  4. Info Adapter bringt jede Menge Fehler
info adaptererror logcaught by controller
6 Beiträge 2 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • D3ltoroxpD Offline
    D3ltoroxpD Offline
    D3ltoroxp
    Hallo Com,
    ich habe mir gestern ioBroker mit dem Script installiert. Vorhin mal soweit alles eingerichtet und die Sachen was der Discovery Adapter vorschlägt installiert.
    Nun bekomme ich aber ständig im Log folgende Einträge ..
    host.Smarthome-Zentrale	2020-02-19 20:25:31.568	info	Restart adapter system.adapter.info.0 because enabled
    host.Smarthome-Zentrale	2020-02-19 20:25:31.568	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.568	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.568	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:90593)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.567	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.566	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
    host.Smarthome-Zentrale	2020-02-19 20:25:31.566	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
    info.0	2020-02-19 20:25:31.044	info	(3547) Terminated (NO_ERROR): Without reason
    info.0	2020-02-19 20:25:31.043	info	(3547) terminating
    info.0	2020-02-19 20:25:31.034	info	(3547) cleaned everything up...
    info.0	2020-02-19 20:25:31.033	error	(3547) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.in
    info.0	2020-02-19 20:25:31.032	error	(3547) uncaught exception: Cannot read property 'split' of undefined
    info.0	2020-02-19 20:25:30.936	info	(3547) Popup news was read...
    Hab ich hier trotz Script irgendwas falsch gemacht, fehlt auf meinem System noch irgendwas, oder kann ich hier eine neuere Version des Adapters laden, vllt ist der Fehler auch bekannt und schon behoben, aber noch nicht im Stabel ?
    Grüße,
    • D3ltoroxpD D3ltoroxp
      Hallo Com,
      Grüße,
      crunchipC Abwesend
      crunchipC Abwesend
      @D3ltoroxp ich glaube ein update des Info Adapter schafft Abhilfe (v1.5.7)
        D3ltoroxpD Offline
        D3ltoroxp
        Das ist das aktuellste was ich über ioBroker updaten kann. Habe schon geschaut, auf github gibt es ja die 1.5.7
          crunchipC Abwesend
          crunchipC Abwesend
          @D3ltoroxp welche Admin version ist installiert? Noch der "alte", dann ein Update machen, aktuell im latest v4.0.2
          D3ltoroxpD 1 Antwort Letzte Antwort
            D3ltoroxpD Offline
            D3ltoroxpD Offline
            D3ltoroxp
            schrieb am zuletzt editiert von D3ltoroxp
            @crunchip Wenn du mit latest den Verwahrungsort meinst, der steht bei mir auf default. Kann man hier auf latest stellen ? Das sind dann wohl Betas und nicht Stable Versionen. Admin Version ist bei mir 3.7.8
              crunchipC Abwesend
              crunchipC Abwesend
              @D3ltoroxp korrekt, wenn du auf latest stellst, hast du die Möglichkeit "höhere Versionen" zu downloaden. Was in dem Fall eine Zwickmühle bedeutet und glaub auch schon ein Issue dazu erstellt wurde.
              Auf gut deutsch, du benötigst den Admin grösser v4.x obwohl er noch nicht im stable ist.
              latest bedeutet aber nicht zwangsläufig, das du alles andere updaten musst....du kannst, wenn du möchtest
