  4. Pioneer AVR Skript
    6.0k
Pioneer AVR Skript
45 Beiträge 23 Kommentatoren 17.7k Aufrufe 5 Beobachtet
  • C Offline
    czahn
    Hallo in die Runde,
    falls es da draußen noch ein paar Pioneer Receiver Besitzer gibt.
    Basierend auf diesem node.js Package https://github.com/stormboy/node-pioneer-avr,
    habe ich mir folgendes Skript in iobroker gebaut, womit ich meinen VSX-921 Receiver von Pioneer steuern kann.
    Das Skript legt in iobroker versch. States an, worüber der Receiver gesteuert und Status ausgelesen werden können.
    Für Feedback bin ich offen ;)
    Grüße,
    Christof
    script needs stormboy/node-pioneer-avr package.
    see https://github.com/stormboy/node-pioneer-avr
    To install, excecute the following command in /opt/iobroker/node_modules:
    npm install https://github.com/stormboy/node-pioneer-avr.git
    //path to node-pioneer-avr package
    var avr = require("../../pioneer-avr");
    //new iobroker states
    createState('pioneer.volumeUp'); //set to true to increase Volume
    createState('pioneer.volumeDown'); //set to true to decrease Volume
    createState('pioneer.turnOn'); //set to true to turn receiver on
    createState('pioneer.turnOff'); //set to true to turn receiver off
    createState('pioneer.setInput'); //set new input as numeric value (see below)
    createState('pioneer.onState'); //Status On/Off
    createState('pioneer.inputState'); //Current Input State
    //Options
    var options = {
    port: 23,
    host: "192.168.0.19",
    log: true
    var receiver = new avr.VSX(options);
    //trigger on connection
    receiver.on("connect", function() {
    console.log("receiver connected");
    //trigger on Input change
    receiver.on("input", function(id, name) {
    console.log("current input: " + id + " : " + name);
    setState('javascript.0.pioneer.inputState', id + " : " + name);
    //trigger on power change
    receiver.on("power", function(pwrstate) {
    console.log("Power: " + pwrstate);
    setState('javascript.0.pioneer.onState', pwrstate);
    //inc Vol
    on({id: 'javascript.0.pioneer.volumeUp', val: true}, function (obj) {
    receiver.volumeUp();
    //dec Vol
    on({id: 'javascript.0.pioneer.volumeDown', val: true}, function (obj) {
    receiver.volumeDown();
    //Turn On
    on({id: 'javascript.0.pioneer.turnOn', val: true}, function (obj) {
    receiver.power(true);
    //Turn Off
    on({id: 'javascript.0.pioneer.turnOff', val: true}, function (obj) {
    receiver.power(false);
    /* Input Codes
    dvd: "04",
    bd: "25",
    tv_sat: "05",
    dvr_bdr: "15",
    video_1: "10",
    video_2: "14",
    hdmi_1: "19",
    hdmi_2: "20",
    hdmi_3: "21",
    hdmi_4: "22",
    hdmi_5: "23",
    media: "26",
    ipod_usb: "17",
    xm_radio: "18",
    cd: "01",
    cdr_tape: "03",
    tuner: "02",
    phono: "00",
    multi_ch: "12",
    adapter_port: "33",
    sirius: "27",
    //Set Input
    on({id: 'javascript.0.pioneer.setInput', change: "ne"}, function (obj) {
    var value = obj.state.val;
    console.log(value);
    console.log(receiver.queryInputName());
    receiver.selectInput(value);
    • Alex1808A Offline
      Alex1808A Offline
      Alex1808
      @czahn:
      Hallo in die Runde,
      Grüße,
      Christof
      //Options
      var options = {
      port: 23,
      log: true
      //inc Vol
      //dec Vol
      //Turn On
      //Turn Off
      /* Input Codes
      dvd: "04",
      bd: "25",
      tv_sat: "05",
      dvr_bdr: "15",
      video_1: "10",
      video_2: "14",
      hdmi_1: "19",
      hdmi_2: "20",
      hdmi_3: "21",
      hdmi_4: "22",
      hdmi_5: "23",
      media: "26",
      ipod_usb: "17",
      xm_radio: "18",
      cd: "01",
      cdr_tape: "03",
      tuner: "02",
      phono: "00",
      multi_ch: "12",
      adapter_port: "33",
      sirius: "27",
      //Set Input
      console.log(value);
      Funktioniert einwandfrei! :) (habe auch ein VSX-921)
      Einziges, wie hast du mit der Lautstärke gelöst? Die ändert sich nur mit 0,5 und das dauert….
      • C Offline
        czahn
        Ja, stimmt. Bis Mann da auf einer ordentlichen Lautstärke ist, dauert es ne Weile. Mann könnte bei VolumeUP einen db Wert übergeben, um den die Lautstärke dann erhöht wird. Zusätzlich gibt es die Möglichkeit direkt einen db Wert (bsp. -35) an den Receiver zu senden.
        Werde das die Tage mal implementieren.
        Gesendet von meinem MI 5s mit Tapatalk
          MeisterHoppel
          Hallo Leute,
          irgendwie scheitere ich schon bei der Installation:
          ` > admin@diskstation:/volume1/iobroker/node_modules$ npm install https://github.com/stormboy/node-pioneer-avr.git
          npm WARN addRemoteGit Error: not found: git
          npm WARN addRemoteGit at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
          npm WARN addRemoteGit at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
          npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
          npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
          npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
          npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
          npm WARN addRemoteGit git+https://github.com/stormboy/node-pioneer-avr.git resetting remote /var/services/homes/admin/.npm/_git-remotes/https-github-com-stormboy-node-pioneer-avr-git-8e6aac3b because of error: { [Error: not found: git] code: 'ENOGIT' }
          npm ERR! git clone –template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/stormboy/node-pioneer-avr.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-stormboy-node-pioneer-avr-git-8e6aac3b: undefined
          npm ERR! git clone --template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/stormboy/node-pioneer-avr.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-stormboy-node-pioneer-avr-git-8e6aac3b: undefined
          npm ERR! Linux 3.10.77
          npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/stormboy/node-pioneer-avr.git"
          npm ERR! node v4.4.2
          npm ERR! npm v2.15.0
          npm ERR! code ENOGIT
          npm ERR! not found: git
          npm ERR!
          npm ERR! Failed using git.
          npm ERR! This is most likely not a problem with npm itself.
          npm ERR! Please check if you have git installed and in your PATH.
          npm ERR! Please include the following file with any support request:
          npm ERR! /volume1/iobroker/node_modules/npm-debug.log `
          Sieht so aus, als wenn er der die Seite nicht findet??? :-(
            @MeisterHoppel:
            npm ERR! not found: git `
            bitte git installieren
            Rainer
              pix
              wenn die Lautstärke irgendwo auslesbar ist, kannst du sie ja um einen Prozenwert erhöhen. Ich mache das so bei Sonos:
              // leiser 20%
                  var volume_ist = parseInt(getState("sonos.0.root.192_168_178_51.volume"/*volume*/).val);
                  setState("sonos.0.root.192_168_178_51.volume"/*volume*/, parseInt(volume_ist - Math.ceil(volume_ist/5),10) );
                  log('6fach Wandtaster Küche unten links kurz gedrückt - leiser Sonos - jetzt ' + getState("sonos.0.root.192_168_178_51.volume"/*volume*/).val);
              Das Skript solltest du zu einem Adapter ausbauen!
              Pix
                MeisterHoppel
                Danke Homorun,
                ist anscheinend nicht ganz einfach, da ich Iobroker auf der DiskStation habe laufen. Werde die Woche mal mich weiterbilden….
                Danke euch
                • C Offline
                  czahn
                  ich denke Git ist nicht zwingend nötig. Vielleicht kannst Du Dir das Projekt auch aus github auf die Diskstation runterladen und lokal installieren. (siehe https://docs.npmjs.com/cli/install)
                  • C Offline
                    czahn
                    So, ich habe das Script nun nochmal etwas erweitert.
                    VolumeUp und VolumeDown sind nun numerisch. Sprich es kann ein beliebiger Wert übergeben werden. Das entspricht dann der Anzahl an Schritten um die die Lautstärke erhöht, bzw. reduziert wird.
                    Weiterhin gibt es nun den State "setVolume". Hier kann (indirekt) der db Wert angepasst werden. Allerdings muss man ein bissl rechnen, da negative Zahlen nicht funktionieren. Das hängt leider an der Pioneer Schnittstelle.
                    Die Range beginnt bei 1 und endet bei 185. Sprich, es gilt: 1 = -80dB , 161 = 0dB und 185 = +12dB.
                    Funktioniert bei mir soweit ganz gut. Testfeedback nehme ich wieder gerne entgegen!
                    @pix: Ja, ich sollte das mal in einen Adapter umfunktionieren. Dazu muss ich mir aber vermutlich etwas Zeit nehmen. Hab ich noch nie gemacht :? ;)
                    createState('pioneer.setVolume'); //set Volume as numeric value. [0 .. 185] 1 = -80dB , 161 = 0dB, 185 = +12dB
                    //Options
                    var options = {
                        port: 23,
                        log: true
                    //inc Vol
                    on({id: 'javascript.0.pioneer.volumeUp', change: "any"}, function (obj) {
                      console.log("VolUp: " + value);
                      for(var i = 0; i < value; i++) {
                    //dec Vol
                    on({id: 'javascript.0.pioneer.volumeDown', change: "any"}, function (obj) {
                      console.log("VolDown: " + value);
                    //Set Volume
                    //[0 .. 185] 1 = -80dB , 161 = 0dB, 185 = +12dB
                    on({id: 'javascript.0.pioneer.setVolume', change: "any"}, function (obj) {
                      console.log("Volume: " + value);
                      receiver.volume(value);
                    //Turn On
                    //Turn Off
                    /* Input Codes
                        dvd: "04",
                        bd: "25",
                        tv_sat: "05",
                        dvr_bdr: "15",
                        video_1: "10",
                        video_2: "14",
                        hdmi_1: "19",
                        hdmi_2: "20",
                        hdmi_3: "21",
                        hdmi_4: "22",
                        hdmi_5: "23",
                        media: "26",
                        ipod_usb: "17",
                        xm_radio: "18",
                        cd: "01",
                        cdr_tape: "03",
                        tuner: "02",
                        phono: "00",
                        multi_ch: "12",
                        adapter_port: "33",
                        sirius: "27",
                    //Set Input
                      console.log(value);
                    • Alex1808A Offline
                      Alex1808A Offline
                      Alex1808
                      Heute wollte ich neue Version ausprobieren, bekomme aber Fehler beim starten
                      host.iobroker	2016-12-19 16:59:01.536	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                      javascript.0	2016-12-19 16:59:01.472	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1076:14)
                      javascript.0	2016-12-19 16:59:01.472	error	at exports._exceptionWithHostPort (util.js:934:20)
                      javascript.0	2016-12-19 16:59:01.472	error	at Object.exports._errnoException (util.js:911:11)
                      javascript.0	2016-12-19 16:59:01.472	error	Error: connect ECONNREFUSED 192.168.2.112:23
                      javascript.0	2016-12-19 16:59:01.467	error	uncaught exception: connect ECONNREFUSED 192.168.2.112:23
                      javascript.0	2016-12-19 16:59:01.413	info	script.js.Sonstige.PioneerAVR: registered 6 subscriptions and 0 schedules
                      javascript.0	2016-12-19 16:59:01.389	info	Start javascript script.js.Sonstige.PioneerAVR
                      Verbindung zum Receiver über Konsole aber funktioniert. :?
                      • C Offline
                        czahn
                        Der receiver akzeptiert m.e. nur eine zeitgleiche Verbindung. Hattest du parallel vielleicht eine zweite Verbindung offen?
                        • Alex1808A Offline
                          Alex1808A Offline
                          Alex1808
                          @czahn:
                          Gesendet von meinem MI 5s mit Tapatalk `
                          Ja, das konnte sein.. hatte noch Terminal offen. Jetzt gehts, Danke! :)
                          • F Offline
                            FrankC
                            weiß jemand, ob das Script auch mit dem VSX-922 funktioniert? Ich krieg das irgendwie nicht hin. Habe das Script in den javascript adapter kopiert und die AVR-IP-Adresse angepasst. Die verschiedenen Punkte erscheinen auch (On, Off etc…) aber wie schalte ich die jetzt?
                            Sorry bin der absolute Noob und heut ist mein erster Tag mit IObroker...
                            Danke für eure Hilfe
                            Frank
                              mertensm.72
                              Sorry, für die Frage, aber wie kann ich Christofs Script auf ioBroker installieren?
                                speedy78
                                @FrankC:
                                Frank `
                                Die Frage ist ja schon älter aber es läuft auch auf meinem VSX-923 wichtig im Script die IP Anpassen !!!
                                  schmimla
                                  Ich fürchte, dass meine bisherige Installation fehlerhaft ist. Ich habe in iobroker unter "Objekte" nun einen Systemadapter "system.adapter./stormboy/node-pioneer-avr.upload" mit dem Namen /stormboy/node-pioneer-avr.upload, dem Typ state und der Rolle "indicator.state". Es ist keine Instanz erstellt worden. Das Skript liegt auf meinem Server unter /opt/iobroker/node_modules/pioneer-avr.
                                  Ist das so weit korrekt, und ich habe nur noch was vergessen, oder bin ich vollkommen auf dem Holzpfad?
                                  Edit: Hab es hinbekommen! Mir werden jetzt sieben states wie z.B. inputState usw angezeigt. Vielen Dank schon mal an den Skriptersteller!
                                    sebastian.eberle
                                    Hi zusammen,
                                    ich habe sowohl das Skript als auch die pioneer_avr.js library etwas erweitert. Hintergrund ist folgender: Ich möchte über Alexa meinen Pioneer starten und automatisch eine Internet Radio Sender, den ich als Favorit hinterlegt habe, starten. Das ganze funktioniert ja über den Input H.M.G. bei Pioneer. Habe das Skript daher erweitert, dass die HMG Buttons der Fernbedienung gesendet werden können. Aktuell habe ich folgende Buttons eingebaut: Enter, Return, Up, Down, Num1
                                    Für die Buttons werden entsprechende true/false states im ordner pioneer unter javascript.0 angelegt.
                                    Funktioniert bei mir prima. Ich habe lediglich festgestellt, dass das Skript hin und wieder beim Connect zum receiver auf einen Fehler läuft (uncaught exception: read ECONNRESET).
                                    Die aktualisierte pioneer_avr.js lib gibts hier: https://github.com/EbSe/node-pioneer-avr
                                    Mein aktualisiertes Skript:
                                    createState('pioneer.buttonHMGEnter'); //Enter Button in HMG
                                    createState('pioneer.buttonHMGReturn'); //Return Button in HMG
                                    createState('pioneer.buttonHMGUp'); //Up Button in HMG
                                    createState('pioneer.buttonHMGDown'); //Down Button in HMG
                                    createState('pioneer.buttonHMGPlay'); //Play Button in HMG
                                    createState('pioneer.buttonHMGStop'); //Stop Button in HMG
                                    createState('pioneer.buttonHMG1'); //'1' Button in HMG
                                    //Options
                                    var options = {
                                        port: 23,
                                        host: "192.168.0.99",
                                        log: true
                                    //inc Vol
                                    on({ id: 'javascript.0.pioneer.volumeUp', change: "any" }, function(obj) {
                                        for (var i = 0; i < value; i++) {
                                    //dec Vol
                                    on({ id: 'javascript.0.pioneer.volumeDown', change: "any" }, function(obj) {
                                    //Set Volume
                                    on({ id: 'javascript.0.pioneer.setVolume', change: "any" }, function(obj) {
                                    //Turn On
                                    on({ id: 'javascript.0.pioneer.turnOn', val: true }, function(obj) {
                                    //Turn Off
                                    on({ id: 'javascript.0.pioneer.turnOff', val: true }, function(obj) {
                                    /* Input Codes
                                        dvd: "04",
                                        bd: "25",
                                        tv_sat: "05",
                                        dvr_bdr: "15",
                                        video_1: "10",
                                        video_2: "14",
                                        hdmi_1: "19",
                                        hdmi_2: "20",
                                        hdmi_3: "21",
                                        hdmi_4: "22",
                                        hdmi_5: "23",
                                        media: "26",
                                        ipod_usb: "17",
                                        xm_radio: "18",
                                        cd: "01",
                                        cdr_tape: "03",
                                        tuner: "02",
                                        phono: "00",
                                        multi_ch: "12",
                                        adapter_port: "33",
                                        sirius: "27",
                                    //Set Input
                                    on({ id: 'javascript.0.pioneer.setInput', change: "ne" }, function(obj) {
                                        console.log(value);
                                    //Press Button Enter HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGEnter', val: true }, function(obj) {
                                        console.log("Press Button HMG Enter");
                                        receiver.buttonHMGEnter();
                                    //Press Button Return HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGReturn', val: true }, function(obj) {
                                        console.log("Press Button HMG Return");
                                        receiver.buttonHMGReturn();
                                    //Press Button Play HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGPlay', val: true }, function(obj) {
                                        console.log("Press Button HMG Play");
                                        receiver.buttonHMGPlay();
                                    //Press Button Stop HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGStop', val: true }, function(obj) {
                                        console.log("Press Button HMG Stop");
                                        receiver.buttonHMGStop();
                                    //Press Button Up HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGUp', val: true }, function(obj) {
                                        console.log("Press Button HMG Up");
                                        receiver.buttonHMGUp();
                                    //Press Button Down HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMGDown', val: true }, function(obj) {
                                        console.log("Press Button HMG Down");
                                        receiver.buttonHMGDown();
                                    //Press Button 1 HMG
                                    on({ id: 'javascript.0.pioneer.buttonHMG1', val: true }, function(obj) {
                                        console.log("Press Button HMG '1'");
                                        receiver.buttonHMG1();
                                    • N Offline
                                      N Offline
                                      NyanCat
                                      Hi, das ist genau das, was ich suche.
                                      Im moment steuere ich meine VSX921 noch über kleine scripts mit Telnet befehlen, die ich über IOBroker ausführen lassen. Aber ich habe es nicht geschafft auf diese weise effizient über Alexa lauter und leiser zu machen. Das hier sollte das Problem doch lösen, oder?
                                      Ich bin aber noch ganz neu in der Materie und hab es bis jetzt nur geschafft das alte Script über
                                      in den node_modules ordner vom IO zu installieren. :oops:
                                      Was muss ich jetzt tun, um die neuen Scripts aus diesem Thread und deren outcomes in IOBroker zu sehen und zu nutzen?
                                      Danke und sorry für meine Unwissenheit :mrgreen:
                                      Bitte um Nachsicht: Bin ein hardcore Noob, was Coding angeht. Copy-Paste ist mein Freund.
                                        sebastian.eberle
                                        Wenn dus ganz einfach machen willst lad dir das aktualisierte js file von meinem GitHub runter und kopiere es nach /opt/iobroker/npm_modules/pioneer_avr. Dann musst du den JavaScript Adapter neustarten. Das andere Skript einfach in ioBroker anlegen und starten, es werden dann die states unter javascript.0.pioneer angelegt.
                                        • H Offline
                                          Harry-IO-HM
                                          Vielleicht hilfreich für all diejenigen, die wir ich erst jetzt (nach 1 Jahr oder länger) auf diesen Thread gestoßen sind und das Zeugs installieren wollen.
                                          Bei mir ging das so (Debian Linux):
                                          erst einmal auf ner Konsole git installieren:
                                          sudo apt-get install git-all
                                          Jetzt von stormboy:
                                          cd /opt/iobroker/node_modules
                                          jetzt das Update hinterher - weiß nicht ob mans braucht:
                                           npm install https://github.com/EbSe/node-pioneer-avr
                                          Jetzt den Javascript Adapter im ioBroker.admin einmal neu starten.
                                          Dann unter Skripte ein neues Javascript mit dem Namen "pioneer" anlegen und die letzte Version vom 23.11.2017 (siehe oben) dort reinkopieren.
                                          Dort in Zeile 31 die IP-Adresse Eures Pioneer AV Receivers reinhämmern.
                                          Und dann das Script aktivieren.
