  4. Motio Eye & IoB
    5.6k
Motio Eye & IoB
motion-eye
6 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    bob der 1.
    ich will meine Foscams über Motioneye in mein Vis einbinden.
    Leider scheitert es schon an der Installation,ich gehe nach dieser Anleitung vor https://wiki.instar.de/Erweitert/IOBroker_auf_Raspberry_Pi/motionEye/
    ich bekomme Motion eye einfach nich neben IOB installiert und muss sagen das ich mit meinem Latain am ende bin.
    Anbei meine Istallation und die Fehler die auftauchen
    pi@raspberrypi:~ $ sudo apt-get install ffmpeg v4l-utils
    Reading package lists... Done
    Building dependency tree
    v4l-utils is already the newest version (1.16.3-3).
    ffmpeg is already the newest version (7:4.1.4-1+rpt7~deb10u1).
    0 upgraded, 0 newly installed, 0 to remove and 132 not upgraded.
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo apt-get install libmariadbclient18 libpq5
    Package libmariadbclient18 is not available, but is referred to by another packa        ge.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    However the following packages replace it:
      libmariadb3
    E: Package 'libmariadbclient18' has no installation candidate
    pi@raspberrypi:~ $ wget https://github.com/Motion-Project/motion/releases/downlo        ad/release-4.1.1/pi_stretch_motion_4.1.1-1_armhf.deb
    --2020-07-02 17:47:12--  https://github.com/Motion-Project/motion/releases/downl        oad/release-4.1.1/pi_stretch_motion_4.1.1-1_armhf.deb
    Resolving github.com (github.com)... 140.82.118.3
    Connecting to github.com (github.com)|140.82.118.3|:443... connected.
    HTTP request sent, awaiting response... 302 Found
    Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/208226        20/c4cfe26a-ddca-11e7-87cc-4c84bdcc0f29?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-C        redential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-        Date=20200702T154713Z&X-Amz-Expires=300&X-Amz-Signature=5aded929a336453016bca16b        2ab2b1a6bf6295c5e0a1b3b2bd80dd2dfb0b516b&X-Amz-SignedHeaders=host&actor_id=0&rep        o_id=20822620&response-content-disposition=attachment%3B%20filename%3Dpi_stretch        _motion_4.1.1-1_armhf.deb&response-content-type=application%2Foctet-stream [foll        owing]
    --2020-07-02 17:47:13--  https://github-production-release-asset-2e65be.s3.amazo        naws.com/20822620/c4cfe26a-ddca-11e7-87cc-4c84bdcc0f29?X-Amz-Algorithm=AWS4-HMAC        -SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4        _request&X-Amz-Date=20200702T154713Z&X-Amz-Expires=300&X-Amz-Signature=5aded929a        336453016bca16b2ab2b1a6bf6295c5e0a1b3b2bd80dd2dfb0b516b&X-Amz-SignedHeaders=host        &actor_id=0&repo_id=20822620&response-content-disposition=attachment%3B%20filena        me%3Dpi_stretch_motion_4.1.1-1_armhf.deb&response-content-type=application%2Foct        et-stream
    Resolving github-production-release-asset-2e65be.s3.amazonaws.com (github-produc        tion-release-asset-2e65be.s3.amazonaws.com)... 52.216.241.100
    Connecting to github-production-release-asset-2e65be.s3.amazonaws.com (github-pr        oduction-release-asset-2e65be.s3.amazonaws.com)|52.216.241.100|:443... connected        .
    HTTP request sent, awaiting response... 200 OK
    Length: 282082 (275K) [application/octet-stream]
    Saving to: ‘pi_stretch_motion_4.1.1-1_armhf.deb’
    pi_stretch_motion_4 100%[===================>] 275.47K   694KB/s    in 0.4s
    2020-07-02 17:47:14 (694 KB/s) - ‘pi_stretch_motion_4.1.1-1_armhf.deb’ saved [28        2082/282082]
    pi@raspberrypi:~ $ sudo dpkg -i pi_stretch_motion_4.1.1-1_armhf.deb
    Selecting previously unselected package motion.
    (Reading database ... 100903 files and directories currently installed.)
    Preparing to unpack pi_stretch_motion_4.1.1-1_armhf.deb ...
    Unpacking motion (4.1.1-1) ...
    dpkg: dependency problems prevent configuration of motion:
     motion depends on libavcodec57 (>= 7:3.2.9) | libavcodec-extra57 (>= 7:3.2.9);        however:
      Package libavcodec57 is not installed.
      Package libavcodec-extra57 is not installed.
     motion depends on libavdevice57 (>= 7:3.2.9); however:
      Package libavdevice57 is not installed.
     motion depends on libavformat57 (>= 7:3.2.9); however:
      Package libavformat57 is not installed.
     motion depends on libavutil55 (>= 7:3.2.9); however:
      Package libavutil55 is not installed.
     motion depends on libmariadbclient18 (>= 5.5.36); however:
      Package libmariadbclient18 is not installed.
     motion depends on libpq5; however:
      Package libpq5 is not installed.
     motion depends on libswscale4 (>= 7:3.2.9); however:
      Package libswscale4 is not installed.
    dpkg: error processing package motion (--install):
     dependency problems - leaving unconfigured
    Processing triggers for systemd (241-7~deb10u2+rpi1) ...
    Processing triggers for man-db (2.8.5-2) ...
    Errors were encountered while processing:
     motion
    pi@raspberrypi:~ $  apt-get install ffmpeg libmariadb3 libpq5 libmicrohttpd12
    E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission d        enied)
    E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are y        ou root?
    pi@raspberrypi:~ $  wget https://github.com/Motion-Project/motion/releases/downl        oad/release-4.2.2/pi_buster_motion_4.2.2-1_armhf.deb
    --2020-07-02 17:48:21--  https://github.com/Motion-Project/motion/releases/downl        oad/release-4.2.2/pi_buster_motion_4.2.2-1_armhf.deb
    Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/208226        20/77fdcb80-bc14-11e9-81f5-70e7bfc5bdfb?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-C        redential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-        Date=20200702T154624Z&X-Amz-Expires=300&X-Amz-Signature=ffbe4f9b7c03029c23462eab        eb412aa5c94f758cefdaec0649dbb66f08905325&X-Amz-SignedHeaders=host&actor_id=0&rep        o_id=20822620&response-content-disposition=attachment%3B%20filename%3Dpi_buster_        motion_4.2.2-1_armhf.deb&response-content-type=application%2Foctet-stream [follo        wing]
    --2020-07-02 17:48:21--  https://github-production-release-asset-2e65be.s3.amazo        naws.com/20822620/77fdcb80-bc14-11e9-81f5-70e7bfc5bdfb?X-Amz-Algorithm=AWS4-HMAC        -SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4        _request&X-Amz-Date=20200702T154624Z&X-Amz-Expires=300&X-Amz-Signature=ffbe4f9b7        c03029c23462eabeb412aa5c94f758cefdaec0649dbb66f08905325&X-Amz-SignedHeaders=host        &actor_id=0&repo_id=20822620&response-content-disposition=attachment%3B%20filena        me%3Dpi_buster_motion_4.2.2-1_armhf.deb&response-content-type=application%2Focte        t-stream
    Length: 312748 (305K) [application/octet-stream]
    Saving to: ‘pi_buster_motion_4.2.2-1_armhf.deb’
    pi_buster_motion_4. 100%[===================>] 305.42K   738KB/s    in 0.4s
    2020-07-02 17:48:22 (738 KB/s) - ‘pi_buster_motion_4.2.2-1_armhf.deb’ saved [312        748/312748]
    pi@raspberrypi:~ $  dpkg -i pi_buster_motion_4.2.2-1_armhf.deb
    dpkg: error: requested operation requires superuser privilege
    --2020-07-02 17:48:50--  https://github.com/Motion-Project/motion/releases/downl        oad/release-4.2.2/pi_buster_motion_4.2.2-1_armhf.deb
    Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/208226        20/77fdcb80-bc14-11e9-81f5-70e7bfc5bdfb?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-C        redential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-        Date=20200702T154850Z&X-Amz-Expires=300&X-Amz-Signature=c5be105e65b5a171b6a564a0        f7e13fdf3cb709216c2f613a743b09d1bc99f73e&X-Amz-SignedHeaders=host&actor_id=0&rep        o_id=20822620&response-content-disposition=attachment%3B%20filename%3Dpi_buster_        motion_4.2.2-1_armhf.deb&response-content-type=application%2Foctet-stream [follo        wing]
    --2020-07-02 17:48:50--  https://github-production-release-asset-2e65be.s3.amazo        naws.com/20822620/77fdcb80-bc14-11e9-81f5-70e7bfc5bdfb?X-Amz-Algorithm=AWS4-HMAC        -SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20200702%2Fus-east-1%2Fs3%2Faws4        _request&X-Amz-Date=20200702T154850Z&X-Amz-Expires=300&X-Amz-Signature=c5be105e6        5b5a171b6a564a0f7e13fdf3cb709216c2f613a743b09d1bc99f73e&X-Amz-SignedHeaders=host        &actor_id=0&repo_id=20822620&response-content-disposition=attachment%3B%20filena        me%3Dpi_buster_motion_4.2.2-1_armhf.deb&response-content-type=application%2Focte        t-stream
    Saving to: ‘pi_buster_motion_4.2.2-1_armhf.deb.1’
    pi_buster_motion_4. 100%[===================>] 305.42K   728KB/s    in 0.4s
    2020-07-02 17:48:51 (728 KB/s) - ‘pi_buster_motion_4.2.2-1_armhf.deb.1’ saved [3        12748/312748]
    pi@raspberrypi:~ $ sudo  dpkg -i pi_buster_motion_4.2.2-1_armhf.deb
    (Reading database ... 100939 files and directories currently installed.)
    Preparing to unpack pi_buster_motion_4.2.2-1_armhf.deb ...
    Unpacking motion (4.2.2-1) over (4.1.1-1) ...
     motion depends on libmariadb3 (>= 3.0.0); however:
      Package libmariadb3 is not installed.
     motion depends on libmicrohttpd12 (>= 0.9.50); however:
      Package libmicrohttpd12 is not installed.
     motion
    pi@raspberrypi:~ $ apt-get install python-pip python-dev libssl-dev libcurl4-ope        nssl-dev libjpeg-dev libz-dev
    pi@raspberrypi:~ $ sudo apt-get install python-pip python-dev libssl-dev libcurl        4-openssl-dev libjpeg-dev libz-dev
    Note, selecting 'zlib1g-dev' instead of 'libz-dev'
    libjpeg-dev is already the newest version (1:1.5.2-2).
    python-dev is already the newest version (2.7.16-1).
    python-dev set to manually installed.
    zlib1g-dev is already the newest version (1:1.2.11.dfsg-1).
    zlib1g-dev set to manually installed.
    python-pip is already the newest version (18.1-5+rpt1).
    You might want to run 'apt --fix-broken install' to correct these.
    The following packages have unmet dependencies:
     libcurl4-openssl-dev : Depends: libcurl4 (= 7.64.0-4+deb10u1) but 7.64.0-4 is t        o be installed
     libssl-dev : Depends: libssl1.1 (= 1.1.1d-0+deb10u3+rpt1) but 1.1.1d-0+deb10u2+        rpt1 is to be installed
     motion : Depends: libmariadb3 (>= 3.0.0) but it is not going to be installed
              Depends: libmicrohttpd12 (>= 0.9.50) but it is not going to be install        ed
              Depends: libpq5 but it is not going to be installed
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or speci        fy a solution).
    pi@raspberrypi:~ $  pip install motioneye
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
    Collecting motioneye
      Downloading https://files.pythonhosted.org/packages/c5/ff/139b4b02ed089b2b50ee        e65d1059ae0d29064ab5f4ad429e45c702396697/motioneye-0.42.1.tar.gz (758kB)
        100% |████████████████████████████████| 768kB 483kB/s
    Requirement already satisfied: jinja2 in /usr/lib/python2.7/dist-packages (from        motioneye) (2.10)
    Requirement already satisfied: pillow in /usr/lib/python2.7/dist-packages (from        motioneye) (5.4.1)
    Collecting pycurl (from motioneye)
      Downloading https://files.pythonhosted.org/packages/ef/05/4b773f74f830a90a326b        06f9b24e65506302ab049e825a3c0b60b1a6e26a/pycurl-7.43.0.5.tar.gz (216kB)
        100% |████████████████████████████████| 225kB 1.5MB/s
        Complete output from command python setup.py egg_info:
        Traceback (most recent call last):
          File "<string>", line 1, in <module>
          File "/tmp/pip-install-bpuipw/pycurl/setup.py", line 961, in <module>
            ext = get_extension(sys.argv, split_extension_source=split_extension_sou        rce)
          File "/tmp/pip-install-bpuipw/pycurl/setup.py", line 623, in get_extension
            ext_config = ExtensionConfiguration(argv)
          File "/tmp/pip-install-bpuipw/pycurl/setup.py", line 101, in __init__
            self.configure()
          File "/tmp/pip-install-bpuipw/pycurl/setup.py", line 238, in configure_uni        x
            raise ConfigurationError(msg)
        __main__.ConfigurationError: Could not run curl-config: [Errno 2] No such fi        le or directory
    Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-        bpuipw/pycurl/
    pi@raspberrypi:~ $  mkdir -p /etc/motioneye
    mkdir: cannot create directory ‘/etc/motioneye’: Permission denied
    pi@raspberrypi:~ $ sudo  mkdir -p /etc/motioneye
    pi@raspberrypi:~ $ cp /usr/local/share/motioneye/extra/motioneye.conf.sample /et        c/motioneye/motioneye.conf
    cp: cannot stat '/usr/local/share/motioneye/extra/motioneye.conf.sample': No suc        h file or directory
    pi@raspberrypi:~ $ sudo cp /usr/local/share/motioneye/extra/motioneye.conf.sampl        e /etc/motioneye/motioneye.conf
    pi@raspberrypi:~ $ mkdir -p /var/lib/motioneye
    mkdir: cannot create directory ‘/var/lib/motioneye’: Permission denied
    pi@raspberrypi:~ $ sudo mkdir -p /var/lib/motioneye
    pi@raspberrypi:~ $  cp /usr/local/share/motioneye/extra/motioneye.systemd-unit-l        ocal /etc/systemd/system/motioneye.service
    cp: cannot stat '/usr/local/share/motioneye/extra/motioneye.systemd-unit-local':        No such file or directory
    pi@raspberrypi:~ $ sudo  cp /usr/local/share/motioneye/extra/motioneye.systemd-u        nit-local /etc/systemd/system/motioneye.service
    pi@raspberrypi:~ $ sudo systemctl daemon-reload
    pi@raspberrypi:~ $ systemctl enable motioneye
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
    Authentication is required to manage system service or unit files.
    Multiple identities can be used for authentication:
     1.  ,,, (pi)
     2.  root
    Choose identity to authenticate as (1-2): sudo systemctl enable motioneye
    Invalid response `sudo systemctl enable motioneye'.
    ==== AUTHENTICATION CANCELED ===
    Failed to enable unit: Access denied
    pi@raspberrypi:~ $ sudo systemctl enable motioneye
    Failed to enable unit: Unit file motioneye.service does not exist.
    pi@raspberrypi:~ $ apt --fix-broken install
    pi@raspberrypi:~ $ sudo apt --fix-broken install
    Correcting dependencies... Done
    The following additional packages will be installed:
      libmariadb3 libmicrohttpd12 libpq5 mariadb-common mysql-common
    The following NEW packages will be installed:
    0 upgraded, 5 newly installed, 0 to remove and 132 not upgraded.
    1 not fully installed or removed.
    Need to get 435 kB of archives.
    After this operation, 1,417 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf mysq        l-common all 5.8+1.0.5 [7,324 B]
    Get:2 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf mari        adb-common all 1:10.3.22-0+deb10u1 [31.9 kB]
    Get:4 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian b        uster/main armhf libmicrohttpd12 armhf 0.9.62-1 [86.6 kB]
    Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libm        ariadb3 armhf 1:10.3.22-0+deb10u1 [158 kB]
    Get:5 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libp        q5 armhf 11.7-0+deb10u1 [151 kB]
    Fetched 435 kB in 1s (296 kB/s)
    Selecting previously unselected package mysql-common.
    (Reading database ... 100957 files and directories currently installed.)
    Preparing to unpack .../mysql-common_5.8+1.0.5_all.deb ...
    Unpacking mysql-common (5.8+1.0.5) ...
    Selecting previously unselected package mariadb-common.
    Preparing to unpack .../mariadb-common_1%3a10.3.22-0+deb10u1_all.deb ...
    Unpacking mariadb-common (1:10.3.22-0+deb10u1) ...
    Selecting previously unselected package libmariadb3:armhf.
    Preparing to unpack .../libmariadb3_1%3a10.3.22-0+deb10u1_armhf.deb ...
    Unpacking libmariadb3:armhf (1:10.3.22-0+deb10u1) ...
    Selecting previously unselected package libmicrohttpd12.
    Preparing to unpack .../libmicrohttpd12_0.9.62-1_armhf.deb ...
    Unpacking libmicrohttpd12 (0.9.62-1) ...
    Selecting previously unselected package libpq5:armhf.
    Preparing to unpack .../libpq5_11.7-0+deb10u1_armhf.deb ...
    Unpacking libpq5:armhf (11.7-0+deb10u1) ...
    Setting up mysql-common (5.8+1.0.5) ...
    update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.c        nf (my.cnf) in auto mode
    Setting up libpq5:armhf (11.7-0+deb10u1) ...
    Setting up libmicrohttpd12 (0.9.62-1) ...
    Setting up mariadb-common (1:10.3.22-0+deb10u1) ...
    update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (        my.cnf) in auto mode
    Setting up libmariadb3:armhf (1:10.3.22-0+deb10u1) ...
    Setting up motion (4.2.2-1) ...
    Adding group `motion' (GID 115) ...
    Done.
    Warning: The home dir /var/lib/motion you specified already exists.
    Adding system user `motion' (UID 110) ...
    Adding new user `motion' (UID 110) with group `motion' ...
    The home directory `/var/lib/motion' already exists.  Not copying from `/etc/ske        l'.
    adduser: Warning: The home directory `/var/lib/motion' does not belong to the us        er you are currently creating.
    Adding user `motion' to group `video' ...
    Adding user motion to group video
    Done.
    Processing triggers for libc-bin (2.28-10+rpi1) ...
    pi@raspberrypi:~ $ sudo pip install motioneye
        100% |████████████████████████████████| 768kB 456kB/s
          File "/tmp/pip-install-0WClpT/pycurl/setup.py", line 961, in <module>
          File "/tmp/pip-install-0WClpT/pycurl/setup.py", line 623, in get_extension
          File "/tmp/pip-install-0WClpT/pycurl/setup.py", line 101, in __init__
            self.configure()
          File "/tmp/pip-install-0WClpT/pycurl/setup.py", line 238, in configure_uni        x
    Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-        0WClpT/pycurl/
    pi@raspberrypi:~ $ sudo cp /usr/local/share/motioneye/extra/motioneye.systemd-un        it-local /etc/systemd/system/motioneye.service
    pi@raspberrypi:~ $ sudo systemctl start motioneye
    Failed to start motioneye.service: Unit motioneye.service not found.
    pi@raspberrypi:~ $ sudo pip install motioneye --upgrade
      Using cached https://files.pythonhosted.org/packages/c5/ff/139b4b02ed089b2b50e        ee65d1059ae0d29064ab5f4ad429e45c702396697/motioneye-0.42.1.tar.gz
    Requirement already satisfied, skipping upgrade: jinja2 in /usr/lib/python2.7/di        st-packages (from motioneye) (2.10)
    Requirement already satisfied, skipping upgrade: pillow in /usr/lib/python2.7/di        st-packages (from motioneye) (5.4.1)
      Using cached https://files.pythonhosted.org/packages/ef/05/4b773f74f830a90a326        b06f9b24e65506302ab049e825a3c0b60b1a6e26a/pycurl-7.43.0.5.tar.gz
          File "/tmp/pip-install-5sBgY4/pycurl/setup.py", line 961, in <module>
          File "/tmp/pip-install-5sBgY4/pycurl/setup.py", line 623, in get_extension
          File "/tmp/pip-install-5sBgY4/pycurl/setup.py", line 101, in __init__
            self.configure()
          File "/tmp/pip-install-5sBgY4/pycurl/setup.py", line 238, in configure_uni        x
    Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-        5sBgY4/pycurl/
    pi@raspberrypi:~ $ sudo systemctl restart motioneye
    Failed to restart motioneye.service: Unit motioneye.service not found.
    pi@raspberrypi:~ $
    Wäre nett wenn da mal jemand drüberschaut
    • B bob der 1.
      pi@raspberrypi:~ $
        libmariadb3
       motion
       motion
              self.configure()
       1.  ,,, (pi)
       2.  root
      Done.
      Done.
              self.configure()
              self.configure()
      pi@raspberrypi:~ $
      crunchipC Abwesend
      crunchipC Abwesend
      @bob-der-1 warum nimmst du nicht die offizielle Anleitung
      B 1 Antwort Letzte Antwort
        bob der 1.
        schrieb am zuletzt editiert von bob der 1.
        @crunchip
        Weil das genau den selben effekt hat.
        Im endeffekt habe dir dann auch probiert und es ist genau das gleiche.
        • B bob der 1.
          @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          @bob-der-1 glaube ich nicht
          zuerst mal das System auf den neusten Stand bringen
          und dann sollte man beachten
          All commands require root; use sudo before each command or become root using sudo -i.
          note: Raspbian Buster comes with motion version 4.1; it is however recommended that you install version 4.2, as indicated above
            bob der 1.
            @crunchip
            Ok,ich gehe sofort los ins Büro und versuche es erneut.
            Gut das es an mir liegen soll......das kann man ja verbessern😎
            • B bob der 1.
              @crunchip
              bob der 1.
              @bob-der-1
              Endschuldige aber ich weis nun was es ist...........
              zuerst mal das System auf den neusten Stand bringen.......
              Das habe ich vergessen,lief sofort durch.Das ist mein Testsystem und ich habe das Backup des Produktivsystems eingespielt auf ein jungfräuliches Buster! aber weder update noch upgrade gemacht.
              DANKE, manchmal ist der wald vor lauter bäumen nicht zu sehen,oder ich bin doch zu alt :-)
