  4. Test Adapter BSBLAN v0.1.x GitHub (Write Support!)
bsb lanbsbbrötjeelcoatlanticbaxifroelingmhgweishauptheating
30 Beiträge 5 Kommentatoren 4.9k Aufrufe 7 Beobachtet
  • M Malz1902
    Ne andere Sache, gibt es schon was neues, die Parameter in den Objekten nach Parameter Nummer zu sortieren bzw nach Kategorien?
    hacki11
    @Malz1902
    Habe gerade ein Batch-Processing für das Holen der IDs integriert.
    Kannst du die 0.1.3 vom Github Master installieren und nochmal mit den ursprünglichen IDs testen?
    Für die Sortierung hatte ich bisher noch keine Zeit
    • H hacki11
      @Malz1902
      Malz1902
      @hacki11 scheint wohl nicht zu klaüpen
      2020-08-18 21:41:44.198  - info: bsblan.0 (2916) Values found: 0,1600,1601,1610,1612,1614,1620,1630,1640,1641,1642,1644,1645,1646,5,6,632,633,648,70,700,710,711,712,714,720,721,730,740,741,8000,8003,8004,8006,8400,8410,8411,8412,8450,8451,8456,8457,8700,8703,8756,8830,8831,8840,8841,8842,8843,901,902,903,908,909,912,918,919,920,924,969
      2020-08-18 21:41:44.199  - debug: bsblan.0 (2916) Fetch values ...
      2020-08-18 21:41:44.282  - info: bsblan.0 (2916) Connection established successfully
      2020-08-18 21:41:45.783  - debug: bsblan.0 (2916) system.adapter.admin.0: logging true
      2020-08-18 21:41:50.447  - debug: bsblan.0 (2916) {"0":{"name":"Datum/Zeit","error":0,"value":"18.08.2020 21:44:32","desc":"","dataType":5,"readonly":0,"unit":""},"5":{"name":"Sommerzeitbeginn Tag/Monat","error":0,"value":"25.03","desc":"","dataType":6,"readonly":0,"unit":""},"6":{"name":"Sommerzeitende Tag/Monat","error":0,"value":"25.10","desc":"","dataType":6,"readonly":0,"unit":""},"70":{"name":"Geräte-Version Bedienteil","error":0,"value":"8.5","desc":"","dataType":0,"readonly":0,"unit":""},"632":{"name":"Periode 1 Beginn Tag/Monat","error":0,"value":"---","desc":"","dataType":6,"readonly":0,"unit":""},"633":{"name":"Periode 1 Ende Tag/Monat","error":0,"value":"---","desc":"","dataType":6,"readonly":0,"unit":""},"648":{"name":"Betriebsniveau Ferien","error":0,"value":"0","desc":"Frostschutz","dataType":1,"readonly":0,"unit":""},"700":{"name":"Betriebsart","error":0,"value":"1","desc":"Automatik","dataType":1,"readonly":0,"unit":""},"710":{"name":"Komfortsollwert","error":0,"value":"23.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"711":{"name":"Komfortsollwert Maximum","error":0,"value":"24.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"712":{"name":"Reduziertsollwert","error":0,"value":"21.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"714":{"name":"Frostschutzsollwert","error":0,"value":"8.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"720":{"name":"Kennlinie Steilheit","error":0,"value":"0.44","desc":"","dataType":0,"readonly":0,"unit":""},"721":{"name":"Kennlinie Verschiebung","error":0,"value":"1.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"730":{"name":"Sommer-/ Winterheizgrenze","error":0,"value":"12.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"740":{"name":"Vorlaufsollwert Minimum","error":0,"value":"17.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"741":{"name":"Vorlaufsollwert Maximum","error":0,"value":"35.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"1600":{"name":"Trinkwasserbetrieb","error":0,"value":"1","desc":"Ein","dataType":1,"readonly":0,"unit":""},"1601":{"name":"Manueller TWW-Push","error":0,"value":"0","desc":"Aus","dataType":1,"readonly":0,"unit":""},"1610":{"name":"TWW Nennsollwert","error":0,"value":"45.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"1612":{"name":"TWW Reduziertsollwert","error":0,"value":"44.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"1614":{"name":"TWW Nennsollwert Maximum","error":0,"value":"65.0","desc":"","dataType":0,"readonly":1,"unit":"°C"},"1620":{"name":"TWW Freigabe","error":0,"value":"2","desc":"Zeitprogramm 4/TWW","dataType":1,"readonly":0,"unit":""},"1630":{"name":"TWW Ladevorrang","error":0,"value":"0","desc":"Absolut","dataType":1,"readonly":0,"unit":""},"1640":{"name":"Legionellenfunktion","error":0,"value":"0","desc":"Aus","dataType":1,"readonly":0,"unit":""},"1641":{"name":"Legionellenfkt. Periodizität","error":0,"value":"7","desc":"","dataType":0,"readonly":0,"unit":"Tage"},"1642":{"name":"Legionellenfkt. Wochentag","error":0,"value":"7","desc":"Sonntag","dataType":1,"readonly":0,"unit":""},"1644":{"name":"Legionellenfkt. Zeitpunkt","error":0,"value":"22:00","desc":"","dataType":4,"readonly":0,"unit":""},"1645":{"name":"Legionellenfkt. Sollwert","error":0,"value":"60.0","desc":"","dataType":0,"readonly":0,"unit":"°C"},"1646":{"name":"Legionellenfkt. Verweildauer","error":0,"value":"60","desc":"","dataType":0,"readonly":0,"unit":"min"}}
      2020-08-18 21:41:50.449  - debug: bsblan.0 (2916) Reset Timer
      2020-08-18 21:42:00.450  - debug: bsblan.0 (2916) Fetch values ...
      H 1 Antwort Letzte Antwort
      • M Malz1902
        hacki11
        @Malz1902 Kannst du es mit der 0.1.4 versuchen - auch über Github.
        Es war noch ein Bug beim Batch processing versteckt.
        Zusätzlich gab es noch ein Problem, wenn man Werte schreiben wollte während noch Werte abgefragt werden. Die BSB Firmware ist nicht Multitasking fähig, daher können nicht mehrere Requests gleichzeitig (Schreiben läuft bei iobroker über einen Callback) gefeuert werden. Daher habe ich eine Command Queue integriert, damit sollte das Schreiben robuster funktionieren.
        • H hacki11
          Malz1902
          @hacki11 bin bis nächsten Freitag im Urlaub, werde es dann an WE tetsen und bescheid geben
          Carsten SauermannC H 2 Antworten Letzte Antwort
          • M Malz1902
            Carsten SauermannC Offline
            Carsten Sauermann
            ich habe den Adapter nun auch installiert und aktuell scheint alles zu laufen.
            Vielen Dank für die Arbeit, die darin steckt.
            Was ich bisher nicht hinbekommen habe, ist den 24h-Durchschnittswert in IOBroker abzufragen.
            Die Html Abfrage wäre einfach ein "A" vor der Parameterzahl, also z.B. 8700 = Temperatur A8700 = 24 Durchschnittstemperatur.
            Im Adapter die A8700 einzutragen funktioniert leider nicht, da keine Buchstaben angenommen werden.
            Gibt es eine Möglichkeit, die ich bisher nicht gefunden habe?
            Gruß Carsten
            • Carsten SauermannC Carsten Sauermann
              Gruß Carsten
              hacki11
              @Carsten-Sauermann
              Leider sind die A-Parameter nicht über die JSON Schnittstelle verfügbar, wodurch eine Integration mit ein wenig Aufwand verbunden wäre.
              Für solche statistischen Themen würde ich aber generell andere Systeme empfehlen.
              Ich speichere z.B. alles in einer InfluxDB und erzeuge sämtliche statistische Auswertungen über Grafana.
              Eine andere Möglichkeit wäre den Adapter Sourceanalytix zu nutzen um aggregierte Daten zu sammeln.
              Carsten SauermannC 1 Antwort Letzte Antwort
              • H hacki11
                @Carsten-Sauermann
                Carsten Sauermann
                @hacki11 Danke dir. Ich habe ein entsprechendes Ticket im Github (BSB-Lan Adapter) angelegt, evtl. können die Jungs das noch implementieren.
                Was die Abfrage angeht, so habe ich mich oben was vertan. Aktuell kann man alle Durchschnittswerte mit /A abrufen aber nicht explizit einen wie oben beschrieben, wie das dann später auf der JSON Schnittstelle aussieht werden wir dann ja sehen.
                Nochmals danke für die tolle Arbeit
                Gruß Carsten
                • M Malz1902
                  hacki11
                  @Malz1902 Hi, bist du schon zu einem Test gekommen? Würde dann ein Release schnüren
                    Gruß Carsten
                    hacki11
                    @Carsten-Sauermann
                    Die Version im Master liest nun die neue /JA Schnittstelle ein, habe einen neuen Thread erstellt.
                    Kannst du Testen? Bei mir hats schon mal geklappt:
                    https://forum.iobroker.net/topic/36566/test-adapter-bsblan-v0-2-x
                    • H hacki11
                      Malz1902
                      schrieb am zuletzt editiert von Malz1902
                      @hacki11 Hey, sorry bisher nicht geschafft lag nach meinem Urlaub ne Woche flach, aber kein Corona es gibt noch normale Erkältungen^^
                      gerade getestet, scheint zu klappen mit version 0.2.0
