  4. Alexa2.0 Adapter startet nicht mehr
alexa 2.0adapter
3 Beiträge 1 Kommentatoren 475 Aufrufe
    Tottbeck
    N'abend,
    mein Alexa2.0-Adapter (Version 3.0.5) will plötzlich nicht mehr:
    host.raspberrypi	2020-04-26 18:24:08.635	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-04-26 18:24:08.635	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-04-26 18:24:08.635	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-04-26 18:24:08.634	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/hub/dist/index.js:2:15)
    host.raspberrypi	2020-04-26 18:24:08.634	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-04-26 18:24:08.634	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-04-26 18:24:08.634	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-04-26 18:24:08.633	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-04-26 18:24:08.633	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-04-26 18:24:08.633	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-04-26 18:24:08.632	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
    host.raspberrypi	2020-04-26 18:24:08.632	error	Caught by controller[0]: SyntaxError: Unexpected number
    host.raspberrypi	2020-04-26 18:24:08.632	error	Caught by controller[0]: ^
    host.raspberrypi	2020-04-26 18:24:08.632	error	Caught by controller[0]: Scope.xrototype.addScopeListener 9 func5ion (callback) {
    host.raspberrypi	2020-04-26 18:24:08.630	error	Caught by controller[0]: /opt/iobroker/node_modules/@sentry/hub/dist/scope.js:31
    Habe den Adapter schon gelöscht und neu installiert ohne Erfolg.
    Das Einspielen eines 3 Tage alten Backups wo es noch ging hat auch nicht gebracht.
    Ist da eine Datei korrupt geworden ? "func5ion" sieht schon komisch aus.
      Tottbeck
      Also die Datei \opt\iobroker\node_modules@sentry\hub\dist\scope.js
      war definitiv korrupt. Wenn ich die austausche (ist fast gleich zur ../esm/scope.js) kommt ein anderer Fehler:
      host.raspberrypi	2020-04-27 12:15:28.082	info	instance system.adapter.alexa2.0 terminated with code NaN ()
      host.raspberrypi	2020-04-27 12:15:28.081	warn	instance system.adapter.alexa2.0 terminated due to SIGSEGV
      Ich versuche mal npm zu installieren. Sonst muss ich wohl (mal wieder) neu aufsetzen.
        Tottbeck
        Ticket kann zu. Ich musste komplett neu aufsetzen. Das Filesystem war defekt.
