  4. Zigbee Adapter keine Verbindung zu CC2652R möglich
zigbee2mqttzigbee adaptercc2652r
21 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • arteckA arteck
    lass mal den fixer drüber laufen
    iobroker fix
    dann istallier nochmal den Adapter von GIT
    https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
    AdenmaraA Offline
    AdenmaraA Offline
    Adenmara
    @arteck Vielen Dank! Das hats getan :)
    2021-03-21 11:05:39.909  - ^[[32minfo^[[39m: zigbee.0 (20204) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
    2021-03-21 11:05:39.917  - ^[[32minfo^[[39m: zigbee.0 (20204) Starting Zigbee  npm ...
    2021-03-21 11:05:39.970  - ^[[32minfo^[[39m: zigbee.0 (20204) Installed Version: ioBroker/ioBroker.zigbee#6d9f7c8f59c924ef362efc7e9648250a6956328e
    2021-03-21 11:05:43.963  - ^[[32minfo^[[39m: zigbee.0 (20204) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200715}}
    2021-03-21 11:05:43.967  - ^[[32minfo^[[39m: zigbee.0 (20204) Unable to disable LED, unsupported function.
    2021-03-21 11:05:43.967  - ^[[32minfo^[[39m: zigbee.0 (20204)   --> transmitPower : normal
    2021-03-21 11:05:43.970  - ^[[32minfo^[[39m: zigbee.0 (20204) Currently no devices.
    2021-03-21 11:05:43.971  - ^[[32minfo^[[39m: zigbee.0 (20204) Zigbee started
    2021-03-21 11:05:43.981  - ^[[32minfo^[[39m: host.MediaServer stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-03-21 11:05:43.983  - ^[[32minfo^[[39m: zigbee.0 (20204) Got terminate signal TERMINATE_YOURSELF
    2021-03-21 11:05:43.983  - ^[[32minfo^[[39m: zigbee.0 (20204) cleaned everything up...
    2021-03-21 11:05:43.984  - ^[[32minfo^[[39m: zigbee.0 (20204) Zigbee: disabling joining new devices.
    2021-03-21 11:05:44.023  - ^[[32minfo^[[39m: host.MediaServer stopInstance system.adapter.zigbee.0 send kill signal
    2021-03-21 11:05:44.293  - ^[[32minfo^[[39m: zigbee.0 (20204) terminating
    2021-03-21 11:05:44.295  - ^[[32minfo^[[39m: zigbee.0 (20204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-21 11:05:44.824  - ^[[32minfo^[[39m: host.MediaServer instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-21 11:05:47.029  - ^[[32minfo^[[39m: host.MediaServer instance system.adapter.zigbee.0 started with pid 20277
    2021-03-21 11:05:47.500  - ^[[32minfo^[[39m: zigbee.0 (20277) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
    2021-03-21 11:05:47.525  - ^[[32minfo^[[39m: zigbee.0 (20277) Starting Zigbee  npm ...
    2021-03-21 11:05:47.580  - ^[[32minfo^[[39m: zigbee.0 (20277) Installed Version: ioBroker/ioBroker.zigbee#6d9f7c8f59c924ef362efc7e9648250a6956328e
    2021-03-21 11:05:49.752  - ^[[32minfo^[[39m: zigbee.0 (20277) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200715}}
    2021-03-21 11:05:49.756  - ^[[32minfo^[[39m: zigbee.0 (20277) Unable to disable LED, unsupported function.
    2021-03-21 11:05:49.756  - ^[[32minfo^[[39m: zigbee.0 (20277)   --> transmitPower : normal
    2021-03-21 11:05:49.759  - ^[[32minfo^[[39m: zigbee.0 (20277) Currently no devices.
    2021-03-21 11:05:49.759  - ^[[32minfo^[[39m: zigbee.0 (20277) Zigbee started
    Damit hat sich das Thema erledigt, kann geschlossen werden.
    Als nächstes mal hoffen, dass ich alle Geräte hinzugefügt bekomme, die ich will.
    Danke an euch, für eure Hilfe!
