  4. Lichter Zählen
    5.7k
Lichter Zählen
javascript
23 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
    manuel99
    Ich bin von Openhab umgestiegen, und versuche mich jetzt mit Iobroker.
    In diversen Foren Einträgen habe ich das Lichter Zählen Skript gefunden und wollte es anwenden.
    Leider bekomme ich immer Fehler im Log.
    javascript.0	2020-03-17 09:13:14.334	error	(19631) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-03-17 09:13:14.334	error	(19631) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-03-17 09:13:14.334	error	(19631) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-03-17 09:13:14.334	error	(19631) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1411:37)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1188:28)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at Object.createScript (vm.js:277:10)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) at new Script (vm.js:83:7)
    javascript.0	2020-03-17 09:13:14.333	error	(19631) SyntaxError: Unexpected token var
    javascript.0	2020-03-17 09:13:14.333	error	(19631) ^^^
    javascript.0	2020-03-17 09:13:14.333	error	(19631) ! var idAnzahlEin = 'javascript.0.Status.Lichter.Anzahl_ein',
    javascript.0	2020-03-17 09:13:14.332	error	at script.js.Skript_1:19
    javascript.0	2020-03-17 09:13:14.332	error	(19631) script.js.Skript_1 compile failed:
    Eine Aufzählung mit dem Namen : enum.functions.Licht habe ich erstellt und sämtliche Leuchten zu der Funktion hinzugefügt.
    • M manuel99
      @manuel99 sagte:
      Was steht in Zeile 13 des Scripts ?
      Offenbar wurde das Script aus einer fehlerhaften Quelle (altes Forum) kopiert.
        manuel99
        Hier mal das Skript:
        /* Status Zahl Lichter
        ! zählt die Lichter in allen Räumen und meldet die Eingeschalteten namentlich
        Daten kommen vom Gewerk "Licht"
        ! erstellt: 17.06.2015 nach diesem Vorbild: viewtopic.php?f=21&t=869&sid=f9ba5657489ff431a1990884f90779c1#p6564
        23.06.2015 globale Variablendefinition zählen_Lichter.textLichterAn fehlte und wurde hinzugefügt
        Log Ausgabe auskommentiert
        05.08.2015 STATE aus der Ausgabe entfernt nach Idee von stephan61 http://forum.iobroker.org/viewtopic.php ... t=20#p9267
        24.03.2016 keine Anzeigen von virtuellen Kanälen mehr (in Abhängigkeit der Abfrage des Namens)
        06.05.2016 Datenpunkt für Ansagen zugefügt
        02.07.2016 abgeschaltet, da Fehler
        03.07.2016 Zähl-Funktion getrennt nach Schalter und Dimmer
        search statt indexOf und RegEx für Suche nach Virtuellen Kanälen
        27.11.2016 Verschoben in Status
        Code optimiert
        23.12.2016 Räume eingebaut
        var logging = true;
        idAnzahl = 'javascript.0.Status.Lichter.Anzahl',
        idText = 'javascript.0.Status.Lichter.Text',
        idRaum = 'javascript.0.Status.Lichter.Raum', // <---- NEU
        idAnsage = 'javascript.0.Status.Lichter.Ansage';
        ! // Ab hier nix mehr ändern
        createState(idAnzahl, { // wenn benötigt: Anzahl der vorhandenen Lichter
        type: 'number',
        name: 'Anzahl aller Lichter',
        min: 0,
        def: 0,
        role: 'value'
        createState(idAnzahlEin, { // Anzahl der Lichter, die auf sind als Variable unter Javascript.0 anlegen
        type: 'number',
        name: 'Anzahl der eingeschalteten Lichter',
        min: 0,
        def: 0,
        role: 'value'
        createState(idText, { // Anzahl der brennenden Lichter und deren Namen als Variable unter Javascript.0 anlegen
        type: 'string',
        name: 'Eingeschaltete Lichter',
        desc: 'Namen der eingeschalteten Lichter',
        def: ' ',
        role: 'value'
        createState(idAnsage, {
        type: 'string',
        name: 'Eingeschaltete Lichter (Ansage)',
        desc: 'Namen der eingeschalteten Lichter (für Ansage aufbereitet)',
        def: ' ',
        role: 'value'
        createState(idRaum, { // Räume, in denen Lichter brennen // <---- NEU
        type: 'string',
        name: 'Räume mit eingeschalteten Lichter',
        desc: 'Namen der Räume, in denen Lichter eingeschaltet sind',
        def: ' ',
        role: 'value'
        ! var cacheSelectorState = $('channelstate.id=.STATE'); // Gewerk Licht
        var cacheSelectorLevel = $('channelstate.id=.LEVEL');
        ! function checkDevices(obj) {
        // Setzt die Zähler vor dem Durchlauf aller Elemente *.STATE im Gewerk Licht auf 0
        var anzahlLichterAn = 0;
        var anzahlLichter = 0;
        var textLichterAn = [];
        var textRaum = [];
        if (logging) {
        log('++++++ Lichter Anzahl ++++ ');
        log('#### SCHALTER ##### ');
        cacheSelectorState.each(function (id, i) { // Schleife für jedes gefundenen Element *.STATE im Gewerk Licht
        var obj = getObject(id);
        var name = getObject(id).common.name;
        var status = getState(id).val; // Zustand *.STATE abfragen (jedes Element)
        var devicename = name.substring(0, name.indexOf(".STATE")); //.state aus Text entfernen
        var raumname = getObject(id, "rooms"); // <---- NEU
        ! // ########## Abfrage ob Virtueller Kanal? VK oder : im Namen)
        // if ( (devicename.search(/(CUX)|(K2)|(K3)|(VK)|(:)/ig) == -1) ) {
        if (logging) {
        log('-------');
        log('Kanal: ' + name);
        log('Status: ' + status);
        if (status) { // wenn Zustand = true, dann wird die ANzahl der Lichter hochgezählt
        ++anzahlLichterAn;
        textLichterAn.push(devicename); // Zu Array hinzufügen
        textRaum.push(raumname.enumNames); // <---- NEU
        ++anzahlLichter; // Zählt die Anzahl der vorhandenen Lichter unabhängig vom Status
        // } // ENDE VK-Abfrage
        ! if (logging) log('#### DIMMER ##### ');
        cacheSelectorLevel.each(function (id, i) { // Schleife für jedes gefundenen Element *.LEVEL im Gewerk Licht
        var status = getState(id).val; // Zustand *.LEVEL abfragen (jedes Element)
        var devicename = name.substring(0, name.indexOf(".LEVEL")); //.state aus Text entfernen
        // if ( (devicename.search(/(CUX)|(K2)|(K3)|(V10)|(VK)|(:)/ig) == -1) ) { // Geräte mit diesen Strings im namen nicht beachten
        ! if (logging) {
        log('-------');
        log('Status: ' + status + '%');
        if (parseFloat(status) > 0) { // Wenn Dimmwert über 0
        ++anzahlLichterAn;
        // } // Ende Abfrage VK
        ! // Array mit Lichternamen sortieren
        textLichterAn.sort();
        textRaum.sort(); // <---- NEU
        // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon an) ausgegeben
        if (logging) log("Text: " + textLichterAn);
        if (logging) log("Anzahl Lichter: " + anzahlLichter + " # davon Lichter an: " + anzahlLichterAn);
        // die ermittelten Werte werden als javascript.0. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
        setState(idText, textLichterAn.join(',
        ')); // Schreibt die aktuelle Namen der eingeschalteten Lichter
        setState(idAnzahlEin, textLichterAn.length); // Schreibt die aktuelle Anzahl der eingeschalteten Lichter
        setState(idAnzahl, anzahlLichter); // Schreibt die aktuelle Anzahl der vorhandene Elemente im Gewerk Licht
        // setState(idRaum, textRaum.join(',
        ')); // Räume, in denen Licht brennt // <---- NEU
        setState(idRaum, textRaum.join(', ')); // Räume, in denen Licht brennt // <---- NEU
        ! // Trigger
        cacheSelectorState.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk Licht
        if (logging) log('Auslösender Schalter: ' + obj.id + ': ' + obj.state.val); // Info im Log, welcher Zustand sich geändert hat
        checkDevices();
        cacheSelectorLevel.on(function(obj) { // bei Zustandänderung *.LEVEL im Gewerk Licht
        if (logging) log('Auslösender Dimmer: ' + obj.id + ': ' + obj.state.val); // Info im Log, welcher Zustand sich geändert hat
        checkDevices();
        ! function main() {
        setTimeout(function(){
        if (logging) log('Auslöser Skriptstart');
        checkDevices();
        }, 2000);
        ! main(); // Skriptstart-Auslöser
        ! // Aufbereitung für Ansage
        function strip_tags(data) {
        var rueckgabe = data.replace(/( |<([^>]+)>)/ig, " ");
        return(rueckgabe);
        ! on(idText, function (obj) {
        var text = obj.state.val;
        text = (getState(idAnzahl).val > 0 ) ? 'Lichter eingeschaltet: ' + strip_tags(text) : 'Alle Lichter sind ausgeschaltet';
        setState(idAnsage, text);
        • M manuel99
          Code optimiert
          var logging = true;
          type: 'number',
          min: 0,
          def: 0,
          role: 'value'
          type: 'number',
          min: 0,
          def: 0,
          role: 'value'
          type: 'string',
          def: ' ',
          role: 'value'
          type: 'string',
          def: ' ',
          role: 'value'
          type: 'string',
          def: ' ',
          role: 'value'
          var textRaum = [];
          if (logging) {
          if (logging) {
          log('-------');
          ++anzahlLichterAn;
          ! if (logging) {
          log('-------');
          ++anzahlLichterAn;
          ! // Trigger
          checkDevices();
          checkDevices();
          ! function main() {
          checkDevices();
          }, 2000);
          return(rueckgabe);
          @manuel99 sagte:
          Wie vermutet: Es sind viele Fehler enthalten, da aus einer fehlerhaften (alten) Quelle kopiert.
            manuel99
            Danke für die Info.
            Hättest du ein aktuelles Skript für mich mit den gleichen Funktionen?
            paul53P dslraserD 2 Antworten Letzte Antwort
            • M manuel99
              Danke für die Info.
              @manuel99 sagte:
              Nein, ich verwende es nicht. Bitte den Script-Ersteller, den Beitrag zu korrigieren (Link erforderlich).
                manuel99
                Danke, werde es versuchen.
                • M manuel99
                  Danke für die Info.
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @manuel99
                  wenn es auch Blockly sein darf, dann ist hier vielleicht auch was für Dich dabei.
                  https://forum.iobroker.net/post/346230
                  • dslraserD dslraser
                    @manuel99
                    manuel99
                    @dslraser
                    Habe es mir gerade angesehen, Danke für deine Arbeit.
                    Was muss ich einstellen um es nützen zu können, bei meinen Aufzählungen gibt es kein .state?
                    M paul53P 2 Antworten Letzte Antwort
                    • M manuel99
                      @dslraser
                      manuel99
                      @manuel99 said in Lichter Zählen:
                      @dslraser
                      Wenn ich .STATE lösche funktioniert es, aber Die Lampen werden doppelt gezählt statt 8 sind es 16.
                      • M manuel99
                        @dslraser
                        @manuel99 sagte:
                        Es sind nur die Namen zu sehen. Wie endet die Datenpunkt-ID ?
                          @manuel99 sagte:
                          manuel99
                          schrieb am zuletzt editiert von manuel99
                          Die hat kein ende.
                          knx.0.Beleuchtung.RM_Schalten.Licht_Kinderzimmer_Status
                          • M manuel99
                            Die hat kein ende.
                            @manuel99 sagte:
                            Dann nimm [id=*_Status]
                            , vorausgesetzt, die IDs enden einheitlich.
                              @manuel99 sagte:
                              manuel99
                              Jetzt findet das Skript nichts mehr.
                              • M manuel99
                                @dslraser
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @manuel99
                                brauchst Du überhaupt zwei Abfragen ? Dieses Beispiel ist für meine HMIP Steckdosen und HUE Lampen
                                  @manuel99
                                  manuel99
                                  @dslraser
                                  Ich denke nicht 😀
                                  Was müsste ich löschen ?
                                  Kenn mich leider noch nicht so aus mit Blocky/Java.
                                  • M manuel99
                                    @dslraser
                                    Ich denke nicht 😀
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @manuel99
                                    als erstes zeige mal ein RAW von so einer Lampe/Licht (am besten als/in Code Tags)
                                    Und dann stelle mal das Blockly hier rein, welches Du jetzt bei Dir hast.
                                      @manuel99
                                      manuel99
                                      @dslraser
                                      Habe jetzt was rausgelöscht jetzt wird richtig gezählt.
                                      Hier das Raw
                                       "_id": "knx.0.Beleuchtung.RM_Schalten.Licht_Garage_Status",
                                       "type": "state",
                                       "common": {
                                         "name": "Licht Garage Status",
                                         "type": "boolean",
                                         "read": true,
                                         "write": false,
                                         "role": "indicator.switch",
                                         "min": false,
                                         "max": true
                                       "native": {
                                         "dpt": "DPT1.001",
                                         "address": "1/1/8",
                                         "addressRefId": "P-0427-0_GA-179",
                                         "statusGARefId": "",
                                         "actGARefId": "P-0427-0_GA-46"
                                       "from": "system.adapter.knx.0",
                                       "user": "system.user.admin",
                                       "ts": 1584380922332,
                                       "acl": {
                                         "object": 1636,
                                         "state": 1636,
                                         "owner": "system.user.admin",
                                      Hier das Blocky:
                                      • M manuel99
                                        @dslraser
                                        Hier das Raw
                                         "type": "state",
                                         "common": {
                                           "type": "boolean",
                                           "read": true,
                                           "write": false,
                                           "min": false,
                                           "max": true
                                         "native": {
                                           "dpt": "DPT1.001",
                                           "address": "1/1/8",
                                         "acl": {
                                           "object": 1636,
                                           "state": 1636,
                                        Hier das Blocky:
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        @manuel99
                                        probiere mal....Im Blockly ist nicht alles aktiviert, es geht nur darum ob er was findet
                                        (ich wollte mir nicht alle Datenpunkte erstellen usw.)
                                         <variables>
                                           <variable type="" id="E-2Ms[EQ*lEe7IRh*cIa">id</variable>
                                           <variable type="" id=",CKGwqCVMH?=oFfDM}">arry</variable>
                                           <variable type="" id="9,LX9Q_^1Zm.XL]5L%Y">trenner</variable>
                                           <variable type="" id="#8GHEd)j7S$#s,^/Sbk%">textAusgabe</variable>
                                           <variable type="" id=".Yia3JB]R6UM8||#rtEy">Anzahl_Licht_eingeschaltet</variable>
                                           <variable type="" id="GBP*^g/p%y(A!z9wYIAp">Anzahl_Licht_gesamt</variable>
                                           <variable type="" id="kf.|gUBRrt]]ET/7VV`i">Licht_eingeschaltet_Liste</variable>
                                           <variable type="" id="?Iruv;}=6m-+T=![x@`H">Licht_gesamt_Liste</variable>
                                           <variable type="" id="M#.~fDd[/KAfhHH%W2-K">Licht_html_Liste</variable>
                                           <variable type="undefined" id="timeout">timeout</variable>
                                           <variable type="" id="HYyl#n^=-9$2h^y`Y;N?">htmlText</variable>
                                           <variable type="" id="O.g)=vuxy/!=!?vJ]|ep">Licht_an</variable>
                                           <variable type="" id="s=n-:M5Oe8@rDy8F^Czv">Licht_aus</variable>
                                         </variables>
                                         <block type="procedures_defcustomreturn" id="!N6;}kSECsPgA~=}mQv" x="13" y="13">
                                           <mutation statements="false">
                                             <arg name="id" varid="E-2Ms[EQ*lEe7IRh*cIa"></arg>
                                           </mutation>
                                           <field name="NAME">getParentName</field>
                                           <field name="SCRIPT">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</field>
                                         </block>
                                         <block type="procedures_defcustomreturn" id="_(a~5[lFS^_b-QSlk(!i" x="13" y="63">
                                             <arg name="arry" varid=",CKGwqCVMH?=oFfDM}"></arg>
                                             <arg name="trenner" varid="9,LX9Q_^1Zm.XL]5L%Y"></arg>
                                           </mutation>
                                           <field name="NAME">arry, trenner</field>
                                           <field name="SCRIPT">cmV0dXJuIGFycnkuam9pbih0cmVubmVyKTs=</field>
                                         </block>
                                         <block type="procedures_defcustomnoreturn" id="hvz=#RO?t*_4B%(i4;;$" disabled="true" x="13" y="113">
                                             <arg name="textAusgabe" varid="#8GHEd)j7S$#s,^/Sbk%"></arg>
                                           </mutation>
                                           <field name="NAME">iQontrol_File_schreiben</field>
                                           <field name="SCRIPT">ICBjb25zdCBwYXRoID0gIi9odG1sbGljaHQuaHRtbCI7DQogIA0KICB3cml0ZUZpbGUoJ2lxb250cm9sLm1ldGEnLCBwYXRoICx0ZXh0QXVzZ2FiZSwgZnVuY3Rpb24gKGVycm9yKSB7DQogICAgbG9nKCdpUW9udHJvbCBMaWNodCBEYXRlaSBnZXNjaHJpZWJlbicpOw0KfSk7</field>
                                           <comment pinned="false" h="80" w="160">Funktion zum schreiben einer html Datei für iQontrol</comment>
                                         </block>
                                         <block type="procedures_defcustomnoreturn" id="EJhG@Zv:/.r@(DzIU,:6" disabled="true" x="13" y="163">
                                           <mutation statements="false"></mutation>
                                           <field name="NAME">Datenpunkte_erstellen</field>
                                           <field name="SCRIPT">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</field>
                                         </block>
                                         <block type="procedures_callcustomnoreturn" id=":$M_%{Ds0d-b,5nDEcL." disabled="true" x="13" y="213">
                                           <mutation name="Datenpunkte_erstellen"></mutation>
                                           <next>
                                             <block type="variables_set" id="m{3CIJBGWgyR970.R?.8">
                                               <field name="VAR" id=".Yia3JB]R6UM8||#rtEy" variabletype="">Anzahl_Licht_eingeschaltet</field>
                                               <value name="VALUE">
                                                 <block type="math_number" id="@{xLucodgvjj5zwTIk+E">
                                                   <field name="NUM">0</field>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="variables_set" id="e??qlY4^1C,ST6I3@3Oo">
                                                   <field name="VAR" id="GBP*^g/p%y(A!z9wYIAp" variabletype="">Anzahl_Licht_gesamt</field>
                                                     <block type="math_number" id="_sj},NBYrXSWN8fg!cTK">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="variables_set" id="|:0:NXviBH3ts|PxK|E[">
                                                       <field name="VAR" id="kf.|gUBRrt]]ET/7VV`i" variabletype="">Licht_eingeschaltet_Liste</field>
                                                         <block type="lists_create_with" id="Bqe9#!`.vRu+(AZe8J2#">
                                                           <mutation items="0"></mutation>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="variables_set" id="ch;k==7_X11LA3[*__@n">
                                                           <field name="VAR" id="?Iruv;}=6m-+T=![x@`H" variabletype="">Licht_gesamt_Liste</field>
                                                             <block type="lists_create_with" id="Ps*.9B^QUD?wJtCnX8jL">
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="variables_set" id="Ze3P{Jv`0,K34)]|4A8x">
                                                               <field name="VAR" id="M#.~fDd[/KAfhHH%W2-K" variabletype="">Licht_html_Liste</field>
        <block type="lists_create_with" id="PnK._4y#V:}^D10q36@I">
        </block>
                                                               </value>
                                                               <next>
        <block type="on_ext" id="hafx;Y{*x?Xn(,sMW.+n">
        <value name="OID0">
        <shadow type="field_oid" id="#4w([E@;X_!loV@[Dy]:">
        </shadow>
        <block type="selector" id="+{AR;_jRS67rU:cIQl%?">
        <field name="TEXT">[id=*_Status](functions=Licht)</field>
        </block>
        </value>
        <statement name="STATEMENT">
        <block type="variables_set" id="p=KHiUK+Y+|fQ)HcFDyO">
        <block type="math_number" id="[jU@VEbQfpj$4AXB1Hf1">
        </block>
        </value>
        <next>
        <block type="variables_set" id="P.1UaFjJOJP+NHRlsqPK">
        <block type="math_number" id=".Bxds~9rDXplhV2C)}x.">
        </block>
        </value>
        <next>
        <block type="variables_set" id=",I)$oiHDlf!``82c}Jr8">
        <block type="lists_create_with" id="|uw:aJhFPc}JD~rwG#f?">
        </block>
        </value>
        <next>
        <block type="variables_set" id="[(`mc9Ts+WbCoPlHiF2}">
        <block type="lists_create_with" id="Vh0bIxSdFaUUrynRZ^fa">
        </block>
        </value>
        <next>
        <block type="variables_set" id="kj9)qx1[rc,_^tzUf|k8">
        <block type="lists_create_with" id="G9[si:i3V3IM8S=on#ga">
        </block>
        </value>
        <next>
        <block type="variables_set" id="Bee!z}f_8!1s@cHV4/Vm">
        <field name="VAR" id="HYyl#n^=-9$2h^y`Y;N?" variabletype="">htmlText</field>
        <block type="text_join" id="p$RrX883u4,oKT*ew?jR">
        <mutation items="8"></mutation>
        <value name="ADD0">
        <block type="text" id="a:Ub=w1b*t!t_e`7!OUc">
        <field name="TEXT">&lt;!DOCTYPE html&gt;&lt;html lang="de"&gt;&lt;head&gt;&lt;title&gt;Licht&lt;/title&gt;&lt;meta http-equiv="content-type" content="text/html; charset=utf-8"&gt;&lt;/head&gt;&lt;body&gt;</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="vQ4-VDa*5hb|sv6:[@7#">
        <field name="TEXT">&lt;p style="color:#0000FF; font-family:Helvetica; font-weight: bold"&gt;Lichtstatus&lt;/p&gt; </field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="|F2=N*fP,:1#E[E:nzx]">
        <field name="TEXT">&lt;p style="color:#ff0000; font-family:Helvetica; font-weight: bold"&gt;letze Änderung:  </field>
        </block>
        </value>
        <value name="ADD3">
        <block type="time_get" id="!O)qFVPd9F4Y{c7sQqW/">
        <mutation format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">TT.MM.JJJJ SS:mm:ss</field>
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="|*GsEfGV1J*d`ZFXlDi,">
        <field name="TEXT"> &lt;/p&gt; </field>
        </block>
        </value>
        <value name="ADD5">
        <block type="text" id="=2d-n1(V^qS_)EYA]f=_">
        <field name="TEXT">&lt;table border="8" cellspacing="10" cellpadding="20" style="color:black; font-family:Helvetica;background-image: linear-gradient(42deg,transparent,lightblue);"&gt;</field>
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="fRZ.!bM#xY$BL?#_JkD.">
        <field name="TEXT">&lt;tr style="color:#0000FF"; font-weight: bold"&gt;&lt;td&gt;Licht&amp;ensp;&amp;ensp;&amp;ensp;&lt;/td&gt;&lt;td&gt;Status&lt;/td&gt;&lt;/tr&gt;</field>
        </block>
        </value>
        <value name="ADD7">
        <block type="text" id="n#g5W5tqsLc{jJ@V#!wm">
        <field name="TEXT">&lt;tr&gt;&lt;td&gt;</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_forEach" id="G!}uXUNe]!g=EHrV74L~">
        <field name="VAR" id="O.g)=vuxy/!=!?vJ]|ep" variabletype="">Licht_an</field>
        <value name="LIST">
        <block type="selector" id="z0W(;:pV^paS3QB6f{x#">
        </block>
        </value>
        <statement name="DO">
        <block type="math_change" id="bCX,Jrt-yTpU?qB#sR~5">
        <value name="DELTA">
        <shadow type="math_number" id="7`=B;!^UTT2{xL9KtsBf">
        <field name="NUM">1</field>
        </shadow>
        </value>
        <next>
        <block type="controls_if" id="}4vd1#YZDcH=oOE*8~0d">
        <value name="IF0">
        <block type="logic_compare" id="g4G|LhWTY!;.GG+z=J.F">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="get_value_var" id="E(cAi=#i)25dXS=XyKD,">
        <value name="OID">
        <shadow type="text" id="H+Si!dLFm_55HjmGoqp+">
        <field name="TEXT"></field>
        </shadow>
        <block type="variables_get" id="Gt!b/b{W?Y~vWS@=09o*">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="e./C[g0TvcNuG%N~mE`D">
        </block>
        </value>
        </block>
        </value>
        <statement name="DO0">
        <block type="math_change" id="J/3_pk@bHqVZV9TkhWdM">
        <shadow type="math_number" id="%$(c9F?#C}Y-L0cd8+y[">
        </shadow>
        </value>
        <next>
        <block type="lists_setIndex" id="1hr9X8pA*|4Q1zL}rBJ}">
        <mutation at="false"></mutation>
        <field name="MODE">INSERT</field>
        <field name="WHERE">LAST</field>
        <value name="LIST">
        <block type="variables_get" id="4mG9){=ao#FFx#8|$=x~">
        </block>
        </value>
        <value name="TO">
        <block type="text_join" id="!BJ:wJ^yk_kad?pygD9]">
        <value name="ADD0">
        <block type="procedures_callcustomreturn" id="]qjE%||0Ho+nX]p^Go?V">
        <mutation name="getParentName">
        <arg name="id"></arg>
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="K!q*-#{vI|sJ37#D]{?6">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="}Mt)bU3UI$dz(U[Hj^}5">
        <field name="TEXT"> eingeschaltet</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="lists_setIndex" id="+ffyh?-1O7`uPjA)f?yK">
        <value name="LIST">
        <block type="variables_get" id="vnrSS8[-bS_@$B45t)|v">
        </block>
        </value>
        <value name="TO">
        <block type="text_join" id="5GN5`vhGS;:R+N;)s!;/">
        <value name="ADD0">
        <block type="procedures_callcustomreturn" id="+GH1pLfc:-3a@KL@grP/">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="m|*sob7GthrzYTg~gQ=n">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="mV+Rx.IK5_{`(/Pl3~)l">
        <field name="TEXT"> an</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="lists_setIndex" id="Wswu+2xPDSi{!*V}$-Uw">
        <value name="LIST">
        <block type="variables_get" id="a=@|uxl2b+@Xuiaud)ms">
        </block>
        </value>
        <value name="TO">
        <block type="text_join" id="uF#1PVo@,S|XT%hZYbuC">
        <value name="ADD0">
        <block type="procedures_callcustomreturn" id="/elCjez0c2QH1S%%-d}O">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="{sMf]2kObn^5nv?4CGc`">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="y92n$gdgaAqLSSVYC*NM">
        <field name="TEXT">&lt;td&gt;&lt;span style="color:#FF0000"&gt; an 💡&lt;/span&gt;</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_forEach" id="tzCG{$=#M;w}6NzNokX6">
        <field name="VAR" id="s=n-:M5Oe8@rDy8F^Czv" variabletype="">Licht_aus</field>
        <value name="LIST">
        <block type="selector" id="2-0]Yu/8Q]v[_?W(f82E">
        </block>
        </value>
        <block type="controls_if" id="O8_g4Z[ppph)712s!4}j">
        <value name="IF0">
        <block type="logic_compare" id="/cYIgVH-nJmeDj2[(Sx*">
        <value name="A">
        <block type="get_value_var" id="WQp$07`9U63Hj[3A}Gv]">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="X4~qu+|$t12Li!AzIlLb">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="W7.{5mp8PC}^y@LvCXfh">
        </block>
        </value>
        </block>
        </value>
        <block type="lists_setIndex" id="){683b+;[9t~jNdJOc?}">
        <value name="LIST">
        <block type="variables_get" id="ZF3~TA%$xo0_y*dvJ~Dp">
        </block>
        </value>
        <value name="TO">
        <block type="text_join" id="O;Y($KL{TMe@!uNBx0qn">
        <value name="ADD0">
        <block type="procedures_callcustomreturn" id="Y{6Xl-|alG{Jbe59BMQ+">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="kD26(YC0Z]0$dXs1S=oc">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="sx_pnh$4IUzyw.W^cxL3">
        <field name="TEXT"> aus</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="lists_setIndex" id="WTHgF/ns$Hpx5m=8W/Q=">
        <value name="LIST">
        <block type="variables_get" id="9Sw_}aQMd;iT3kmRGY{P">
        </block>
        </value>
        <value name="TO">
        <block type="text_join" id="[hX4Scn#{MDwOc`$~BYd">
        <value name="ADD0">
        <block type="procedures_callcustomreturn" id="D(E,397!R$CmCT1rR(U:">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="Y*bH$f7%w+`fIWa.TCnc">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="sq_YxxcNWvk~Evq{T)A%">
        <field name="TEXT">&lt;td&gt;aus 👍</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <block type="update" id="BRUEt{SxHthj,HJC;u0g" disabled="true">
        <field name="OID">javascript.0.Geraete_zaehlen.Licht_zaehlen.01Licht_Anzahl_eingeschaltet</field>
        <block type="variables_get" id="X`BV[yZwgx}QT2(f~3;a">
        </block>
        </value>
        <next>
        <block type="update" id="VnZud=~v2I?UkrzwyRSG" disabled="true">
        <field name="OID">javascript.0.Geraete_zaehlen.Licht_zaehlen.02Licht_Anzahl_gesamt</field>
        <block type="variables_get" id="2=ru[-MFb,Qz]kN(m_jT">
        </block>
        </value>
        <next>
        <block type="controls_if" id="7a03/(m4w0_5{)7++!j`" disabled="true">
        <value name="IF0">
        <block type="logic_compare" id="}oljbU;u0-Ps]?[zmt%e">
        <field name="OP">NEQ</field>
        <value name="A">
        <block type="variables_get" id="Avxax[9?4idcrZ{~*O?_">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="46}8y9!,uL/F[[#z)pD$">
        </block>
        </value>
        </block>
        </value>
        <block type="update" id="J+;HlsED3i(E5[nA;XMT">
        <field name="OID">javascript.0.Geraete_zaehlen.Licht_zaehlen.03Licht_text_eingeschaltet_Liste</field>
        <block type="procedures_callcustomreturn" id="9%wQA*VtZvVJ.~_C$xnY">
        <mutation name="arry, trenner">
        <arg name="arry"></arg>
        <arg name="trenner"></arg>
        </mutation>
        <value name="ARG0">
        <block type="lists_sort" id="A1|6Ct9eCV`yqXYDQ(If">
        <field name="TYPE">TEXT</field>
        <field name="DIRECTION">1</field>
        <value name="LIST">
        <block type="variables_get" id="$O/s~t^RpSUk4HOEA@`7">
        </block>
        </value>
        </block>
        </value>
        <value name="ARG1">
        <block type="text" id="{l%(E:c!^]`oF%4j`!:2">
        <field name="TEXT">, </field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="update" id="NIq@Ep$O[G`:%h2gi38x">
        <block type="text" id="iCsJ:OXCcTlm(T%|m/Py">
        <field name="TEXT">Alle Lampen sind ausgeschaltet.</field>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="update" id="SkC8k@_ho!#A[{if#9S/" disabled="true">
        <field name="OID">javascript.0.Geraete_zaehlen.Licht_zaehlen.04Licht_text_Gesamt_Liste</field>
        <block type="procedures_callcustomreturn" id="8XY6@y!(7EtlTui%Sl!s">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="vZ8nkQ~MvkvFUv2Df:lK">
        </block>
        </value>
        <value name="ARG1">
        <block type="text" id="rwX])r?*]K%EMlH(T`S`">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="WLR!ze5](]Hs8TX{|[rn" disabled="true">
        <field name="OID">javascript.0.Geraete_zaehlen.Licht_zaehlen.05Licht_html_Liste</field>
        <block type="text_join" id="qL)/)8Bp!XNXrDry%D:F">
        <value name="ADD0">
        <block type="variables_get" id="1Gd,]P|0}C0@DLdfn55B">
        </block>
        </value>
        <value name="ADD1">
        <block type="procedures_callcustomreturn" id="eF2,7Unb/X#+~r8bZeD4">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="An8=VpH]rZw}lll!_LSI">
        </block>
        </value>
        <value name="ARG1">
        <block type="text" id="+j[Pf^94lrYLPiIrtxm=">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="z1d/zrdGPfBiu+dF{!_=">
        <field name="TEXT">&lt;/table&gt;&lt;/body&gt;</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="on_ext" id="0QfC!m)[(ofB-v[%:|{P" disabled="true">
        <value name="OID0">
        <shadow type="field_oid" id="whek(^?ZC85iamrP5:/-">
        <field name="oid">javascript.0.Geraete_zaehlen.Licht_zaehlen.05Licht_html_Liste</field>
        </shadow>
        </value>
        <block type="timeouts_cleartimeout" id="Cu.60D-p8xWhkJnHnRol">
        <next>
        <block type="timeouts_settimeout" id="eMWZ_Dde4qR`n%o99$Et">
        <field name="DELAY">1000</field>
        <field name="UNIT">ms</field>
        <block type="procedures_callcustomnoreturn" id="w0^g}FdxfJyZ3MC14WVn" disabled="true">
        <mutation name="iQontrol_File_schreiben">
        <arg name="textAusgabe"></arg>
        </mutation>
        <value name="ARG0">
        <block type="get_value" id=":JXbmERS{@9iY$vW,M#p">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                        </xml>
                                        • M manuel99
                                          @dslraser
                                          Hier das Raw
                                           "type": "state",
                                           "common": {
                                             "type": "boolean",
                                             "read": true,
                                             "write": false,
                                             "min": false,
                                             "max": true
                                           "native": {
                                             "dpt": "DPT1.001",
                                             "address": "1/1/8",
                                           "acl": {
                                             "object": 1636,
                                             "state": 1636,
                                          Hier das Blocky:
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          @manuel99
                                          und falls nicht gefunden wird, dann starte mal die Javascript Instanz und den Admin neu. Nicht auf Pause, nur Neustart mit dem Pfeilkreis.
                                          Selektor, dieser findet bei mir Deine DP
                                          EDIT:
                                          vielleicht sogar besser so...
