  4. Send this info to Developer
info
4 Beiträge 3 Kommentatoren 361 Aufrufe 2 Beobachtet
    bwl
    schrieb am zuletzt editiert von bwl
    habe mir die Homematic IP Fernbedienung "HMIP-KRCA" zugelegt, in iobroker eingebunden, Tasten werden auch angezeigt aber keine Werte angezeigt/aktualisiert. Im logfile steht:
    2020-02-19 18:04:42.607  - info: hm-rpc.0 (13305) xmlrpc <- newDevices 7
    2020-02-19 18:04:42.678  - info: hm-rpc.0 (13305) new HmIP devices/channels after filter: 7
    2020-02-19 18:04:42.753  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:0","VALUES"]
    2020-02-19 18:04:42.788  - warn: hm-rpc.0 (13305) Send this info to developer: {"_id":"hm-rpc.meta.VALUES.HmIP-KRCA.MAINTENANCE.2","type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"OPERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
    2020-02-19 18:04:42.871  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:1","VALUES"]
    2020-02-19 18:04:42.889  - warn: hm-rpc.0 (13305) Send this info to developer: {"_id":"hm-rpc.meta.VALUES.HmIP-KRCA.KEY_TRANSCEIVER.2","type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_SHORT":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_SHORT","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.SHORT"},"PRESS_LONG":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_LONG","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.LONG"}}}
    2020-02-19 18:04:42.961  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:5","VALUES"]
    Wäre toll wenn jemand die Fernbedienung einpflegen könnte.
    Liebe Grüße
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi 4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: DietPi
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      Ja, braucht bestimmt ein Dummy Programm auf der CCU.
      Metas als Issue sind ok das andere potentiell kein Issue, siehe oben.
      Videotutorials & mehr
      • B bwl
        Liebe Grüße
        NPM-Version: 6.x.x
        Image genutzt: Nein
        sigi234S Online
        sigi234S Online
        sigi234
        @bwl sagte in Send this info to Developer:
        Issues an:
        https://github.com/ioBroker/ioBroker.hm-rpc
        Immer Daten sichern!
          foxriver76F Offline
          foxriver76
            bwl
            Ah danke für den Tipp, lag an fehlendem Dummy Programm war wohl etwas zu voreilig bzw verwirrt durch die Log Meldung
            Grüße
