Nach neustart läuft nach neustart nicht mehr
@homoran sagte in Nach neustart läuft nach neustart nicht mehr:
@digi-bit sagte in Nach neustart läuft nach neustart nicht mehr:
Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
Versuch mal:
iobroker stop cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller --production iobroker startpi@raspberrypi4-iob:~ $ iobroker stop pi@raspberrypi4-iob:~ $ cd /opt/iobroker pi@raspberrypi4-iob:/opt/iobroker $ sudo -H npm install iobroker.js-controller --production > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.11 > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram > node-gyp rebuild gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.21.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp" gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/build' gyp ERR! System Linux 5.10.17-v7l+ gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram gyp ERR! node -v v12.21.0 gyp ERR! node-gyp -v v5.1.0 gyp ERR! not ok > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional > node rebuild.js ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks. internal/fs/utils.js:269 throw err; ^ Error: EACCES: permission denied, open './stdout.log' at Object.openSync (fs.js:462:3) at Object.writeFileSync (fs.js:1384:35) at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10) at Module._compile (internal/modules/cjs/loader.js:999:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) at internal/main/run_main_module.js:17:47 { errno: -13, syscall: 'open', code: 'EACCES', path: './stdout.log' } > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage > node-gyp rebuild gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.21.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp" gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/build' gyp ERR! System Linux 5.10.17-v7l+ gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/diskusage gyp ERR! node -v v12.21.0 gyp ERR! node-gyp -v v5.1.0 gyp ERR! not ok > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat' Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat' Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat' internal/fs/utils.js:269 throw err; ^ Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp' at Object.mkdirSync (fs.js:921:3) at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:835:16) at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:500:23) at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2896:5) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24) at Module._compile (internal/modules/cjs/loader.js:999:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) { errno: -13, syscall: 'mkdir', code: 'EACCES', path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp' } npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules/unix-dgram): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules/diskusage): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.js-controller@3.2.16 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2021-03-16T18_20_04_172Z-debug.log pi@raspberrypi4-iob:/opt/iobroker $funktioniert danach immer noch nicht.....
hab ich ja einen volltreffder gelandet
aber schon früher!
in /root hat nichts zu liegen
Du warst zu schnell, ich hatte noch was editiert, versuch es bitte nochmal, mit dem erweiteretn Befehl nochmal.
Allerdings darf auch der user iobroker nicht auf /root zugreifen -
aber schon früher!
Allerdings darf auch der user iobroker nicht auf /root zugreifen@homoran sagte in Nach neustart läuft nach neustart nicht mehr:
aber schon früher!
Allerdings darf auch der user iobroker nicht auf /root zugreifenich weiss ja noch nocht mal wie ich nach /root komme :(
und Ich habe da auch nie was hinkopiert....
soll ich da was löschen ?
aber schon früher!
Versuch mal:
iobroker stop cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller --production iobroker start@homoran sagte in Nach neustart läuft nach neustart nicht mehr:
Versuch mal:
iobroker stop cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller --production iobroker startpi@raspberrypi4-iob:~ $ iobroker stop pi@raspberrypi4-iob:~ $ cd /opt/iobroker pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --production > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.11 > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram > node-gyp rebuild make: Verzeichnis â/opt/iobroker/node_modules/unix-dgram/buildâ wird betreten CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o In file included from ../../nan/nan.h:56, from ../src/unix_dgram.cc:5: /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro âNODE_MODULE_Xâ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro âNODE_MODULEâ NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~ SOLINK_MODULE(target) Release/obj.target/unix_dgram.node COPY Release/unix_dgram.node make: Verzeichnis â/opt/iobroker/node_modules/unix-dgram/buildâ wird verlassen > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional > node rebuild.js ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks. > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage > node-gyp rebuild make: Verzeichnis â/opt/iobroker/node_modules/diskusage/buildâ wird betreten CXX(target) Release/obj.target/diskusage/src/main.o In file included from ../../nan/nan.h:56, from ../src/main.cpp:3: /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro âNODE_MODULE_Xâ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro âNODE_MODULEâ NODE_MODULE(diskusage, Init) ^~~~~~~~~~~ CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o SOLINK_MODULE(target) Release/obj.target/diskusage.node COPY Release/diskusage.node make: Verzeichnis â/opt/iobroker/node_modules/diskusage/buildâ wird verlassen > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object _design/system updated > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme > node scripts/postinstall npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + iobroker.js-controller@3.2.16 added 240 packages from 220 contributors and removed 1 package in 60.737s 18 packages are looking for funding run `npm fund` for details âââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ® â â â New major version of npm available! 6.14.11 â 7.6.3 â â Changelog: https://github.com/npm/cli/releases/tag/v7.6.3 â â Run npm install -g npm to update! â â â â°âââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ⯠pi@raspberrypi4-iob:/opt/iobroker $ iobroker start pi@raspberrypi4-iob:/opt/iobroker $ohha, du bist der knaller.... web ist da
aber richtig starten tut er nicht, also die instanzen werdern nicht hochgefahren
Versuch mal:
der scheint immer das selbe irgend wie zu machen kommt aber nicht wirklich aus der hüfte
host.raspberrypi4-iob 2021-03-16 19:51:28.911 info iobroker npm-install: npm install iobroker.ping@1.4.12 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:51:28.906 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:51:26.307 info iobroker install ping@1.4.12 using installedFrom host.raspberrypi4-iob 2021-03-16 19:51:26.305 warn startInstance cannot find adapter "ping@1.4.12". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:51:25.301 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:51:24.225 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.midea created/updated host.raspberrypi4-iob 2021-03-16 19:51:24.062 info iobroker npm-install: upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/admin.d.ts admin.d.ts video/mp2t host.raspberrypi4-iob 2021-03-16 19:51:24.004 info iobroker npm-install: upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html host.raspberrypi4-iob 2021-03-16 19:51:23.946 info iobroker npm-install: upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png host.raspberrypi4-iob 2021-03-16 19:51:23.889 info iobroker npm-install: upload [3] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/style.css style.css text/css host.raspberrypi4-iob 2021-03-16 19:51:23.792 info iobroker npm-install: upload [4] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/words.js words.js application/javascript host.raspberrypi4-iob 2021-03-16 19:51:23.772 info iobroker npm-install: host.raspberrypi4-iob install adapter midea@0.0.6 host.raspberrypi4-iob 2021-03-16 19:51:02.800 info iobroker npm-install: npm install iobroker.midea@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:51:02.798 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:51:00.191 info iobroker install midea@0.0.6 using installedFrom host.raspberrypi4-iob 2021-03-16 19:51:00.190 warn startInstance cannot find adapter "midea@0.0.6". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:50:59.186 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:50:58.079 info iobroker npm-install: Update "system.adapter.yahka.0" host.raspberrypi4-iob 2021-03-16 19:50:58.031 info iobroker npm-install: host.raspberrypi4-iob object yahka.meta._accessoryCategories created/updated host.raspberrypi4-iob 2021-03-16 19:50:58.022 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.yahka created/updated host.raspberrypi4-iob 2021-03-16 19:50:57.918 info iobroker npm-install: upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.857 info iobroker npm-install: upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.797 info iobroker npm-install: upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.734 info iobroker npm-install: upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.667 info iobroker npm-install: upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.293 info iobroker npm-install: upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.228 info iobroker npm-install: upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css host.raspberrypi4-iob 2021-03-16 19:50:57.169 info iobroker npm-install: upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject host.raspberrypi4-iob 2021-03-16 19:50:57.093 info iobroker npm-install: upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml host.raspberrypi4-iob 2021-03-16 19:50:57.022 info iobroker npm-install: upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf host.raspberrypi4-iob 2021-03-16 19:50:56.929 info iobroker npm-install: upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff host.raspberrypi4-iob 2021-03-16 19:50:56.855 info iobroker npm-install: upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json host.raspberrypi4-iob 2021-03-16 19:50:56.795 info iobroker npm-install: upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript host.raspberrypi4-iob 2021-03-16 19:50:56.738 info iobroker npm-install: upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png host.raspberrypi4-iob 2021-03-16 19:50:56.681 info iobroker npm-install: upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html host.raspberrypi4-iob 2021-03-16 19:50:56.624 info iobroker npm-install: upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html host.raspberrypi4-iob 2021-03-16 19:50:56.529 info iobroker npm-install: upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript host.raspberrypi4-iob 2021-03-16 19:50:55.808 info iobroker npm-install: upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript host.raspberrypi4-iob 2021-03-16 19:50:54.881 info iobroker npm-install: upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json host.raspberrypi4-iob 2021-03-16 19:50:54.784 info iobroker npm-install: upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png host.raspberrypi4-iob 2021-03-16 19:50:54.765 error iobroker npm-install: Cannot install "pam-devel": E: Paket pam-devel kann nicht gefunden werden.The following apt-get packages could not be installed: pam-devel. Please install them manually. host.raspberrypi4-iob 2021-03-16 19:50:52.600 info iobroker npm-install: host.raspberrypi4-iob install adapter yahka@0.12.0 host.raspberrypi4-iob 2021-03-16 19:50:27.635 info iobroker npm-install: npm install iobroker.yahka@0.12.0 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:50:27.632 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:50:24.996 info iobroker install yahka@0.12.0 using installedFrom host.raspberrypi4-iob 2021-03-16 19:50:24.994 warn startInstance cannot find adapter "yahka@0.12.0". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:50:23.990 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:50:22.940 info iobroker npm-install: Update "system.adapter.vis-hqwidgets.0" host.raspberrypi4-iob 2021-03-16 19:50:22.913 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-hqwidgets created/updated host.raspberrypi4-iob 2021-03-16 19:50:22.815 info iobroker npm-install: Adapter "system.adapter.vis.0" restarted. host.raspberrypi4-iob 2021-03-16 19:50:22.812 info "system.adapter.vis.0" enabled host.raspberrypi4-iob 2021-03-16 19:50:22.793 info "system.adapter.vis.0" disabled host.raspberrypi4-iob 2021-03-16 19:50:22.761 info iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted. host.raspberrypi4-iob 2021-03-16 19:50:22.703 info iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png host.raspberrypi4-iob 2021-03-16 19:50:22.603 info iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html host.raspberrypi4-iob 2021-03-16 19:50:22.580 info iobroker npm-install: host.raspberrypi4-iob install adapter vis-hqwidgets@1.1.7 host.raspberrypi4-iob 2021-03-16 19:50:04.872 info iobroker npm-install: npm install iobroker.vis-hqwidgets@1.1.7 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:50:04.869 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:50:02.218 info iobroker install vis-hqwidgets@1.1.7 using installedFrom host.raspberrypi4-iob 2021-03-16 19:50:02.217 warn startInstance cannot find adapter "vis-hqwidgets@1.1.7". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:50:01.212 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:50:00.156 info iobroker npm-install: Update "system.adapter.vis-colorpicker.0" host.raspberrypi4-iob 2021-03-16 19:50:00.133 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-colorpicker created/updated host.raspberrypi4-iob 2021-03-16 19:50:00.042 info iobroker npm-install: Adapter "system.adapter.vis.0" restarted. host.raspberrypi4-iob 2021-03-16 19:50:00.039 info "system.adapter.vis.0" enabled host.raspberrypi4-iob 2021-03-16 19:50:00.021 info "system.adapter.vis.0" disabled host.raspberrypi4-iob 2021-03-16 19:49:59.991 info iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted. host.raspberrypi4-iob 2021-03-16 19:49:59.893 info iobroker npm-install: upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png host.raspberrypi4-iob 2021-03-16 19:49:59.873 info iobroker npm-install: host.raspberrypi4-iob install adapter vis-colorpicker@1.2.0 host.raspberrypi4-iob 2021-03-16 19:49:42.065 info iobroker npm-install: npm install iobroker.vis-colorpicker@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:49:42.062 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:49:39.462 info iobroker install vis-colorpicker@1.2.0 using installedFrom host.raspberrypi4-iob 2021-03-16 19:49:39.449 warn startInstance cannot find adapter "vis-colorpicker@1.2.0". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:49:38.448 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:49:37.409 info iobroker npm-install: Update "system.adapter.vis-bars.0" host.raspberrypi4-iob 2021-03-16 19:49:37.389 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-bars created/updated host.raspberrypi4-iob 2021-03-16 19:49:37.309 info iobroker npm-install: Adapter "system.adapter.vis.0" restarted. host.raspberrypi4-iob 2021-03-16 19:49:37.307 info "system.adapter.vis.0" enabled host.raspberrypi4-iob 2021-03-16 19:49:37.292 info "system.adapter.vis.0" disabled host.raspberrypi4-iob 2021-03-16 19:49:37.268 info iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-bars/www" was not found! Nothing was uploaded or deleted. host.raspberrypi4-iob 2021-03-16 19:49:37.211 info iobroker npm-install: upload [0] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/bars.png bars.png image/png host.raspberrypi4-iob 2021-03-16 19:49:37.118 info iobroker npm-install: upload [1] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/index.html index.html text/html host.raspberrypi4-iob 2021-03-16 19:49:37.098 info iobroker npm-install: host.raspberrypi4-iob install adapter vis-bars@0.1.4 host.raspberrypi4-iob 2021-03-16 19:49:22.193 info Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" host.raspberrypi4-iob 2021-03-16 19:49:18.716 info iobroker npm-install: npm install iobroker.vis-bars@0.1.4 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi4-iob 2021-03-16 19:49:18.714 info iobroker npm-install: NPM version: 6.14.11 host.raspberrypi4-iob 2021-03-16 19:49:16.156 info iobroker install vis-bars@0.1.4 using installedFrom host.raspberrypi4-iob 2021-03-16 19:49:16.155 warn startInstance cannot find adapter "vis-bars@0.1.4". Try to install it... 1 attempt host.raspberrypi4-iob 2021-03-16 19:49:15.148 info iobroker npm-install: exit 51 host.raspberrypi4-iob 2021-03-16 19:49:14.115 info iobroker npm-install: adapter "icons-mfd-svg" already installed. Use "upgrade" to upgrade to a newer version. host.raspberrypi4-iob 2021-03-16 19:49:12.319 info iobroker install icons-mfd-svg using installedVersion host.raspberrypi4-iob 2021-03-16 19:49:12.318 warn startInstance cannot find adapter "icons-mfd-svg". Try to install it... 2 attempt host.raspberrypi4-iob 2021-03-16 19:49:11.317 info iobroker npm-install: exit 51 host.raspberrypi4-iob 2021-03-16 19:49:10.282 info iobroker npm-install: adapter "icons-mfd-png" already installed. Use "upgrade" to upgrade to a newer version. host.raspberrypi4-iob 2021-03-16 19:49:08.475 info iobroker install icons-mfd-png using installedVersion host.raspberrypi4-iob 2021-03-16 19:49:08.474 warn startInstance cannot find adapter "icons-mfd-png". Try to install it... 2 attempt host.raspberrypi4-iob 2021-03-16 19:49:07.471 info iobroker npm-install: exit 0 host.raspberrypi4-iob 2021-03-16 19:49:06.414 info iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-icontwo created/updated host.raspberrypi4-iob 2021-03-16 19:49:06.269 info iobroker npm-install: upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png host.raspberrypi4-iob 2021-03-16 19:49:06.203 info iobroker npm-install: upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_RED.png Alarm/alarm_RED.png image/png host.raspberrypi4-iob 2021-03-16 19:49:06.136 info iobroker npm-install: upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_green.png Alarm/alarm_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:06.068 info iobroker npm-install: upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_red2.png Alarm/alarm_red2.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.973 info iobroker npm-install: upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off.png Alarm/bell_off.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.900 info iobroker npm-install: upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off_green.png Alarm/bell_off_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.825 info iobroker npm-install: upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off_red.png Alarm/bell_off_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.750 info iobroker npm-install: upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on.png Alarm/bell_on.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.671 info iobroker npm-install: upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on_green.png Alarm/bell_on_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.594 info iobroker npm-install: upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on_red.png Alarm/bell_on_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.517 info iobroker npm-install: upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera.png Alarm/camera.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.440 info iobroker npm-install: upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2.png Alarm/camera2.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.361 info iobroker npm-install: upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2_green.png Alarm/camera2_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.288 info iobroker npm-install: upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2_red.png Alarm/camera2_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.212 info iobroker npm-install: upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera_green.png Alarm/camera_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.137 info iobroker npm-install: upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera_red.png Alarm/camera_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:05.060 info iobroker npm-install: upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm.png Alarm/fire_alarm.png image/png host.raspberrypi4-iob 2021-03-16 19:49:04.987 info iobroker npm-install: upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm_green.png Alarm/fire_alarm_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:04.911 info iobroker npm-install: upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm_red.png Alarm/fire_alarm_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:04.835 info iobroker npm-install: upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/flame.png Alarm/flame.png image/png host.raspberrypi4-iob 2021-03-16 19:49:04.757 info iobroker npm-install: upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/flame_green.png Alarm/flame_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:04.003 info iobroker npm-install: upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/home_onnection_red.png Alarm/home_onnection_red.png image/png host.raspberrypi4-iob 2021-03-16 19:49:03.255 info iobroker npm-install: upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/sensor_door_green.png Alarm/sensor_door_green.png image/png host.raspberrypi4-iob 2021-03-16 19:49:02.503 info iobroker npm-install: upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/smoke.png Alarm/smoke.png image/png host.raspberrypi4-iob 2021-03-16 19:49:01.754 info iobroker npm-install: upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Arrows/arrow_21_up.png Arrows/arrow_21_up.png image/png host.raspberrypi4-iob 2021-03-16 19:49:01.000 info iobroker npm-install: upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/101_g.jpg Backgrounds/101_g.jpg image/jpeg host.raspberrypi4-iob 2021-03-16 19:49:00.236 info iobroker npm-install: upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/110.jpg Backgrounds/110.jpg image/jpeg host.raspberrypi4-iob 2021-03-16 19:48:59.210 info iobroker npm-install: upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/207.jpg Backgrounds/207.jpg image/jpeg host.raspberrypi4-iob 2021-03-16 19:48:59.016 info "system.adapter.alexa2.0" enabled host.raspberrypi4-iob 2021-03-16 19:48:58.401 info iobroker npm-install: upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/300.png Backgrounds/Seamless/300.png image/png host.raspberrypi4-iob 2021-03-16 19:48:55.847 info "system.adapter.history.0" disabled host.raspberrypi4-iob 2021-03-16 19:48:54.815 info "system.adapter.harmony.0" disabled host.raspberrypi4-iob 2021-03-16 19:48:54.725 info iobroker npm-install: upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/kodi.png Brands/kodi.png image/png host.raspberrypi4-iob 2021-03-16 19:48:53.165 info "system.adapter.broadlink2.0" disabled host.raspberrypi4-iob 2021-03-16 19:48:51.773 info "system.adapter.backitup.0" disabled host.raspberrypi4-iob 2021-03-16 19:48:50.969 info "system.adapter.alexa2.0" disabled -
immer das selbe, oder immer das gleiche für jeden Adapter?
dann dauert dasimmer hin ist er schon bei midea
ja, so langsam werden die alle grün, dauert aber echt sehr lange.....
denke mal das der doch noch irgend wie ein kanll weg hat oder ?
mfg
mfg
ist wie nach einem restore. Je nach Leistung des Pi und Umfang der Installation kann das bis zu 2 Stunden dauern
ahha, ok....
jedenfalls noch mal ein fettes DANKE für die hilfe !
werde ein backup machen und dann erstmal feierabend, reicht mir für heute !
die noch einen schönen abend !
mfg !
