  4. Mqtt-Client | Login auf Cloudmqtt.com nicht möglich
23 Beiträge 3 Kommentatoren 3.7k Aufrufe
    Michy
    ich habe folgende Fehlermeldungen, wenn ich versuche mich mit dem Adapter "Mqtt-Client" bei CloudMqtt.com anzumelden:
    *** **TypeError: 2016-11-15 18:47:58.618 error at Manager.ondata (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
    TypeError: 2016-11-15 18:47:58.618 error at Decoder.add (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
    TypeError: 2016-11-15 18:47:58.618 error at Decoder.Emitter.emit (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    TypeError: 2016-11-15 18:47:58.618 error at Decoder. (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-11-15 18:47:58.618 error at Manager.ondecoded (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
    TypeError: 2016-11-15 18:47:58.618 error at Manager.Emitter.emit (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError: 2016-11-15 18:47:58.618 error at Manager. (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-11-15 18:47:58.618 error at Socket.onpacket (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
    TypeError: 2016-11-15 18:47:58.618 error at Socket.onack (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
    TypeError: 2016-11-15 18:47:58.618 error at Socket. (/root/node_modules/iobroker.mqtt-client/client.js:119:92)
    TypeError: 2016-11-15 18:47:58.618 error Cannot read property 'topic' of undefined
    uncaught 2016-11-15 18:47:58.610 error exception: Cannot read property 'topic' of undefined
    mqtt-client.1 2016-11-15 18:47:58.540 info starting. Version 0.3.0 in /root/node_modules/iobroker.mqtt-client****
    Kann das vielleicht an einer falschen Nodejs Version liegen? Der Mqtt-Adapter (Client/Broker) hat keine Probleme beim Login.
    Danke!
    Michy
      Pman
      Hallo, kannst du nochmal die Version 0.3.1 von Github testen?
        Michy
        werde ich gleich machen!
        Edit: Klappt wunderbar, besten Dank!
        Woran lag es jetzt?
        Micha
          Michy
          Eine Sache hätte ich noch..
          Ich versuche über MQTT - Befehle, bzw. States mit true/false zu ändern.
          In den Einstellungen des Objekts: MQTT aktiviert, einen Haken bei "publish", "subscripe", und "nur Änderungen" gesetzt
          Wenn ich jetzt an dem bestimmten Topic eine Message mit "true" oder "false" sende, ändert sich zwar der Wert in der Objektliste - in Wirklichkeit tut sich jedoch nichts.
          Muss ich evtl. in der Message einen Code verpacken, damit ich die z.B. Lampe auch tatsächlich ausschalte und sich nicht nur der Wert ändert?
          Micha
            Pman
            Hast du vielleicht "ack" ein bei den MQTT-Settings des Datenpunktes? Das müsste in diesem Fall aus sein, damit es quasi ein Befehl zum ausschalten ist. Der Adapter, welcher die Lampe schaltet sollte dann das ack auf true setzen.
              Michy
              Jo, das war es… Läuft alles danke
                Michy
                Mir ist gerade noch was aufgefallen,
                sobald ich den I/O-Broker bzw. den Adapter neu starte, verliert der Mqtt-Client seine Funktion.
                Die Message kommt an aber es tut sich nichts, die Hue bleibt aus.
                Sobald ich die Einstellungen des Werte-Objekts einmal ändere (irgendwo einen Haken raus, rein und wieder speichern)
                funktioniert alles wie gehabt. Im Log ist keine Fehlermeldung zu sehen.
                Bestimmt eine Kleinigkeit 8-)
                Micha
                  Pman
                  bitte nochmal von Github laden.
                  Danke auf jeden Fall fürs viele Testen :)
                    Michy
                    also die Einstellungen bleiben in der Ansicht so wie sie sind, gehen also "optisch" nicht verloren. Ich muss lediglich einen Haken z.B. Aktiviert raus - und wieder rein machen + Speichern. Dann funktioniert es wieder. Wenn ich jetzt mit der neuen Version 0.3.2 den Adapter neu starte, flackern die Hue Lichter einmal. Die Einstellungen gehen leider trotzdem noch verloren.
                      Pman
                      Das bekomme ich gerade nicht reproduziert. Kannst du nochmal von Github updaten und mal nachgucken was beim Adapterneustart geloggt wird?
                        Michy
                        Alles klar
                          Michy
                          Hier einmal der Log, bevor es funktioniert hat und dann nach neustarten des Adapters:
                          mqtt-client.1 2016-11-19 14:10:01.248 info connected to broker
                          mqtt-client.1 2016-11-19 14:10:00.735 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
                          mqtt-client.1 2016-11-19 14:10:00.734 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:10:00.731 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:10:00.664 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
                          mqtt-client.1 2016-11-19 14:09:56.606 info terminating
                          mqtt-client.1 2016-11-19 14:08:46.283 info subscribed to {"/Hue":0}
                          mqtt-client.1 2016-11-19 14:08:46.243 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:08:19.104 info connected to broker
                          mqtt-client.1 2016-11-19 14:08:18.594 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
                          mqtt-client.1 2016-11-19 14:08:18.594 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:08:18.590 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:08:18.530 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
                          mqtt-client.1 2016-11-19 14:08:14.377 info terminating
                          mqtt-client.1 2016-11-19 14:08:03.002 info subscribed to {"/Hue":0}
                          mqtt-client.1 2016-11-19 14:08:02.959 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:06:32.995 info connected to broker
                          mqtt-client.1 2016-11-19 14:06:32.467 info Try to connect to mqtts://IOBroker:*******************@m21.cloudmqtt.com:27200?clientId=IOBroker with lwt
                          mqtt-client.1 2016-11-19 14:06:32.466 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:06:32.463 info enabled syncing of system.adapter.hue.0.alive (publish/subscribe:true/true)
                          mqtt-client.1 2016-11-19 14:06:32.379 info starting. Version 0.3.2 in /root/node_modules/iobroker.mqtt-client
                          mqtt-client.1 2016-11-19 14:06:28.194 info terminating
                          mqtt-client.1 2016-11-19 14:06:15.583 info subscribed to {"/Hue":0}
                          mqtt-client.1 2016-11-19 14:06:15.538 info enabled syncing of hue.0.Michy_Zimmer.All.on (publish/subscribe:true/true)
                          Mir ist noch etwas aufgefallen. Die Messages kommen nach dem neu Starten trotzdem an:
                          http://www.directupload.net ~~und so sehen die Einstellungen für das Objekt aus - auch nach dem Neustart:
                          http://www.directupload.net ~~Gruß
                          Micha~~~~
                            Pman
                            Also so weit ich aus dem Log lese wird das Topic korrekt wieder abonniert nach dem Neustart. Du schreibst auch, dass die Nachrichten noch ankommen. Der Wert wird auch gesetzt, aber die Lampe nicht geschaltet oder der Wert wird schon nicht gesetzt? An irgend einer Stelle geht es anscheinend nicht weiter. Hast du mal Testweise das "nur bei Änderung" raus genommen?
                              Michy
                              Richtig, der Wert wird gesetzt aber die Lampen nicht ausgeschaltet. Auch bei "nur bei Änderungen" tritt das auf
                                Pman
                                Ich glaube ich weiß jetzt wo der Fehler lag. Du kannst nochmal die neue Version von Github testen, ich glaube allerdings, dass für diese Änderung ein neuinstallieren des Adapters notwendig sein könnte. Dazu den Adapter im Admin löschen und von Github neu installieren, nur die Instanz löschen reicht nicht.
                                  Michy
                                  So,
                                  also ich habe den Adapter komplett gelöscht (Adapterbereich, Instanzen, Objekte) und ihn dann über Github neu installiert.
                                  Danach wollte ich in den Einstellungen Mqtt-Client für das Objekt die vorherigen Einstellungen vornehmen und kann leider nicht speichern.
                                  Der Button lässt sich drücken ist aber ohne Funktion. Drücke ich speichern und dann auf das X oben rechts am Fenster sind die Einstellungen wieder weg.
                                  (Haken bei aktiviert, Topic usw. wieder auf Default)
                                  Micha
                                    Pman
                                    Hattest du den Admin mal neu geladen? Ansonsten versuch mal ein "iobroker upload mqtt-client" in der Console. Ist der Adapter schon mit einem Server verbunden?
                                      Michy
                                      Einen Schritt weiter.
                                      Ich kann auf Speichern drücken, er schließt das Fenster - speichert die Werte aber nicht.
                                        Pman
                                        Am speichern der Optionen hatte ich eigentlich gar nichts geändert :evil:
                                        Ich werde mir den Adapter auch nochmal löschen / neu installieren und gucken ob ich das reproduzieren kann.
                                          Michy
                                          @Pman:
                                          Ich werde mir den Adapter auch nochmal löschen / neu installieren und gucken ob ich das reproduzieren kann. `
                                          Nicht, das ich mir jetzt irgendetwas zerschossen habe :lol: …
                                          Die SQL-Optionen lassen sich ohne Probleme abspeichern.
