  4. Falsche repository
Falsche repository
repository
50 Beiträge 4 Kommentatoren 2.7k Aufrufe 2 Beobachtet
    @zgadgeter
    Als root:
    usermod -aG sudo tyrone
    Dr. BakteriusD Offline
    Dr. Bakterius
    #41
    @Thomas-Braun sagte in Falsche repository:
    Man meldet sich einfach NIE als root an.
    Als root:
    Ach ja... 😆
      @zgadgeter
      Mal mal ein zweites Terminal auf:
      tail -f /opt/iobroker/log/iobroker.current.log
      Und dann schaust du, was da passiert, wenn im anderen Terminal der iobroker gestartet wird:
      iobroker restart
      Z Offline
      Z Offline
      zgadgeter
      #42
      @Thomas-Braun said in Falsche repository:
      @zgadgeter
      iobroker restart
      ok, verstehen tuh ich da wenig....
      tyrone@Iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log
      2020-05-30 18:47:35.195  - info: host.Iobroker instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2020-05-30 18:47:35.197  - info: host.Iobroker instance system.adapter.text2command.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2020-05-30 18:47:35.199  - info: host.Iobroker instance system.adapter.proxmox.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2020-05-30 18:47:35.203  - info: host.Iobroker stopInstance system.adapter.enigma2.0 killing pid 2792
      2020-05-30 18:47:35.245  - warn: host.Iobroker instance system.adapter.enigma2.0 terminated due to SIGTERM
      2020-05-30 18:47:35.246  - info: host.Iobroker instance system.adapter.enigma2.0 terminated with code null ()
      2020-05-30 18:47:35.247  - info: history.0 (2641) Terminated (NO_ERROR): Without reason
      2020-05-30 18:47:35.776  - info: host.Iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2020-05-30 18:47:35.777  - info: host.Iobroker All instances are stopped.
      2020-05-30 18:47:36.105  - info: host.Iobroker terminated
      2020-05-30 18:48:14.453  - info: host.Iobroker iobroker.js-controller version 3.1.4 js-controller starting
      2020-05-30 18:48:14.467  - info: host.Iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-05-30 18:48:14.469  - info: host.Iobroker hostname: Iobroker, node: v10.20.1
      2020-05-30 18:48:14.473  - info: host.Iobroker ip addresses: 192.168.178.11 2003:dc:6704:1f00:8846:3dff:fe6e:ddbf fe80::8846:3dff:fe6e:ddbf
      2020-05-30 18:48:16.413  - info: host.Iobroker connected to Objects and States
      2020-05-30 18:48:16.903  - info: host.Iobroker 41 instances found
      2020-05-30 18:48:16.989  - info: host.Iobroker starting 31 instances
      2020-05-30 18:48:17.063  - info: host.Iobroker instance system.adapter.admin.0 started with pid 2838
      2020-05-30 18:48:20.532  - info: admin.0 (2838) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:20.610  - info: admin.0 (2838) requesting all states
      2020-05-30 18:48:20.611  - info: admin.0 (2838) requesting all objects
      2020-05-30 18:48:21.086  - info: host.Iobroker instance system.adapter.admin.1 started with pid 2853
      2020-05-30 18:48:24.770  - info: admin.0 (2838) received all objects
      2020-05-30 18:48:25.071  - info: host.Iobroker instance system.adapter.ping.0 started with pid 2864
      2020-05-30 18:48:24.938  - info: admin.0 (2838) http server listening on port 8081
      2020-05-30 18:48:24.939  - info: admin.0 (2838) Use link "http://localhost:8081" to configure.
      2020-05-30 18:48:25.491  - error: admin.0 (2838) uncaught exception: Invalid Version: npm error
      2020-05-30 18:48:25.502  - error: admin.0 (2838) TypeError: Invalid Version: npm error
          at new SemVer (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:332:11)
          at compare (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:647:39)
          at Function.gt (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:683:10)
          at upToDate (/opt/iobroker/node_modules/iobroker.admin/main.js:223:16)
          at Object.keys.forEach.name (/opt/iobroker/node_modules/iobroker.admin/main.js:268:22)
          at Array.forEach (<anonymous>)
          at adapter.getState (/opt/iobroker/node_modules/iobroker.admin/main.js:265:30)
          at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2020-05-30 18:48:25.506  - info: admin.0 (2838) terminating http server on port 8081
      2020-05-30 18:48:25.579  - info: admin.0 (2838) terminating
      2020-05-30 18:48:25.582  - info: admin.0 (2838) Terminated (NO_ERROR): Without reason
      2020-05-30 18:48:25.788  - info: admin.1 (2853) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:25.939  - info: admin.1 (2853) requesting all states
      2020-05-30 18:48:25.967  - info: admin.1 (2853) requesting all objects
      2020-05-30 18:48:26.029  - error: host.Iobroker Caught by controller[0]: TypeError: Invalid Version: npm error
      2020-05-30 18:48:26.032  - error: host.Iobroker Caught by controller[0]:     at new SemVer (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:332:11)
      2020-05-30 18:48:26.032  - error: host.Iobroker Caught by controller[0]:     at compare (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:647:39)
      2020-05-30 18:48:26.034  - error: host.Iobroker Caught by controller[0]:     at Function.gt (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:683:10)
      2020-05-30 18:48:26.034  - error: host.Iobroker Caught by controller[0]:     at upToDate (/opt/iobroker/node_modules/iobroker.admin/main.js:223:16)
      2020-05-30 18:48:26.035  - error: host.Iobroker Caught by controller[0]:     at Object.keys.forEach.name (/opt/iobroker/node_modules/iobroker.admin/main.js:268:22)
      2020-05-30 18:48:26.035  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2020-05-30 18:48:26.036  - error: host.Iobroker Caught by controller[0]:     at adapter.getState (/opt/iobroker/node_modules/iobroker.admin/main.js:265:30)
      2020-05-30 18:48:26.036  - error: host.Iobroker Caught by controller[0]:     at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
      2020-05-30 18:48:26.037  - error: host.Iobroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2020-05-30 18:48:26.037  - error: host.Iobroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2020-05-30 18:48:26.047  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2020-05-30 18:48:26.048  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
      2020-05-30 18:48:28.366  - info: ping.0 (2864) starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.ping, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:28.390  - info: admin.1 (2853) received all objects
      2020-05-30 18:48:28.605  - info: admin.1 (2853) http server listening on port 8099
      2020-05-30 18:48:28.606  - info: admin.1 (2853) Use link "http://localhost:8099" to configure.
      2020-05-30 18:48:29.049  - info: host.Iobroker instance system.adapter.hm-rega.0 started with pid 2888
      2020-05-30 18:48:29.045  - error: admin.1 (2853) uncaught exception: Invalid Version: npm error
      2020-05-30 18:48:29.047  - error: admin.1 (2853) TypeError: Invalid Version: npm error
      2020-05-30 18:48:29.049  - info: admin.1 (2853) terminating http server on port 8099
      2020-05-30 18:48:29.102  - info: admin.1 (2853) terminating
      2020-05-30 18:48:29.105  - info: admin.1 (2853) Terminated (NO_ERROR): Without reason
      2020-05-30 18:48:29.775  - error: host.Iobroker Caught by controller[0]: TypeError: Invalid Version: npm error
      2020-05-30 18:48:29.775  - error: host.Iobroker Caught by controller[0]:     at new SemVer (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:332:11)
      2020-05-30 18:48:29.776  - error: host.Iobroker Caught by controller[0]:     at compare (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:647:39)
      2020-05-30 18:48:29.776  - error: host.Iobroker Caught by controller[0]:     at Function.gt (/opt/iobroker/node_modules/iobroker.admin/node_modules/semver/semver.js:683:10)
      2020-05-30 18:48:29.776  - error: host.Iobroker Caught by controller[0]:     at upToDate (/opt/iobroker/node_modules/iobroker.admin/main.js:223:16)
      2020-05-30 18:48:29.777  - error: host.Iobroker Caught by controller[0]:     at Object.keys.forEach.name (/opt/iobroker/node_modules/iobroker.admin/main.js:268:22)
      2020-05-30 18:48:29.777  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2020-05-30 18:48:29.777  - error: host.Iobroker Caught by controller[0]:     at adapter.getState (/opt/iobroker/node_modules/iobroker.admin/main.js:265:30)
      2020-05-30 18:48:29.778  - error: host.Iobroker Caught by controller[0]:     at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
      2020-05-30 18:48:29.778  - error: host.Iobroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2020-05-30 18:48:29.778  - error: host.Iobroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2020-05-30 18:48:29.779  - error: host.Iobroker instance system.adapter.admin.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2020-05-30 18:48:29.779  - info: host.Iobroker Restart adapter system.adapter.admin.1 because enabled
      2020-05-30 18:48:32.290  - info: hm-rega.0 (2888) starting. Version 2.6.9 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:32.497  - info: hm-rega.0 (2888) subscribe hm-rpc.1.BidCoS-RF.50.PRESS_SHORT
      2020-05-30 18:48:32.676  - info: hm-rega.0 (2888) ReGaHSS 192.168.178.9 up
      2020-05-30 18:48:32.781  - info: hm-rega.0 (2888) time difference local-ccu 1s
      2020-05-30 18:48:33.074  - info: host.Iobroker instance system.adapter.web.0 started with pid 2911
      2020-05-30 18:48:33.356  - info: hm-rega.0 (2888) update favorites to enum.favorites
      2020-05-30 18:48:33.450  - info: hm-rega.0 (2888) update functions to enum.functions
      2020-05-30 18:48:33.520  - info: hm-rega.0 (2888) update rooms to enum.rooms
      2020-05-30 18:48:33.578  - info: hm-rega.0 (2888) hm-rpc.1.MEQ1118434.1 has been added to room roomGarden
      2020-05-30 18:48:33.579  - info: hm-rega.0 (2888) hm-rpc.1.MEQ1118434 has been removed from room roomGarden
      2020-05-30 18:48:33.593  - info: hm-rega.0 (2888) hm-rpc.1.MEQ0790322.4 has been added to room Wellness room
      2020-05-30 18:48:33.594  - info: hm-rega.0 (2888) hm-rpc.1.LEQ0770521 has been removed from room Wellness room
      2020-05-30 18:48:33.605  - info: hm-rega.0 (2888) hm-rpc.1.MEQ0792120.4 has been added to room Guestroom
      2020-05-30 18:48:33.606  - info: hm-rega.0 (2888) hm-rpc.1.MEQ0792120 has been removed from room Guestroom
      2020-05-30 18:48:33.959  - info: hm-rega.0 (2888) renamed hm-rpc.0.CUX0200001.1 to "fs20:1"
      2020-05-30 18:48:33.969  - info: hm-rega.0 (2888) renamed hm-rpc.0.CUX0200001.0 to "fs20_1:0"
      2020-05-30 18:48:33.982  - info: hm-rega.0 (2888) renamed hm-rpc.0.CUX0200001 to "fs20_1"
      2020-05-30 18:48:34.039  - info: hm-rega.0 (2888) got 1 programs
      2020-05-30 18:48:34.062  - info: hm-rega.0 (2888) added/updated 1 programs
      2020-05-30 18:48:34.065  - info: hm-rega.0 (2888) deleted 0 programs
      2020-05-30 18:48:34.111  - info: hm-rega.0 (2888) got 9 variables
      2020-05-30 18:48:34.255  - info: hm-rega.0 (2888) added/updated 9 variables
      2020-05-30 18:48:34.256  - info: hm-rega.0 (2888) deleted 0 variables
      2020-05-30 18:48:34.528  - info: hm-rega.0 (2888) added/updated 1 objects
      2020-05-30 18:48:34.534  - info: hm-rega.0 (2888) request state values
      2020-05-30 18:48:35.043  - info: hm-rega.0 (2888) got state values
      2020-05-30 18:48:37.066  - info: host.Iobroker instance system.adapter.hm-rpc.1 started with pid 2938
      2020-05-30 18:48:37.179  - info: web.0 (2911) starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:37.736  - info: web.0 (2911) socket.io server listening on port 8082
      2020-05-30 18:48:37.744  - info: web.0 (2911) http server listening on port 8082
      2020-05-30 18:48:39.799  - info: hm-rpc.1 (2938) starting. Version 1.14.5 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:40.215  - info: hm-rpc.1 (2938) xmlrpc server is trying to listen on 192.168.178.11:2001
      2020-05-30 18:48:40.216  - info: hm-rpc.1 (2938) xmlrpc client is trying to connect to 192.168.178.9:2001/ with ["http://192.168.178.11:2001","hm-rpc.1"]
      2020-05-30 18:48:40.273  - info: hm-rpc.1 (2938) xmlrpc <- system.listMethods ["hm-rpc.1"]
      2020-05-30 18:48:40.289  - info: hm-rpc.1 (2938) xmlrpc <- listDevices ["hm-rpc.1"]
      2020-05-30 18:48:40.451  - info: hm-rpc.1 (2938) xmlrpc -> 144 devices
      2020-05-30 18:48:40.519  - info: hm-rpc.1 (2938) Connected
      2020-05-30 18:48:41.023  - info: host.Iobroker instance system.adapter.backitup.0 started with pid 2961
      2020-05-30 18:48:44.761  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:44.775  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:44.776  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:44.777  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:45.031  - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 2971
      2020-05-30 18:48:45.100  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.123
      2020-05-30 18:48:45.117  - info: web.0 (2911) <==Disconnect system.user.admin from ::ffff:192.168.178.32 vis.0
      2020-05-30 18:48:45.179  - info: web.0 (2911) <==Disconnect system.user.admin from ::ffff:192.168.178.32 vis.0
      2020-05-30 18:48:45.593  - info: web.0 (2911) <==Disconnect system.user.admin from ::ffff:192.168.178.123 vis.0
      2020-05-30 18:48:46.128  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.123
      2020-05-30 18:48:48.895  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:48.987  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:49.032  - info: host.Iobroker instance system.adapter.scenes.0 started with pid 2991
      2020-05-30 18:48:49.041  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:49.327  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.123
      2020-05-30 18:48:49.475  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.32
      2020-05-30 18:48:49.551  - info: backitup.0 (2961) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:49.580  - info: zigbee.0 (2971) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:49.820  - info: web.0 (2911) ==>Connected system.user.admin from ::ffff:192.168.178.123
      2020-05-30 18:48:49.775  - info: zigbee.0 (2971) Starting Zigbee...
      2020-05-30 18:48:50.334  - error: zigbee.0 (2971) Failed to start Zigbee
      2020-05-30 18:48:50.338  - error: zigbee.0 (2971) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
          at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
          at Generator.next (<anonymous>)
          at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
          at new Promise (<anonymous>)
          at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
          at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
          at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
          at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
      2020-05-30 18:48:49.846  - info: backitup.0 (2961) [iobroker] backup was activated at 02:00 every 1 day(s)
      2020-05-30 18:48:49.916  - info: backitup.0 (2961) [ccu] backup was activated at 01:30 every 2 day(s)
      2020-05-30 18:48:52.772  - info: scenes.0 (2991) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:48:53.070  - info: host.Iobroker instance system.adapter.shuttercontrol.0 started with pid 3024
      2020-05-30 18:48:56.117  - info: host.Iobroker instance system.adapter.admin.0 started with pid 3038
      2020-05-30 18:48:57.034  - info: host.Iobroker instance system.adapter.sonoff.0 started with pid 3045
      2020-05-30 18:48:59.826  - info: host.Iobroker instance system.adapter.admin.1 started with pid 3060
      2020-05-30 18:49:00.342  - info: zigbee.0 (2971) Try to reconnect. 1 attempts left
      2020-05-30 18:49:00.343  - info: zigbee.0 (2971) Starting Zigbee...
      2020-05-30 18:49:00.440  - error: zigbee.0 (2971) Failed to start Zigbee
      2020-05-30 18:49:00.455  - error: zigbee.0 (2971) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
      2020-05-30 18:49:01.212  - info: host.Iobroker instance system.adapter.javascript.0 started with pid 3070
      2020-05-30 18:49:02.578  - info: shuttercontrol.0 (3024) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:49:05.275  - info: host.Iobroker instance system.adapter.history.0 started with pid 3085
      2020-05-30 18:49:06.232  - info: sonoff.0 (3045) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.20.1, js-controller: 3.1.4
      2020-05-30 18:49:06.680  - info: sonoff.0 (3045) Starting MQTT  server on port 1883
        Als root:
        Ach ja... 😆
        #43
        @Dr-Bakterius sagte in Falsche repository:
        Als root:
        Ach ja... 😆
        :-) Danach NIE mehr. :-D
        Z 1 Antwort Letzte Antwort
          Als root:
          Ach ja... 😆
          Z Offline
          Z Offline
          zgadgeter
          #44
          @Thomas-Braun ich habe es gelernt und mache es immer so.
          • Z zgadgeter
            #45
            @zgadgeter
            Und das heißt nun?
              @zgadgeter
              Und das heißt nun?
              Z Offline
              Z Offline
              zgadgeter
              #46
              @Thomas-Braun Werde es von jetzt immer so machen, vorher habe ich es fast immer so gemacht :) aber halt auch nicht immer.
              • Z zgadgeter
                #47
                @zgadgeter
                cd /opt/iobroker
                iobroker stop
                npm rebuild
                iobroker fix
                  @zgadgeter
                  cd /opt/iobroker
                  iobroker stop
                  npm rebuild
                  iobroker fix
                  Z Offline
                  Z Offline
                  zgadgeter
                  #48
                  @zgadgeter
                  cd /opt/iobroker
                  iobroker stop
                  npm rebuild
                  iobroker fix
                  gesagt getan....hat nicht funktioniert. ...:(
                  • Z zgadgeter
                    @zgadgeter
                    cd /opt/iobroker
                    iobroker stop
                    npm rebuild
                    iobroker fix
                    #49
                    @zgadgeter
                    Dann fällt mir auch nix mehr ein.
                    Zück dein Backup und dann installierst du den iobroker fix neu.
                      @zgadgeter
                      Z Offline
                      Z Offline
                      zgadgeter
                      #50
                      @Thomas-Braun Ich denke Du hast recht...backup ist nur 2 Tage alt, also nicht viel verloren. Danke nochmals!
