  4. Nach neustart läuft nach neustart nicht mehr
29 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    @digi-bit sagte in Nach neustart läuft nach neustart nicht mehr:
    Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Versuch mal:
    iobroker stop
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller --production
    iobroker start
    Digi-Bit
    @homoran sagte in Nach neustart läuft nach neustart nicht mehr:
    Versuch mal:
    iobroker stop
    cd /opt/iobroker
    iobroker start
    pi@raspberrypi4-iob:~ $ iobroker stop
    pi@raspberrypi4-iob:~ $ cd /opt/iobroker
    pi@raspberrypi4-iob:/opt/iobroker $ sudo -H npm install iobroker.js-controller --production
    > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.11
    > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.21.0"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
    gyp ERR! configure error
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/build'
    gyp ERR! System Linux 5.10.17-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v12.21.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    internal/fs/utils.js:269
        throw err;
    Error: EACCES: permission denied, open './stdout.log'
        at Object.openSync (fs.js:462:3)
        at Object.writeFileSync (fs.js:1384:35)
        at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        at internal/main/run_main_module.js:17:47 {
      errno: -13,
      syscall: 'open',
      code: 'EACCES',
      path: './stdout.log'
    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/build'
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    gyp ERR! not ok
    > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:921:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:835:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:500:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2896:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
      errno: -13,
      syscall: 'mkdir',
      code: 'EACCES',
      path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules/unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules/diskusage):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
    npm ERR!     /root/.npm/_logs/2021-03-16T18_20_04_172Z-debug.log
    funktioniert danach immer noch nicht.....
    hab ich ja einen volltreffder gelandet 😧
    Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
    7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
    • D Digi-Bit
      Versuch mal:
      iobroker stop
      cd /opt/iobroker
      iobroker start
      > node-gyp rebuild
      gyp ERR! not ok
      > node rebuild.js
          throw err;
        errno: -13,
        syscall: 'open',
        code: 'EACCES',
      > node-gyp rebuild
      gyp ERR! not ok
          throw err;
        errno: -13,
        syscall: 'mkdir',
        code: 'EACCES',
      npm ERR! errno 1
      npm ERR!
      HomoranH Offline
      HomoranH Offline
      aber schon früher!
      in /root hat nichts zu liegen
      Du warst zu schnell, ich hatte noch was editiert, versuch es bitte nochmal, mit dem erweiteretn Befehl nochmal.
      Allerdings darf auch der user iobroker nicht auf /root zugreifen
        aber schon früher!
        Digi-Bit
        aber schon früher!
        ich weiss ja noch nocht mal wie ich nach /root komme :(
        und Ich habe da auch nie was hinkopiert....
        soll ich da was löschen ?
        • D Digi-Bit
          aber schon früher!
          HomoranH Offline
          HomoranH Offline
          da musst du wohl mal als root unterwegs gewesen sein.
          Deswegen soll man das nicht
            Versuch mal:
            iobroker stop
            cd /opt/iobroker
            iobroker start
            Digi-Bit
            Versuch mal:
            iobroker stop
            cd /opt/iobroker
            iobroker start
            pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --production
            > node-gyp rebuild
            make: Verzeichnis â/opt/iobroker/node_modules/unix-dgram/buildâ wird betreten
              CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            In file included from ../../nan/nan.h:56,
                             from ../src/unix_dgram.cc:5:
            /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type]
                   (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro âNODE_MODULE_Xâ
               NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro âNODE_MODULEâ
             NODE_MODULE(unix_dgram, Initialize)
              SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
              COPY Release/unix_dgram.node
            make: Verzeichnis â/opt/iobroker/node_modules/unix-dgram/buildâ wird verlassen
            > node rebuild.js
            > node-gyp rebuild
            make: Verzeichnis â/opt/iobroker/node_modules/diskusage/buildâ wird betreten
              CXX(target) Release/obj.target/diskusage/src/main.o
                             from ../src/main.cpp:3:
            ../src/main.cpp:42:1: note: in expansion of macro âNODE_MODULEâ
             NODE_MODULE(diskusage, Init)
              CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
              SOLINK_MODULE(target) Release/obj.target/diskusage.node
              COPY Release/diskusage.node
            make: Verzeichnis â/opt/iobroker/node_modules/diskusage/buildâ wird verlassen
            object _design/system updated
            > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
            > node scripts/postinstall
            + iobroker.js-controller@3.2.16
            added 240 packages from 220 contributors and removed 1 package in 60.737s
            18 packages are looking for funding
              run `npm fund` for details
               â­ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ®
               â                                                               â
               â      New major version of npm available! 6.14.11 â 7.6.3      â
               â   Changelog: https://github.com/npm/cli/releases/tag/v7.6.3   â
               â               Run npm install -g npm to update!               â
               â                                                               â
               â°ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¯
            pi@raspberrypi4-iob:/opt/iobroker $ iobroker start
            ohha, du bist der knaller.... web ist da
            aber richtig starten tut er nicht, also die instanzen werdern nicht hochgefahren
            • D Digi-Bit
              Versuch mal:
              iobroker stop
              cd /opt/iobroker
              iobroker start
              > node-gyp rebuild
              > node rebuild.js
              > node-gyp rebuild
                 â                                                               â
                 â                                                               â
              Digi-Bit
              der scheint immer das selbe irgend wie zu machen kommt aber nicht wirklich aus der hüfte
              host.raspberrypi4-iob	2021-03-16 19:51:28.911	info	iobroker npm-install: npm install iobroker.ping@1.4.12 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:51:28.906	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:51:26.307	info	iobroker install ping@1.4.12 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:51:26.305	warn	startInstance cannot find adapter "ping@1.4.12". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:51:25.301	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:51:24.225	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.midea created/updated
              host.raspberrypi4-iob	2021-03-16 19:51:24.062	info	iobroker npm-install: upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/admin.d.ts admin.d.ts video/mp2t
              host.raspberrypi4-iob	2021-03-16 19:51:24.004	info	iobroker npm-install: upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
              host.raspberrypi4-iob	2021-03-16 19:51:23.946	info	iobroker npm-install: upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
              host.raspberrypi4-iob	2021-03-16 19:51:23.889	info	iobroker npm-install: upload [3] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/style.css style.css text/css
              host.raspberrypi4-iob	2021-03-16 19:51:23.792	info	iobroker npm-install: upload [4] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/words.js words.js application/javascript
              host.raspberrypi4-iob	2021-03-16 19:51:23.772	info	iobroker npm-install: host.raspberrypi4-iob install adapter midea@0.0.6
              host.raspberrypi4-iob	2021-03-16 19:51:02.800	info	iobroker npm-install: npm install iobroker.midea@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:51:02.798	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:51:00.191	info	iobroker install midea@0.0.6 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:51:00.190	warn	startInstance cannot find adapter "midea@0.0.6". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:50:59.186	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:50:58.079	info	iobroker npm-install: Update "system.adapter.yahka.0"
              host.raspberrypi4-iob	2021-03-16 19:50:58.031	info	iobroker npm-install: host.raspberrypi4-iob object yahka.meta._accessoryCategories created/updated
              host.raspberrypi4-iob	2021-03-16 19:50:58.022	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.yahka created/updated
              host.raspberrypi4-iob	2021-03-16 19:50:57.918	info	iobroker npm-install: upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.857	info	iobroker npm-install: upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.797	info	iobroker npm-install: upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.734	info	iobroker npm-install: upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.667	info	iobroker npm-install: upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.293	info	iobroker npm-install: upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.228	info	iobroker npm-install: upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
              host.raspberrypi4-iob	2021-03-16 19:50:57.169	info	iobroker npm-install: upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
              host.raspberrypi4-iob	2021-03-16 19:50:57.093	info	iobroker npm-install: upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
              host.raspberrypi4-iob	2021-03-16 19:50:57.022	info	iobroker npm-install: upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
              host.raspberrypi4-iob	2021-03-16 19:50:56.929	info	iobroker npm-install: upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
              host.raspberrypi4-iob	2021-03-16 19:50:56.855	info	iobroker npm-install: upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
              host.raspberrypi4-iob	2021-03-16 19:50:56.795	info	iobroker npm-install: upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
              host.raspberrypi4-iob	2021-03-16 19:50:56.738	info	iobroker npm-install: upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
              host.raspberrypi4-iob	2021-03-16 19:50:56.681	info	iobroker npm-install: upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
              host.raspberrypi4-iob	2021-03-16 19:50:56.624	info	iobroker npm-install: upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
              host.raspberrypi4-iob	2021-03-16 19:50:56.529	info	iobroker npm-install: upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
              host.raspberrypi4-iob	2021-03-16 19:50:55.808	info	iobroker npm-install: upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
              host.raspberrypi4-iob	2021-03-16 19:50:54.881	info	iobroker npm-install: upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
              host.raspberrypi4-iob	2021-03-16 19:50:54.784	info	iobroker npm-install: upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
              host.raspberrypi4-iob	2021-03-16 19:50:54.765	error	iobroker npm-install: Cannot install "pam-devel": E: Paket pam-devel kann nicht gefunden werden.The following apt-get packages could not be installed: pam-devel. Please install them manually.
              host.raspberrypi4-iob	2021-03-16 19:50:52.600	info	iobroker npm-install: host.raspberrypi4-iob install adapter yahka@0.12.0
              host.raspberrypi4-iob	2021-03-16 19:50:27.635	info	iobroker npm-install: npm install iobroker.yahka@0.12.0 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:50:27.632	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:50:24.996	info	iobroker install yahka@0.12.0 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:50:24.994	warn	startInstance cannot find adapter "yahka@0.12.0". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:50:23.990	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:50:22.940	info	iobroker npm-install: Update "system.adapter.vis-hqwidgets.0"
              host.raspberrypi4-iob	2021-03-16 19:50:22.913	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-hqwidgets created/updated
              host.raspberrypi4-iob	2021-03-16 19:50:22.815	info	iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
              host.raspberrypi4-iob	2021-03-16 19:50:22.812	info	"system.adapter.vis.0" enabled
              host.raspberrypi4-iob	2021-03-16 19:50:22.793	info	"system.adapter.vis.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:50:22.761	info	iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
              host.raspberrypi4-iob	2021-03-16 19:50:22.703	info	iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
              host.raspberrypi4-iob	2021-03-16 19:50:22.603	info	iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
              host.raspberrypi4-iob	2021-03-16 19:50:22.580	info	iobroker npm-install: host.raspberrypi4-iob install adapter vis-hqwidgets@1.1.7
              host.raspberrypi4-iob	2021-03-16 19:50:04.872	info	iobroker npm-install: npm install iobroker.vis-hqwidgets@1.1.7 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:50:04.869	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:50:02.218	info	iobroker install vis-hqwidgets@1.1.7 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:50:02.217	warn	startInstance cannot find adapter "vis-hqwidgets@1.1.7". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:50:01.212	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:50:00.156	info	iobroker npm-install: Update "system.adapter.vis-colorpicker.0"
              host.raspberrypi4-iob	2021-03-16 19:50:00.133	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-colorpicker created/updated
              host.raspberrypi4-iob	2021-03-16 19:50:00.042	info	iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
              host.raspberrypi4-iob	2021-03-16 19:50:00.039	info	"system.adapter.vis.0" enabled
              host.raspberrypi4-iob	2021-03-16 19:50:00.021	info	"system.adapter.vis.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:49:59.991	info	iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted.
              host.raspberrypi4-iob	2021-03-16 19:49:59.893	info	iobroker npm-install: upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:59.873	info	iobroker npm-install: host.raspberrypi4-iob install adapter vis-colorpicker@1.2.0
              host.raspberrypi4-iob	2021-03-16 19:49:42.065	info	iobroker npm-install: npm install iobroker.vis-colorpicker@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:49:42.062	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:49:39.462	info	iobroker install vis-colorpicker@1.2.0 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:49:39.449	warn	startInstance cannot find adapter "vis-colorpicker@1.2.0". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:49:38.448	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:49:37.409	info	iobroker npm-install: Update "system.adapter.vis-bars.0"
              host.raspberrypi4-iob	2021-03-16 19:49:37.389	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-bars created/updated
              host.raspberrypi4-iob	2021-03-16 19:49:37.309	info	iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
              host.raspberrypi4-iob	2021-03-16 19:49:37.307	info	"system.adapter.vis.0" enabled
              host.raspberrypi4-iob	2021-03-16 19:49:37.292	info	"system.adapter.vis.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:49:37.268	info	iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-bars/www" was not found! Nothing was uploaded or deleted.
              host.raspberrypi4-iob	2021-03-16 19:49:37.211	info	iobroker npm-install: upload [0] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/bars.png bars.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:37.118	info	iobroker npm-install: upload [1] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/index.html index.html text/html
              host.raspberrypi4-iob	2021-03-16 19:49:37.098	info	iobroker npm-install: host.raspberrypi4-iob install adapter vis-bars@0.1.4
              host.raspberrypi4-iob	2021-03-16 19:49:22.193	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              host.raspberrypi4-iob	2021-03-16 19:49:18.716	info	iobroker npm-install: npm install iobroker.vis-bars@0.1.4 --loglevel error --prefix "/opt/iobroker" (System call)
              host.raspberrypi4-iob	2021-03-16 19:49:18.714	info	iobroker npm-install: NPM version: 6.14.11
              host.raspberrypi4-iob	2021-03-16 19:49:16.156	info	iobroker install vis-bars@0.1.4 using installedFrom
              host.raspberrypi4-iob	2021-03-16 19:49:16.155	warn	startInstance cannot find adapter "vis-bars@0.1.4". Try to install it... 1 attempt
              host.raspberrypi4-iob	2021-03-16 19:49:15.148	info	iobroker npm-install: exit 51
              host.raspberrypi4-iob	2021-03-16 19:49:14.115	info	iobroker npm-install: adapter "icons-mfd-svg" already installed. Use "upgrade" to upgrade to a newer version.
              host.raspberrypi4-iob	2021-03-16 19:49:12.319	info	iobroker install icons-mfd-svg using installedVersion
              host.raspberrypi4-iob	2021-03-16 19:49:12.318	warn	startInstance cannot find adapter "icons-mfd-svg". Try to install it... 2 attempt
              host.raspberrypi4-iob	2021-03-16 19:49:11.317	info	iobroker npm-install: exit 51
              host.raspberrypi4-iob	2021-03-16 19:49:10.282	info	iobroker npm-install: adapter "icons-mfd-png" already installed. Use "upgrade" to upgrade to a newer version.
              host.raspberrypi4-iob	2021-03-16 19:49:08.475	info	iobroker install icons-mfd-png using installedVersion
              host.raspberrypi4-iob	2021-03-16 19:49:08.474	warn	startInstance cannot find adapter "icons-mfd-png". Try to install it... 2 attempt
              host.raspberrypi4-iob	2021-03-16 19:49:07.471	info	iobroker npm-install: exit 0
              host.raspberrypi4-iob	2021-03-16 19:49:06.414	info	iobroker npm-install: host.raspberrypi4-iob object system.adapter.vis-icontwo created/updated
              host.raspberrypi4-iob	2021-03-16 19:49:06.269	info	iobroker npm-install: upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:06.203	info	iobroker npm-install: upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_RED.png Alarm/alarm_RED.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:06.136	info	iobroker npm-install: upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_green.png Alarm/alarm_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:06.068	info	iobroker npm-install: upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm_red2.png Alarm/alarm_red2.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.973	info	iobroker npm-install: upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off.png Alarm/bell_off.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.900	info	iobroker npm-install: upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off_green.png Alarm/bell_off_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.825	info	iobroker npm-install: upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_off_red.png Alarm/bell_off_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.750	info	iobroker npm-install: upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on.png Alarm/bell_on.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.671	info	iobroker npm-install: upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on_green.png Alarm/bell_on_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.594	info	iobroker npm-install: upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/bell_on_red.png Alarm/bell_on_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.517	info	iobroker npm-install: upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera.png Alarm/camera.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.440	info	iobroker npm-install: upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2.png Alarm/camera2.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.361	info	iobroker npm-install: upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2_green.png Alarm/camera2_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.288	info	iobroker npm-install: upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera2_red.png Alarm/camera2_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.212	info	iobroker npm-install: upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera_green.png Alarm/camera_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.137	info	iobroker npm-install: upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/camera_red.png Alarm/camera_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:05.060	info	iobroker npm-install: upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm.png Alarm/fire_alarm.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:04.987	info	iobroker npm-install: upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm_green.png Alarm/fire_alarm_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:04.911	info	iobroker npm-install: upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/fire_alarm_red.png Alarm/fire_alarm_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:04.835	info	iobroker npm-install: upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/flame.png Alarm/flame.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:04.757	info	iobroker npm-install: upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/flame_green.png Alarm/flame_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:04.003	info	iobroker npm-install: upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/home_onnection_red.png Alarm/home_onnection_red.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:03.255	info	iobroker npm-install: upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/sensor_door_green.png Alarm/sensor_door_green.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:02.503	info	iobroker npm-install: upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/smoke.png Alarm/smoke.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:01.754	info	iobroker npm-install: upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Arrows/arrow_21_up.png Arrows/arrow_21_up.png image/png
              host.raspberrypi4-iob	2021-03-16 19:49:01.000	info	iobroker npm-install: upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/101_g.jpg Backgrounds/101_g.jpg image/jpeg
              host.raspberrypi4-iob	2021-03-16 19:49:00.236	info	iobroker npm-install: upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/110.jpg Backgrounds/110.jpg image/jpeg
              host.raspberrypi4-iob	2021-03-16 19:48:59.210	info	iobroker npm-install: upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/207.jpg Backgrounds/207.jpg image/jpeg
              host.raspberrypi4-iob	2021-03-16 19:48:59.016	info	"system.adapter.alexa2.0" enabled
              host.raspberrypi4-iob	2021-03-16 19:48:58.401	info	iobroker npm-install: upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/300.png Backgrounds/Seamless/300.png image/png
              host.raspberrypi4-iob	2021-03-16 19:48:55.847	info	"system.adapter.history.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:48:54.815	info	"system.adapter.harmony.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:48:54.725	info	iobroker npm-install: upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/kodi.png Brands/kodi.png image/png
              host.raspberrypi4-iob	2021-03-16 19:48:53.165	info	"system.adapter.broadlink2.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:48:51.773	info	"system.adapter.backitup.0" disabled
              host.raspberrypi4-iob	2021-03-16 19:48:50.969	info	"system.adapter.alexa2.0" disabled
              • D Digi-Bit
                HomoranH Offline
                HomoranH Offline
                immer das selbe, oder immer das gleiche für jeden Adapter?
                dann dauert das
                immer hin ist er schon bei midea
                  dann dauert das
                  Digi-Bit
                  dann dauert das
                  ja, so langsam werden die alle grün, dauert aber echt sehr lange.....
                  denke mal das der doch noch irgend wie ein kanll weg hat oder ?
                  mfg
                  • D Digi-Bit
                    dann dauert das
                    mfg
                    HomoranH Offline
                    HomoranH Offline
                    ist wie nach einem restore. Je nach Leistung des Pi und Umfang der Installation kann das bis zu 2 Stunden dauern
                      Digi-Bit
                      ahha, ok....
                      jedenfalls noch mal ein fettes DANKE für die hilfe !
                      werde ein backup machen und dann erstmal feierabend, reicht mir für heute !
                      die noch einen schönen abend !
                      mfg !
