  4. gelöst - IOT Adapter - Fehler
iot adapter
12 Beiträge 8 Kommentatoren 1.4k Aufrufe 9 Beobachtet
  • H Offline
    Hicki
    schrieb am zuletzt editiert von Hicki
    ich kann mein IOT-Adapter nicht updatet, mit dieser Fehlermeldung:
    $ ./iobroker upgrade iot
    Update iot from @1.1.8 to @1.4.0
    host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
    NPM version: 6.13.4
    npm install iobroker.iot@1.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp
     ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.97-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-03T19_42_54_922Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.iot@1.4.0: 1
    Was ist der Fehler?
    Gruß Hicki
      Semenchkare
      schrieb am zuletzt editiert von Semenchkare
      Habe ebenso den Fehler...
      Update iot from @1.3.4 to @1.4.0
      host.Raspi4-Iobroker Adapter "system.adapter.iot.0" is stopped.
      NPM version: 6.13.4npm install iobroker.iot@1.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:311:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.16.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:311:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.16.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-04T07_37_23_188Z-debug.log
      ERROR: host.Raspi4-Iobroker Cannot install iobroker.iot@1.4.0: 1
      Viele Grüße
      Semenchkare
      raspberry 5 8GB mit iobroker,
      raspberry 5 8GB mit Raspberrymatic
      • MaufloM Offline
        MaufloM Offline
        Mauflo
        Systemdata Bitte Ausfüllen
        Hardwaresystem: Raspberry 4 ARMv7 Processor rev 3 (v7l)
        Arbeitsspeicher: 4GB
        Festplattenart: SD-Karte
        Betriebssystem: Linux
        Node-Version: 10.19.0
        Nodejs-Version: 10.19.0
        NPM-Version: 6.14.2
        Installationsart: Skript
        Image genutzt: Ja
        Ort/Name der Imagedatei: ioBroker Image für Raspberry Pi2/3/4 Buster 20191127
        Wenn ich versuche IoT Assistants mit dem Link in Info update bekomme ich folgende Fehlermeldung:
        host.iobrokerP4 Adapter "system.adapter.iot.0" is stopped.
        NPM version: 6.14.2
        gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.93-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.93-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
        npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-04T07_33_36_000Z-debug.log
        ERROR: host.iobrokerP4 Cannot install iobroker.iot@1.4.0: 1
        Was läuft da schief? Kenne mich nicht aus!
        • haselchenH Offline
          haselchenH Offline
          haselchen
          Dieser Beitrag wurde gelöscht!
          MaufloM NegaleinN 2 Antworten Letzte Antwort
            SaiBot1981
            schrieb am zuletzt editiert von SaiBot1981
            Schließe mich an. Hab auch div. Tricks prpbiert. Sogar den InstallerFix. Keine Besserung.
            Hier meine Log 2020-04-04T08_42_54_905Z-debug.log
            • MaufloM Offline
              MaufloM Offline
              Mauflo
              • haselchenH haselchen
                MaufloM Offline
                MaufloM Offline
                Mauflo
                • MaufloM Mauflo
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  • khgK Offline
                    khgK Offline
                    khg
                    schrieb am zuletzt editiert von khg
                    gleiches Problem. Benötige von Alexa keine Zuckerwerte, habe aber gerne alle Adapter aktuell.
                    • khgK khg
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      @khg sagte in IOT Adapter - Fehler:
                      Kann mir wer erklären was das ist?
                      Immer Daten sichern!
                      • H Offline
                        Hicki
                        Hey Leute es gibt ein neues Update, jetzt funktioniert alles wieder.
                        Vielen Dank für das Update.
                        Was war nun eigentlich das Problem?
                        Gruß Hicki
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          @haselchen sagte in IOT Adapter - Fehler:
                          Kannst du die beiden Threads bitte zusammenlegen.
                          Mod-Edit: Erledigt
                          ° Fixer ---> iob fix
