  4. Update node-red mit error
5 Beiträge 2 Kommentatoren 1.8k Aufrufe
    Beim aktuellen update von node-red gab es einiges gemecker:
     host-quad-pi	2015-03-25 22:34:57	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
    node-red-0	2015-03-25 22:34:57	info	 node-red exited with 8
    TypeError:	2015-03-25 22:34:57	error	 at Pipe.onread (net.js:526:21)
    TypeError:	2015-03-25 22:34:57	error	 at Socket.Readable.push (_stream_readable.js:127:10)
    TypeError:	2015-03-25 22:34:57	error	 at readableAddChunk (_stream_readable.js:165:9)
    TypeError:	2015-03-25 22:34:57	error	 at emitReadable (_stream_readable.js:404:5)
    TypeError:	2015-03-25 22:34:57	error	 at emitReadable_ (_stream_readable.js:408:10)
    TypeError:	2015-03-25 22:34:57	error	 at Socket.EventEmitter.emit (events.js:92:17)
    TypeError:	2015-03-25 22:34:57	error	 at Socket. (_stream_readable.js:746:14)
    TypeError:	2015-03-25 22:34:57	error	 at Socket.EventEmitter.emit (events.js:95:17)
    TypeError:	2015-03-25 22:34:57	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:100:18)
    TypeError:	2015-03-25 22:34:57	error	 has no method 'indexOf'
    TypeError:	2015-03-25 22:34:57	error	 at Module.load (module.js:356:32)
    TypeError:	2015-03-25 22:34:57	error	 at Object.Module._extensions..js (module.js:474:10)
    TypeError:	2015-03-25 22:34:57	error	 at Module._compile (module.js:456:26)
    TypeError:	2015-03-25 22:34:57	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
    TypeError:	2015-03-25 22:34:57	error	 at require (module.js:380:17)
    TypeError:	2015-03-25 22:34:57	error	 at Module.require (module.js:364:17)
    TypeError:	2015-03-25 22:34:57	error	 at Function.Module._load (module.js:312:12)
    TypeError:	2015-03-25 22:34:57	error	 at Object.Module._extensions..json (module.js:482:27)
    TypeError:	2015-03-25 22:34:57	error	 at Object.parse (native)
    TypeError:	2015-03-25 22:34:57	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
    TypeError:	2015-03-25 22:34:57	error	 ^
    TypeError:	2015-03-25 22:34:57	error	 throw err;
    TypeError:	2015-03-25 22:34:57	error	 Object module.js:485
    uncaught	2015-03-25 22:34:57	error	 has no method 'indexOf'
    uncaught	2015-03-25 22:34:57	error	 at Module.load (module.js:356:32)
    uncaught	2015-03-25 22:34:57	error	 at Object.Module._extensions..js (module.js:474:10)
    uncaught	2015-03-25 22:34:57	error	 at Module._compile (module.js:456:26)
    uncaught	2015-03-25 22:34:57	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
    uncaught	2015-03-25 22:34:57	error	 at require (module.js:380:17)
    uncaught	2015-03-25 22:34:57	error	 at Module.require (module.js:364:17)
    uncaught	2015-03-25 22:34:57	error	 at Function.Module._load (module.js:312:12)
    uncaught	2015-03-25 22:34:57	error	 at Object.Module._extensions..json (module.js:482:27)
    uncaught	2015-03-25 22:34:57	error	 at Object.parse (native)
    uncaught	2015-03-25 22:34:57	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
    uncaught	2015-03-25 22:34:57	error	 ^
    uncaught	2015-03-25 22:34:57	error	 throw err;
    uncaught	2015-03-25 22:34:57	error	 exception: Object module.js:485
    node-red-0	2015-03-25 22:34:56	info	 Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
    node-red-0	2015-03-25 22:34:54	info	 starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.node-red
    2015-03-25 22:34:53	info	info
    host-quad-pi	2015-03-25 22:34:52	info	 instance system.adapter.node-red.0 started with pid 11468
    host-quad-pi	2015-03-25 22:34:22	info	 Restart adapter system.adapter.node-red.0 because enabled
    host-quad-pi	2015-03-25 22:34:22	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
    node-red-0	2015-03-25 22:34:22	info	 node-red exited with 8
    TypeError:	2015-03-25 22:34:22	error	 at Pipe.onread (net.js:526:21)
    TypeError:	2015-03-25 22:34:22	error	 at Socket.Readable.push (_stream_readable.js:127:10)
    TypeError:	2015-03-25 22:34:22	error	 at readableAddChunk (_stream_readable.js:165:9)
    TypeError:	2015-03-25 22:34:22	error	 at emitReadable (_stream_readable.js:404:5)
    TypeError:	2015-03-25 22:34:22	error	 at emitReadable_ (_stream_readable.js:408:10)
    TypeError:	2015-03-25 22:34:22	error	 at Socket.EventEmitter.emit (events.js:92:17)
    TypeError:	2015-03-25 22:34:22	error	 at Socket. (_stream_readable.js:746:14)
    TypeError:	2015-03-25 22:34:22	error	 at Socket.EventEmitter.emit (events.js:95:17)
    TypeError:	2015-03-25 22:34:22	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:100:18)
    TypeError:	2015-03-25 22:34:22	error	 has no method 'indexOf'
    TypeError:	2015-03-25 22:34:22	error	 at Module.require (module.js:364:17)
    TypeError:	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:312:12)
    TypeError:	2015-03-25 22:34:22	error	 at Module.load (module.js:356:32)
    TypeError:	2015-03-25 22:34:22	error	 at Object.Module._extensions..js (module.js:474:10)
    TypeError:	2015-03-25 22:34:22	error	 at Module._compile (module.js:456:26)
    TypeError:	2015-03-25 22:34:22	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/lib/proto.js:12:20)
    TypeError:	2015-03-25 22:34:22	error	 at require (module.js:380:17)
    TypeError:	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:280:25)
    TypeError:	2015-03-25 22:34:22	error	 at Function.Module._resolveFilename (module.js:338:15)
    TypeError:	2015-03-25 22:34:22	error	Error: Cannot find module 'finalhandler'
    TypeError:	2015-03-25 22:34:22	error	 ^
    TypeError:	2015-03-25 22:34:22	error	 throw err;
    TypeError:	2015-03-25 22:34:22	error	 Object module.js:340
    uncaught	2015-03-25 22:34:22	error	 has no method 'indexOf'
    uncaught	2015-03-25 22:34:22	error	 at Module.require (module.js:364:17)
    uncaught	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:312:12)
    uncaught	2015-03-25 22:34:22	error	 at Module.load (module.js:356:32)
    uncaught	2015-03-25 22:34:22	error	 at Object.Module._extensions..js (module.js:474:10)
    uncaught	2015-03-25 22:34:22	error	 at Module._compile (module.js:456:26)
    uncaught	2015-03-25 22:34:22	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/lib/proto.js:12:20)
    uncaught	2015-03-25 22:34:22	error	 at require (module.js:380:17)
    uncaught	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:280:25)
    uncaught	2015-03-25 22:34:22	error	 at Function.Module._resolveFilename (module.js:338:15)
    uncaught	2015-03-25 22:34:22	error	Error: Cannot find module 'finalhandler'
    uncaught	2015-03-25 22:34:22	error	 ^
    uncaught	2015-03-25 22:34:22	error	 throw err;
    uncaught	2015-03-25 22:34:22	error	 exception: Object module.js:340
    node-red-0	2015-03-25 22:34:21	info	 Starting node-red: /opt/iobroker
    • BluefoxB Offline
      BluefoxB Offline
      Probiere jetzt
        Naja, sieht auch nicht gut sus:
         iobroker	2015-03-26 16:28:38	info	> node-gyp rebuild
        iobroker	2015-03-26 16:28:38	info	 > iconv@2.1.6 install /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/iconv
        host-quad-pi	2015-03-26 16:28:12	info	 Restart adapter system.adapter.node-red.0 because enabled
        host-quad-pi	2015-03-26 16:28:12	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
        node-red-0	2015-03-26 16:28:12	info	 node-red exited with 8
        TypeError:	2015-03-26 16:28:12	error	 at Pipe.onread (net.js:526:21)
        TypeError:	2015-03-26 16:28:12	error	 at Socket.Readable.push (_stream_readable.js:127:10)
        TypeError:	2015-03-26 16:28:12	error	 at readableAddChunk (_stream_readable.js:165:9)
        TypeError:	2015-03-26 16:28:12	error	 at emitReadable (_stream_readable.js:404:5)
        TypeError:	2015-03-26 16:28:12	error	 at emitReadable_ (_stream_readable.js:408:10)
        TypeError:	2015-03-26 16:28:12	error	 at Socket.EventEmitter.emit (events.js:92:17)
        TypeError:	2015-03-26 16:28:12	error	 at Socket. (_stream_readable.js:746:14)
        TypeError:	2015-03-26 16:28:12	error	 at Socket.EventEmitter.emit (events.js:95:17)
        TypeError:	2015-03-26 16:28:12	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:103:18)
        TypeError:	2015-03-26 16:28:12	error	 has no method 'indexOf'
        TypeError:	2015-03-26 16:28:12	error	 at Module.load (module.js:356:32)
        TypeError:	2015-03-26 16:28:12	error	 at Object.Module._extensions..js (module.js:474:10)
        TypeError:	2015-03-26 16:28:12	error	 at Module._compile (module.js:456:26)
        TypeError:	2015-03-26 16:28:12	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
        TypeError:	2015-03-26 16:28:12	error	 at require (module.js:380:17)
        TypeError:	2015-03-26 16:28:12	error	 at Module.require (module.js:364:17)
        TypeError:	2015-03-26 16:28:12	error	 at Function.Module._load (module.js:312:12)
        TypeError:	2015-03-26 16:28:12	error	 at Object.Module._extensions..json (module.js:482:27)
        TypeError:	2015-03-26 16:28:12	error	 at Object.parse (native)
        TypeError:	2015-03-26 16:28:12	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
        TypeError:	2015-03-26 16:28:12	error	 ^
        TypeError:	2015-03-26 16:28:12	error	 throw err;
        TypeError:	2015-03-26 16:28:12	error	 Object module.js:485
        uncaught	2015-03-26 16:28:12	error	 has no method 'indexOf'
        uncaught	2015-03-26 16:28:12	error	 at Module.load (module.js:356:32)
        uncaught	2015-03-26 16:28:12	error	 at Object.Module._extensions..js (module.js:474:10)
        uncaught	2015-03-26 16:28:12	error	 at Module._compile (module.js:456:26)
        uncaught	2015-03-26 16:28:12	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
        uncaught	2015-03-26 16:28:12	error	 at require (module.js:380:17)
        uncaught	2015-03-26 16:28:12	error	 at Module.require (module.js:364:17)
        uncaught	2015-03-26 16:28:12	error	 at Function.Module._load (module.js:312:12)
        uncaught	2015-03-26 16:28:12	error	 at Object.Module._extensions..json (module.js:482:27)
        uncaught	2015-03-26 16:28:12	error	 at Object.parse (native)
        uncaught	2015-03-26 16:28:12	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
        uncaught	2015-03-26 16:28:12	error	 ^
        uncaught	2015-03-26 16:28:12	error	 throw err;
        uncaught	2015-03-26 16:28:12	error	 exception: Object module.js:485
        node-red-0	2015-03-26 16:28:11	info	 Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
        node-red-0	2015-03-26 16:28:07	info	 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.node-red
        Rainer
        Gesendet von meinem Cynus T7 mit Tapatalk
        • BluefoxB Offline
          BluefoxB Offline
          Bei dir hat npm versagt. Kannst du folgendes machen:
          cd /opt/iobroker
          sudo rm -r /opt/iobroker/node_modules/iobroker.node-red/
          npm install iobroker.node-red
            Sieht leider auch nicht gut aus:
            make: Entering directory '/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector/build'
              CXX(target) Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o
            ../node-icu-charset-detector.cpp:5:28: fatal error: unicode/ucsdet.h: Datei oder Verzeichnis nicht gefunden
            compilation terminated.
            node-icu-charset-detector.target.mk:77: recipe for target 'Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o' failed
            make: *** [Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o] Error 1
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector/build'
            gyp ERR! build error
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
            gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
            gyp ERR! System Linux 3.18.7-v7+
            gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector
            gyp ERR! node -v v0.10.22
            gyp ERR! node-gyp -v v0.11.0
            gyp ERR! not ok
            npm http GET https://registry.npmjs.org/hoek
            npm http GET https://registry.npmjs.org/boom
