  4. ZZH! Stick läuft nicht mit dem Zigbee Adapter
    6.6k
27 Beiträge 4 Kommentatoren 5.1k Aufrufe 5 Beobachtet
  • N Offline
    N Offline
    Neko
    schrieb am zuletzt editiert von Neko
    Hallo, ich bekomme den Electrolama ZZH! Zigbee Stick (CC2652R) auf meinem Pi nicht ans laufen.
    Der Adapter bleibt gelb und ich habe folgende Meldungen im Log:
    zigbee.0 2021-03-18 13:15:36.798 error at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0 2021-03-18 13:15:36.798 error at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    zigbee.0 2021-03-18 13:15:36.798 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    zigbee.0 2021-03-18 13:15:36.798 error at new Promise ()
    zigbee.0 2021-03-18 13:15:36.798 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    zigbee.0 2021-03-18 13:15:36.798 error at Generator.next ()
    zigbee.0 2021-03-18 13:15:36.798 error at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    zigbee.0 2021-03-18 13:15:36.798 error (2039) Error: Error while opening serialport ‘Error: Error Resource temporarily unavailable Cannot lock port’
    zigbee.0 2021-03-18 13:15:36.797 error (2039) Failed to start Zigbee
    zigbee.0 2021-03-18 13:15:36.573 info (2039) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0 2021-03-18 13:15:36.531 info (2039) Starting Zigbee npm …
    zigbee.0 2021-03-18 13:15:36.529 info (2039) Try to reconnect. 1 attempts left
    zigbee.0 2021-03-18 13:15:26.526 error at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:25:65)
    zigbee.0 2021-03-18 13:15:26.526 error at Generator.throw ()
    zigbee.0 2021-03-18 13:15:26.526 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:172:23
    zigbee.0 2021-03-18 13:15:26.526 error (2039) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
    zigbee.0 2021-03-18 13:15:26.524 error (2039) Failed to start Zigbee
    Was ich bis jetzt gemacht habe:
    • Auf dem Windows PC mit TI’s Flash Programmer 2 “CC2652R_coordinator_20210120” geflasht und verifiziert.
    • “ls -l /dev/serial/by-id” liefert “usb-1a86_USB_Serial-if00-port0 -> …/…/ttyUSB0” also habe ich im Adapter “/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0” als Com Anschluss genommen (Ich habe auch /dev/ttyUSB0 und /dev/ttyAMA0 versucht)
    • Pan ID mehrfach geändert, auch die Extended Pan ID. Zigbee Adapter neu installiert (Vers. 1,44)
    • Den Stick abgezogen und neu eingesteckt.
    • “test -w /dev/ttyACM0 && echo success || echo failure” liefert successful
      “test -w /dev/ttyUSB0 && echo success || echo failure” liefert successful
    Ich bin mit meinem Latein echt am Ende, wäre schön, wenn ihr mir helfen könntet.
    Gruss,
    Neko
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Raspbian
    Node-Version: 10.x.x
    Nodejs-Version: v12.21.0
    NPM-Version: 6.14.11
    Installationsart: Skript
    Viele Grüße,
    Neko
    • N Neko
      Gruss,
      Neko
      Hardwaresystem: Pi4
      Festplattenart: SSD
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @neko sagte in ZZH! Stick läuft nicht mit dem Zigbee Adapter:
      Das System beschwert sich darüber das es bereits ein Netz mit den gleichen Parametern gibt. Bitte folgendes Tun:
      • den Adapter anhalten
      • die Datei nvbackup.json im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen
      • die Datein shepherd.db im gleichen Verzeichnis umbenennen.
      • den Stick abziehen
      • 30 sekunden warten
      • den Stick wieder einstecken
      • den Adapter starten.
      A.
      N 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        A.
        N Offline
        N Offline
        Neko
        @asgothian said in ZZH! Stick läuft nicht mit dem Zigbee Adapter:
        Das Verzeichnis ist leer.
        Viele Grüße,
        Neko
        • N Neko
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @neko
          Diese Meldung deutet darauf hin das der Zigbee Stick den Aufbau des Netzes verweigert.
          Hast du noch eine andere Instanz laufen ?
          A.
          N 2 Antworten Letzte Antwort
            @neko
            A.
            N Offline
            N Offline
            Neko
            @asgothian Nein, von dem Zigbee Adapter nicht. Ich habe allerdings noch einen Tradfri Adapter laufen.
            Viele Grüße,
            Neko
            • N Neko
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @neko zeig mal bitte einen Screenshot von der Konfiguration
              A.
                A.
                N Offline
                N Offline
                Neko
                @asgothian Meinst du die Einstellungen im Zigbee Adapter oder meine Instanzen?
                Viele Grüße,
                Neko
                  @neko
                  A.
                  N Offline
                  N Offline
                  Neko
                  @neko
                  Meine Vermutung wäre, dass das hier das Problem ist.
                  Den Tradfri Adapter hatte ich schon ausgeschaltet und auch die PanID mehrfach gewechselt. Ist aber nur eine Vermutung, ich bin für jeden Tipp dankbar.
                  Viele Grüße,
                  Neko
                  • N Neko
                    @neko
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @neko
                    Ich meinte schon die Einstellungen des Zigbee Adapters.
                    und die Meldung mit dem cannot lock port kommt nach dem Versuch das Netz aufzubauen (Siehe Timestamp der Log Meldungen
                    A.
                      @neko
                      A.
                      N Offline
                      N Offline
                      Neko
                      @asgothian Hier die Einstellungen:
                      Eine Sache ist mir noch aufgefallen, wenn ich auf "Speichen und Schließen" klicke, bekomme ich immer die Meldung "Bitte bestätigen - Einige Daten wurden nicht gespeichert. Verwerfen?" Wenn ich ok klicke und dann nachsehe, sind die Einstellungen trotzdem gespeichert.
                      Viele Grüße,
                      Neko
                      • N Neko
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @neko ich habe eine Vermutung..
                        der Tradfri baut ein Netz auf.. auch wen ndu diesen Abschaltest laufen die Router weiter und senden eine PANID..
                        der Zigbee Adapter merkt es und macht sein Netz nicht auf..
                        du könntest wenn es nicht viel Mühe macht ..
                        Tradfri Adapter abschalten
                        alle Router (Geräte die am Strom hängen) vom Netz trennen..nicht nur abschalten sonder acht trennen (Bulbs rausschrauben, Plug rausziehen)
                        dann Zigbee Adapter starten
                        • arteckA arteck
                          N Offline
                          N Offline
                          Neko
                          @arteck Ich habe das gerade mal ausprobiert keine Änderung, gleiche Fehlermeldung.
                          Welches ist eigentlich die aktuelle, stabile Version vom Zigbee Adapter? Ich habe gerade mal von stabil auf beta gestellt und jetzt wird mir angezeigt, Aktuell: 1.1.1 und installiert: 1.4.4 Kann es sein, dass da mit Stabil und Beta was durcheinander gekommen ist und ich da eine Beta vom Adapter installiert habe?
                          Viele Grüße,
                          Neko
                          • arteckA arteck
                            N Offline
                            N Offline
                            Neko
                            @arteck Ich habe gerade noch folgendes Probiert, den 1.4.4 Adapter deinstalliert und den 1.1.1 installiert. Tradfri ist noch aus, trotzdem bekomme ich noch folgenden Meldungen:
                            zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                            zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                            zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                            zigbee.0	2021-03-19 11:49:26.335	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                            zigbee.0	2021-03-19 11:49:26.335	error	at new Promise (<anonymous>)
                            zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                            zigbee.0	2021-03-19 11:49:26.335	error	at Generator.next (<anonymous>)
                            zigbee.0	2021-03-19 11:49:26.335	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                            zigbee.0	2021-03-19 11:49:26.335	error	(5545) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                            zigbee.0	2021-03-19 11:49:26.333	error	(5545) Failed to start Zigbee
                            zigbee.0	2021-03-19 11:49:26.081	info	(5545) Starting Zigbee...
                            zigbee.0	2021-03-19 11:49:26.081	info	(5545) Try to reconnect. 1 attempts left
                            zigbee.0	2021-03-19 11:49:16.079	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:6:65)
                            zigbee.0	2021-03-19 11:49:16.079	error	at Generator.throw (<anonymous>)
                            zigbee.0	2021-03-19 11:49:16.079	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:158:23
                            zigbee.0	2021-03-19 11:49:16.079	error	(5545) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
                            zigbee.0	2021-03-19 11:49:16.078	error	(5545) Failed to start Zigbee
                            zigbee.0	2021-03-19 11:48:10.693	info	(5545) Starting Zigbee...
                            zigbee.0	2021-03-19 11:48:10.653	info	(5545) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                            host.raspberrypi	2021-03-19 11:48:08.966	info	instance system.adapter.zigbee.0 started with pid 5545
                            Kann es sein, dass dort vielleicht noch etwas mit Stick auf Betriebssystem Ebene nicht stimmt? Das der Serial Port nicht richtig konfiguriert ist oder sowas?
                            Viele Grüße,
                            Neko
                            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                            • N Neko
                              @neko
                              Ist eigentlich der Serial Port im Raspi aktiv?
                              Kann man in
                              sudo raspi-config
                              irgendwo schauen.
                                @neko
                                Kann man in
                                sudo raspi-config
                                irgendwo schauen.
                                N Offline
                                N Offline
                                Neko
                                @thomas-braun Also in der Config wurde er mir jetzt als "active" angezeigt. Die Frage ist halt ob ich ihn damit jetzt angeschaltet habe oder ob er schon an war.
                                Jedenfalls weiterhin keine Änderung...
                                Viele Grüße,
                                Neko
                                • N Neko
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  Nein kann es nicht.
                                  Diese Meldung
                                  besagt eindeutig das es eine Kommunikation zwischen dem Koordinator und dem Adapter gegeben hat. Damit ist die serielle Schnittstelle aussen vor.
                                  Das blockieren der Schnittstelle ist darauf zurück zu führen das die Bibliothek die Schnittstelle nicht so schnell wieder frei gibt wie der Adapter versucht das ganze neu zu initialisieren.
                                  A.
                                    Nein kann es nicht.
                                    Diese Meldung
                                    A.
                                    N Offline
                                    N Offline
                                    Neko
                                    @asgothian
                                    Ok, und was kann man da machen?
                                    Viele Grüße,
                                    Neko
                                    • N Neko
                                      @asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @neko Ich würde an dieser Stelle die Vermutung äussern das der Stick nicht ok ist. Immerhin verweigert er systematisch den Aufbau eines Zigbee Netzes.
                                      A.
                                        A.
                                        N Offline
                                        N Offline
                                        Neko
                                        @asgothian Ja, ich fürchte es fast auch...
                                        Von Electrolama gibt es ein Skript um zu testen, ob der Stick richtig geflasht ist: https://gist.github.com/omerk/0ee0e447a9e36786b4ff71d8f8126a23
                                        Allerdings bekomme ich dieses nicht ans laufen. Ich bekomme immer die Meldung "ModuleNotFoundError: No module named 'serial'". Ich habe dann auch schon pyserial installiert, aber das änderte auch nichts. Irgendwie stoße ich da an meine Grenzen. 😞
                                        Viele Grüße,
                                        Neko
                                          A.
                                          N Offline
                                          N Offline
                                          Neko
                                          @asgothian Also, der Stick ist in Ordnung. Damit ich mir nicht meinen ganzen Raspberry zumülle, habe ich auf dem Windows Rechner Zigbee2MQTT installiert und in iobroker einen MQTT Server aufgesetzt. Mit diesem Setup konnte ich Sensoren pairen und Werte abgreifen.
                                          Mit anderen Worten, der Stick funktioniert, es muss ein Problem mit dem Raspberry oder iobroker sein.
                                          Viele Grüße,
                                          Neko
