  4. Node-Red
  5. (Bitte um Hilfe) Switch Node Wert übernehmen klappt nicht
    6.5k
6 Beiträge 3 Kommentatoren 788 Aufrufe 3 Beobachtet
    Theo56
    schrieb am zuletzt editiert von Theo56
    Ich möchte im Zweig >= den Wert aus MaxBat übernehmen, ich denke das am Syntax was nicht stimmt.
    "id": "cd8dce56.ce8c28",
    "type": "tab",
    "label": "Flow 3",
    "disabled": false,
    "info": ""
    "id": "5fcf69d9.6b13b",
    "type": "switch",
    "z": "cd8dce56.ce8c28",
    "name": "",
    "property": "payload",
    "propertyType": "msg",
    "rules": [
    "t": "lte",
    "v": "76",
    "vt": "num"
    "t": "gte",
    "v": "({(node-red.0.UserData.MaxBat)})",
    "vt": "num"
    "checkall": "true",
    "repair": false,
    "outputs": 2,
    "x": 450,
    "y": 200,
    "wires": [
    "cfaccd95.314a98"
    "5628800a.aa224"
    "id": "cfaccd95.314a98",
    "type": "debug",
    "name": "",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "false",
    "x": 610,
    "y": 160,
    "wires": []
    "id": "5628800a.aa224",
    "type": "debug",
    "name": "",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "x": 610,
    "y": 240,
    "wires": []
    "id": "6c9c8400.163fd4",
    "type": "inject",
    "name": "",
    "topic": "",
    "payload": "90",
    "payloadType": "num",
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "x": 290,
    "y": 200,
    "wires": [
    "5fcf69d9.6b13b"
    • T Theo56
      "type": "tab",
      "label": "Flow 3",
      "disabled": false,
      "info": ""
      "type": "switch",
      "name": "",
      "rules": [
      "t": "lte",
      "v": "76",
      "vt": "num"
      "t": "gte",
      "vt": "num"
      "checkall": "true",
      "repair": false,
      "outputs": 2,
      "x": 450,
      "y": 200,
      "wires": [
      "cfaccd95.314a98"
      "5628800a.aa224"
      "type": "debug",
      "name": "",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "x": 610,
      "y": 160,
      "wires": []
      "type": "debug",
      "name": "",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "x": 610,
      "y": 240,
      "wires": []
      "type": "inject",
      "name": "",
      "topic": "",
      "payload": "90",
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "x": 290,
      "y": 200,
      "wires": [
      "5fcf69d9.6b13b"
      mickymM Offline
      mickymM Offline
      mickym
      @Theo56 Ein Switch Node verteilt nur Nachrichten.
      Im ersten Fall gibst Du 76 an Ausgang 1 aus. Die Nachricht aus Ausgang 2 willst Du in einen iobroker Datenpunkt schreiben.
      Deshalb musst Du an iobroker out node an den Ausgang 2 klemmen und Bedingung im Switch Node ist dann "Andernfalls".
      • mickymM mickym
        Theo56
        @mickym sagte in (Bitte um Hilfe) Switch Node Wert übernehmen klappt nicht:
        Sorry, ist so nicht meine Absicht,
        ich will im Ausgang 2 den Wert von IoBroker (node-red.0.UserData.MaxBat)
        eintragen um ihn dann im Node weiter zu nutzen.
        • T Theo56
          mickymM Offline
          mickymM Offline
          mickym
          @Theo56 dann nimmst keinen Switch Node- sondern eine ioBroker get node
            Seb_123
            Moin,
            soweit ich es verstanden habe, kannst du in Node-Red nicht direkt auf ioBroker-Objekte zugreifen. Du müsstest also zuerst den Wert deines ioBroker-Objektes (node-red.0.UserData.MaxBat) in Node-Red einlesen und dann dort weiterverarbeiten.
            Könnte es das sein was du benötigst?
            Du müsstest das Topic des ioBroker-get-Nodes noch anpassen.7fdb3947-aec9-40b4-8991-9320b9fec2b8-image.png
                    "id": "21bc3a0a.07fcc6",
                    "type": "inject",
                    "z": "ea637c16.c6b6f",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "90",
                    "x": 90,
                    "y": 220,
                    "wires": [
                            "958d5445.8a3ff8"
                    "id": "bc8a7625.508f58",
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "lte",
                            "v": "76",
                            "vt": "num"
                            "t": "gte",
                            "v": "MaxBat",
                            "vt": "msg"
                            "t": "else"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 3,
                    "x": 870,
                    "y": 220,
                    "wires": [
                            "914e33e6.5d56b"
                            "d07ca42.7a2ab58"
                            "97ccfc25.b4e91"
                    "id": "914e33e6.5d56b",
                    "type": "debug",
                    "name": "<=76",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "complete": "payload",
                    "targetType": "msg",
                    "statusVal": "",
                    "statusType": "auto",
                    "x": 1410,
                    "y": 180,
                    "wires": []
                    "id": "d07ca42.7a2ab58",
                    "type": "debug",
                    "name": ">= MaxBat",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1430,
                    "y": 220,
                    "wires": []
                    "id": "97ccfc25.b4e91",
                    "type": "debug",
                    "name": "alle anderen Werte ",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1450,
                    "y": 260,
                    "wires": []
                    "id": "958d5445.8a3ff8",
                    "type": "ioBroker get",
                    "name": "",
                    "topic": "0_userdata.0.MaxBat",
                    "attrname": "MaxBat",
                    "payloadType": "value",
                    "x": 320,
                    "y": 220,
                    "wires": [
                            "bc8a7625.508f58"
            • S Seb_123
              Moin,
                      "type": "inject",
                      "name": "",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "90",
                      "x": 90,
                      "y": 220,
                      "wires": [
                              "958d5445.8a3ff8"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "lte",
                              "v": "76",
                              "vt": "num"
                              "t": "gte",
                              "v": "MaxBat",
                              "vt": "msg"
                              "t": "else"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 870,
                      "y": 220,
                      "wires": [
                              "914e33e6.5d56b"
                              "d07ca42.7a2ab58"
                              "97ccfc25.b4e91"
                      "type": "debug",
                      "name": "<=76",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1410,
                      "y": 180,
                      "wires": []
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1430,
                      "y": 220,
                      "wires": []
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1450,
                      "y": 260,
                      "wires": []
                      "name": "",
                      "x": 320,
                      "y": 220,
                      "wires": [
                              "bc8a7625.508f58"
              mickymM Offline
              mickymM Offline
              mickym
              @Seb_123 @Theo56 hat wohl 2 Threads zum selben Thema geöffnet. Ich hab ihm nun in dem anderen Thread geantwortet - da er da den ganzen Flow exportiert hat - und hab den etwas angepasst. ;)
              https://forum.iobroker.net/topic/35394/was-ist-an-dem-switch-node-falsch
