  4. Windows Service startet nicht mehr
windowsadminssl
1 Beiträge 1 Kommentatoren 158 Aufrufe 1 Beobachtet
    deus82ex
    ich habe versuche SSL zu aktivieren. Nachdem ich das im Admin Adapter getan habe startet der Windows Dienst nicht mehr.
    Hat jemand eine Idee woran das liegt, bzw. wie ich die Einstellung rückgängig machen kann?
    Cannot parse "C:\Program Files (x86)\iobroker\node_modules\iobroker.vis\lib/../../iobroker.info/io-package.json": Error: ENOENT: no such file or directory, open 'C:\Program Files (x86)\iobroker\node_modules\iobroker.vis\lib/../../iobroker.info/io-package.json'
    Unknown request: {"type":"config/auth/list","id":26}
    Unknown request: {"type":"config/auth/list","id":47}
    Unknown request: {"type":"config/auth/list","id":48}
    Unknown request: {"type":"config/auth/list","id":66}
    Unknown request: {"type":"lovelace/dashboards/list","id":32}
    (node:8448) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 connect listeners added to [Socket]. Use emitter.setMaxListeners() to increase limit
    Error: listen EADDRINUSE: address already in use 0.0.0.0:1884
        at Server.setupListenHandle [as _listen2] (node:net:1285:16)
        at listenInCluster (node:net:1333:12)
        at doListen (node:net:1470:7)
        at processTicksAndRejections (node:internal/process/task_queues:81:21)
    node:internal/modules/cjs/loader:922
      throw err;
    Error: Cannot find module 'C:\Program Files (x86)\iobroker\node_modules\node-windows\lib\wrapper.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:15)
        at Function.Module._load (node:internal/modules/cjs/loader:763:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:76:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
      throw err;
      requireStack: []
      throw err;
      requireStack: []
      throw err;
      requireStack: []
      throw err;
      requireStack: []
      throw err;
      requireStack: []
    MOD-Edit: Code in code-tags gesetzt!
    Mario
