  4. Fehlermeldung beim javascript update 3.0.8
5 Beiträge 3 Kommentatoren 865 Aufrufe
    rascal
    Hey,
    Fehlermeldung beim update auf einem Rasp3 im Multihost modus:
    javascript.2	2016-09-12 21:23:23.003	info	javascript.2 requesting all objects
    javascript.2	2016-09-12 21:23:23.003	info	javascript.2 requesting all states
    javascript.2	2016-09-12 21:23:23.002	info	javascript.2 noble@1.6.0 opt/iobroker/node_modules/iobroker.javascript/node_modules/noble ├── bplist-parser@0.0.6 ├── debug@2.2.0 (ms@0.7.1) └── bluetooth-hci-socket@0.4.4 (nan@2.4.0, usb@1.2.0)
    javascript.2	2016-09-12 21:23:20.345	info	javascript.2 make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    javascript.2	2016-09-12 21:23:20.327	info	javascript.2 COPY Release/binding.node
    javascript.2	2016-09-12 21:23:20.051	info	javascript.2 SOLINK_MODULE(target) Release/obj.target/binding.node
    javascript.2	2016-09-12 21:23:15.074	info	javascript.2 CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
    javascript.2	2016-09-12 21:23:15.070	info	javascript.2 make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/build'
    javascript.2	2016-09-12 21:23:12.742	info	javascript.2 > bluetooth-hci-socket@0.4.4 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket > node-gyp rebuild
    javascript.2	2016-09-12 21:23:12.686	info	javascript.2 make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    javascript.2	2016-09-12 21:23:12.674	info	javascript.2 TOUCH Release/obj.target/action_after_build.stamp
    javascript.2	2016-09-12 21:23:12.651	info	javascript.2 COPY /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/src/binding/usb_bindings.node
    javascript.2	2016-09-12 21:23:12.629	info	javascript.2 COPY Release/usb_bindings.node
    javascript.2	2016-09-12 21:23:12.314	info	javascript.2 SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
    javascript.2	2016-09-12 21:23:07.663	info	javascript.2 CXX(target) Release/obj.target/usb_bindings/src/transfer.o
    javascript.2	2016-09-12 21:22:59.783	info	javascript.2 CXX(target) Release/obj.target/usb_bindings/src/device.o
    javascript.2	2016-09-12 21:22:55.124	info	javascript.2 CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
    javascript.2	2016-09-12 21:22:55.101	info	javascript.2 COPY Release/usb.a
    javascript.2	2016-09-12 21:22:55.075	info	javascript.2 AR(target) Release/obj.target/usb.a
    javascript.2	2016-09-12 21:22:54.509	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
    javascript.2	2016-09-12 21:22:44.711	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
    javascript.2	2016-09-12 21:22:44.206	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
    javascript.2	2016-09-12 21:22:43.840	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
    javascript.2	2016-09-12 21:22:43.424	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
    javascript.2	2016-09-12 21:22:42.601	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
    javascript.2	2016-09-12 21:22:41.000	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/io.o
    javascript.2	2016-09-12 21:22:40.297	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
    javascript.2	2016-09-12 21:22:38.360	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
    javascript.2	2016-09-12 21:22:36.731	info	javascript.2 CC(target) Release/obj.target/libusb/libusb/libusb/core.o
    javascript.2	2016-09-12 21:22:36.727	info	javascript.2 make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
    javascript.2	2016-09-12 21:22:33.087	error	javascript.2 ERR! Pre-built binaries not found for usb@1.2.0 and node@4.4.7 (node-v46 ABI) (falling back to source compile with node-gyp)
    javascript.2	2016-09-12 21:22:33.086	error	javascript.2 ERR! Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v46-linux-arm.tar.gz node-pre-gyp
    javascript.2	2016-09-12 21:22:33.086	error	javascript.2 node-pre-gyp
    javascript.2	2016-09-12 21:22:30.649	info	javascript.2 > usb@1.2.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb > node-pre-gyp install --fallback-to-build
    da Läuft nur javascript drauf für die Bluetooth erkennung
    • BluefoxB Offline
      BluefoxB Offline
      Aber es läuft oder?
        rascal
        Ja
        Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
        • BluefoxB Offline
          BluefoxB Offline
          Ich weiß nicht, warum es als ERROR markiert wird, es ist nur die Meldung, dass prebuild biniraies für dein System nicht gefunden sind
            Pman
            Hatten wir jetzt schon mehrfach:
            http://forum.iobroker.net/viewtopic.php … 89&p=34294
            http://forum.iobroker.net/viewtopic.php … 45&p=32951
            http://forum.iobroker.net/viewtopic.php … 11&p=26333
