  4. FB-Checkpresence Adapter wird nicht grün [gelöst]
    6.6k
34 Beiträge 4 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • M MM2029
    @wendy2702 Habe jetzt nochmal einen neuen Benutzer angelegt. Überall Haken gesetzt ohne Erfolg.
    Adapter gelöscht und neu installiert.
    fb-checkpresence.0	2021-03-07 20:29:50.688	info	(9051) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0	2021-03-07 20:29:50.653	info	(9051) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
    host.raspberrypi4	2021-03-07 20:29:49.097	info	instance system.adapter.fb-checkpresence.0 started with pid 9051
    host.raspberrypi4	2021-03-07 20:29:46.593	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    fb-checkpresence.0	2021-03-07 20:29:45.974	info	(9032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2021-03-07 20:29:45.973	info	(9032) terminating
    fb-checkpresence.0	2021-03-07 20:29:45.972	error	(9032) onUnload: TypeError: Cannot read property 'exitRequest' of null
    host.raspberrypi4	2021-03-07 20:29:45.970	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
    fb-checkpresence.0	2021-03-07 20:29:45.970	info	(9032) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi4	2021-03-07 20:29:45.960	info	stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
    fb-checkpresence.0	2021-03-07 20:29:11.060	info	(9032) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0	2021-03-07 20:29:11.027	info	(9032) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
    host.raspberrypi4	2021-03-07 20:29:09.651	info	instance system.adapter.fb-checkpresence.0 started with pid 9032
    host.raspberrypi4	2021-03-07 20:29:07.060	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    fb-checkpresence.0	2021-03-07 20:29:06.478	info	(9003) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2021-03-07 20:29:06.476	info	(9003) terminating
    fb-checkpresence.0	2021-03-07 20:29:06.475	error	(9003) onUnload: TypeError: Cannot read property 'exitRequest' of null
    MOD EDIT: LOG IN CODE TAGS </>
    wendy2702W Online
    wendy2702W Online
    wendy2702
    @mm2029 Gab es bei der Adapter Installation irgendwelche Error oder so?
    • wendy2702W wendy2702
      MM2029
      @wendy2702
      $ ./iobroker add fb-checkpresence  --host raspberrypi4
      NPM version: 6.14.11
      npm install iobroker.fb-checkpresence@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
      host.raspberrypi4 install adapter fb-checkpresence
      upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
      upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
      upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
      upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
      upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
      upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/admin.d.ts admin.d.ts video/mp2t
      host.raspberrypi4 object system.adapter.fb-checkpresence created/updated
      host.raspberrypi4 create instance fb-checkpresence
      host.raspberrypi4 object fb-checkpresence.0.info created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.logLevel created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.sigKill created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.eventLoopLag created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.outputCount created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.inputCount created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.uptime created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.memRss created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.memHeapTotal created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.memHeapUsed created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.cputime created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.cpu created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.compactMode created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.connected created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0.alive created
      host.raspberrypi4 object system.adapter.fb-checkpresence.0 created
      process exited with code 0
      • M MM2029
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @mm2029 Hast du im Adapter SSL aktiviert ?
          MM2029
          @wendy2702 Diese Möglichkeit sehe ich dem Adapter nicht
          • M MM2029
            wendy2702W Online
            wendy2702W Online
            wendy2702
            @mm2029 Hm,
            steht in Anleitung:
              @mm2029 Hm,
              steht in Anleitung:
              MM2029
              @wendy2702 kann leider nichts dazu finden.. 😞
              • M MM2029
                wendy2702W Online
                wendy2702W Online
                wendy2702
                @mm2029 Kann dir heute nicht mehr helfen. Muss noch für Dienstreise packen,
                Auf die schnelle fällt mir nichts mehr ein.
                  MM2029
                  @wendy2702 vielen Dank trotzdem und gute Reise
                  • M MM2029
                    Dragon
                    @mm2029 Neben dem Feld zur Passworteingabe kann man ssl deaktivieren...
                    WinniW 1 Antwort Letzte Antwort
                    • D Dragon
                      WinniW Offline
                      WinniW Offline
                      Winni
                      @dragon ich glaube aber erst ab der Version 1.11 wenn ich das read.me richtig verstehe. Im stable ist erst die 1.10.
                      Es gibt nicht Gutes. Außer man tut es. Erich Kästner
                      • WinniW Winni
                        Dragon
                        @winni achso, oki...
                        • D Dragon
                          MM2029
                          @dragon @wendy2702 Hab den Adapter wieder grün, was genau schief lief kann ich nicht sagen.
                          Mit neuen Benutzer lief er heute wieder. Vielen Dank für eure Bemühungen. Hätte noch eine Frage zum Broadling2 Adapter. Habe den RM4 pro hier und der taucht auch im Adapter auf nur ohne Datenpunkte zum Anlernen. Hat jemand eine Idee ?
                          D wendy2702W 2 Antworten Letzte Antwort
                          • M MM2029
                            Dragon
                            @mm2029 Ich hatte mit allen Geräten Probleme außer dem RM Pro +. Ich würde es mit dem versuchen...
                            • M MM2029
                              wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              @mm2029 sagte in FB-Checkpresence Adapter wird nicht grün:
                              Mach dafür besser ein neues Thema auf und setze das hier bitte auf [Gelöst]
