  4. Javascript update fehler?
3 Beiträge 2 Kommentatoren 834 Aufrufe
    rascal
    hey,
    beim letzten update hat er mir auf einem Rasp 3 im Multihost Modus folgende Fehler ausgegeben, er zeigt die neue Version als installiert an:
    javascript-2	2016-10-02 18:27:09.480	info	received all objects
    javascript-2	2016-10-02 18:27:08.329	info	received all states
    javascript-2	2016-10-02 18:27:06.844	info	requesting all objects
    javascript-2	2016-10-02 18:27:06.841	info	requesting all states
    javascript-2	2016-10-02 18:27:06.795	info	└── bluetooth-hci-socket@0.5.1 (nan@2.4.0, usb@1.2.0)
    javascript-2	2016-10-02 18:27:06.795	info	├── debug@2.2.0 (ms@0.7.1)
    javascript-2	2016-10-02 18:27:06.795	info	├── bplist-parser@0.0.6
    javascript-2	2016-10-02 18:27:06.795	info	noble@1.7.0 opt/iobroker/node_modules/iobroker.javascript/node_modules/noble
    javascript-2	2016-10-02 18:27:04.570	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    javascript-2	2016-10-02 18:27:04.552	info	COPY Release/binding.node
    javascript-2	2016-10-02 18:27:04.277	info	SOLINK_MODULE(target) Release/obj.target/binding.node
    javascript-2	2016-10-02 18:26:59.626	info	CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
    javascript-2	2016-10-02 18:26:59.622	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    javascript-2	2016-10-02 18:26:57.307	info	> node-gyp rebuild
    javascript-2	2016-10-02 18:26:57.307	info	> bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket
    javascript-2	2016-10-02 18:26:57.250	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    javascript-2	2016-10-02 18:26:57.238	info	TOUCH Release/obj.target/action_after_build.stamp
    javascript-2	2016-10-02 18:26:57.215	info	COPY /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/src/binding/usb_bindings.node
    javascript-2	2016-10-02 18:26:57.193	info	COPY Release/usb_bindings.node
    javascript-2	2016-10-02 18:26:56.824	info	SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
    javascript-2	2016-10-02 18:26:52.705	info	CXX(target) Release/obj.target/usb_bindings/src/transfer.o
    javascript-2	2016-10-02 18:26:45.353	info	CXX(target) Release/obj.target/usb_bindings/src/device.o
    javascript-2	2016-10-02 18:26:39.932	info	CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
    javascript-2	2016-10-02 18:26:39.909	info	COPY Release/usb.a
    javascript-2	2016-10-02 18:26:39.879	info	AR(target) Release/obj.target/usb.a
    javascript-2	2016-10-02 18:26:35.337	info	CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
    javascript-2	2016-10-02 18:26:21.374	info	CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
    javascript-2	2016-10-02 18:26:21.180	info	CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
    javascript-2	2016-10-02 18:26:20.940	info	CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
    javascript-2	2016-10-02 18:26:20.521	info	CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
    javascript-2	2016-10-02 18:26:20.245	info	CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
    javascript-2	2016-10-02 18:26:18.768	info	CC(target) Release/obj.target/libusb/libusb/libusb/io.o
    javascript-2	2016-10-02 18:26:18.321	info	CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
    javascript-2	2016-10-02 18:26:16.867	info	CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
    javascript-2	2016-10-02 18:26:14.433	info	CC(target) Release/obj.target/libusb/libusb/libusb/core.o
    javascript-2	2016-10-02 18:26:14.427	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    javascript-2	2016-10-02 18:26:09.391	error	node-pre-gyp ERR! Pre-built binaries not found for usb@1.2.0 and node@4.4.7 (node-v46 ABI) (falling back to source compile with node-gyp)
    javascript-2	2016-10-02 18:26:09.391	error	ERR! Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v46-linux-arm.tar.gz
    javascript-2	2016-10-02 18:26:09.390	error	node-pre-gyp
    javascript-2	2016-10-02 18:26:06.959	info	> node-pre-gyp install --fallback-to-build
    javascript-2	2016-10-02 18:26:06.959	info	> usb@1.2.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
    javascript-2	2016-10-02 18:25:52.938	error	WARN optional dep failed, continuing xpc-connection@0.1.4
    javascript-2	2016-10-02 18:25:52.937	error
    javascript-2	2016-10-02 18:25:52.935	error	npm
    javascript-2	2016-10-02 18:25:43.195	info	npm install noble --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
    javascript-2	2016-10-02 18:25:43.183	info	starting. Version 3.0.10 in /opt/iobroker/node_modules/iobroker.javascript
    host-	2016-10-02 18:25:43.117	info	States connected to redis 192.168.1.10:6379
    • apollon77A Offline
      sollte eigentlich sagen das er es selbst komppiliert … also an sich alles ok.
      Funktioniert alles?
        rascal
        Ja, sonst passt alles
        Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
