  4. Tuya Adapter: Schema fehlt
tuya adapter
15 Beiträge 2 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    Masteryotta
    Re: [Tuya Adapter: No schema exists](init basic states ???)
    Hallo @apollon77 , mein Roboterstaubsauger hat mit den Tuya Adapter gut funktioniert, nach eine neue Installation von iobroker, bekomme ich den nicht mehr zu steuern. Adapter ist grün.
    Kannst du mir weiterhelfen?
    Hier der Log:
    2021-03-15 13:05:46.254 - info: host.raspberrypi "system.adapter.tuya.0" enabled
    2021-03-15 13:05:46.589 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 15577
    2021-03-15 13:05:52.109 - debug: tuya.0 (15577) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-03-15 13:05:52.649 - debug: tuya.0 (15577) Objects client ready ... initialize now
    2021-03-15 13:05:52.718 - debug: tuya.0 (15577) Objects create System PubSub Client
    2021-03-15 13:05:52.733 - debug: tuya.0 (15577) Objects create User PubSub Client
    2021-03-15 13:05:52.737 - debug: tuya.0 (15577) Objects client initialize lua scripts
    2021-03-15 13:05:52.809 - debug: tuya.0 (15577) Objects connected to redis: 127.0.0.1:9001
    2021-03-15 13:05:52.851 - debug: tuya.0 (15577) objectDB connected
    2021-03-15 13:05:52.861 - debug: tuya.0 (15577) Redis States: Use Redis connection: 127.0.0.1:6379
    2021-03-15 13:05:52.891 - debug: tuya.0 (15577) States create System PubSub Client
    2021-03-15 13:05:52.894 - debug: tuya.0 (15577) States create User PubSub Client
    2021-03-15 13:05:52.922 - debug: tuya.0 (15577) States connected to redis: 127.0.0.1:6379
    2021-03-15 13:05:52.925 - debug: tuya.0 (15577) statesDB connected
    2021-03-15 13:05:53.778 - debug: tuya.0 (15577) Plugin sentry Initialize Plugin (enabled=true)
    2021-03-15 13:05:53.807 - info: tuya.0 (15577) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-15 13:05:53.920 - info: tuya.0 (15577) starting. Version 3.5.6 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.24.0, js-controller: 3.2.16
    2021-03-15 13:05:54.142 - debug: tuya.0 (15577) init 1 known devices
    2021-03-15 13:05:54.155 - debug: tuya.0 (15577) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
    2021-03-15 13:05:54.187 - debug: tuya.0 (15577) 0120042868c63a875aed: Create device objects if not exist
    2021-03-15 13:05:54.202 - debug: tuya.0 (15577) connected set to false
    2021-03-15 13:05:54.354 - info: tuya.0 (15577) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
    2021-03-15 13:05:54.371 - info: tuya.0 (15577) Existing devices initialized
    2021-03-15 13:05:54.397 - info: tuya.0 (15577) Listen for local Tuya devices on port 6666
    2021-03-15 13:05:54.399 - info: tuya.0 (15577) Listen for encrypted local Tuya devices on port 6667
    2021-03-15 13:05:54.557 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:05:55.506 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":90,"ack":false,"time":1615809955503},"_id":70121589}
    2021-03-15 13:05:55.511 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:05:55.537 - debug: tuya.0 (15577) 0120042868c63a875aed: Connected to device
    2021-03-15 13:05:55.564 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1615809955555,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615809955555}
    2021-03-15 13:05:55.566 - debug: tuya.0 (15577) connected set to true
    2021-03-15 13:05:55.568 - debug: tuya.0 (15577) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1615809955556,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615809955556}
    2021-03-15 13:05:55.601 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":85,"25":true,"26":"5","27":"5","28":false}
    2021-03-15 13:05:55.602 - info: tuya.0 (15577) 0120042868c63a875aed: No schema exists, init basic states ...
    2021-03-15 13:05:55.633 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1615809955629,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
    2021-03-15 13:05:55.658 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1615809955654,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090659}
    2021-03-15 13:05:55.682 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":85,"ack":true,"ts":1615809955678,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615809897998}
    2021-03-15 13:05:55.708 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.25 {"val":true,"ack":true,"ts":1615809955703,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615808939860}
    2021-03-15 13:05:55.732 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1615809955728,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
    2021-03-15 13:05:55.768 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.27 {"val":"5","ack":true,"ts":1615809955762,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615808942727}
    2021-03-15 13:05:55.805 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1615809955801,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
    2021-03-15 13:06:07.543 - debug: tuya.0 (15577) 0120042868c63a875aed: Disconnected from device
    2021-03-15 13:06:07.552 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1615809967548,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615809967548}
    2021-03-15 13:06:07.554 - debug: tuya.0 (15577) connected set to false
    2021-03-15 13:06:07.559 - debug: tuya.0 (15577) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1615809967551,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615809967551}
    2021-03-15 13:06:19.821 - debug: tuya.0 (15577) system.adapter.admin.0: logging true
    2021-03-15 13:06:29.460 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":91,"ack":false,"time":1615809989457},"_id":70121590}
    2021-03-15 13:06:29.462 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:06:33.578 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:36.548 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:39.557 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:42.543 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:45.554 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:48.559 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:51.550 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:54.562 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:06:57.540 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:07:00.562 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:07:03.582 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:07:06.551 - debug: tuya.0 (15577) Discovered device: 192.168.178.27:49154 - U��{"ip":"192.168.178.27","gwId":"0120042868c63a875aed","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"gGUj6WJeZHA1QBDU","version":"3.1"}(>�Q�U
    2021-03-15 13:07:07.692 - debug: tuya.0 (15577) 0120042868c63a875aed: Connected to device
    2021-03-15 13:07:07.718 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1615810027707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810027707}
    2021-03-15 13:07:07.720 - debug: tuya.0 (15577) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1615810027708,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810027708}
    2021-03-15 13:07:07.722 - debug: tuya.0 (15577) connected set to true
    2021-03-15 13:07:07.727 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":84,"25":true,"26":"5","27":"5","28":false}
    2021-03-15 13:07:07.802 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1615810027759,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
    2021-03-15 13:07:07.805 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1615810027761,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090659}
    2021-03-15 13:07:07.806 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":84,"ack":true,"ts":1615810027762,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810027762}
    2021-03-15 13:07:07.808 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.25 {"val":true,"ack":true,"ts":1615810027763,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615808939860}
    2021-03-15 13:07:07.809 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1615810027765,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
    2021-03-15 13:07:07.811 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.27 {"val":"5","ack":true,"ts":1615810027766,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615808942727}
    2021-03-15 13:07:07.813 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1615810027767,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
    2021-03-15 13:07:14.161 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":86}
    2021-03-15 13:07:14.173 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":86,"ack":true,"ts":1615810034168,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810034168}
    2021-03-15 13:07:30.252 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":92,"ack":false,"time":1615810050249},"_id":70121591}
    2021-03-15 13:07:30.253 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:07:36.821 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":87}
    2021-03-15 13:07:36.832 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":87,"ack":true,"ts":1615810056828,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810056828}
    2021-03-15 13:07:48.153 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":86}
    2021-03-15 13:07:48.171 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":86,"ack":true,"ts":1615810068165,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810068165}
    2021-03-15 13:07:59.495 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":87}
    2021-03-15 13:07:59.508 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":87,"ack":true,"ts":1615810079503,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810079503}
    2021-03-15 13:08:22.210 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":86}
    2021-03-15 13:08:22.224 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":86,"ack":true,"ts":1615810102218,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810102218}
    2021-03-15 13:08:30.255 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":93,"ack":false,"time":1615810110252},"_id":70121592}
    2021-03-15 13:08:30.256 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:08:33.574 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":87}
    2021-03-15 13:08:33.581 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":87,"ack":true,"ts":1615810113578,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810113578}
    2021-03-15 13:08:44.909 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":88}
    2021-03-15 13:08:44.924 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":88,"ack":true,"ts":1615810124919,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810124919}
    2021-03-15 13:08:56.209 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":87}
    2021-03-15 13:08:56.222 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":87,"ack":true,"ts":1615810136217,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810136217}
    2021-03-15 13:09:07.629 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":88}
    2021-03-15 13:09:07.649 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":88,"ack":true,"ts":1615810147645,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810147645}
    2021-03-15 13:09:18.994 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":86}
    2021-03-15 13:09:19.010 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":86,"ack":true,"ts":1615810159002,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810159002}
    2021-03-15 13:09:30.249 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":88}
    2021-03-15 13:09:30.260 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":88,"ack":true,"ts":1615810170256,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810170256}
    2021-03-15 13:09:31.256 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":94,"ack":false,"time":1615810171255},"_id":70121593}
    2021-03-15 13:09:31.257 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:10:32.249 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":95,"ack":false,"time":1615810232246},"_id":70121594}
    2021-03-15 13:10:32.250 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:11:12.455 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":89}
    2021-03-15 13:11:12.473 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":89,"ack":true,"ts":1615810272467,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810272467}
    2021-03-15 13:11:33.250 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":96,"ack":false,"time":1615810293247},"_id":70121595}
    2021-03-15 13:11:33.251 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:12:09.098 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":88}
    2021-03-15 13:12:09.108 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":88,"ack":true,"ts":1615810329104,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810329104}
    2021-03-15 13:12:20.461 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":89}
    2021-03-15 13:12:20.473 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":89,"ack":true,"ts":1615810340469,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810340469}
    2021-03-15 13:12:33.272 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":97,"ack":false,"time":1615810353258},"_id":70121596}
    2021-03-15 13:12:33.273 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:12:43.206 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":90}
    2021-03-15 13:12:43.216 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":90,"ack":true,"ts":1615810363212,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810363212}
    2021-03-15 13:12:54.511 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":89}
    2021-03-15 13:12:54.522 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":89,"ack":true,"ts":1615810374517,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810374517}
    2021-03-15 13:13:05.826 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":90}
    2021-03-15 13:13:05.839 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":90,"ack":true,"ts":1615810385833,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810385833}
    2021-03-15 13:13:17.165 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":89}
    2021-03-15 13:13:17.175 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":89,"ack":true,"ts":1615810397171,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810397171}
    2021-03-15 13:13:28.505 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":90}
    2021-03-15 13:13:28.516 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":90,"ack":true,"ts":1615810408512,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810408512}
    2021-03-15 13:13:34.260 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":98,"ack":false,"time":1615810414256},"_id":70121597}
    2021-03-15 13:13:34.261 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:13:51.187 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":89}
    2021-03-15 13:13:51.199 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":89,"ack":true,"ts":1615810431194,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810431194}
    2021-03-15 13:14:02.499 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":90}
    2021-03-15 13:14:02.514 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":90,"ack":true,"ts":1615810442507,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810442507}
    2021-03-15 13:14:13.866 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":91}
    2021-03-15 13:14:13.879 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":91,"ack":true,"ts":1615810453874,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810453874}
    2021-03-15 13:14:35.249 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":99,"ack":false,"time":1615810475246},"_id":70121598}
    2021-03-15 13:14:35.251 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:15:21.968 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":92}
    2021-03-15 13:15:21.978 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":92,"ack":true,"ts":1615810521974,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810521974}
    2021-03-15 13:15:33.217 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":91}
    2021-03-15 13:15:33.239 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":91,"ack":true,"ts":1615810533233,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810533233}
    2021-03-15 13:15:35.273 - debug: tuya.0 (15577) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":100,"ack":false,"time":1615810535270},"_id":70121599}
    2021-03-15 13:15:35.275 - debug: tuya.0 (15577) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2021-03-15 13:15:55.909 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":92}
    2021-03-15 13:15:55.920 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":92,"ack":true,"ts":1615810555915,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810555915}
    2021-03-15 13:16:07.254 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":91}
    2021-03-15 13:16:07.265 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":91,"ack":true,"ts":1615810567261,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810567261}
    2021-03-15 13:16:18.628 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":92}
    2021-03-15 13:16:18.643 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":92,"ack":true,"ts":1615810578637,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810578637}
    2021-03-15 13:16:41.321 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":91}
    2021-03-15 13:16:41.332 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":91,"ack":true,"ts":1615810601328,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810601328}
    2021-03-15 13:16:52.685 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":92}
    2021-03-15 13:16:52.716 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":92,"ack":true,"ts":1615810612709,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810612709}
    2021-03-15 13:17:15.365 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":93}
    2021-03-15 13:17:15.376 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":93,"ack":true,"ts":1615810635371,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810635371}
    2021-03-15 13:17:38.055 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":92}
    2021-03-15 13:17:38.064 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":92,"ack":true,"ts":1615810658060,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810658060}
    2021-03-15 13:17:49.419 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":93}
    2021-03-15 13:17:49.429 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":93,"ack":true,"ts":1615810669425,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810669425}
    2021-03-15 13:18:00.815 - debug: tuya.0 (15577) 0120042868c63a875aed: Received data: {"14":91}
    2021-03-15 13:18:00.830 - debug: tuya.0 (15577) stateChange tuya.0.0120042868c63a875aed.14 {"val":91,"ack":true,"ts":1615810680823,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615810680823}
    • M Masteryotta
      Hier der Log:
      @masteryotta proxy sync gemacht? Dabeiliesst er das Schema aus
      • apollon77A apollon77
        Masteryotta
        @apollon77 Habe ich gemacht, hat auch geklappt, das Schema wird aber nicht dabei erkannt. Habe es mehrmals schon versucht, weiß jetzt nicht mehr weiter.
        • M Masteryotta
          @masteryotta Was sagen die Logs? ALso: Klappt der Sync wirklich )Dann kommt im Admin ein grüner haken und der Proxy geht alleine zu!
            Masteryotta
            @apollon77 Genau, ich habe die Anleitung gefolgt mit einen Android Emulator. Dann kommt der Grüne Hacken, Proxy schließt und Tuya wird grün.
            In den Logs steht das hier:
            tuya.0 2021-03-18 10:26:01.950 debug (13204) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
            tuya.0 2021-03-18 10:26:01.948 debug (13204) Found 1 devices
            tuya.0 2021-03-18 10:26:01.946 debug (13204) Found 1 device schema information
            • M Masteryotta
              @masteryotta Nein beim sync
              M 2 Antworten Letzte Antwort
                Masteryotta
                @apollon77
                Jetzt bekomme ich Fehler Meldungen bei erneuten Versuch:
                tuya.0 2021-03-18 12:39:37.139 debug (12011) sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                tuya.0 2021-03-18 12:39:37.137 debug (12011) Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":85,"ack":false,"time":1616067577134},"_id":72470375}
                tuya.0 2021-03-18 12:39:24.746 debug (12011) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                tuya.0 2021-03-18 12:39:24.745 debug (12011) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":84,"ack":false,"time":1616067564742},"_id":72470374}
                tuya.0 2021-03-18 12:39:24.146 error (12011) 0120042868c63a875aed: connect ECONNRESET 192.168.178.27:6668
                tuya.0 2021-03-18 12:39:24.144 debug (12011) 0120042868c63a875aed: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect ECONNRESET 192.168.178.27:6668
                tuya.0 2021-03-18 12:39:24.041 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                tuya.0 2021-03-18 12:39:24.023 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616067564016,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067563841}
                tuya.0 2021-03-18 12:39:23.997 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                tuya.0 2021-03-18 12:39:23.994 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                tuya.0 2021-03-18 12:39:23.992 debug (12011) Found 1 devices
                tuya.0 2021-03-18 12:39:23.991 debug (12011) Found 1 device schema information
                tuya.0 2021-03-18 12:39:23.846 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616067563841,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067563841}
                tuya.0 2021-03-18 12:39:23.841 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616067563833,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067563833}
                tuya.0 2021-03-18 12:39:23.835 debug (12011) 0120042868c63a875aed: Disconnected from device
                tuya.0 2021-03-18 12:39:23.834 debug (12011) 0120042868c63a875aed: Error from device (0): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                tuya.0 2021-03-18 12:39:23.828 debug (12011) 0120042868c63a875aed: Connected to device
                tuya.0 2021-03-18 12:39:23.744 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                tuya.0 2021-03-18 12:39:23.725 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616067563719,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067562214}
                tuya.0 2021-03-18 12:39:23.704 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                tuya.0 2021-03-18 12:39:23.702 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                tuya.0 2021-03-18 12:39:23.700 debug (12011) Found 1 devices
                tuya.0 2021-03-18 12:39:23.698 debug (12011) Found 1 device schema information
                tuya.0 2021-03-18 12:39:22.226 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616067562214,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067562214}
                tuya.0 2021-03-18 12:39:22.219 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616067562212,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067562212}
                tuya.0 2021-03-18 12:39:22.204 debug (12011) 0120042868c63a875aed: Disconnected from device
                tuya.0 2021-03-18 12:39:22.198 debug (12011) 0120042868c63a875aed: Error from device (0): App still open on your mobile phone? Error: Error from socket: write ECONNRESET
                tuya.0 2021-03-18 12:39:22.192 debug (12011) 0120042868c63a875aed: Connected to device
                tuya.0 2021-03-18 12:39:22.164 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                tuya.0 2021-03-18 12:39:22.144 debug (12011) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                tuya.0 2021-03-18 12:39:22.142 debug (12011) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":83,"ack":false,"time":1616067562138},"_id":72470373}
                tuya.0 2021-03-18 12:39:22.136 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616067562130,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616067055407}
                tuya.0 2021-03-18 12:39:22.115 debug (12011) sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
                tuya.0 2021-03-18 12:39:22.090 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                tuya.0 2021-03-18 12:39:22.088 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                tuya.0 2021-03-18 12:39:22.086 debug (12011) Found 1 devices
                tuya.0 2021-03-18 12:39:22.084 debug (12011) Found 1 device schema information
                tuya.0 2021-03-18 12:38:45.046 debug (12011) Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":82,"ack":false,"time":1616067525043},"_id":72470372}
                tuya.0 2021-03-18 12:38:45.011 debug (12011) sendTo "startProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                tuya.0 2021-03-18 12:38:44.930 info (12011) SSL-Proxy ready to receive requests
                tuya.0 2021-03-18 12:38:44.899 debug (12011) Use first network interface (192.168.178.23)
                tuya.0 2021-03-18 12:38:44.896 debug (12011) Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":81,
                  Masteryotta
                  @apollon77 Noch ein Versuch, Hacken ist Grün geworden, proxy hat sich geschlossen, hier die Logs:
                  tuya.0 2021-03-18 12:54:46.786 debug (12011) system.adapter.admin.0: logging true
                  tuya.0 2021-03-18 12:54:32.211 debug (12011) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                  tuya.0 2021-03-18 12:54:32.210 debug (12011) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":101,"ack":false,"time":1616068472206},"_id":72470391}
                  tuya.0 2021-03-18 12:54:31.033 debug (12011) sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                  tuya.0 2021-03-18 12:54:31.031 debug (12011) Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":100,"ack":false,"time":1616068471029},"_id":72470390}
                  tuya.0 2021-03-18 12:54:20.049 debug (12011) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616068460024,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                  tuya.0 2021-03-18 12:54:20.048 debug (12011) stateChange tuya.0.0120042868c63a875aed.27 {"val":"5","ack":true,"ts":1616068460023,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020645}
                  tuya.0 2021-03-18 12:54:20.047 debug (12011) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616068460023,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                  tuya.0 2021-03-18 12:54:20.045 debug (12011) stateChange tuya.0.0120042868c63a875aed.25 {"val":true,"ack":true,"ts":1616068460022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020644}
                  tuya.0 2021-03-18 12:54:20.044 debug (12011) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616068460022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                  tuya.0 2021-03-18 12:54:20.043 debug (12011) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616068460022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                  tuya.0 2021-03-18 12:54:20.041 debug (12011) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616068460021,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                  tuya.0 2021-03-18 12:54:20.008 debug (12011) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":true,"26":"5","27":"5","28":false}
                  tuya.0 2021-03-18 12:54:20.004 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616068460001,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068460001}
                  tuya.0 2021-03-18 12:54:19.995 debug (12011) 0120042868c63a875aed: Connected to device
                  tuya.0 2021-03-18 12:54:19.986 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                  tuya.0 2021-03-18 12:54:19.974 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068459963,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068459963}
                  tuya.0 2021-03-18 12:54:19.973 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068459962,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068459962}
                  tuya.0 2021-03-18 12:54:19.952 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                  tuya.0 2021-03-18 12:54:19.951 debug (12011) 0120042868c63a875aed: Disconnected from device
                  tuya.0 2021-03-18 12:54:19.948 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                  tuya.0 2021-03-18 12:54:19.947 debug (12011) Found 1 devices
                  tuya.0 2021-03-18 12:54:19.945 debug (12011) Found 1 device schema information
                  tuya.0 2021-03-18 12:54:19.491 debug (12011) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616068459473,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                  tuya.0 2021-03-18 12:54:19.490 debug (12011) stateChange tuya.0.0120042868c63a875aed.27 {"val":"5","ack":true,"ts":1616068459472,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020645}
                  tuya.0 2021-03-18 12:54:19.489 debug (12011) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616068459472,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                  tuya.0 2021-03-18 12:54:19.488 debug (12011) stateChange tuya.0.0120042868c63a875aed.25 {"val":true,"ack":true,"ts":1616068459472,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020644}
                  tuya.0 2021-03-18 12:54:19.487 debug (12011) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616068459471,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                  tuya.0 2021-03-18 12:54:19.486 debug (12011) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616068459471,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                  tuya.0 2021-03-18 12:54:19.419 debug (12011) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616068459414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                  tuya.0 2021-03-18 12:54:19.411 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616068459402,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068459402}
                  tuya.0 2021-03-18 12:54:19.406 debug (12011) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":true,"26":"5","27":"5","28":false}
                  tuya.0 2021-03-18 12:54:19.394 debug (12011) 0120042868c63a875aed: Connected to device
                  tuya.0 2021-03-18 12:54:19.387 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                  tuya.0 2021-03-18 12:54:19.365 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068459350,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068459350}
                  tuya.0 2021-03-18 12:54:19.363 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068459349,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068459349}
                  tuya.0 2021-03-18 12:54:19.340 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                  tuya.0 2021-03-18 12:54:19.338 debug (12011) 0120042868c63a875aed: Disconnected from device
                  tuya.0 2021-03-18 12:54:19.336 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                  tuya.0 2021-03-18 12:54:19.334 debug (12011) Found 1 devices
                  tuya.0 2021-03-18 12:54:19.332 debug (12011) Found 1 device schema information
                  tuya.0 2021-03-18 12:54:16.367 error at addChunk (_stream_readable.js:288:12)
                  tuya.0 2021-03-18 12:54:16.367 error at Socket.emit (events.js:198:13)
                  tuya.0 2021-03-18 12:54:16.367 error at Socket.ondata (_stream_readable.js:710:20)
                  tuya.0 2021-03-18 12:54:16.367 error at Socket.Writable.write (_stream_writable.js:299:11)
                  tuya.0 2021-03-18 12:54:16.367 error at writeOrBuffer (_stream_writable.js:399:5)
                  tuya.0 2021-03-18 12:54:16.367 error at doWrite (_stream_writable.js:415:12)
                  tuya.0 2021-03-18 12:54:16.367 error at Socket._write (net.js:726:8)
                  tuya.0 2021-03-18 12:54:16.367 error at Socket._writeGeneric (net.js:714:5)
                  tuya.0 2021-03-18 12:54:16.367 error at writeGeneric (internal/stream_base_commons.js:73:3)
                  tuya.0 2021-03-18 12:54:16.367 error at afterWriteDispatched (internal/stream_base_commons.js:78:25)
                  tuya.0 2021-03-18 12:54:16.367 error (12011) Error: write EPIPE
                  tuya.0 2021-03-18 12:54:16.365 error (12011) SSL-Proxy ERROR: Error: write EPIPE
                  tuya.0 2021-03-18 12:54:16.120 debug (12011) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616068456101,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                  tuya.0 2021-03-18 12:54:16.118 debug (12011) stateChange tuya.0.0120042868c63a875aed.27 {"val":"5","ack":true,"ts":1616068456100,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020645}
                  tuya.0 2021-03-18 12:54:16.117 debug (12011) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616068456100,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                  tuya.0 2021-03-18 12:54:16.116 debug (12011) stateChange tuya.0.0120042868c63a875aed.25 {"val":true,"ack":true,"ts":1616068456099,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068020644}
                  tuya.0 2021-03-18 12:54:16.115 debug (12011) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616068456099,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                  tuya.0 2021-03-18 12:54:16.111 debug (12011) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616068456098,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                  tuya.0 2021-03-18 12:54:16.109 debug (12011) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616068456095,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                  tuya.0 2021-03-18 12:54:16.088 debug (12011) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":true,"26":"5","27":"5","28":false}
                  tuya.0 2021-03-18 12:54:16.085 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616068456081,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068456081}
                  tuya.0 2021-03-18 12:54:16.075 debug (12011) 0120042868c63a875aed: Connected to device
                  tuya.0 2021-03-18 12:54:16.052 info (12011) 0120042868c63a875aed Init with IP=192.168.178.27, Key=afb36a0fee2dc749, Version=3.1
                  tuya.0 2021-03-18 12:54:16.048 debug (12011) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                  tuya.0 2021-03-18 12:54:16.047 debug (12011) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":99,"ack":false,"time":1616068456030},"_id":72470389}
                  tuya.0 2021-03-18 12:54:16.042 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068456019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068456019}
                  tuya.0 2021-03-18 12:54:16.039 debug (12011) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616068456018,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068456018}
                  tuya.0 2021-03-18 12:54:16.006 debug (12011) sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
                  tuya.0 2021-03-18 12:54:16.004 debug (12011) 0120042868c63a875aed: Create device objects if not exist
                  tuya.0 2021-03-18 12:54:16.002 debug (12011) 0120042868c63a875aed: Disconnected from device
                  tuya.0 2021-03-18 12:54:16.000 debug (12011) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                  tuya.0 2021-03-18 12:54:15.997 debug (12011) Found 1 devices
                  tuya.0 2021-03-18 12:54:15.996 debug (12011) Found 1 device schema information
                  maxcul.0 2021-03-18 12:53:45.255 info (15878) checkTimeIntervalFired
                  tuya.0 2021-03-18 12:53:38.578 debug (12011) system.adapter.admin.0: logging false
                  tuya.0 2021-03-18 12:53:36.716 debug (12011) Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":98,"ack":false,"time":1616068416713},"_id":72470388}
                  tuya.0 2021-03-18 12:53:36.689 debug (12011) sendTo "startProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                  tuya.0 2021-03-18 12:53:36.603 info (12011) SSL-Proxy ready to receive requests
                  tuya.0 2021-03-18 12:53:36.568 debug (12011) Use first network interface (192.168.178.23)
                  tuya.0 2021-03-18 12:53:36.565 debug (12011) Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":97,
                  tuya.0 2021-03-18 12:53:32.208 debug (12011) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                  • apollon77A Offline
                    Please try to run "iobroker fix". It seems that the ssl proxy can not be started ... so honestly... how you were abl to do a proxy sync??
                      Masteryotta
                      @apollon77 iobroker fix durchgeführt
                      Proxy erneut gestartet und über den Android Emulator synchronisiert. Grüner Hacken und proxy schließt.
                      Log ist identisch.
                      tuya.0 2021-03-18 15:22:38.764 debug (3646) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                      tuya.0 2021-03-18 15:22:38.761 debug (3646) Found 1 devices
                      tuya.0 2021-03-18 15:22:38.759 debug (3646) Found 1 device schema information
                        Masteryotta
                        @apollon77
                        • M Masteryotta
                          @apollon77
                          @masteryotta Das log vom dem Prox sync wäre hilfreich
                            Masteryotta
                            @apollon77 Das hier?:
                            tuya.0 2021-03-18 15:26:48.930 debug (3646) system.adapter.admin.0: logging true
                            tuya.0 2021-03-18 15:26:48.045 debug (3646) system.adapter.admin.0: logging false
                            tuya.0 2021-03-18 15:26:41.910 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:26:41.909 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":23,"ack":false,"time":1616077601906},"_id":88999535}
                            tuya.0 2021-03-18 15:26:26.945 debug (3646) system.adapter.admin.0: logging true
                            tuya.0 2021-03-18 15:26:24.488 debug (3646) system.adapter.admin.0: logging false
                            tuya.0 2021-03-18 15:24:12.581 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:24:12.580 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":20,"ack":false,"time":1616077452577},"_id":88999532}
                            tuya.0 2021-03-18 15:23:38.586 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:23:38.585 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":19,"ack":false,"time":1616077418582},"_id":88999531}
                            tuya.0 2021-03-18 15:23:11.586 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:23:11.584 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":18,"ack":false,"time":1616077391580},"_id":88999530}
                            tuya.0 2021-03-18 15:22:52.695 debug (3646) sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:22:52.689 debug (3646) Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":17,"ack":false,"time":1616077372686},"_id":88999529}
                            tuya.0 2021-03-18 15:22:50.072 debug (3646) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616077370054,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                            tuya.0 2021-03-18 15:22:50.067 debug (3646) stateChange tuya.0.0120042868c63a875aed.27 {"val":"0","ack":true,"ts":1616077370053,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990925}
                            tuya.0 2021-03-18 15:22:50.066 debug (3646) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616077370052,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                            tuya.0 2021-03-18 15:22:50.064 debug (3646) stateChange tuya.0.0120042868c63a875aed.25 {"val":false,"ack":true,"ts":1616077370051,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990922}
                            tuya.0 2021-03-18 15:22:50.044 debug (3646) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616077370013,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                            tuya.0 2021-03-18 15:22:50.039 debug (3646) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616077370004,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                            tuya.0 2021-03-18 15:22:50.038 debug (3646) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616077370003,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                            tuya.0 2021-03-18 15:22:50.036 debug (3646) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1616077370002,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077370002}
                            tuya.0 2021-03-18 15:22:50.030 debug (3646) connected set to true
                            tuya.0 2021-03-18 15:22:50.009 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616077369985,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077369985}
                            tuya.0 2021-03-18 15:22:49.989 debug (3646) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":false,"26":"5","27":"0","28":false}
                            tuya.0 2021-03-18 15:22:49.976 debug (3646) 0120042868c63a875aed: Connected to device
                            tuya.0 2021-03-18 15:22:49.969 info (3646) 0120042868c63a875aed Init with IP=192.168.178.27, Key=b1690f8879745615, Version=3.1
                            tuya.0 2021-03-18 15:22:49.940 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077369918,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077369918}
                            tuya.0 2021-03-18 15:22:49.939 debug (3646) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1616077369914,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077369914}
                            tuya.0 2021-03-18 15:22:49.937 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077369913,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077369913}
                            tuya.0 2021-03-18 15:22:49.932 debug (3646) connected set to false
                            tuya.0 2021-03-18 15:22:49.884 debug (3646) 0120042868c63a875aed: Create device objects if not exist
                            tuya.0 2021-03-18 15:22:49.882 debug (3646) 0120042868c63a875aed: Disconnected from device
                            tuya.0 2021-03-18 15:22:49.878 debug (3646) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                            tuya.0 2021-03-18 15:22:49.876 debug (3646) Found 1 devices
                            tuya.0 2021-03-18 15:22:49.874 debug (3646) Found 1 device schema information
                            tuya.0 2021-03-18 15:22:38.977 debug (3646) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616077358951,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                            tuya.0 2021-03-18 15:22:38.976 debug (3646) stateChange tuya.0.0120042868c63a875aed.27 {"val":"0","ack":true,"ts":1616077358951,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990925}
                            tuya.0 2021-03-18 15:22:38.975 debug (3646) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616077358950,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                            tuya.0 2021-03-18 15:22:38.973 debug (3646) stateChange tuya.0.0120042868c63a875aed.25 {"val":false,"ack":true,"ts":1616077358949,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990922}
                            tuya.0 2021-03-18 15:22:38.972 debug (3646) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616077358948,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                            tuya.0 2021-03-18 15:22:38.961 debug (3646) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616077358937,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                            tuya.0 2021-03-18 15:22:38.959 debug (3646) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616077358936,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                            tuya.0 2021-03-18 15:22:38.910 debug (3646) connected set to true
                            tuya.0 2021-03-18 15:22:38.909 debug (3646) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1616077358896,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077358896}
                            tuya.0 2021-03-18 15:22:38.908 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616077358895,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077358895}
                            tuya.0 2021-03-18 15:22:38.905 debug (3646) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":false,"26":"5","27":"0","28":false}
                            tuya.0 2021-03-18 15:22:38.883 debug (3646) 0120042868c63a875aed: Connected to device
                            tuya.0 2021-03-18 15:22:38.836 info (3646) 0120042868c63a875aed Init with IP=192.168.178.27, Key=b1690f8879745615, Version=3.1
                            tuya.0 2021-03-18 15:22:38.810 debug (3646) connected set to false
                            tuya.0 2021-03-18 15:22:38.808 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077358796,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077358790}
                            tuya.0 2021-03-18 15:22:38.807 debug (3646) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1616077358795,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077358795}
                            tuya.0 2021-03-18 15:22:38.806 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077358790,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077358790}
                            tuya.0 2021-03-18 15:22:38.772 debug (3646) 0120042868c63a875aed: Create device objects if not exist
                            tuya.0 2021-03-18 15:22:38.770 debug (3646) 0120042868c63a875aed: Disconnected from device
                            tuya.0 2021-03-18 15:22:37.990 debug (3646) stateChange tuya.0.0120042868c63a875aed.28 {"val":false,"ack":true,"ts":1616077357957,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1581362090776}
                            tuya.0 2021-03-18 15:22:37.988 debug (3646) stateChange tuya.0.0120042868c63a875aed.27 {"val":"0","ack":true,"ts":1616077357956,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990925}
                            tuya.0 2021-03-18 15:22:37.964 debug (3646) stateChange tuya.0.0120042868c63a875aed.26 {"val":"5","ack":true,"ts":1616077357912,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582459106230}
                            tuya.0 2021-03-18 15:22:37.952 debug (3646) stateChange tuya.0.0120042868c63a875aed.25 {"val":false,"ack":true,"ts":1616077357897,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616068990922}
                            tuya.0 2021-03-18 15:22:37.949 debug (3646) stateChange tuya.0.0120042868c63a875aed.14 {"val":100,"ack":true,"ts":1616077357896,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1615811282041}
                            tuya.0 2021-03-18 15:22:37.947 debug (3646) stateChange tuya.0.0120042868c63a875aed.11 {"val":0,"ack":true,"ts":1616077357894,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616065636382}
                            tuya.0 2021-03-18 15:22:37.945 debug (3646) stateChange tuya.0.0120042868c63a875aed.1 {"val":true,"ack":true,"ts":1616077357892,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1582457931892}
                            tuya.0 2021-03-18 15:22:37.943 debug (3646) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1616077357890,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077357890}
                            tuya.0 2021-03-18 15:22:37.940 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":true,"ack":true,"ts":1616077357889,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077357889}
                            tuya.0 2021-03-18 15:22:37.924 debug (3646) connected set to true
                            tuya.0 2021-03-18 15:22:37.861 debug (3646) 0120042868c63a875aed: Received data: {"1":true,"11":0,"14":100,"25":false,"26":"5","27":"0","28":false}
                            tuya.0 2021-03-18 15:22:37.828 debug (3646) 0120042868c63a875aed: Connected to device
                            tuya.0 2021-03-18 15:22:37.814 info (3646) 0120042868c63a875aed Init with IP=192.168.178.27, Key=b1690f8879745615, Version=3.1
                            tuya.0 2021-03-18 15:22:37.760 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077357698,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077357698}
                            tuya.0 2021-03-18 15:22:37.757 debug (3646) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1616077357697,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077357697}
                            tuya.0 2021-03-18 15:22:37.754 debug (3646) stateChange tuya.0.0120042868c63a875aed.online {"val":false,"ack":true,"ts":1616077357695,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1616077357695}
                            tuya.0 2021-03-18 15:22:37.742 debug (3646) connected set to false
                            tuya.0 2021-03-18 15:22:37.728 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:22:37.725 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":16,"ack":false,"time":1616077357698},"_id":88999528}
                            tuya.0 2021-03-18 15:22:37.658 debug (3646) sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:22:37.651 debug (3646) 0120042868c63a875aed: Create device objects if not exist
                            tuya.0 2021-03-18 15:22:37.648 debug (3646) 0120042868c63a875aed: Disconnected from device
                            tuya.0 2021-03-18 15:22:37.641 debug (3646) 0120042868c63a875aed: Schema found for gGUj6WJeZHA1QBDU: null
                            tuya.0 2021-03-18 15:22:37.638 debug (3646) Found 1 devices
                            tuya.0 2021-03-18 15:22:37.636 debug (3646) Found 1 device schema information
                            tuya.0 2021-03-18 15:22:26.479 error at addChunk (_stream_readable.js:288:12)
                            tuya.0 2021-03-18 15:22:26.479 error at Socket.emit (events.js:198:13)
                            tuya.0 2021-03-18 15:22:26.479 error at Socket.ondata (_stream_readable.js:710:20)
                            tuya.0 2021-03-18 15:22:26.479 error at Socket.Writable.write (_stream_writable.js:299:11)
                            tuya.0 2021-03-18 15:22:26.479 error at writeOrBuffer (_stream_writable.js:399:5)
                            tuya.0 2021-03-18 15:22:26.479 error at doWrite (_stream_writable.js:415:12)
                            tuya.0 2021-03-18 15:22:26.479 error at Socket._write (net.js:726:8)
                            tuya.0 2021-03-18 15:22:26.479 error at Socket._writeGeneric (net.js:714:5)
                            tuya.0 2021-03-18 15:22:26.479 error at writeGeneric (internal/stream_base_commons.js:73:3)
                            tuya.0 2021-03-18 15:22:26.479 error at afterWriteDispatched (internal/stream_base_commons.js:78:25)
                            tuya.0 2021-03-18 15:22:26.479 error (3646) Error: write EPIPE
                            tuya.0 2021-03-18 15:22:26.471 error (3646) SSL-Proxy ERROR: Error: write EPIPE
                            tuya.0 2021-03-18 15:22:10.706 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:22:10.704 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":15,"ack":false,"time":1616077330701},"_id":88999527}
                            tuya.0 2021-03-18 15:21:51.758 debug (3646) Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":14,"ack":false,"time":1616077311755},"_id":88999526}
                            tuya.0 2021-03-18 15:21:51.723 debug (3646) sendTo "startProxy" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:21:50.660 info (3646) SSL-Proxy ready to receive requests
                            tuya.0 2021-03-18 15:21:50.492 debug (3646) Use first network interface (192.168.178.23)
                            tuya.0 2021-03-18 15:21:50.486 debug (3646) Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":13,"
                            tuya.0 2021-03-18 15:21:10.707 debug (3646) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
                            tuya.0 2021-03-18 15:21:10.704 debug (3646) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":12,"ack":false,"time":1616077270699},"_id":88999524}
                            • M Masteryotta
                              @masteryotta sagte in Tuya Adapter: Schema fehlt:
                              Der Proxy beendet sich mit einem Fehler. Also irgendwas tit nicht.
                              EPIPE heisst das irgendwas mit der cOnnection kaputt geht ... Reboote mal die Kiste. iobroker fixer hattest du laufen lassen?
                              Sonst keine Ahnung was das sein kann - ins Internet kommt der iobroker host? Auch zu Tuya hosts? Nicht das Du irgendwo ne Firewall, DNS Block oder so drin hast?
                                Masteryotta
                                @apollon77 Das ist ja das komische, alles läuft, Tuya ist verbunden, den fixer habe ich auch laufen lassen. Ich sehe nicht woran es liegen kann.
                                Trotzdem danke für deine Hilfe, ich schau mir alles nochmal an. Wenn ich den Fehler gefunden habe, sage ich bescheid.
