected
        zigbee.0
        	2021-11-09 11:47:48.123	silly	redis psubscribe cfg.o.system.user.*
        zigbee.0
        	2021-11-09 11:47:48.119	debug	Objects connected to redis: 127.0.0.1:9001
        zigbee.0
        	2021-11-09 11:47:48.106	debug	Objects client initialize lua scripts
        zigbee.0
        	2021-11-09 11:47:48.104	debug	Objects create User PubSub Client
        zigbee.0
        	2021-11-09 11:47:48.090	debug	Objects create System PubSub Client
        zigbee.0
        	2021-11-09 11:47:48.088	debug	Objects client ready ... initialize now
        zigbee.0
        	2021-11-09 11:47:48.052	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        • P pi_noob15
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          @pi_noob15 Bitte nicht als irgendwelche Datei posten, wie oben in CodeTags setzen.
          Außerdem wäre es schön wenn nicht parallel in mehreren Threads hantiert würde...
          Hier geht's weiter:
          https://forum.iobroker.net/topic/49164/sonoff-zigbee-bridge-pairing-devices/4?_=1636455396897
