  5. Suche anwesensheits skript
    6.3k
111 Beiträge 8 Kommentatoren 14.9k Aufrufe 7 Beobachtet
    @denjo
    "Voll die Sachen da stehen" könnte auf krumme Installation von nodeJS hindeuten.
    Ausgabe von
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    mal zeigen. Ein- und Ausgabe, nix kürzen.
    denjo
    @Thomas-Braun sagte in Suche anwesensheits skript:
    Linux raspberrypi 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Tue Dec  8 12:25:29 2020 from 192.168.178.121
    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.20.0
    /usr/bin/node
    v12.20.0
    /usr/bin/npm
    6.14.8
    nodejs:
      Installiert:           12.20.0-1nodesource1
      Installationskandidat: 12.20.0-1nodesource1
      Versionstabelle:
     *** 12.20.0-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.21.0~dfsg-1~deb10u1+rpi1 500
    pi@raspberrypi:~ $
    • D denjo
      /usr/bin/nodejs
      v12.20.0
      /usr/bin/node
      v12.20.0
      /usr/bin/npm
      6.14.8
      nodejs:
        Versionstabelle:
      pi@raspberrypi:~ $
      @denjo
      Gut, das passt.
      apt policy build-essential
        @denjo
        Gut, das passt.
        denjo
        @Thomas-Braun
        pi@raspberrypi:~ $ apt policy build-essential
        build-essential:
          Installiert:           12.6
          Installationskandidat: 12.6
          Versionstabelle:
         *** 12.6 500
        pi@raspberrypi:~ $
        • D denjo
          @Thomas-Braun
          build-essential:
            Installiert:           12.6
            Versionstabelle:
           *** 12.6 500
          pi@raspberrypi:~ $
          @denjo
          apt policy libpam0g-dev
            @denjo
            denjo
            @Thomas-Braun
            pi@raspberrypi:~ $ apt policy libpam0g-dev
            libpam0g-dev:
              Installiert:           1.3.1-5+rpt2
              Installationskandidat: 1.3.1-5+rpt2
              Versionstabelle:
             *** 1.3.1-5+rpt2 500
                    500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                 1.3.1-5 500
            pi@raspberrypi:~ $
            • D denjo
              @Thomas-Braun
              libpam0g-dev:
                Versionstabelle:
                   1.3.1-5 500
              pi@raspberrypi:~ $
              @denjo
              Das passt soweit. Ich würde den Adapter allerdings nicht aus git ziehen, sondern aus dem Verwahrort 'default/stable'
                @denjo
                denjo
                @Thomas-Braun also ganz normal über adapter meinst du???
                • D denjo
                  @denjo Ja, ganz normal aus der Liste der Adapter.
                  latest:	4.2.1 for 24 days
                  stable:	4.2.1 for 24 days
                  D 4 Antworten Letzte Antwort
                    denjo
                    @Thomas-Braun mache ich gerade
                    am anfang habe ich imer ein error stehen ist das normal
                    $ ./iobroker add tr-064  --host raspberrypi
                    NPM version: 6.14.8
                    npm install iobroker.tr-064@4.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
                    J 1 Antwort Letzte Antwort
                      denjo
                      @Thomas-Braun so adapter ist wieder da und die objekte trotzdem dauert das leider ewigkeiten bis er erkennt das jemand false ist
                        denjo
                        @Thomas-Braun und jetzt war ich ca für 1 sekunde falso dann wieder true sofort wobei ich nix geändert habe. echt komisch alles
                        • D denjo
                          NPM version: 6.14.8
                          Jan1
                          @denjo sagte in Suche anwesensheits skript:
                          Das Loglevel ist auf error gestellt, also nur ne Info für Dich wie der geloggt wird, mehr ist das nicht ;)
                          Was läuft denn für ne FW auf der Fritz? Da gabs mal eine, die nervig bei der WLAN Geschichte war.
                          • J Jan1
                            denjo
                            @Jan1 7.21 und ich bin immer noch true wobei ich seit 10 min kein wlan an habe.
                            und in der fritzbox steht das
                            • D denjo
                              Jan1
                              @denjo
                              Ich bin gerade nicht zu Hause, aber in den Einstellungen des TR-064 gibts eine Option, die die Erkennung anders realisiert. Hast die angehakt?
                              7.21 ist doch ne Labor oder? Wenn schon Labor, dann wäre 7.24 aktuell.
                              Falls es mit dem TR-064 nicht klappt, versuchs mal mit dem Radar2, der macht das etwas anders und bei der Erkennung etwas schneller.
                              • J Jan1
                                @denjo
                                denjo
                                @Jan1 nur das kann man einstellen
                                • D denjo
                                  Jan1
                                  @denjo
                                  Ja und bei MDNS fehlt der Haken.
                                  Schau doch mal was da dabei steht ;)
                                  • J Jan1
                                    @denjo
                                    denjo
                                    @Jan1 keine veränderung und bei radar dauert es auch ewig, und nein 7.21 ist die aktuellste FW der fritz
                                    Albert KA 1 Antwort Letzte Antwort
                                      denjo
                                      @Thomas-Braun so also ich habe es jetzt mal beobachtet in der fritzbox. wenn ich offline gehe dann steht zwar das ich nicht mehr verbunden bin aber ich gehe erst viel später in untere offline liste
                                      • D denjo
                                        @denjo
                                        Ja, das meinte ich ja mit der längeren Verzögerung.
                                        • D denjo
                                          Albert KA Offline
                                          Albert KA Offline
                                          Albert K
                                          @denjo
                                          hast denn jetzt mal einen ping auf die fritzbox gemacht? Nur um auszuschließen dass du keine Netzwerk Latenz hast?
