  3. Entwicklung
  4. (gelöst) ble Adapter crashed nach Update auf node.js V12
ble adapter
5 Beiträge 2 Kommentatoren 669 Aufrufe 2 Beobachtet
    Marty56
    schrieb am zuletzt editiert von Marty56
    Das Update auf node.js V12 hat im Großen und Ganz geklappt. Nur der BLE- Adapter will nicht.
    ble.0	2020-05-03 22:24:56.307	error	the module (for instance, using `npm rebuild` or `npm install`).
    ble.0	2020-05-03 22:24:56.307	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    ble.0	2020-05-03 22:24:56.307	error	NODE_MODULE_VERSION 64. This version of Node.js requires
    ble.0	2020-05-03 22:24:56.307	error	was compiled against a different Node.js version using
    ble.0	2020-05-03 22:24:56.307	error	(5352) unhandled promise rejection: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
    ble.0	2020-05-03 22:24:56.300	error	at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    ble.0	2020-05-03 22:24:56.300	error	at Module.load (internal/modules/cjs/loader.js:977:32)
    ble.0	2020-05-03 22:24:56.300	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    ble.0	2020-05-03 22:24:56.300	error	at Module._compile (internal/modules/cjs/loader.js:1133:30)
    ble.0	2020-05-03 22:24:56.300	error	at Object.<anonymous> (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)
    ble.0	2020-05-03 22:24:56.300	error	at require (internal/modules/cjs/helpers.js:77:18)
    ble.0	2020-05-03 22:24:56.300	error	at Module.require (internal/modules/cjs/loader.js:1019:19)
    ble.0	2020-05-03 22:24:56.300	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    ble.0	2020-05-03 22:24:56.300	error	the module (for instance, using `npm rebuild` or `npm install`).
    ble.0	2020-05-03 22:24:56.300	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    ble.0	2020-05-03 22:24:56.300	error	NODE_MODULE_VERSION 64. This version of Node.js requires
    ble.0	2020-05-03 22:24:56.300	error	was compiled against a different Node.js version using
    ble.0	2020-05-03 22:24:56.300	error	(5352) Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
    ble.0	2020-05-03 22:24:56.291	error	the module (for instance, using `npm rebuild` or `npm install`).
    ble.0	2020-05-03 22:24:56.291	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    ble.0	2020-05-03 22:24:56.291	error	NODE_MODULE_VERSION 64. This version of Node.js requires
    ble.0	2020-05-03 22:24:56.291	error	was compiled against a different Node.js version using
    ble.0	2020-05-03 22:24:56.291	error	(5352) uncaught exception: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
    Gibt es hier schon eine Lösung?
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • M Marty56
      @Marty56
      iobroker rebuild ble --install
        Marty56
        @Thomas-Braun sagte in ble Adapter crashed nach Update auf node.js V12:
        Das ging schnell. Danke.
        Muss ich dazu ins iobroker Verzeichnis wechseln?
        HW:NUC (16 GB Ram)
        • M Marty56
          @Marty56
          Ja, mach dich mal auf zu /opt/iobroker
          Und bitte auch daran denken, die setcapabilities zu aktualisieren:
          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
          Muss ich jedenfalls immer machen, wenn die node-Version sich ändert.
            Marty56
            iobroker
            Hat geklappt! Vielen Dank!!
            Das mit den capabilities war bei mir nicht notwendig.
            HW:NUC (16 GB Ram)
