  4. Netatmo-Crawler wie installieren
    5.4k
githubadapaternetatmo adapter
30 Beiträge 9 Kommentatoren 4.4k Aufrufe 7 Beobachtet
    @co_er sagte in Netatmo-Crawler wie installieren:
    Gibt es einen Zusammenhang mit der geänderten IP-Adresse?
    Möglich. Da scheint was in deinem Netzwerksetup falsch zu sein.
    Bei mir läuft es nämlich im ersten Anlauf durch:
    echad@chet:~/iob_diag $ iob add iobroker.netatmo-crawler --debug
    NPM version: 9.5.1
    Installing iobroker.netatmo-crawler@0.8.1... (System call)
    added 3 packages in 8s
    104 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter netatmo-crawler
    upload [4] netatmo-crawler.admin /opt/iobroker/node_modules/iobroker.netatmo-crawler/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] netatmo-crawler.admin /opt/iobroker/node_modules/iobroker.netatmo-crawler/admin/index_m.html index_m.html text/html
    upload [2] netatmo-crawler.admin /opt/iobroker/node_modules/iobroker.netatmo-crawler/admin/netatmo-crawler.png netatmo-crawler.png image/png
    upload [1] netatmo-crawler.admin /opt/iobroker/node_modules/iobroker.netatmo-crawler/admin/style.css style.css text/css
    upload [0] netatmo-crawler.admin /opt/iobroker/node_modules/iobroker.netatmo-crawler/admin/words.js words.js application/javascript
    host.chet object system.adapter.netatmo-crawler created/updated
    host.chet create instance netatmo-crawler
    host.chet object system.adapter.netatmo-crawler.0.alive created
    host.chet object system.adapter.netatmo-crawler.0.connected created
    host.chet object system.adapter.netatmo-crawler.0.compactMode created
    host.chet object system.adapter.netatmo-crawler.0.cpu created
    host.chet object system.adapter.netatmo-crawler.0.cputime created
    host.chet object system.adapter.netatmo-crawler.0.memHeapUsed created
    host.chet object system.adapter.netatmo-crawler.0.memHeapTotal created
    host.chet object system.adapter.netatmo-crawler.0.memRss created
    host.chet object system.adapter.netatmo-crawler.0.uptime created
    host.chet object system.adapter.netatmo-crawler.0.inputCount created
    host.chet object system.adapter.netatmo-crawler.0.outputCount created
    host.chet object system.adapter.netatmo-crawler.0.eventLoopLag created
    host.chet object system.adapter.netatmo-crawler.0.sigKill created
    host.chet object system.adapter.netatmo-crawler.0.logLevel created
    host.chet object system.adapter.netatmo-crawler.0 created
    Was ist denn da bei dir umgestellt worden? IPv6? Die Adresse kann bei dir jedenfalls nicht erreicht werden.
    co_er
    schrieb am zuletzt editiert von co_er
    Ich weiß nicht, was der Auslöser war. Ich habe lediglich an einem Tag festgestellt, dass ich mich bei ioBroker nicht anmelden konnte und die Seite nicht verfügbar war. Dann habe ich nochmal im Router nachgeschlagen und festgestellt, dass der raspberrypi eine andere Ip zugewiesen bekommen hatte. Hatte nun eine statische Zuweisung (der neuen IP) eingerichtet und dachte, damit wäre es behoben. Einwahl und Bearbeitung geht ja nun wieder, aber Installationen offenbar nicht.
    • C co_er
      Das ist ja nicht schlimm, dafür hat man ja hostnames...
      ip a
      traceroute npmjs.org
      traceroute6 npmjs.org
      sagt?
      C 1 Antwort Letzte Antwort
        ip a
        sagt?
        co_er
        @thomas-braun said in Netatmo-Crawler wie installieren:
        Kannst du das bitte mehr erläutern? Ich weiß nicht, was das meint.
        • C co_er
          @co_er
          Die drei Kommandos in dein Terminal einhacken, Ausgaben in CodeTags eingebettet hier wieder rein.
            @co_er
            co_er
            Ja, aber offenbar mache ich dabei etwas falsch 😅
            Hier meine Versuche:
            ck_smart@raspberrypi:~ $ select ip a
            -bash: syntax error near unexpected token `a'
            ck_smart@raspberrypi:~ $ select all
            > ip a
            -bash: syntax error near unexpected token `ip'
            • C co_er
              > ip a
              @co_er
              Nicht das select all.
              Das kommt machmal hier in der Darstellung so durch.
                @co_er
                co_er
                ip a
                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                    inet 127.0.0.1/8 scope host lo
                       valid_lft forever preferred_lft forever
                    inet6 ::1/128 scope host
                2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                    link/ether dc:a6:32:a4:9d:b5 brd ff:ff:ff:ff:ff:ff
                    inet 192.168.0.252/24 brd 192.168.0.255 scope global dynamic noprefixroute eth0
                       valid_lft 603519sec preferred_lft 506626sec
                    inet6 2a02:8108:8b80:15b8:30a3:52a4:b0d9:747d/128 scope global dynamic noprefixroute
                       valid_lft 301049sec preferred_lft 301049sec
                    inet6 2a02:8108:8b80:15b8:e6bf:3c8a:bb52:8627/64 scope global dynamic mngtmpaddr noprefixroute
                       valid_lft 300sec preferred_lft 300sec
                    inet6 fe80::31d6:659c:2a0b:6a76/64 scope link
                3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                    link/ether dc:a6:32:a4:9d:b6 brd ff:ff:ff:ff:ff:ff
                    inet 192.168.0.250/24 brd 192.168.0.255 scope global dynamic noprefixroute wlan0
                       valid_lft 379119sec preferred_lft 303519sec
                    inet6 2a02:8108:8b80:15b8:eca7:68d2:ed0:65d1/128 scope global dynamic noprefixroute
                       valid_lft 379121sec preferred_lft 379121sec
                    inet6 2a02:8108:8b80:15b8:6679:3:3872:197e/64 scope global dynamic mngtmpaddr noprefixroute
                    inet6 fe80::bfce:5a0:4420:fc5/64 scope link
                traceroute to npmjs.org (104.16.21.35), 30 hops max, 60 byte packets
                 1  kabelbox (192.168.0.1)  1.458 ms  1.575 ms  1.735 ms
                 2  * * *
                 3  ip5886cb89.static.kabel-deutschland.de (88.134.203.137)  12.183 ms ip5886cb7f.static.kabel-deutschland.de (88.134.203.127)  12.175 ms ip5886cb89.static.kabel-deutschland.de (88.134.203.137)  17.758 ms
                 4  145.254.3.72 (145.254.3.72)  17.786 ms  17.675 ms  17.580 ms
                 5  198.41.240.18 (198.41.240.18)  20.204 ms  22.238 ms  22.247 ms
                 6  198.41.240.18 (198.41.240.18)  22.260 ms  22.223 ms  21.710 ms
                 7  104.16.21.35 (104.16.21.35)  21.572 ms  20.347 ms  20.330 ms
                traceroute to npmjs.org (2606:4700::6810:1823), 30 hops max, 80 byte packets
                 1  * * *
                 2  * * *
                 3  * * *
                 4  * * *
                 5  * * *
                 6  * * *
                 7  * * *
                 8  * * *
                 9  * * *
                10  * * *
                11  * * *
                12  * * *
                13  * * *
                14  * * *
                15  * * *
                16  * * *
                17  * * *
                18  * * *
                19  * * *
                20  * * *
                21  * * *
                22  * * *
                23  * * *
                24  * * *
                25  * * *
                26  * * *
                27  * * *
                28  * * *
                29  * * *
                30  * * *
                • C co_er
                  ip a
                   2  * * *
                   1  * * *
                   2  * * *
                   3  * * *
                   4  * * *
                   5  * * *
                   6  * * *
                   7  * * *
                   8  * * *
                   9  * * *
                  10  * * *
                  11  * * *
                  12  * * *
                  13  * * *
                  14  * * *
                  15  * * *
                  16  * * *
                  17  * * *
                  18  * * *
                  19  * * *
                  20  * * *
                  21  * * *
                  22  * * *
                  23  * * *
                  24  * * *
                  25  * * *
                  26  * * *
                  27  * * *
                  28  * * *
                  29  * * *
                  30  * * *
                  @co_er
                  Bitte die Befehle immer inkl. der kompletten Eingabe-Zeile zeigen, damit man sich orientieren kann wo was aufhört und wo was anfängt...
                  Über IPv6 wird also nicht geroutet.
                    @co_er
                    co_er
                    Keine Idee oder Anregung, was die Netzwerkeinstellungen betrifft und damit das Timeout verursachen könnte?
                    Ich habe ansonsten mit dem Netzwerk keine Probleme. Daher würde ich annehmen, dass es einen direkten Bezug zu meinem ioBroker Setup haben müsste. Nur, dass es bis vor Kurzem keine Probleme bei der Installation von Adaptern gab.
                    • C co_er
                      @co_er
                      Nö, bin aber auch kein Netzwerk-Spezi.
                      Dein System versucht jedenfalls die Installation via ipv6, die wird aber nicht geroutet.
