  2. English
  3. Scripting / Logic
  5. Control datapoint with Blockly SOLVED
blockly
5 Beiträge 2 Kommentatoren 1.8k Aufrufe 1 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    I need to set Boolean datapoint based on result of variable number compared with constant. Here is how I think it should work, but it does not. Datapoint does not get updated regardless of variable value. What am I doing wrong?
    • A ap2017
      @ap2017 sagte:
      So it works only at script start. You need a trigger.
      A 1 Antwort Letzte Antwort
        @ap2017 sagte:
        ap2017
        @paul53 Thank you, it works! I think that this concept is not described clearly in documentation
        • A ap2017
          @ap2017 sagte:
          Really ?
            @ap2017 sagte:
            Really ?
            ap2017
            @paul53 I miss general discussion about blocks execution, for example for repeatable action user must be using Trigger block, without Trigger block the command will be executed once on script start. This is very important in my mind.
