  4. Mi vacuum Adapter kann nicht installiert werden
mi vacuumerroradapter
4 Beiträge 3 Kommentatoren 956 Aufrufe 2 Beobachtet
  • H Offline
    haenk93
    Hallo
    Ich versuche den mi vacuum adapter zu installieren leider kommt bei der Installation immer ein oder mehrere Errors. Leider bin ich ein absoluter Noob und kann damit nichts anfangen
    $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master" mihome-vacuum --debug
    install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master
    NPM version: 6.13.4
    npm install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.93-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5
    gyp ERR! not ok
    node-pre-gyp
    ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.93-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR! code
     ELIFECYCLE
    npm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-02-29T11_13_28_603Z-debug.log
    ERROR: host.raspberrypi Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • MeistertrM Offline
      MeistertrM Offline
      Meistertr
      Hallo, als Anfänger sollte man nicht die Entwicklerversionen installieren außer man weiß was man macht. Desweiteren sollte man auch immer die readme lesen bevor man loslegt. Dort ist der Fehler aufgeführt und beschrieben was gemacht werden muss
      • Espace0401E Offline
        Espace0401E Offline
        Espace0401
        vorab, ich habe die Readme gelesen und die Bibliotheken manuell installiert. Hierbei hatte ich jedoch folgenden Fehler, vielleicht kann einer was damit anfangen.
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/gettext/autopoint_0.19.8.1-2_all.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/gettext/gettext_0.19.8.1-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/i/icu/icu-devtools_57.1-6+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/e/expat/libexpat1_2.2.0-2+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/e/expat/libexpat1-dev_2.2.0-2+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-bin_2.50.3-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-dev_2.50.3-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/i/icu/libicu-dev_57.1-6+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
        Beim Update kommt es trotzdem zu dem unten stehenden Fehler. Ferner ist bei dem fehlerhaften Update, der Adapter auch anschließend aus der Liste der Adapter verschwunden, die Instanze ist aber noch da. Habe dann manuell wieder die Version 1.1.5 installiert.
        $ ./iobroker upgrade mihome-vacuum
        Update mihome-vacuum from @1.1.5 to @2.0.7
        NPM version: 6.9.0
        npm install iobroker.mihome-vacuum@2.0.7 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
        gyp
         ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.14.34-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.0gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
        node-pre-gyp ERR!
        build error
        node-pre-gyp
         ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR!
        stack
        node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
        npm
         ERR! code
         ELIFECYCLE
        npm
        ERR!
        errno 1
        npm
        ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2020-03-02T07_59_18_524Z-debug.log
        ERROR: host.ioBroker-RasPi Cannot install iobroker.mihome-vacuum@2.0.7: 1
        Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
        Espace0401E 1 Antwort Letzte Antwort
        • Espace0401E Espace0401
          NPM version: 6.9.0
          gyp
          node-pre-gyp ERR!
          build error
          node-pre-gyp
          stack
          npm
           ERR! code
           ELIFECYCLE
          npm
          ERR!
          errno 1
          npm
          Espace0401E Offline
          Espace0401E Offline
          Espace0401
          @Espace0401
          hat sich erledigt. Habe den Fixer drüber laufen lassen
