  4. Gosund WB4 8W- OTA Flash - geht nicht
    5.6k
wb4 gosund ota
32 Beiträge 8 Kommentatoren 5.7k Aufrufe 8 Beobachtet
    pampulea
    schrieb am zuletzt editiert von pampulea
    kann mir bitte jemand helfen?
    Ich versuche ein Gosund LED WB4 zu flashen:
    [sudo] password for openhabian:
    tuya-convert v2.4.3
    Checking for network interface wlan0... Found.
    Checking UDP port 53... Occupied by dnsmasq with PID 624.
    Port 53 is needed to resolve DNS queries
    Do you wish to terminate dnsmasq? [y/N] y
    Attempting to stop dnsmasq.service
    Checking UDP port 67... Available.
    Checking TCP port 80... Available.
    Checking TCP port 443... Available.
    Checking UDP port 6666... Available.
    Checking UDP port 6667... Available.
    Checking TCP port 1883... Occupied by mosquitto with PID 552.
    Port 1883 is needed to run MQTT
    Do you wish to terminate mosquitto? [y/N] y
    Attempting to stop mosquitto.service
    Checking TCP port 8886... Available.
    sudo: ufw: command not found
      Starting AP in a screen.........................
      Starting web server in a screen
      Starting Mosquitto in a screen
      Starting PSK frontend in a screen
      Starting Tuya Discovery in a screen
    IMPORTANT
    1. Connect any other device (a smartphone or something) to the WIFI vtrust-flash
       This step is IMPORTANT otherwise the smartconfig may not work!
    2. Put your IoT device in autoconfig/smartconfig/pairing mode (LED will blink fast). This is usually done by pressing and holding the primary button of the device
       Make sure nothing else is plugged into your IoT device while attempting to flash.
    3. Press ENTER to continue
    Starting smart config pairing procedure
    Waiting for the device to install the intermediate firmware
    .........Put device in EZ config mode (blinking fast)
    Sending SSID                  vtrust-flash
    Sending wifiPassword
    Sending token                 00000000
    Sending secret                0101
    SmartConfig complete.
    Resending SmartConfig Packets
    Device did not appear with the intermediate firmware
    Check the *.log files in the scripts folder
    Do you want to try flashing another device? [y/N]
    Meine Vorgehensweise:
    alles bis zu Ziele 33 zuerst
    dann die LED im "Pairing Mode" setzten (3 Mal ein und ausschalten - danach blinkt schnell)
    auf Enter drücken
    Ergebnis:
    Led blinkt bis zu Mitte-Ende Zeile 44. Danach bleibt an!
    Was soll ich noch tun?
    VG,
    Valentin
    • P pampulea
      tuya-convert v2.4.3
      IMPORTANT
      Sending secret                0101
      auf Enter drücken
      Ergebnis:
      VG,
      Valentin
      smarthome2020
      schrieb am zuletzt editiert von smarthome2020
      @pampulea
      Schritt für Schritt
      Dein System scheint sich nicht mit deiner Birne zu verbinden. Ich hatte das gleiche Problem. Hab dann die SD Karte komplett geplättet und nochmal alles aufgesetzt. Habe die Anleitung im Link dazu geschrieben. So klappte es jedenfalls bei mir.
      P 1 Antwort Letzte Antwort
      • S smarthome2020
        @pampulea
        Schritt für Schritt
        pampulea
        @smarthome2020 said in Gosund WB4 8W- OTA Flash - geht nicht:
        @pampulea
        Schritt für Schritt
        Der verbindet sich nicht mit deiner Birne. Das ist die Anleitung von mir mit der es ging.
        Hallo @smarthome2020,
        nach deiner Anleitung habe ich es gemacht!
        Hast du vielleicht eine andere Idee?
        Valentin
        S 2 Antworten Letzte Antwort
        • P pampulea
          @pampulea
          Schritt für Schritt
          Valentin
          smarthome2020
          @pampulea
          Also hast du das System komplett neu aufgesetzt? Bei mir ging es nur danach. Ich kann dir allerdings nicht sagen wieso. Ich probiere gleich noch 4 neue Gosund Steckdosen OTA zu flashen.
          Die Birne ist sicher im Pairing-Modus?
          • P pampulea
            @pampulea
            Schritt für Schritt
            Valentin
            smarthome2020
            @pampulea
            Also bei mir ging es ohne Probleme.
            Allerdings an der Gosund SP111.
            Was hast du denn für ein System? RPi4?
              pampulea
              @smarthome2020
              Ja bei mir auch!
              habe heute auch 8 Steckdose geflasht!
              Nur beim LED´s will nicht.
              BG, Valentin
              Edit: RPi3B+
              • P pampulea
                @smarthome2020
                Ja bei mir auch!
                BG, Valentin
                Edit: RPi3B+
                smarthome2020
                @pampulea
                Es könnte sein, dass deine Birne nicht im Pairing-Modus war. Wenn die das ist, dann blinkt die wahnsinnig schnell. Hat dann schon Disco-Charakter ^^
                Wenn sie ca. im 0,5Sekunden-Takt blinkt, dann sollte das Flashen gehen.
                  pampulea
                  @smarthome2020
                  Also tut sie es.
                  Aber so bald der Code sendet angefangen mit dem Zeile 85.
                  Weiter also im Ziele 87 zwischen 4-10 Punkt bleib der Lampe an.
                  Das was!
                  Valentin
                  • P pampulea
                    @smarthome2020
                    Also tut sie es.
                    Das was!
                    Valentin
                    smarthome2020
                    @pampulea
                    Also du hast:
                    1.Pi neu aufgesetzt (bei mir ging es nun auch ohne neues aufsetzen des PIs auf der zweiten SD Karte, wo nichts sondst installiert ist.)
                    2. Birne ist in Reichweite vom Pi? Oder ist sie so weit weg, dass keine Verbindung aufgebaut werden kann?
                    3. Hast du mal in die log Datei geschaut? Der wirft am Ende ja die Info raus, dass man da schauen soll.
                    4. 5GHz WLAN ist aus?
                    5. Du hattest du Birne nie über die Smartlife App oder wie die heißt eingebunden oder? Die hat also kein Update gezogen?
                    Hat überhaupt schon eine Birne funktioniert? Bei mir waren die auch problematischer, gingen irgendwann aber auch. Geht die Birne denn nach Flashversuch noch?
                    Gestern hatte die letzte Steckdose auch Probleme. War danach sozusagen tot. Es leuchtete nichts mehr. Hab einfach nochmal den Flashvorgang laufen lassen und das Problem war behoben.
                    Wo kommst du denn her? Wenns um die Ecke ist, dann kann ich es ja mal mit einem anderen System probieren. Sonst löten.
                      pampulea
                      @smarthome2020
                      1. Ja. Geht nicht! Dann habe ich auf einen alte System wo ich immer meine Gosund Steckdosen gefläsht hatte. Geht auch nicht
                      2. Ja, daneben
                      3. Ja geschaut. vertehe aber nicht viel, aber im welche Datei sollte man schauen? Wenn du mir es sagst dann zeige ich Euch hier
                      4. Dass muss aber gestehen, habe ich nicht gemacht! Bringt es was?
                      5. Nein die beider die ich habe sind frisch. Also noch nicht im App oder irgendwo angemeldet!
                      Ich wohne im Königstädten bei Rüsselsheim!
                      Vielen Dank für deinen Hilfe und sorry fürs verpätete Antwort,
                      Valentin
                      P.S. meinst du dass ich die 5Ghz auschalten soll und nochmal probieren? Bei der Steckdose funtioniert einwandfrei. Habe 20 Stück gefläsht!
                      • P pampulea
                        @smarthome2020
                        2. Ja, daneben
                        Valentin
                        smarthome2020
                        @pampulea
                        Würde das 5GHz Netz ausschalten und nochmal probieren. Ich schaue nachher mal, ob ich in die Log Datei komme bzw. wo die angelegt ist.
                        Letztlich kann es immer sein, dass die OTA Methode bei neueren Birnen und Steckdosen nicht mehr geht.
                        Rüsselsheim ist leider nicht um die Ecke :D
                        • P pampulea
                          @smarthome2020
                          2. Ja, daneben
                          Valentin
                          smarthome2020
                          @pampulea
                          Also ich hab die SD-Karte verloren mit der ich die Flashs mache. In deinem Log oben ist aufgeführt, dass du im "scripts" nachschauen sollst. Kannst ja mit WinSCP oder vergleichbaren Programmen von deinem Windowsrechner auf deinen Pi zugreifen und die Ordner mal durchsuchen.
                            pampulea
                            @smarthome2020
                            In welche log-Datei soll ich nachschauen? ic weiß wo abgelegt sind, hier:
                            backups/Datum
                            Habe die verbindung über WinSCP schon immer.
                            • P pampulea
                              @smarthome2020
                              backups/Datum
                              smarthome2020
                              @pampulea
                              Musst du mal durchforsten. Ich hab bisher nie reinschauen müssen.
                              • P pampulea
                                @smarthome2020
                                backups/Datum
                                smarthome2020
                                @pampulea
                                Musst mal bisschen googlen.
                                Hier wird zB auch von Birnen berichtet, bei denen der Flashvorgang nicht klappte. Sind paar Lösungen oder Anregungen dabei.
                                Tuya-Convert-Problems
                                Du hast bei deinem RPi aber auch kein WLAN konfiguriert oder? Dein RPi ist über LAN angebunden?
                                Hier meine Konsoleninfos von vor paar Tagen:
                                pi@raspberrypi:~/tuya-convert $ sudo ./start_flash.sh
                                tuya-convert v2.4.3
                                Checking UDP port 53... Occupied by dnsmasq with PID 542.
                                Checking TCP port 1883... Occupied by mosquitto with PID 527.
                                IMPORTANT
                                Sending secret                0101
                                IoT-device is online with ip 10.42.42.42
                                Fetching firmware backup
                                  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                100 1024k  100 1024k    0     0  41760      0  0:00:25  0:00:25 --:--:-- 22918
                                curl: Saved to filename 'firmware-b9ad8c.bin'
                                Getting Info from IoT-device
                                VTRUST-FLASH 1.5
                                (c) VTRUST GMBH https://www.vtrust.de/35c3/
                                READ FLASH: http://10.42.42.42/backup
                                ChipID: b9ad8c
                                MAC: C1:C1:C1:C1:C1
                                BootVersion: 7
                                BootMode: normal
                                FlashMode: 1M DOUT @ 40MHz
                                FlashChipId: 144051
                                FlashChipRealSize: 1024K
                                Active Userspace: user2 0x81000
                                Ready to flash third party firmware!
                                For your convenience, the following firmware images are already included in this repository:
                                  Tasmota v8.1.0.2 (wifiman)
                                  ESPurna 1.13.5 (base)
                                You can also provide your own image by placing it in the /files directory
                                Please ensure the firmware fits the device and includes the bootloader
                                MAXIMUM SIZE IS 512KB
                                Available options:
                                  0) return to stock
                                  1) flash espurna.bin
                                  2) flash tasmota.bin
                                  q) quit; do nothing
                                Please select 0-2: 2
                                Are you sure you want to flash tasmota.bin? This is the point of no return [y/N] y
                                Attempting to flash tasmota.bin, this may take a few seconds...
                                Flashed http://10.42.42.1/files/tasmota.bin successfully in 15172ms, rebooting...
                                Look for a tasmota-xxxx SSID to which you can connect and configure
                                Be sure to configure your device for proper function!
                                HAVE FUN!
                                Do you want to flash another device? [y/N]
                                Hier wird in einem anderen Beitrag auch nochmal das Flashen thematisiert: OTA-Flash
                                Wie du beim Vergleich siehst, packt er die Verbindung nicht zur Birne.
                                Daher mach wirklich mal das 5GHz aus. Zur Not nochmal die SD-Karte wie in meiner Anleitung beschrieben neu aufsetzen.
                                In der Anleitung, die den Birnen beigelegt ist, steht aber auch WB4 drin? Sollte auf dem Cover der Anleitung stehen.
                                  pampulea
                                  @smarthome2020
                                  Ich werde nochmal versuchen.
                                  Melde ich mich mit dem Neuigkeiten!
                                  Schöne Abend,
                                  Valentin
                                  • W Offline
                                    W Offline
                                    wannabe
                                    schrieb am zuletzt editiert von wannabe
                                    Die Logdateien aus tuya-convert/scripts wären gut
                                      pampulea
                                      @smarthome2020
                                      habe den 5Ghz Band ausgeschaltet.
                                      Immer noch nicht.
                                      Ich installiere auf neue SD-Karte und versuche nochmal.
                                      Melde mich wenn ich so weit bin.
                                      Danke Euch,
                                      Valentin
                                        pampulea
                                        habe heute auf eine neue Installierte Openhab SD-Karte nochmal probiert.
                                        Und klappt immer noch nicht.
                                        Anbei die log´s die ich gefunden habe.
                                        Mit der Hoffnung das mir jemand hilft,
                                        Beste Grüße,
                                        Valentin
                                        smarthack-wifi.log
                                        smarthack-web.log
                                        smarthack-udp.log
                                        smarthack-psk.log
                                        smarthack-mqtt.log
                                        • W Offline
                                          W Offline
                                          wannabe
                                          ID: 0242416f68626d6436614739314946523199b1fd7c4380200f439b4c79633f3398e5f6cb2a81b70545aaddaac993ef0d6a
                                          PSK: 458bd69c8dc4ae92f87b664842b70d8e955681aa3181df8a9e85ba6af9b100b3
                                          could not establish sslpsk socket: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac
                                          das sieht komisch aus oder anders gesagt, in meinen logs taucht sowas nicht auf. Aber einschätzen aus welcher Richtung der Fehler kommt, puh.
                                          Also die WB4 scheint laut internet flashbar
                                          Du hast berreits andere Geräte geflashed
                                          Netwerkanbindungen sind korrekt? LAN und WLAN
                                          Du siehst den AccessPoint von anderen Geräten aus?
                                          Versuch evtl. mal ein anderes Smartphone/Tablet
